Wed, Mar 1, 2023 2:17 PM
I started a run of 200 animation frames last night; I have about 50 more
frames to go. Memory use started at about 350 KB, and is now around 3.5
GB. Clearly, at some point this process will die because of increasing
use of memory.
Is there a way to have OpenSCAD clear the caches prior to each F5,
either always, or only in Animation mode?
Is there a way to have an OpenSCAD program ask to clear the caches at
the start of a program?
These appear to be useful features for some uses.
use of memory.
Wed, Mar 1, 2023 5:42 PM
No.
This must be a really, really complex model if previewing is taking this
long. Or do you have minkowski() or render() in it?
I'm not aware of one.
No.
Wed, Mar 1, 2023 5:48 PM
No minkowski and no render. Since I am only changing the camera view,
render() might be useful, but I've never understood how to use it (only
that the experts rave about it). The model has perhaps 10,000 spheres
in it. It is art, not practical. I downloaded the snapshot and will
try the lazy unions later.
No.
this long. Or do you have minkowski() or render() in it?
> No.
Wed, Mar 1, 2023 5:50 PM
(only that the experts rave about it). The model has perhaps 10,000
spheres in it. It is art, not practical. I downloaded the snapshot
and will try the lazy unions later.
Ah. Yes, 10K of anything is a complex model.
Some people like render(). I've found it useful for fixing one or two
kinds of preview artifacts, but not really otherwise. Maybe I don't
have the right use cases or haven't seen the light.
Wed, Mar 1, 2023 6:18 PM
Maybe if the model doesn't change, only the camera angle, then a render of
the whole scene would be calculated slowly and then cached, so after the
first frame it would be fast.
However a render with 10000 objects might take longer than the universe
will last.
Lazy union would only be useful if you are doing F6 but for animation you
are only doing F5 and union is free for F5.
On Wed, 1 Mar 2023 at 17:50, Jordan Brown openscad@jordan.maileater.net
that the experts rave about it). The model has perhaps 10,000 spheres in
it. It is art, not practical. I downloaded the snapshot and will try the
lazy unions later.
kinds of preview artifacts, but not really otherwise. Maybe I don't have
will last.
On Wed, 1 Mar 2023 at 17:50, Jordan Brown <openscad@jordan.maileater.net>
> lazy unions later.
Wed, Mar 1, 2023 6:21 PM
Yes, I've not been brave enough to try an F6 again after it failed last
time.
Lazy union does not seem to be helping much with F5
Does anyone know how to tell if OpenSCAD is busy animating or not in
the latest snapshot? I have to set a 10 minute timer, and then come
back and see what it is doing. Infuriating.
I hate being a leader.
render of the whole scene would be calculated slowly and then cached,
so after the first frame it would be fast.
universe will last.
you are only doing F5 and union is free for F5.
view, render() might be useful, but I've never understood how to
use it (only that the experts rave about it). The model has
perhaps 10,000 spheres in it. It is art, not practical. I
downloaded the snapshot and will try the lazy unions later.
two kinds of preview artifacts, but not really otherwise. Maybe I
don't have the right use cases or haven't seen the light.
time.
> universe will last.
Wed, Mar 1, 2023 11:59 PM
Yeah, lazy union won't help with preview, only with actual render. Can't
you tell if OpenSCAD is busy by looking at CPU use? Seems to me that you
really should bite the bullet and figure out how to make openscad compute
one frame. Then you'll know exactly what's going on. I am somewhat
puzzled about why this is complicated to do. I took a look at the help
message and tried 'openscad -o test.png mymodel.scad' and it produced an
output image in test.png.
Jordan, my experience with render() was that it was crucially useful for
avoiding recomputes of minkowski() operations: it made iterating a minkowki
based design 100x faster in situations where the change didn't require the
minkowski to be recomputed.
time.
Does anyone know how to tell if OpenSCAD is busy animating or not in the
latest snapshot? I have to set a 10 minute timer, and then come back and
will last.
lazy unions later.
> time.
> Jon
> will last.
>> lazy unions later.
Thu, Mar 2, 2023 12:18 AM
Adrian:
I have OpenSCAD running in Animation mode with the Dump Pictures option
enabled. I am up to 68 out of 200 images with 4.5 hours of CPU time;
the process is up to a working set of 497K and private bytes of 677K. I
will let it run over night.
I will try your command line use if my current run fails. Last time I
made the mistake of trying to fill in a few of the missing frames using
a different release of OpenSCAD, and the resulting video was horrible.
I don't know where the dimensions of the PNG come from, but they could
be the accident of how the screen is currently set up (running from the
GUI).
Thanks for your help!
Can't you tell if OpenSCAD is busy by looking at CPU use? Seems to
me that you really should bite the bullet and figure out how to make
openscad compute one frame. Then you'll know exactly what's going
on. I am somewhat puzzled about why this is complicated to do. I
mymodel.scad' and it produced an output image in test.png.
for avoiding recomputes of minkowski() operations: it made iterating a
minkowki based design 100x faster in situations where the change
didn't require the minkowski to be recomputed.
last time.
in the latest snapshot? I have to set a 10 minute timer, and then
come back and see what it is doing. Infuriating.
cached, so after the first frame it would be fast.
universe will last.
animation you are only doing F5 and union is free for F5.
camera view, render() might be useful, but I've never
understood how to use it (only that the experts rave about
it). The model has perhaps 10,000 spheres in it. It is
one or two kinds of preview artifacts, but not really
otherwise. Maybe I don't have the right use cases or haven't
seen the light.
Adrian:
GUI).
> last time.
> Jon
>> universe will last.
>> seen the light.
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
Thu, Mar 2, 2023 8:43 AM
I get it that caching is good. But a cache usually expires those
cached objects after they haven't been used for a while. I'd say that
you need to start expiring objects from the cache once you hit about
half the memory of the machine. Complaints about 32Gb would not
be coming in if that machine had 64Gb of memory.
Sidenote: e2fsck would "cache" some info about inodes. It did that
wrong, resulting in a quadratic algorithm that would also run out of
memory. It resulted in "extrapolations based on linear progress" of a
month runtime when it was a day in. I decided it would be faster to
investigate and fix the problem than to wait for it to finish. I was
correct. My fix eventually got included. Runtime reduced to a couple
of hours with my fix.
will last.
What I don't understand is that openscad uses my graphiscs card for
rendering, right?
My graphics card is capable of doing on the order of 1 billion triangles
per second. so with 10000 objects, maybe 100000 triangles, it should
be capable of on the order of 1000 frames per second.
It is not optimally coded can be used to explain away one order of
magnitude, but not five.
> will last.
rendering, right?
Thu, Mar 2, 2023 8:56 AM
Yes it would be great if OpenSCAD expired old cache entries. If I work on a
complex model each F5 uses more and more memory until I either flush the
cache or restart and then it takes minutes to recreate the cached items
that are needed. It needs to record hits juring F5 and flush items that
have not been hit after a few F5s.
F5 time isn't taken up by drawing on the screen. It is mainly the time to
execute the statements for me. Once it is drawn I can pan and zoom it very
quickly with the mouse but animation always runs the entire script each
frame.
will last.
rendering, right?
frame.
> of
> > will last.
> rendering, right?
> Roger.
> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
> f equals m times a. When your f is steady, and your m is going down
