I want to put some text, automatically wrapped within a bounding box.
Something like a module with a signature somewhat like this:
module textbox(text, font, textsize, xsize,ysize)
What I'm missing is any way to know the dimensions of a string.
I can't see a way to do this, but sometimes I'm stupid and missing something
obvious, so I'll throw the question out here.
Short answer, No.
Long answer has lots of font tech reasons.
Possibly for 2035 climate compliant version...
You can't do that in OpenSCAD. In general you can't query the model for
information such as dimensions.
It is possible in other systems
https://gist.github.com/arnholm/23c482530fd1882c615f5e6e3c9eedca
I don't think this is doing what was asked for ("automatically
wrapped within a bounding box").
Everyone is free to think what they want, but that's what
boundingbox@ b = txt2d.box();
does.
does.
Automatically wrapped means, the size of the box is given
and the text will automatically break the text to fit that
box from a single line string.
Basically doing a layout with a flexible number of lines
depending of the width of the defined box.
You say that's what that code line is doing?
I knew I saw it somewhere, and I finally found it. Unfortunately, I have not
been able to get it to work from either the Thingiverse link or the github
link, each for a different reason.
Perhaps soemone more knowledgeable than I can figure out the errors.
https://www.thingiverse.com/thing:3004457
https://github.com/arpruss/miscellaneous-scad
There is no demo in the github repository.
Nice. The example from Thingiverse works fine. You
need both the fontmetrics.scad and fontmetricsdata.scad
files.
With that:
use <fontmetrics.scad>
text="Lorem ipsum dolor sit amet, quibusdam integer ut condimentum id interdum, in convallis varius nibh consectetuer ut, sed mauris in ut
vel, phasellus non eu tortor quis ante. Nisl lobortis donec, blandit enim pulvinar a wisi suscipit ut, volutpat magna ad ornare metus orci,
id tempor dapibus sit sed ultricies. Magna nibh libero, viverra suspendisse auctor. Egestas magna nullam pulvinar consequat, a enim eu
ornare quis, lacus quis dui id quisque eros. Vitae dignissim dolor sociis, fusce elit a sit, eget posuere sit neque, vivamus enim luctus
etiam et, vitae pellentesque. Sed proin mauris consectetuer tempor auctor, et malesuada magna a torquent non et, mi arcu vitae ligula.";
drawWrappedText(text, font = "Liberation Sans", size = 10, spacing = 1, linespacing = 1, indent = 0, width = 250, halign = "left");
does exactly what it says, it wraps by word at the given
width.
files.
Ahh... I just checked, and I had downloaded it in July 1018, so it was
obviously out of date.
It failed with a 'variable size not specified as parameter'
There is a lot of interesting looking stuff on the github repository.
for information such as dimensions.
This is kind of a special case. Although you can't ask anything about
the results of the text() operator, you could have a function that did
the same underlying font processing and gave you text metric
information without ever getting to the geometry processing.
Just like you can't get the bounding box of a polygon, but you can get
the bounding box of the array of points that you feed to polygon().
Not that you can do it today, but it's not the same as the general
problem of querying geometry.
Michael says it's hard to do internally. I don't know anything about Qt
so I don't know.
