G
Gadgetmind
Thu, Sep 14, 2017 3:45 PM
On 2017-09-14 16:13, nop head wrote:
Ha, you wouldn't believe the amount of opposition I got to adding
$preview and I was doing the change myself, not asking others to do it.
Wow, I hadn't spotted $preview and am using a far less elegant way to
disable debug during renders from my makefile. I'll get fixing my code!
Thu, Sep 14, 2017 4:10 PM
The inevitability of "ECHO:" has also annoyed me, since I started programming
with OpenSCAD. A "cheap" way to implement such a switch would be to add it
in "preferences".
in "preferences".
KM
Kuba Marek
Fri, Sep 15, 2017 6:03 AM
From my POV the best option would be to add a MoreSane(tm) solution
controlled by a commandline option, preferences or a runtime call,
then after a year or two switch it to default and deprecate "ECHO:" and
after another year or two remove "ECHO:" completely.
The new solution could be echos going to stdout without any
additional text and everything else to stderr.
On 9/14/2017 4:28 AM, Troberg wrote:
I think it is far too late to change now as people like me have
scripts built around it for making BOMs for many years.
I can see that problem, it's not fun going back and rebuild old
scripts...
Not that it wouldn't be a nuisance, but the straightforward thing to
do would be to change the .scad files to emit the "ECHO:" so that the
post-processing scripts wouldn't need to change.
> > scripts...
ST
Shaporev, Timur
Fri, Sep 15, 2017 7:17 AM
scripts...
Sigh.
Why stick on "echo"?
Why not add new primitive name like print, show, type...
No real need to change existing behaviour.
________________________________
From: Discuss <discuss-bounces@lists.openscad.org> on behalf of Kuba Marek <blue.cube@seznam.cz>
Sent: 15 September 2017 09:03:05
Subject: Re: [OpenSCAD] Why does echo print the entire line?
> > scripts...
Jerry Davis
Fri, Sep 15, 2017 11:57 AM
I like Tim's suggestion. In fact, why not a up the stakes to a modified
printf kind of behavior?
That way scripts who have been based on the old ECHO behavior don't break,
but new way of printing output is added for those who want something
different.
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
On Fri, Sep 15, 2017 at 12:17 AM, Shaporev, Timur tim@auriga.com wrote:
Sigh.
From: Discuss discuss-bounces@lists.openscad.org on behalf of Kuba
Marek blue.cube@seznam.cz
scripts...
different.
*The most exciting phrase to hear in science - the one that heralds new
discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov
On Fri, Sep 15, 2017 at 12:17 AM, Shaporev, Timur <tim@auriga.com> wrote:
> Sigh.
> *From:* Discuss <discuss-bounces@lists.openscad.org> on behalf of Kuba
> *Sent:* 15 September 2017 09:03:05
> *To:* discuss@lists.openscad.org
> *Subject:* Re: [OpenSCAD] Why does echo print the entire line?
> > > scripts...
MC
Mr C Camacho
Fri, Sep 15, 2017 12:26 PM
I like that idea I once coded an opengl version of printf and using
stdarg.h to access va_lists
(variable number of parameters...) its super easy....
modified printf kind of behavior?
break, but new way of printing output is added for those who want
something different.
/The most exciting phrase to hear in science - the one that heralds
new discoveries - is not "Eureka!" but "That's funny...".
/- Isaac. Asimov
mailto:tim@auriga.com> wrote:
Sigh.
<mailto:discuss-bounces@lists.openscad.org>> on behalf of Kuba
Marek <blue.cube@seznam.cz <mailto:blue.cube@seznam.cz>>
*To:* discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>
"ECHO:" and
scripts...
> /- Isaac. Asimov
> <mailto:tim@auriga.com>> wrote:
> Sigh.
> "ECHO:" and
> > > scripts...
> that the
> <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org>
memsfactory
Fri, Sep 15, 2017 9:57 PM
Great ideas....but please make it so that we can write output to a file.
Here is an example of a recent issue. I coded up a special design with 100K+
of objects (yes, really!) and I output them to dxf for import into a chip
design software. However, the chip design crashes so now I need a way for
the same openscad code to output all the object coordinates in a data file,
but I can't. A printf to file would be great!!!!
Fri, Sep 15, 2017 10:12 PM
For at least 2015.03-2+, specifying the extension .echo causes openscad to
produce a text file containing error messages and the output of all echo()
calls in filename as they would appear in the console window visible in
the GUI. Multiple output files are not supported, so using this option you
cannot also obtain the model that would have normally been generated.
It would be a good next step to support .echo in addition to normal
output...
Wiki
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment#Export_options>
output...
G
Gadgetmind
Sat, Sep 16, 2017 7:38 AM
output...
Hmmm, thanks, this is actually useful to me now and I hadn't spotted it.
I must read the docs from start to end!
I have an aeroplane fuselage held as a multi D vector and need to
"probe" this to get locations and angles of all of the windows. Doing
this at "run time" every time would be slow, so running it as a separate
pass only when this geometry changes, outputting the data from probing
to a file with .echo, cleaning it up with some Python, and then
importing the resulting structure/data for when I need to create the
windows, makes a lot of sense.
I'd still be minded to abuse echo() with extra variables (special, not,
dunno) to set verbosity and maybe even output file (keep a list of ones
already opened, close them at the end, etc.) but maybe that's my
assembly hacked roots!
> output...
I *must* read the docs from start to end!
Jerry Davis
Sat, Sep 16, 2017 12:07 PM
as for going to a file, I don't believe that is necessary.
I do this for some of my scripts:
example:
centerpiece4_build.sh > out.txt 2>&1
the output (all of it) goes to out.txt and you can do with it what you want.
output...
Hmmm, thanks, this is actually useful to me now and I hadn't spotted it. I
I have an aeroplane fuselage held as a multi D vector and need to "probe"
this to get locations and angles of all of the windows. Doing this at "run
time" every time would be slow, so running it as a separate pass only when
this geometry changes, outputting the data from probing to a file with
.echo, cleaning it up with some Python, and then importing the resulting
structure/data for when I need to create the windows, makes a lot of sense.
already opened, close them at the end, etc.) but maybe that's my assembly
hacked roots!
example:
>> output...
> hacked roots!
