Fri, Nov 27, 2015 1:01 PM
The license is GPL compatible, I checked that on gnu.org.
On Thursday, 26 November 2015, Tim Hawkins tim.thawkins@gmail.com wrote:
It looks interesting.
It does have CSG operations. While reading about voxel based systems, I
found a claim that CSG is slow on voxel systems, compared to mesh systems,
and I found a forum post complaining about the speed of CSG operations in
OpenVDB. So this might not solve our speed problems with CGAL.
I didn't find any operations for convex hull or minkowski sum. It's not
obvious how you implement these without converting to a mesh first, which I
bet is slow.
It is described as a visual effects library, and the home page demos
effects like clouds, fog, dust clouds, particle based fluid simulations. If
this is the focus, then I'm not sure it will be efficient for our use
cases. We could try it and do some performance measurements.
I wonder what kind of 3D modelling operations are enabled by a voxel
engine, stuff that's difficult with our current mesh engine?
On 26 November 2015 at 22:16, Tim Hawkins <tim.thawkins@gmail.com
javascript:_e(%7B%7D,'cvml','tim.thawkins@gmail.com');> wrote:
http://www.openvdb.org
This may not be what you are looking for but its worth considering.
It is a voxel based csg tree system with mesh import and export. You
create shapes as voxel grids and then it can perform csg operations on
them, it uses a sparse storage mechanism so its effectivly only storing the
surface voxels amd thier relationships.
On Fri, Nov 27, 2015, 07:40 doug moen <doug@moens.org
javascript:_e(%7B%7D,'cvml','doug@moens.org');> wrote:
Yes, but the "Eigen data constructs" (I don't understand this yet) use
floating point representation, and the conversion from CGAL to native
representation can result in an invalid mesh. This is mentioned in the
tutorial. Therefore, I don't see how we can use this: it's not robust.
What I think we want is a robust CSG geometry engine that works with
floating point meshes. This is extremely difficult to program correctly,
because you have to repair damage to the mesh caused by transformations,
deal with floating point instability, and so on, and there are a lot of
tricky edge cases. I'd be looking for a well-exercised engine with about 20
years worth of development and maintenance, and definitely not a
single-person project with only a year or two of work done.
On 26 November 2015 at 17:43, Andrew Plumb <andrew@plumb.org
javascript:_e(%7B%7D,'cvml','andrew@plumb.org');> wrote:
Ah, so it does:
https://github.com/libigl/libigl/blob/master/tutorial/609_Boolean/main.cpp
https://github.com/libigl/libigl/blob/master/include/igl/copyleft/boolean/mesh_boolean.cpp
On the plus side, looks like the meshes going into the operations and
coming out are Eigen data constructs, so it may be easier to parallelize
the operations and faster non-CSG mesh transforms (translate, rotate, etc.).
Something to play with…
Andrew.
On Nov 26, 2015, at 3:51 PM, doug moen <doug@moens.org
This appears to use CGAL and Cork to implement boolean operations.
https://github.com/gilbo/cork
They mention that Cork is available as an alternative: it is faster,
but not always robust.
On 26 November 2015 at 15:38, clothbot <andrew@plumb.org
On Thursday, 26 November 2015, Tim Hawkins <tim.thawkins@gmail.com> wrote:
> Also you need to decide if the license is acceptable, it uses the Mozia
> Public License, which is a mashup of the BSD License and the GPL V2
> License.
> On Fri, Nov 27, 2015, 12:29 doug moen <doug@moens.org
>> bet is slow.
>>>> <javascript:_e(%7B%7D,'cvml','andrew@plumb.org');>> wrote:
>>>>> Ah, so it does:
>>>>> Andrew.
>>>>>> Hey Everyone,
>>>>>> Has anyone looked into using libigl as a (partial) CGAL replacement
>>>>>> for 3D
>>>>>> boolean op's and mesh manipulations?
>>>>>> http://libigl.github.io/libigl/
>>>>>> http://www.alecjacobson.com/weblog/?tag=libigl
>>>>>> Looks to be quite powerful!
>>>>>> Andrew.
>>>>>> View this message in context:
>>>>>> http://forum.openscad.org/libigl-anyone-poked-at-it-for-CGAL-partial-replacement-tp14769.html
>>>>>> Sent from the OpenSCAD mailing list archive at Nabble.com
>>>>>> <http://nabble.com>.
>>>>>> _______________________________________________
>>>>>> Discuss@lists.openscad.org
>>>>>> <javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');>
>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
>>>>> "The future is already here. It's just not very evenly distributed"
>>>>> -- William Gibson
>>>>> Me: http://clothbot.com/wiki/
C
clothbot
Fri, Nov 27, 2015 1:31 PM
Thinking out-loud more than anything else, I'm curious of what OpenVDB might
bring to the table in the way of multi-material (discrete and mixed),
variable-density and/or texture and colour support. The stuff that the AMF
file format hints at supporting but toolset support doesn't quite exist for
yet.
As it relates to OpenSCAD, I suspect it may be a case of us still needing
CGAL, but compartmentalizing/threading its use. Taking a
voxel-mesh-cgal-mesh-voxel path may be cleaner w.r.t. not breaking on the
final mesh-STL export stage because it's voxel-STL.
Gotta pick our battles. :-)
I
bet is slow.
If
yet.
> I
> bet is slow.
> If
View this message in context: http://forum.openscad.org/libigl-anyone-poked-at-it-for-CGAL-partial-replacement-tp14769p14793.html
Fri, Nov 27, 2015 1:42 PM
If you want to read about a voxel based solid modelling language written in
JavaScript, check out ShapeJS.
http://shapejs.shapeways.com/getting-started
It is built on top of very powerful primitive operations.
You can specify an arbitrary 3d shape by a function that maps each
coordinate in the voxel grid to a signed distance. The CSG operations are
available for composing objects. You can specify an arbitrary non affine
transformation using a function, as proposed by Trygon.
But I bet they don't support convex hull. You need to identify the vertexes
in order to compute this, and that's not easily done with a voxel
representation.
It seems to me that we would need to design a hybrid system supporting a
mixture of mesh and voxel representations if we wanted to extend openscad
with voxel support, while retaining full backward compatibility.
It does claim to be multithreaded, which i can belive as voxel operations
are easy to partition, i dont claim to have any expertice in this, my
graphics abilities are limited to 2d, i used to write postscript
rasterisation engines, which render down to a trapezoid list which is easy
to slice and hand out to different threads for operations like colour
correction and halftoning.
Given it does work on a different set of principles there will be
operations that are missing or sub optimimal, like wise there will be
aspects that are faster and open up new capabilities, its just a case of
determining what the tradeoffs are.
bet is slow.
Ah, so it does:
Andrew.
representation.
>> bet is slow.
>>>>> Ah, so it does:
>>>>> Andrew.
>>>>>> Hey Everyone,
>>>>>> for 3D
>>>>>> Andrew.
>>>>> -- William Gibson
Fri, Nov 27, 2015 2:49 PM
in JavaScript, check out ShapeJS.
vertexes in order to compute this, and that's not easily done with a voxel
representation.
bet is slow.
On 26 November 2015 at 22:16, Tim Hawkins tim.thawkins@gmail.com
On 26 November 2015 at 17:43, Andrew Plumb andrew@plumb.org wrote:
Ah, so it does:
Andrew.
On 26 November 2015 at 15:38, clothbot andrew@plumb.org wrote:
Openvdb and ShapeJS specify primitive geometric objects using a "signed
distance function", which maps an (x,y,z) coordinate to an integer, which
is negative inside the object, positive outside, and zero at the surface.
This is the same as the " implicit function" representation used by
ImplicitCAD.
https://christopherolah.wordpress.com/2011/11/06/manipulation-of-implicit-functions-with-an-eye-on-cad/
> representation.
>>> bet is slow.
>>> On 26 November 2015 at 22:16, Tim Hawkins <tim.thawkins@gmail.com>
>>>>> On 26 November 2015 at 17:43, Andrew Plumb <andrew@plumb.org> wrote:
>>>>>> Ah, so it does:
>>>>>> Andrew.
>>>>>> On 26 November 2015 at 15:38, clothbot <andrew@plumb.org> wrote:
>>>>>>> Hey Everyone,
>>>>>>> for 3D
>>>>>>> Andrew.
>>>>>> -- William Gibson
Fri, Nov 27, 2015 3:29 PM
The implicit function representation for geometric objects is awesome.
First, it is an exact, analytic representation for things like spheres. The
object eventually has to be converted to an approximation, for export, but
this is delayed as long as possible. Meanwhile, transformations and CSG
operations on analytic objects return exact results, not approximations.
If you have analytic objects, then Trygon transformations are trivial. They
are just function composition. You compose the transformation function with
the implicit function, to produce another implicit function. So much
easier, faster and precise than applying a Trygon transformation to a mesh.
CSG operations are also trivial, as described by Chris Olah's essay
(previous post). Union is the 'min' function, intersection is the 'max'
function.
Maybe what the voxel libraries give us is an infrastructure that wraps
around implicit functions, so we can convert them to and from meshes, and
preview them.
representation.
operations are easy to partition, i dont claim to have any expertice in
this, my graphics abilities are limited to 2d, i used to write postscript
bet is slow.
use floating point representation, and the conversion from CGAL to native
Ah, so it does:
and coming out are Eigen data constructs, so it may be easier to
parallelize the operations and faster non-CSG mesh transforms (translate,
rotate, etc.).
Andrew.
function.
preview them.
> ImplicitCAD.
>> representation.
>>>> bet is slow.
>>>>>>> Ah, so it does:
>>>>>>> rotate, etc.).
>>>>>>> Andrew.
>>>>>>>> Hey Everyone,
>>>>>>>> for 3D
>>>>>>>> Andrew.
>>>>>>> -- William Gibson
Fri, Nov 27, 2015 4:31 PM
F-Rep is a good short form: https://en.wikipedia.org/wiki/Function_representation
I’d love to have a way of supporting F-Rep in OpenSCAD, as I often see designs where F-Rep would be a significantly cleaner representation.
There are a number of projects are exploring F-Reps for solid modeling. Too many to mention really, but in the Open Source domain of 3D printing-related projects: ShapeJS, ImplicitCAD, Antimony.
Tessellation quality is a challenge, but Shapeways makes a good argument for staying with voxels in some cases: http://abfab3d.com/2015/02/27/voxels-versus-triangles/
As Doug mentions, a hybrid approach seems tempting. I find that extremely scary, but it’s worth exploring.
Fri, Nov 27, 2015 5:36 PM
IceSL has been mentioned on the list before. Their solid modelling language
supports most of what's in OpenSCAD (and they accept OpenSCAD syntax
directly, as an option). But it also supports F-Rep (what they call
"implicits").
It's a hybrid system that supports both functional and mesh objects. Some
operations, like convex_hull, only work on meshes, not on "implicits".
Preview is so fast that they update the preview pane on each keystroke.
Preview is implemented using FPU programming, and they have a list of
supported graphics hardware.
It's closed source, unfortunately. It's one of the products of a research
group at Inria, and it's a fascinating window into what can be accomplished
by a small group of people, and what's technically possible.
My takeaway is that a hybrid system is feasible, and preview for a hybrid
system can be made very fast*. STL export of functional objects remains a
problem: it's going to be expensive. But it's feasible, and there are
plenty of open source projects that implement code for this.
*If we want fast preview, then there is still the engineering tradeoff
between expressive power and fast preview. Some graphical operations can't
be previewed quickly, it would seem. We've encountered this problem in
OpenSCAD, where the prohibition on querying the mesh exists to keep preview
fast. IceSL has fast preview, but you can't apply convex_hull to a
functional object. PLASM finesses this problem by supporting progressive
preview, where you render a crude approximation and preview that, then
progressively improve the preview quality over time.
"implicits").
> -Marius
Fri, Nov 27, 2015 6:08 PM
clothbot said: "I'm curious of what OpenVDB might bring to the table in the
way of multi-material (discrete and mixed), variable-density and/or texture
and colour support. The stuff that the AMF file format hints at supporting
but toolset support doesn't quite exist for yet."
If you want to apply a texture to a surface (as AMF supports), then you
need to implement that using a mesh representation, not a voxel/functional
representation (in my opinion). The mesh represents surfaces explicitly,
whereas the surface is expensive to recover from a voxel or functional
representation.
All of that other stuff should be quite feasible using a voxel/functional
system. ShapeWays talks about how much better their voxel system is for
supporting this. They have an SVX voxel file format, and the ShapeJS
language for generating SVX files.
quote: "One promise of 3D printing is that complexity is free. Sadly with
STL files we’ve had the disconnect that more complexity equals more
triangles equals larger files. Above a certain limit you just can’t use
triangles to specify the details you want in a 3D printed model. Whether
that information be material allocation, density, RGB color both internal
and external or a custom id that could be used for another variable, not
yet available in the 3D printers on the market."
might
yet.
I
bet is slow.
If
representation.
> might
> yet.
> systems,
> > I
> > bet is slow.
> > If
Fri, Nov 27, 2015 9:24 PM
research group at Inria, and it's a fascinating window into what can be
accomplished by a small group of people, and what's technically possible.
Yeah, it's quite interesting stuff.
Although we are only allowed to look through the closed windows and
watch what they can do with more the a million of €. It makes me a
bit sad the EU funds research that is not open.
