Its value does have some considerations.
It needs to be small enough to not be visible but large enough to not allow
z-fighting when zoomed out a reasonable distance.
I also make sure it is representable exactly in floating point, so I use
1/128.
On Thu, 23 Apr 2020 at 14:51, Troberg troberg.anders@gmail.com wrote:
I call it itsy (as it itsy bitsy). Any small number where the precise value
isn't of importance.
Max Bond wrote
Your approach is the conventional one. But we usually call the variable
epsilon :)
Yes but only when the shared boundary can't be represented in floating
point. Objects with exactly shared faces can be unioned by CGAL.
On Thu, 23 Apr 2020 at 15:06, Kenneth R Sloan kennethrsloan@gmail.com
This is a general principle of computing : “any program such depends on (a
== b) is broken”
Manufacturing has a similar concept : tolerance.
I disagree with the claim that only “difference” needs a tolerance. It’s
also necessary when doing a “union” of two objects with a shared boundary.
-Kenneth Sloan
The common way to eliminate Z-fighting is switching to a logarithmic Z-buffer
But i'm not sure if OpenCSG Require linear Z-buffer for boolean ops.
Anyways i use the far faster and more robust 2d subsystem whenever possible.
