aha...thank you.
Wiki
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment#Export_options>
For at least 2015.03-2+, specifying the extension .echo causes openscad to
produce a text file containing error messages and the output of all echo()
calls in filename as they would appear in the console window visible in
the GUI. Multiple output files are not supported, so using this option you
cannot also obtain the model that would have normally been generated.
aha...thank you.
Wiki
