zero thickness membranes in Preview as a result of difference()
K
khackbarth
Wed, Apr 22, 2020 11:25 PM
When I difference two objects that have a common length on one dimension, I
see a thin membrane in Preview rather than a hole:
http://forum.openscad.org/file/t2199/membrane.png Here's sample
code:$fn=40;dist=3;difference(){    cube([5,5,dist],center=true);
cylinder(r=2,h=dist,center=true);}I know that this membrane goes away when
the model is rendered but I'm producing complex objects where the rendering
process can take several minutes.  I'm also using the customizer so the
membrane is redisplayed each time a parameter is changed.I have worked
around this behavior by liberally peppering my code with references to a
global fudge factor:fudge=0.005.I add this factor to any object that will be
used to difference another object.  Often, I have to add a translate() call
just to move the resultant object down by fudge/2 to ensure that the hole is
uncovered on both sides of the first object.Since I'm 3D printing the final
model, this fudge factor is in the noise but it makes a mess of my code.
How have you all solved this problem?  Remember, requiring a render step
isn't a solution.Thanks,Ken
When I difference two objects that have a common length on one dimension, I see a thin membrane in Preview rather than a hole: <http://forum.openscad.org/file/t2199/membrane.png> Here's sample code:$fn=40;dist=3;difference(){ cube([5,5,dist],center=true); cylinder(r=2,h=dist,center=true);}I know that this membrane goes away when the model is rendered but I'm producing complex objects where the rendering process can take several minutes. I'm also using the customizer so the membrane is redisplayed each time a parameter is changed.I have worked around this behavior by liberally peppering my code with references to a global fudge factor:fudge=0.005.I add this factor to any object that will be used to difference another object. Often, I have to add a translate() call just to move the resultant object down by fudge/2 to ensure that the hole is uncovered on both sides of the first object.Since I'm 3D printing the final model, this fudge factor is in the noise but it makes a mess of my code. How have you all solved this problem? Remember, requiring a render step isn't a solution.Thanks,Ken -- Sent from: http://forum.openscad.org/
MB
Max Bond
Wed, Apr 22, 2020 11:34 PM
Your approach is the conventional one. But we usually call the variable
epsilon :)
This is actually pretty common in 3D printing and other fields. You'll find
the same approach occasionally used in vector graphics, for example.
Floating point precision errors cause headaches all around.
I know you say rendering is not an option, but you might check out the
render() primitive, which allows you to force rendering for particular
parts of your model. Depending on the geometry you're working with, you may
be able to render the outermost parts so you can see the interior details,
without rendering the whole thing.
Best of luck!
I see a thin membrane in Preview rather than a hole: Here's sample code:
$fn=40; dist=3; difference(){ cube([5,5,dist],center=true);
cylinder(r=2,h=dist,center=true); } I know that this membrane goes away
so the membrane is redisplayed each time a parameter is changed. I have
to a global fudge factor: fudge=0.005. I add this factor to any object that
ensure that the hole is uncovered on both sides of the first object. Since
requiring a render step isn't a solution. Thanks, Ken
at Nabble.com.
Hi, Your approach is the conventional one. But we usually call the variable epsilon :) This is actually pretty common in 3D printing and other fields. You'll find the same approach occasionally used in vector graphics, for example. Floating point precision errors cause headaches all around. I know you say rendering is not an option, but you might check out the render() primitive, which allows you to force rendering for particular parts of your model. Depending on the geometry you're working with, you may be able to render the outermost parts so you can see the interior details, without rendering the whole thing. Best of luck! On Wed, Apr 22, 2020, 5:25 PM khackbarth <ken@volksswitch.org> wrote: > When I difference two objects that have a common length on one dimension, > I see a thin membrane in Preview rather than a hole: Here's sample code: > $fn=40; dist=3; difference(){ cube([5,5,dist],center=true); > cylinder(r=2,h=dist,center=true); } I know that this membrane goes away > when the model is rendered but I'm producing complex objects where the > rendering process can take several minutes. I'm also using the customizer > so the membrane is redisplayed each time a parameter is changed. I have > worked around this behavior by liberally peppering my code with references > to a global fudge factor: fudge=0.005. I add this factor to any object that > will be used to difference another object. Often, I have to add a > translate() call just to move the resultant object down by fudge/2 to > ensure that the hole is uncovered on both sides of the first object. Since > I'm 3D printing the final model, this fudge factor is in the noise but it > makes a mess of my code. How have you all solved this problem? Remember, > requiring a render step isn't a solution. Thanks, Ken > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Apr 22, 2020 11:35 PM
I simple always subtract something that is bigger. It's like drilling a
hole, you always use a drill longer than the hole.  I often default to
subtracting a cylinder 100 long.
at Nabble.com.
I simple always subtract something that is bigger. It's like drilling a hole, you always use a drill longer than the hole. I often default to subtracting a cylinder 100 long. On Thu, 23 Apr 2020 at 00:25, khackbarth <ken@volksswitch.org> wrote: > When I difference two objects that have a common length on one dimension, > I see a thin membrane in Preview rather than a hole: Here's sample code: > $fn=40; dist=3; difference(){ cube([5,5,dist],center=true); > cylinder(r=2,h=dist,center=true); } I know that this membrane goes away > when the model is rendered but I'm producing complex objects where the > rendering process can take several minutes. I'm also using the customizer > so the membrane is redisplayed each time a parameter is changed. I have > worked around this behavior by liberally peppering my code with references > to a global fudge factor: fudge=0.005. I add this factor to any object that > will be used to difference another object. Often, I have to add a > translate() call just to move the resultant object down by fudge/2 to > ensure that the hole is uncovered on both sides of the first object. Since > I'm 3D printing the final model, this fudge factor is in the noise but it > makes a mess of my code. How have you all solved this problem? Remember, > requiring a render step isn't a solution. Thanks, Ken > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Apr 22, 2020 11:37 PM
It's called z-fighting, see the link  here
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#What_are_those_strange_flickering_artifacts_in_the_preview?
Your fudged is the correct way too handle it.
It is also good to use the fudge, as sometimes these co-incident faces can
cause non-manifoldness or other problems.
It's called z-fighting, see the link here <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#What_are_those_strange_flickering_artifacts_in_the_preview?> . Your fudged is the correct way too handle it. It is also good to use the fudge, as sometimes these co-incident faces can cause non-manifoldness or other problems. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
MB
Max Bond
Wed, Apr 22, 2020 11:38 PM
I will say that I, too, balked when I was first asked to do this, but once
one becomes used to it & plans for it at the outset, one finds idiomatic
ways to incorporate it and it doesn't feel like such a hack.
epsilon :)
Best of luck!
at Nabble.com.
I will say that I, too, balked when I was first asked to do this, but once one becomes used to it & plans for it at the outset, one finds idiomatic ways to incorporate it and it doesn't feel like such a hack. On Wed, Apr 22, 2020, 5:34 PM Max Bond <max.o.bond@gmail.com> wrote: > Hi, > > Your approach is the conventional one. But we usually call the variable > epsilon :) > > This is actually pretty common in 3D printing and other fields. You'll > find the same approach occasionally used in vector graphics, for example. > Floating point precision errors cause headaches all around. > > I know you say rendering is not an option, but you might check out the > render() primitive, which allows you to force rendering for particular > parts of your model. Depending on the geometry you're working with, you may > be able to render the outermost parts so you can see the interior details, > without rendering the whole thing. > > Best of luck! > > On Wed, Apr 22, 2020, 5:25 PM khackbarth <ken@volksswitch.org> wrote: > >> When I difference two objects that have a common length on one dimension, >> I see a thin membrane in Preview rather than a hole: Here's sample code: >> $fn=40; dist=3; difference(){ cube([5,5,dist],center=true); >> cylinder(r=2,h=dist,center=true); } I know that this membrane goes away >> when the model is rendered but I'm producing complex objects where the >> rendering process can take several minutes. I'm also using the customizer >> so the membrane is redisplayed each time a parameter is changed. I have >> worked around this behavior by liberally peppering my code with references >> to a global fudge factor: fudge=0.005. I add this factor to any object that >> will be used to difference another object. Often, I have to add a >> translate() call just to move the resultant object down by fudge/2 to >> ensure that the hole is uncovered on both sides of the first object. Since >> I'm 3D printing the final model, this fudge factor is in the noise but it >> makes a mess of my code. How have you all solved this problem? Remember, >> requiring a render step isn't a solution. Thanks, Ken >> ------------------------------ >> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> >> at Nabble.com. >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >
Wed, Apr 22, 2020 11:41 PM
BTW your original post has that large paragraph without line breaks, I
presume it was not formatted that way originally, what method did you use to
post it.
I don't normally see "Sent from the OpenSCAD mailing list archive at
Nabble.com"
BTW your original post has that large paragraph without line breaks, I presume it was not formatted that way originally, what method did you use to post it. I don't normally see "Sent from the OpenSCAD mailing list archive at Nabble.com" ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Wed, Apr 22, 2020 11:47 PM
post it.
Nabble.com"
Forum Admin
BTW your original post has that large paragraph without line breaks, I presume it was not formatted that way originally, what method did you use to post it. I don't normally see "Sent from the OpenSCAD mailing list archive at Nabble.com" MichaelAtOz Forum Admin ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Thu, Apr 23, 2020 1:49 AM
The fudge factor should be applied only to the "negative" objects, the
second-and-later children of the difference().
Since it only applies to the negative objects, it never appears in the
final result.
On 4/22/2020 4:25 PM, khackbarth wrote: > Since I'm 3D printing the final model, this fudge factor is in the > noise but it makes a mess of my code. The fudge factor should be applied only to the "negative" objects, the second-and-later children of the difference(). Since it only applies to the negative objects, it never appears in the final result.
Troberg
Thu, Apr 23, 2020 1:50 PM
I call it itsy (as it itsy bitsy). Any small number where the precise value
isn't of importance.
epsilon :)
I call it itsy (as it itsy bitsy). Any small number where the precise value isn't of importance. Max Bond wrote > Your approach is the conventional one. But we usually call the variable > epsilon :) -- Sent from: http://forum.openscad.org/
KR
Kenneth R Sloan
Thu, Apr 23, 2020 2:05 PM
This is a general principle of computing : “any program such depends on (a
== b) is broken”
Manufacturing has a similar concept : tolerance.
I disagree with the claim that only “difference” needs a tolerance.  It’s
also necessary when doing a “union” of two objects with a shared boundary.
-Kenneth Sloan
This is a general principle of computing : “any program such depends on (a == b) is broken” Manufacturing has a similar concept : tolerance. I disagree with the claim that only “difference” needs a tolerance. It’s also necessary when doing a “union” of two objects with a shared boundary. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- -Kenneth Sloan
