Thu, Mar 2, 2023 12:48 PM
While I understand the flexibility that the $time variable allows
(varying the model generated over time), in my case ALL I am doing is a
walk through my model; it only needs to be calculated once. So, it would
be helpful if there was a way to say "keep the old model that is in the
cache and just re-display it on the screen". Perhaps another global
variable? Evaluating the code to see how the $time variable is used
probably is infeasible.
Maybe my kind of Animation is different, or a sub-set of the
full-featured Animation.
Animations continue to be very difficult for me to use. I Kill OpenSCAD
using the Task Manager over and over again, because it is unresponsive,
and because I have no idea what it is doing. Recalculating the model
(unnecessarily)? Are Animations enabled or disabled? It is easier to
kill OpenSCAD than to use the controls that are available.
I was told to use a batch file and the command line. That involved me
creating 200 lines of custom code to get the invocations right. Not
impossible, but it is so much easier to allow OpenSCAD to generate these
scenarios. Except that it isn't easier.
Am I a special case (4-5 minute F5 times)? Quite likely.
On 3/2/2023 3:56 AM, nop head wrote:
Yes it would be great if OpenSCAD expired old cache entries. If I work
on a complex model each F5 uses more and more memory until I either
flush the cache or restart and then it takes minutes to recreate the
cached items that are needed. It needs to record hits juring F5 and
flush items that have not been hit after a few F5s.
F5 time isn't taken up by drawing on the screen. It is mainly the time
to execute the statements for me. Once it is drawn I can pan and zoom
it very quickly with the mouse but animation always runs the entire
script each frame.
On Thu, 2 Mar 2023 at 08:44, Rogier Wolff R.E.Wolff@bitwizard.nl wrote:
On Wed, Mar 01, 2023 at 06:18:04PM +0000, nop head wrote:
Maybe if the model doesn't change, only the camera angle, then a
the whole scene would be calculated slowly and then cached, so
first frame it would be fast.
I get it that caching is good. But a cache usually expires those
cached objects after they haven't been used for a while. I'd say that
you need to start expiring objects from the cache once you hit about
half the memory of the machine. Complaints about 32Gb would not
be coming in if that machine had 64Gb of memory.
Sidenote: e2fsck would "cache" some info about inodes. It did that
wrong, resulting in a quadratic algorithm that would also run out of
memory. It resulted in "extrapolations based on linear progress" of a
month runtime when it was a day in. I decided it would be faster to
investigate and fix the problem than to wait for it to finish. I was
correct. My fix eventually got included. Runtime reduced to a couple
of hours with my fix.
However a render with 10000 objects might take longer than the
What I don't understand is that openscad uses my graphiscs card for
rendering, right?
My graphics card is capable of doing on the order of 1 billion
triangles
per second. so with 10000 objects, maybe 100000 triangles, it should
be capable of on the order of 1000 frames per second.
It is not optimally coded can be used to explain away one order of
magnitude, but not five.
** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/
<https://www.BitWizard.nl/> ** +31-15-2049110 **
** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK:
27239233 **
your a is going up. -- Chris Hadfield about flying up the space
shuttle.
> script each frame.
> render of
> after the
> universe
> > will last.
> rendering, right?
> triangles
> Roger.
> 27239233 **
> f equals m times a. When your f is steady, and your m is going down
> shuttle.
GB
Glenn Butcher
Thu, Mar 2, 2023 2:03 PM
Here's a thought: Do an export of your model to a file, then write a
separate animation script that just imports the model for each
iteration. This assumes your filesystem is faster at delivering the
mesh than your cpu is at creating it from scratch for each frame...
a walk through my model; it only needs to be calculated once. So, it
would be helpful if there was a way to say "keep the old model that is
in the cache and just re-display it on the screen". Perhaps another
global variable? Evaluating the code to see how the $time variable is
used probably is infeasible.
OpenSCAD using the Task Manager over and over again, because it is
unresponsive, and because I have no idea what it is doing.
Recalculating the model (unnecessarily)? Are Animations enabled or
disabled? It is easier to kill OpenSCAD than to use the controls that
are available.
these scenarios. Except that it isn't easier.
.org
> are available.
> Jon
> .org
Thu, Mar 2, 2023 5:11 PM
Glenn:
Good idea, except that I have not yet succeeded in an F6 because
OpenSCAD blows up at 32 GB of memory used. I am working to see how
this might be improved, but I'm not there yet.
is in the cache and just re-display it on the screen". Perhaps
another global variable? Evaluating the code to see how the $time
variable is used probably is infeasible.
that are available.
me creating 200 lines of custom code to get the invocations right.
Not impossible, but it is so much easier to allow OpenSCAD to
generate these scenarios. Except that it isn't easier.
.org
Glenn:
>> that are available.
>> Jon
>> .org
GB
Glenn Butcher
Thu, Mar 2, 2023 5:24 PM
Jon,
Same thinking, applied to the model. Divide it into major assemblies,
render each to a file, then import them back in to move into place. I'm
doing this with my locomotive; in fact, I'm printing such an integration
right now, the boiler with the smokestack, steam and sand domes modeled
separately and integrated as .stl meshes.
Now, I did the integration with a separate program to prove the concept
of using a simple program like MeshMixer, Meshlab, or 3DBuilder to do
simple parts placement to make models, a lower bar of entry for folk
intimidated by full-out CAD. You might find using such easier than doing
it in OpenSCAD, although I've done it there too. For printing, just
need to make sure each connecting part-pair has a solid interface that
the slicer will make a continuous part. For animation, probably not as
important.
Yeah, complex models start to bog down the functional nature of the
OpenSCAD script language. Me, what I think would be helpful would be to
allow the loading of a mesh from either a render() or import() to a
variable, then make copies of that variable and place them later in the
script. Modeling the locomotive tender right now, has a gazillion
round-head rivets, each has to be recreated during each render...
Glenn
On 3/2/23 10:11, jon wrote:
Glenn:
is a walk through my model; it only needs to be calculated once.
So, it would be helpful if there was a way to say "keep the old
model that is in the cache and just re-display it on the screen".
Perhaps another global variable? Evaluating the code to see how the
$time variable is used probably is infeasible.
that are available.
.org
Jon,
important.
Glenn
> Glenn:
> Jon
>>> that are available.
>>> Jon
>>> .org
Thu, Mar 2, 2023 5:30 PM
I wonder how Nop Head manages to make his complex printer models.
"what I think would be helpful would be to allow the loading of a mesh
from either a render() or import() to a variable, then make copies of
that variable and place them later in the script."
Yes, please. This.
On 3/2/2023 12:24 PM, Glenn Butcher wrote:
Jon,
I'm doing this with my locomotive; in fact, I'm printing such an
integration right now, the boiler with the smokestack, steam and sand
domes modeled separately and integrated as .stl meshes.
concept of using a simple program like MeshMixer, Meshlab, or
3DBuilder to do simple parts placement to make models, a lower bar of
entry for folk intimidated by full-out CAD. You might find using such
easier than doing it in OpenSCAD, although I've done it there too.
For printing, just need to make sure each connecting part-pair has a
solid interface that the slicer will make a continuous part. For
animation, probably not as important.
to allow the loading of a mesh from either a render() or import() to a
the script. Modeling the locomotive tender right now, has a gazillion
Glenn
Glenn:
the $time variable is used probably is infeasible.
that are available.
.org
Yes, please. This.
> Jon,
> Glenn
>> Glenn:
>> Jon
>>>> that are available.
>>>> Jon
>>>> .org
Thu, Mar 2, 2023 9:17 PM
jon, you should just write a script to manage invoking OpenSCAD 200 times
or whatever, not write 200 lines of code. It should be a simple script to
write.
On Thu, Mar 2, 2023 at 7:49 AM jon jon@jonbondy.com wrote:
While I understand the flexibility that the $time variable allows (varying
the model generated over time), in my case ALL I am doing is a walk through
my model; it only needs to be calculated once. So, it would be helpful if
there was a way to say "keep the old model that is in the cache and just
re-display it on the screen". Perhaps another global variable? Evaluating
the code to see how the $time variable is used probably is infeasible.
Maybe my kind of Animation is different, or a sub-set of the full-featured
Animation.
using the Task Manager over and over again, because it is unresponsive, and
(unnecessarily)? Are Animations enabled or disabled? It is easier to kill
Yes it would be great if OpenSCAD expired old cache entries. If I work on
a complex model each F5 uses more and more memory until I either flush the
cache or restart and then it takes minutes to recreate the cached items
that are needed. It needs to record hits juring F5 and flush items that
F5 time isn't taken up by drawing on the screen. It is mainly the time to
execute the statements for me. Once it is drawn I can pan and zoom it very
quickly with the mouse but animation always runs the entire script each
frame.
Maybe if the model doesn't change, only the camera angle, then a render
the whole scene would be calculated slowly and then cached, so after the
However a render with 10000 objects might take longer than the universe
will last.
rendering, right?
My graphics card is capable of doing on the order of 1 billion triangles
** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233
write.
> Animation.
> Jon
> frame.
>> of
>> > will last.
>> rendering, right?
>> Roger.
>> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
Thu, Mar 2, 2023 9:18 PM
Glenn, he has 10,000 spheres. You are assuming that he can render, and
hence save models. He can't do that. The model is much too big. There is
no way to save anything except images.
On Thu, Mar 2, 2023 at 12:26 PM Glenn Butcher glenn.butcher@gmail.com
Jon,
important.
Glenn
Glenn:
that are available.
.org
On Thu, Mar 2, 2023 at 12:26 PM Glenn Butcher <glenn.butcher@gmail.com>
> Jon,
> important.
> Glenn
> > Glenn:
> > Jon
> >>> that are available.
> >>> Jon
> >>> .org
Thu, Mar 2, 2023 9:20 PM
There is a future scheme involving access to geometry data which would
allow this. But really, for your application what is the practical
difference between creating a module that makes the thing? That's what
modules are for: making copies of things and placing them later in a
script. It is not going to be faster to operate on mesh data as suggested
by the quoted idea.
Yes, please. This.
Jon,
Glenn
Glenn:
that are available.
.org
by the quoted idea.
> Yes, please. This.
> > Jon,
> > Glenn
> >> Glenn:
> >> Jon
> >>>> that are available.
> >>>> Jon
> >>>> .org
Thu, Mar 2, 2023 9:24 PM
I do as much as possible in 2D and extrude it to 3D and union bits
together because union is free in F5. For example to make a posi panhead
screw I don't subtract the crossed slot. I rotate_extrude the rounded head
with a hole in the middle and then linear extrude a circle with the cross
subtracted to fill it. Then I can place hundreds of screws without any
issue because OPENCSG just has to draw lots of polyhedrons and that is very
fast.
The slow bit for me is the time to execute the script due to the fact it
recalculates all the constant expressions millions of times in a big
project.
Yes, please. This.
Jon,
Glenn
Glenn:
that are available.
.org
fast.
project.
> Yes, please. This.
> > Jon,
> > Glenn
> >> Glenn:
> >> Jon
> >>>> that are available.
> >>>> Jon
> >>>> .org
Fri, Mar 3, 2023 4:53 AM
How large are your spheres?
