O
otto
Thu, Nov 24, 2016 8:29 PM
On Nov 23, 2016, at 09:41, otto otto@123phase.com wrote:
Another way to achieve this is with the 2-D minkowski which is
moderately efficient.
Note that 2D minkowski is equivalent to 2D offset with a radius, but
2D offset should be considerably faster.
Testing the code shows no difference in speed. The test code is
below. Make sure to clear the cache! div should be a power of 2.
Incidentally, as div gets large both versions show they same failure
artifacts. I think that the offset module is simply a wrapper around
the minkowski. In this program they seem to behave
identically to the agree that they have the same identical timed speed
and with the same identical artifacts. Is there a known algorithm that
can calculate the offset faster than a minkowski algorithm or
that doesn't use the minkowski or some equivalent?
Regards
Otto
function heartRadius(t) = (1.5 - 1.5* sin(t) + (sin(t) *
(sqrt(abs(cos(t)))/(sin(t)+1.6))));
$fn=23;
div=512; //ONLY USE POWERS OF 2
module pHeart(xy,off=0) {
td = 1/div; // theta delta - the resolution of the curve
// Calculate x/y co-ords separetely so I can scale correctly later
xp = [ for (t = [0: td : 360-td]) heartRadius(t) * cos(t) ]; // xco-ordinates on the curve
yp = [ for (t = [0 : td : 360-td]) heartRadius(t) * sin(t) ]; // yco-ordinates on the curve
xsc = xy/(max(xp) - min(xp)); // x scaler to get to fit expected size
ysc = xy/(max(yp) - min(yp)); // y scaler to get to fit expected size
// Generate a vector of points for the polygon to work
p = [ for (i = [0 : 360/td-1]) [xsc*xp[i], ysc*yp[i]] ];
// translate polygon so it is centralised at +/- xy/2
translate([0,ysc*(-max(yp)+(max(yp)-min(yp))/2)])
//// UNCOMMENT LINE TO TEST
//// CLEAR THE CACHE FIRST
/////////////////////// MINKOWSKY
//if(off){minkowski(){polygon(p);circle(off);}}else polygon(p);
/////////////////////// OFFSET
//offset(r=off) polygon(p);
linear_extrude(5) pHeart(xy=78,off=2);
translate([0,0,-.5]) linear_extrude(6) pHeart(xy=78, off=.4);
On Wed, 23 Nov 2016 20:38:02 -0500
> -Marius
Regards
Otto
$fn=23;
Fri, Nov 25, 2016 10:53 AM
I might be wrong but I think OpenSCAD uses the clipper library for offset
and presumably CGAL for 2D Minkowski.
The artefacts from low div values come from the polygon generation, not the
offsetting, so it is no surprise they look identical. Provided clipper
obeys $fn they should produce the same results as they are mathematically
identical operations. There is no ambiguity where each vertex should be, so
any differences should only be down to the different number representations.
I am surprised there is little difference in speed but both are very fast
until you get to tens of thousands of vertices.
BTW rather than linear extruding twice and subtracting 3D shapes I think it
is more efficient to subtract the 2D shapes and extrude that.
linear_extrude(5, convexity = 2)
pHeart(xy = 78, off = 2);
pHeart(xy = 78, off = 0.4);
Regards
Otto
$fn=23;
size
size
> > -Marius
> Regards
> Otto
> $fn=23;
> size
> size
> difference()
Fri, Nov 25, 2016 3:07 PM
On Nov 25, 2016, at 05:53, nop head nop.head@gmail.com wrote:
I might be wrong but I think OpenSCAD uses the clipper library for offset and presumably CGAL for 2D Minkowski.
We use the clipper library for both offset and 2D minkowski. Perhaps they implement offset using minkowski internally?
Fri, Nov 25, 2016 3:30 PM
I didn't realise clipper did Minkowski. A quick look at the code reveals
they don't use Minkowski for offset. Minkowski is just the union of a
polygon shifted by each point in a path. Offset is a lot more complex.
> -Marius
O
otto
Fri, Nov 25, 2016 6:11 PM
not the offsetting, so it is no surprise they look identical.
Provided clipper obeys $fn they should produce the same results as
they are mathematically identical operations. There is no ambiguity
where each vertex should be, so any differences should only be down
fast until you get to tens of thousands of vertices.
think it is more efficient to subtract the 2D shapes and extrude that.
but 2D offset should be considerably faster.
around the minkowski. In this program they seem to behave
speed and with the same identical artifacts. Is there a known
algorithm that can calculate the offset faster than a minkowski
algorithm or that doesn't use the minkowski or some equivalent?
Regards
Otto
$fn=23;
correctly later xp = [ for (t = [0: td : 360-td]) heartRadius(t) *
expected size
expected size
I agree.
Otto
On Fri, 25 Nov 2016 10:53:27 +0000
> difference() {
> > > -Marius
> > Regards
> > Otto
> > $fn=23;
> > expected size
> > expected size
> > difference()
