Gene Heskett
Sat, Jul 24, 2021 5:54 PM
That var names within a module's {} are known only inside that module,
so its a different var within different module, even if the same name is
used in another, different module?
I would like to have all this thing fairly parametric in that changing
a "global var" before any modules are defined, changes the var for every
module that uses it, but with 3d printers having a mind of their own, I
find I need some fudge1, fudge2 etc vars defined inside a module, to
fine tune sizes for a good fit.
So is my first sentence above unconditionally true, or am I barking at
the moon?
Thanks all.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
the moon?
Thanks all.
- Louis D. Brandeis
Sat, Jul 24, 2021 6:14 PM
The only way a variable set in one module can be seen in another is if you
prefix it with $ and then it is visible in modules called by the module
that sets it.
Or you can have global variables seen in all modules in the same file by
defining them at file scope.
I 3D print all the time with no fudge factors. I simply have my 3D printers
set up accurately and only ever use one wall.
the moon?
Thanks all.
that sets it.
> the moon?
> Thanks all.
> - Louis D. Brandeis
FH
Father Horton
Sat, Jul 24, 2021 6:18 PM
Can child modules see variables in the parent's scope?
that sets it.
printers set up accurately and only ever use one wall.
the moon?
Thanks all.
> that sets it.
>> the moon?
>> Thanks all.
>> - Louis D. Brandeis
Sat, Jul 24, 2021 6:22 PM
Only if the variable name starts with a $.
you prefix it with $ and then it is visible in modules called by the module
that sets it.
the moon?
Thanks all.
>> that sets it.
>>> the moon?
>>> Thanks all.
>>> - Louis D. Brandeis
FH
Father Horton
Sat, Jul 24, 2021 7:51 PM
I thought I'd try it:
i = 1;
module test() {
i = 2;
module subtest() {
echo("subtest ", i);
echo("test ", i);
subtest();
test();
produces
ECHO: "test ", 2
ECHO: "subtest ", 2
I might have been using "child" in a different sense than you took it, but
the inner module does see the value in scope in its parent module.
that sets it.
is
every
the moon?
Thanks all.
respectable.
i = 1;
module test() {
i = 2;
module subtest() {
echo("test ", i);
subtest();
test();
produces
ECHO: "test ", 2
ECHO: "subtest ", 2
>>> that sets it.
>>>> is
>>>> every
>>>> the moon?
>>>> Thanks all.
>>>> respectable.
>>>> - Louis D. Brandeis
Sat, Jul 24, 2021 7:55 PM
Yes but that is a nested module, not a child invoked by children ().
i = 1;
module test() {
i = 2;
module subtest() {
echo("test ", i);
subtest();
test();
produces
ECHO: "test ", 2
ECHO: "subtest ", 2
that sets it.
by defining them at file scope.
is
every
I
the moon?
Thanks all.
respectable.
> i = 1;
> module test() {
> i = 2;
> module subtest() {
> echo("test ", i);
> subtest();
> test();
> produces
> ECHO: "test ", 2
> ECHO: "subtest ", 2
>>>> that sets it.
>>>>> is
>>>>> every
>>>>> I
>>>>> the moon?
>>>>> Thanks all.
>>>>> respectable.
>>>>> - Louis D. Brandeis
FH
Father Horton
Sat, Jul 24, 2021 8:25 PM
Like I thought, I was using the term "child" in a non-standard way. Thank
you for clarifying.
i = 1;
module test() {
i = 2;
module subtest() {
echo("test ", i);
subtest();
test();
produces
ECHO: "test ", 2
ECHO: "subtest ", 2
but the inner module does see the value in scope in its parent module.
that sets it.
is
changing
every
I
at
the moon?
Thanks all.
respectable.
you for clarifying.
>> i = 1;
>> module test() {
>> i = 2;
>> module subtest() {
>> echo("test ", i);
>> subtest();
>> test();
>> produces
>> ECHO: "test ", 2
>> ECHO: "subtest ", 2
>>>>> that sets it.
>>>>>> is
>>>>>> changing
>>>>>> every
>>>>>> I
>>>>>> at
>>>>>> the moon?
>>>>>> Thanks all.
>>>>>> respectable.
>>>>>> - Louis D. Brandeis
Sat, Jul 24, 2021 10:12 PM
Normal variables have lexical scope, which means they can be seen in the
current block and any nested block. $ variables have dynamic scope, which
means they can be seen in any module or function called from the current
block.
you for clarifying.
i = 1;
module test() {
i = 2;
module subtest() {
echo("test ", i);
subtest();
test();
produces
ECHO: "test ", 2
ECHO: "subtest ", 2
if you prefix it with $ and then it is visible in modules called by the
module that sets it.
module,
name is
changing
every
own, I
at
the moon?
Thanks all.
respectable.
block.
> you for clarifying.
>>> i = 1;
>>> module test() {
>>> i = 2;
>>> module subtest() {
>>> echo("test ", i);
>>> subtest();
>>> test();
>>> produces
>>> ECHO: "test ", 2
>>> ECHO: "subtest ", 2
>>>>>>> module,
>>>>>>> name is
>>>>>>> changing
>>>>>>> every
>>>>>>> own, I
>>>>>>> at
>>>>>>> the moon?
>>>>>>> Thanks all.
>>>>>>> respectable.
>>>>>>> - Louis D. Brandeis
Ray West
Sat, Jul 24, 2021 10:46 PM
Hi Gene,
There are a few things to think about. Forgetting the 3d printing side
of things, you can't fit a two inch diameter cylinder inside a two inch
diameter hole, say, no matter how you try, even if both are rounder than
a round thing. The hole has to be bigger, or the cylinder smaller, or
the hole a tiny bit bigger, and the cylinder a tiny bit smaller. As you
know, traditionally in most engineering hard materials, then the
differences are taken care of in the specified manufacturer's
tolerances. For woodwork and modern glues, it is not so fussy. I reckon
3d printing is somewhere between the two, at least for the largely
flexible plastics that are commonly used, and the relatively crude diy
3d printers. Couple with that, the way in which openscad, stl, and
whatever slicer and firmware tries to make a round hole (or cylinder),
as you have found, you will never, for example get a two inch diameter
print to fit into a two inch diameter hole, or anywhere near, using
metal fitting tolerances.
If you are talking about both pieces being something you are 3d
printing, then I would decide on the hole diameter, and use a fudge
factor to reduce that diameter for the cylinder. If the cylinder is a
bit too big, it is probably easier to reduce that, rather than
increasing the hole diameter. You will need different factors for
different sized holes, tightness of fit, materials etc. It will take
some iterations to get the right values for your fits. If you were
having, say a metal bearing to fit in a hole in the 3d printed plastic,
then I would use a fudge factor on the hole diameter, it's not so easy
to file down the bearing.
I would keep the fudge factors outside of the modules, possibly one for
each cylinder. I've put a bit of code below, to emphasize an inherent
source of a bad fit
diam1 = 2;
fudge1 = 1.01;
fudge2 = 1.02; //whatever
$fn=6; //obviously change this
module hole(d){
cube(10,true);
translate ([0,0,-20])cylinder(60,d=d);
module peg1(d,f1){
cylinder (50,d=d-f1);
hole(diam1);
peg1(diam1,fudge1);
translate ([20,20,0]) peg1(4,fudge2);
translate ([20,20,0]) hole(4);
the moon?
Thanks all.
Hi Gene,
source of a bad fit
diam1 = 2;
fudge1 = 1.01;
module hole(d){
cube(10,true);
module peg1(d,f1){
hole(diam1);
peg1(diam1,fudge1);
> the moon?
> Thanks all.
Gene Heskett
Sat, Jul 24, 2021 11:12 PM
the current block and any nested block. $ variables have dynamic
scope, which means they can be seen in any module or function called
from the current block.
Eggxactly as my testing seems to confirm. thank you all.
My 6th printer is a prusa MK3S kit and its calibration seems to put a
line at the center of the .4mm nozzle, meaning if something needs to fit
inside of another part, but parts need to adjusted by .2mm in order to
put them together. So thats the basis for using a .2 or -.2 fudge to
get good fittings.
get good fittings.
- Louis D. Brandeis
