Adding a border of d thickness to a polygon
N
nigeljohnson73
Mon, Nov 21, 2016 12:05 PM
I'm not sure where to post this or how to get to the point, please bear with
me and feel free to point me in directions.
I have a function and module that will draw me a heart polygon of an exact
size:
function heartRadius(t) = (1.5 - 1.5* sin(t) + (sin(t) *
(sqrt(abs(cos(t)))/(sin(t)+1.6))));
module njHeart(xy=80, pad = 0) {
td = 1; // theta delta - the resolution of the curve
// Calculate x/y co-ords separetely so I can scale correctly later
xp = [ for (t = [0 : td : 360-td]) heartRadius(t) * cos(t) ]; // x
co-ordinates on the curve
yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) ]; // y
xsc = xy/(max(xp) - min(xp)); // x scaler to get to fit expected size
ysc = xy/(max(yp) - min(yp)); // y scaler to get to fit expected size
// Generate a vector of points for the polygon to work
p = [ for (i = [0 : 360/td - 1]) [xsc*xp[i]+pad, ysc*yp[i]+pad] ];
// translate polygon so it is centralised at +/- xy/2
translate([0,ysc*(-max(yp)+(max(yp)-min(yp))/2)])
linear_extrude(height=0.01) polygon(p);
color("red") njHeart(xy=80);
color("white") njHeart(xy=78);
Originally, I thought this was going to be easy, do it in polar and then
just add 'pad' to the calculated 'r' and it'll all be good... nope.
I had already worked out that scaling is not the answer.
Then I thought about calculating normals to the gradient of the 2 sides of
the point... but then you get a hole at the top of the heart as it loops
back on itself. My most promising idea was to test if the normal (x,y) was
of the same sign in x as the current point, but that got really messy trying
to make the array work- and I never did.
I then wondered if I could find the 'true' center of the object whether the
scaling would work better, but I couldn't figure out how to do it.
The only other option I can think of is to draw the outline of the heart in
hull'd cylinders with a radius of "pad", then subtracting the solid from the
middle. After working out the math it was very clear that the computational
power required was going to make it unworkable.
I have now run out of ideas.
Any help much apprecaited.
Kind regards
Nigel
View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283.html
I'm not sure where to post this or how to get to the point, please bear with me and feel free to point me in directions. I have a function and module that will draw me a heart polygon of an exact size: function heartRadius(t) = (1.5 - 1.5* sin(t) + (sin(t) * (sqrt(abs(cos(t)))/(sin(t)+1.6)))); module njHeart(xy=80, pad = 0) { td = 1; // theta delta - the resolution of the curve // Calculate x/y co-ords separetely so I can scale correctly later xp = [ for (t = [0 : td : 360-td]) heartRadius(t) * cos(t) ]; // x co-ordinates on the curve yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) ]; // y co-ordinates on the curve xsc = xy/(max(xp) - min(xp)); // x scaler to get to fit expected size ysc = xy/(max(yp) - min(yp)); // y scaler to get to fit expected size // Generate a vector of points for the polygon to work p = [ for (i = [0 : 360/td - 1]) [xsc*xp[i]+pad, ysc*yp[i]+pad] ]; // translate polygon so it is centralised at +/- xy/2 translate([0,ysc*(-max(yp)+(max(yp)-min(yp))/2)]) linear_extrude(height=0.01) polygon(p); } color("red") njHeart(xy=80); color("white") njHeart(xy=78); Originally, I thought this was going to be easy, do it in polar and then just add 'pad' to the calculated 'r' and it'll all be good... nope. I had already worked out that scaling is not the answer. Then I thought about calculating normals to the gradient of the 2 sides of the point... but then you get a hole at the top of the heart as it loops back on itself. My most promising idea was to test if the normal (x,y) was of the same sign in x as the current point, but that got really messy trying to make the array work- and I never did. I then wondered if I could find the 'true' center of the object whether the scaling would work better, but I couldn't figure out how to do it. The only other option I can think of is to draw the outline of the heart in hull'd cylinders with a radius of "pad", then subtracting the solid from the middle. After working out the math it was very clear that the computational power required was going to make it unworkable. I have now run out of ideas. Any help much apprecaited. Kind regards Nigel -- View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Nov 21, 2016 1:31 PM
Try offset <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Transformations#offset>.
Mon, Nov 21, 2016 1:36 PM
I think you just need to use offset() to expand the shape in 2D before
extruding it to 3D if I understand the question right.
with
size:
size
size
trying
Kind regards
Nigel
I think you just need to use offset() to expand the shape in 2D before extruding it to 3D if I understand the question right. On 21 November 2016 at 12:05, nigeljohnson73 <nigel@nigeljohnson.net> wrote: > I'm not sure where to post this or how to get to the point, please bear > with > me and feel free to point me in directions. > > I have a function and module that will draw me a heart polygon of an exact > size: > > function heartRadius(t) = (1.5 - 1.5* sin(t) + (sin(t) * > (sqrt(abs(cos(t)))/(sin(t)+1.6)))); > > module njHeart(xy=80, pad = 0) { > > td = 1; // theta delta - the resolution of the curve > > // Calculate x/y co-ords separetely so I can scale correctly later > xp = [ for (t = [0 : td : 360-td]) heartRadius(t) * cos(t) ]; // x > co-ordinates on the curve > yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) ]; // y > co-ordinates on the curve > > xsc = xy/(max(xp) - min(xp)); // x scaler to get to fit expected > size > ysc = xy/(max(yp) - min(yp)); // y scaler to get to fit expected > size > > // Generate a vector of points for the polygon to work > p = [ for (i = [0 : 360/td - 1]) [xsc*xp[i]+pad, ysc*yp[i]+pad] ]; > > // translate polygon so it is centralised at +/- xy/2 > translate([0,ysc*(-max(yp)+(max(yp)-min(yp))/2)]) > linear_extrude(height=0.01) polygon(p); > } > > color("red") njHeart(xy=80); > color("white") njHeart(xy=78); > > Originally, I thought this was going to be easy, do it in polar and then > just add 'pad' to the calculated 'r' and it'll all be good... nope. > > I had already worked out that scaling is not the answer. > > Then I thought about calculating normals to the gradient of the 2 sides of > the point... but then you get a hole at the top of the heart as it loops > back on itself. My most promising idea was to test if the normal (x,y) was > of the same sign in x as the current point, but that got really messy > trying > to make the array work- and I never did. > > I then wondered if I could find the 'true' center of the object whether the > scaling would work better, but I couldn't figure out how to do it. > > The only other option I can think of is to draw the outline of the heart in > hull'd cylinders with a radius of "pad", then subtracting the solid from > the > middle. After working out the math it was very clear that the computational > power required was going to make it unworkable. > > I have now run out of ideas. > > Any help much apprecaited. > Kind regards > Nigel > > > > -- > View this message in context: http://forum.openscad.org/ > Adding-a-border-of-d-thickness-to-a-polygon-tp19283.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
N
nigeljohnson73
Mon, Nov 21, 2016 7:49 PM
Thanks, that's what I was after. It doesn't like the sharp points though, so
a bit of tweaking was required.
View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19298.html
Thanks, that's what I was after. It doesn't like the sharp points though, so a bit of tweaking was required. -- View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19298.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Nov 21, 2016 9:10 PM
Nigel,
There are some parameters to offset() which can be used to control sharp corners, see:
> On Nov 21, 2016, at 14:49, nigeljohnson73 <nigel@nigeljohnson.net> wrote: > > Thanks, that's what I was after. It doesn't like the sharp points though, so > a bit of tweaking was required. > Nigel, There are some parameters to offset() which can be used to control sharp corners, see: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Transformations#offset -Marius
N
nigeljohnson73
Tue, Nov 22, 2016 4:37 PM
Thanks Marius.
I should have been more specific though; with my heart shape, the delta -
which is what I wanted based on the images in the documentation - doesn't
like the top point, and with a bit of delta cuts the whole object in half.
The radius is also not the greatest here, but it works enough for my needs.
Cheers
Nigel
View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19321.html
Thanks Marius. I should have been more specific though; with my heart shape, the delta - which is what I wanted based on the images in the documentation - doesn't like the top point, and with a bit of delta cuts the whole object in half. The radius is also not the greatest here, but it works enough for my needs. Cheers Nigel -- View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19321.html Sent from the OpenSCAD mailing list archive at Nabble.com.
FV
Frank van der Hulst
Tue, Nov 22, 2016 5:37 PM
Check out http://www.thingiverse.com/thing:8483 (this tells you how to make
a heart using Bezier curves) and http://www.thingiverse.com/thing:186660
(tells you how to extrude along a path).
Combine the two to extrude a square or rectangle along a heart-shaped path
and you should have what you're after?
Frank
On Wed, Nov 23, 2016 at 5:37 AM, nigeljohnson73 nigel@nigeljohnson.net
Thanks Marius.
Cheers
Nigel
Check out http://www.thingiverse.com/thing:8483 (this tells you how to make a heart using Bezier curves) and http://www.thingiverse.com/thing:186660 (tells you how to extrude along a path). Combine the two to extrude a square or rectangle along a heart-shaped path and you should have what you're after? Frank On Wed, Nov 23, 2016 at 5:37 AM, nigeljohnson73 <nigel@nigeljohnson.net> wrote: > Thanks Marius. > > I should have been more specific though; with my heart shape, the delta - > which is what I wanted based on the images in the documentation - doesn't > like the top point, and with a bit of delta cuts the whole object in half. > The radius is also not the greatest here, but it works enough for my needs. > > Cheers > Nigel > > > > -- > View this message in context: http://forum.openscad.org/ > Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19321.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
K
kintel
Tue, Nov 22, 2016 5:40 PM
You have a very sharp angle in your heart, which makes it hard to offset. We
have a chamfer flag for this purpose, but that doesn't look too good in this
case.
Another option is to get rid of sharp angles by offsetting the original a
small amount:
color("red") offset(delta=2) offset(delta=0.5) njHeart(xy=80);
color("white") offset(delta=0.5) njHeart(xy=80);
View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19323.html
You have a very sharp angle in your heart, which makes it hard to offset. We have a chamfer flag for this purpose, but that doesn't look too good in this case. Another option is to get rid of sharp angles by offsetting the original a small amount: difference() { color("red") offset(delta=2) offset(delta=0.5) njHeart(xy=80); color("white") offset(delta=0.5) njHeart(xy=80); } -Marius -- View this message in context: http://forum.openscad.org/Adding-a-border-of-d-thickness-to-a-polygon-tp19283p19323.html Sent from the OpenSCAD mailing list archive at Nabble.com.
O
otto
Wed, Nov 23, 2016 2:41 PM
Another way to achieve this is with the 2-D minkowski which is
moderately efficient.
$fn=23;
module pHeart(xy,off=0) {
xp = [ for (t = [0: td : 360-td]) heartRadius(t) * cos(t) ]; // xco-ordinates on the curve
yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) ]; // yco-ordinates on the curve
p = [ for (i = [0 : 360/td-1]) [xsc*xp[i], ysc*yp[i]] ];
if(off)
minkowski(){ polygon(p); circle(off); }
else polygon(p);
linear_extrude(5) pHeart(xy=78,off=2);
translate([0,0,-.5]) linear_extrude(6) pHeart(xy=78, off=.4);
On Mon, 21 Nov 2016 13:36:36 +0000
bear with
an exact size:
expected size
expected size
ysc*yp[i]+pad] ];
nope.
how to do it.
the solid from the
Kind regards
Nigel
Another way to achieve this is with the 2-D minkowski which is moderately efficient. function heartRadius(t) = (1.5 - 1.5* sin(t) + (sin(t) * (sqrt(abs(cos(t)))/(sin(t)+1.6)))); $fn=23; module pHeart(xy,off=0) { td = 1; // theta delta - the resolution of the curve // Calculate x/y co-ords separetely so I can scale correctly later xp = [ for (t = [0: td : 360-td]) heartRadius(t) * cos(t) ]; // xco-ordinates on the curve yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) ]; // yco-ordinates on the curve xsc = xy/(max(xp) - min(xp)); // x scaler to get to fit expected size ysc = xy/(max(yp) - min(yp)); // y scaler to get to fit expected size // Generate a vector of points for the polygon to work p = [ for (i = [0 : 360/td-1]) [xsc*xp[i], ysc*yp[i]] ]; // translate polygon so it is centralised at +/- xy/2 translate([0,ysc*(-max(yp)+(max(yp)-min(yp))/2)]) if(off) { minkowski(){ polygon(p); circle(off); } } else polygon(p); } difference() { linear_extrude(5) pHeart(xy=78,off=2); translate([0,0,-.5]) linear_extrude(6) pHeart(xy=78, off=.4); } On Mon, 21 Nov 2016 13:36:36 +0000 nop head <nop.head@gmail.com> wrote: > I think you just need to use offset() to expand the shape in 2D before > extruding it to 3D if I understand the question right. > > On 21 November 2016 at 12:05, nigeljohnson73 <nigel@nigeljohnson.net> > wrote: > > > I'm not sure where to post this or how to get to the point, please > > bear with > > me and feel free to point me in directions. > > > > I have a function and module that will draw me a heart polygon of > > an exact size: > > > > function heartRadius(t) = (1.5 - 1.5* sin(t) + (sin(t) * > > (sqrt(abs(cos(t)))/(sin(t)+1.6)))); > > > > module njHeart(xy=80, pad = 0) { > > > > td = 1; // theta delta - the resolution of the curve > > > > // Calculate x/y co-ords separetely so I can scale > > correctly later xp = [ for (t = [0 : td : 360-td]) heartRadius(t) * > > cos(t) ]; // x co-ordinates on the curve > > yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) > > ]; // y co-ordinates on the curve > > > > xsc = xy/(max(xp) - min(xp)); // x scaler to get to fit > > expected size > > ysc = xy/(max(yp) - min(yp)); // y scaler to get to fit > > expected size > > > > // Generate a vector of points for the polygon to work > > p = [ for (i = [0 : 360/td - 1]) [xsc*xp[i]+pad, > > ysc*yp[i]+pad] ]; > > > > // translate polygon so it is centralised at +/- xy/2 > > translate([0,ysc*(-max(yp)+(max(yp)-min(yp))/2)]) > > linear_extrude(height=0.01) polygon(p); > > } > > > > color("red") njHeart(xy=80); > > color("white") njHeart(xy=78); > > > > Originally, I thought this was going to be easy, do it in polar and > > then just add 'pad' to the calculated 'r' and it'll all be good... > > nope. > > > > I had already worked out that scaling is not the answer. > > > > Then I thought about calculating normals to the gradient of the 2 > > sides of the point... but then you get a hole at the top of the > > heart as it loops back on itself. My most promising idea was to > > test if the normal (x,y) was of the same sign in x as the current > > point, but that got really messy trying > > to make the array work- and I never did. > > > > I then wondered if I could find the 'true' center of the object > > whether the scaling would work better, but I couldn't figure out > > how to do it. > > > > The only other option I can think of is to draw the outline of the > > heart in hull'd cylinders with a radius of "pad", then subtracting > > the solid from the > > middle. After working out the math it was very clear that the > > computational power required was going to make it unworkable. > > > > I have now run out of ideas. > > > > Any help much apprecaited. > > Kind regards > > Nigel > > > > > > > > -- > > View this message in context: http://forum.openscad.org/ > > Adding-a-border-of-d-thickness-to-a-polygon-tp19283.html > > Sent from the OpenSCAD mailing list archive at Nabble.com. > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Nov 24, 2016 1:38 AM
Note that 2D minkowski is equivalent to 2D offset with a radius, but 2D offset should be considerably faster.
> On Nov 23, 2016, at 09:41, otto <otto@123phase.com> wrote: > > Another way to achieve this is with the 2-D minkowski which is > moderately efficient. Note that 2D minkowski is equivalent to 2D offset with a radius, but 2D offset should be considerably faster. -Marius
