Fri, Feb 24, 2023 1:28 PM
I have a requirement to develop a casting mould for a part e.g. wheel.
All the surfaces which are visible from top needs to be extracted to get
one half of the mould.
Similarly surfaces which are visible from bottom needs to be extracted to
develop other side of the mould.
Parting lines can be zigzag depending on the part geometry.
Any ideas to do such a thing in openscad will be really helpful
Regards
Sanjeev
Regards
Sanjeev
GS
Guenther Sohler
Fri, Feb 24, 2023 1:44 PM
hi Sanjeev,
I know exactly what you mean, I also do green-sand-casting and demolding it
the key for successful metal casting.
I spent over 6 month on writing software to find the best split of a given
bust stl file programmatically. the tool is called "stltool"
Right now developing the tool is on hold as I need some time for more
inspiration.
Examples of successful splits are here:
https://twitter.com/gadget_3d/status/1581385519308890112/photo/1
was also able to split "batman" mold successfully, but by far not all bust
are splittable for molding.
when splitting your weel, which is very symmetrical, isn't it possible to
split the face at the symmetry line using "difference" or "intersection" ?
when you very easily split your triangles into two bins when watching if
the z coordinate of the normal vector is pointing up or down.
For my tool i spent
25% of the time on finding the best cut line around the model
75% of the time to filling the big hole in the model which arises when
splitting the model into 2 halves ....
On Fri, Feb 24, 2023 at 2:29 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
Regards
Sanjeev
hi Sanjeev,
*the* key for successful metal casting.
inspiration.
For my tool i spent
On Fri, Feb 24, 2023 at 2:29 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> Regards
> Sanjeev
Fri, Feb 24, 2023 2:05 PM
Hi Guenther
Your picture of the split looks interesting.
Can you give some more information on the workflow and the logic.
In case it is possible to share the stltool developed by you, would be
great, although i have very limited understanding of softwares.
I started working on openscad as it initially looked simpler to work on.
Then learnt a little bit of python to circumvent the limitations of
openscad language.
Now it seems I need to learn another one. Not sure if I will do that as it
is taking a lot of my time.
Anyway, I am not using it for any professional purposes and is a hobby.
On Fri, 24 Feb, 2023, 7:15 pm Guenther Sohler, guenther.sohler@gmail.com
hi Sanjeev,
it the key for successful metal casting.
inspiration.
For my tool i spent
Regards
Sanjeev
Hi Guenther
openscad language.
On Fri, 24 Feb, 2023, 7:15 pm Guenther Sohler, <guenther.sohler@gmail.com>
> hi Sanjeev,
> it *the* key for successful metal casting.
> inspiration.
> For my tool i spent
>> Regards
>> Sanjeev
GS
Guenther Sohler
Fri, Feb 24, 2023 2:23 PM
Hi Sanjeev,
stltool is coded in C and its a requirement to achieve the speed
stltool - moldsplit main task is to split a model around the biggest
lateral extent(this is where faces-up meet faces-down)
A) Find starting point
this is easy: find the lateral point, which has biggest lateral distance
from the center
B) find cutline around model
from the starting point build a tree, only valid directions are edges
where edge-up meet edge-down
finally hoping you can surround the model in CCW direction and hopefully
hit the start point again
C) find out which triangles are "above" and "below" the cutline. this is
not necessarily the triangles with the normvector show up and down
D) duplicate all points at the culine and use them for bottom and upper
half respectively
E) finally move the objects apart by simply raising z coordinate of upper
half
F) now fill the big hole which arises when pulling the halves apart
- simple polygon fill is not possible as the polygon might be concave
- polygon tesselation is not possible because the points are in 3d, not 2d
- finally i came up which an algoithm which offsets the polygon with
negative values iteratively.
at some point two corners melt into one. this is exaclty the required
"helper point" to use to tesselate the polygon in a concave - friendly way.
(actually i believe this algorithm is very similar to openscad "roof"
function.
Hope you got an idea, how the algorithm works, but i doubt you will make it
in python...
cheers
On Fri, Feb 24, 2023 at 3:07 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
Hi Guenther
openscad language.
hi Sanjeev,
given bust stl file programmatically. the tool is called "stltool"
inspiration.
bust are splittable for molding.
For my tool i spent
to develop other side of the mould.
Regards
Sanjeev
Hi Sanjeev,
from the center
half respectively
half
* simple polygon fill is not possible as the polygon might be concave
* polygon tesselation is not possible because the points are in 3d, not 2d
* finally i came up which an algoithm which offsets the polygon with
function.
in python...
cheers
On Fri, Feb 24, 2023 at 3:07 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> Hi Guenther
> openscad language.
> wrote:
>> hi Sanjeev,
>> inspiration.
>> For my tool i spent
>>> Regards
>>> Sanjeev
Fri, Feb 24, 2023 2:53 PM
These are good tips to find way out.
I will try this in my free time.
Thanks for suggestions
On Fri, 24 Feb, 2023, 7:54 pm Guenther Sohler, guenther.sohler@gmail.com
Hi Sanjeev,
from the center
half respectively
half
function.
it in python...
cheers
Hi Guenther
openscad language.
it is taking a lot of my time.
hi Sanjeev,
inspiration.
to split the face at the symmetry line using "difference" or "intersection"
For my tool i spent
get one half of the mould.
Regards
Sanjeev
On Fri, 24 Feb, 2023, 7:54 pm Guenther Sohler, <guenther.sohler@gmail.com>
> Hi Sanjeev,
> from the center
> half respectively
> half
> function.
> it in python...
> cheers
>> Hi Guenther
>> openscad language.
>> wrote:
>>> hi Sanjeev,
>>> inspiration.
>>> For my tool i spent
>>>> Regards
>>>> Sanjeev
DH
Daniel Harvey
Fri, Feb 24, 2023 3:07 PM
I haven't played with this problem myself, but is there a reason to not
have the algorithm decide a flat cut plane, and then find the triangles in
the stl that intersect this plane, and then cut these triangles into new
ones that are placed in the appropriate half? The intersection with a
triangular face in the model seems like it can only have three forms:
- coincident with a side, which is sort of like a non-intersection
(triangle goes in one half)
- coincident with a corner, which then creates two triangles (one to each
half)
- the else... will produce a triangle to go into one half, and a
trapezoid... the trapezoid can be broken into two (or more) co-planar
triangles.
Or just have the program suggest the best cut plane and let openscad handle
things using difference or intersection appropriately...?
In the case of the wheel, I'm not sure I understand why this is a challenge
(intersection with a cube where one face is the center line) - can you
explain?
On Fri, Feb 24, 2023 at 7:53 AM Sanjeev Prabhakar sprabhakar2006@gmail.com
Hi Sanjeev,
distance from the center
half respectively
half
2d
function.
it in python...
cheers
Hi Guenther
openscad language.
guenther.sohler@gmail.com> wrote:
hi Sanjeev,
demolding it the key for successful metal casting.
inspiration.
if the z coordinate of the normal vector is pointing up or down.
For my tool i spent
Regards
Sanjeev
1) coincident with a side, which is sort of like a non-intersection
2) coincident with a corner, which then creates two triangles (one to each
half)
3) the else... will produce a triangle to go into one half, and a
triangles.
explain?
On Fri, Feb 24, 2023 at 7:53 AM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> wrote:
>> Hi Sanjeev,
>> half respectively
>> half
>> 2d
>> function.
>> it in python...
>> cheers
>>> Hi Guenther
>>> openscad language.
>>>> hi Sanjeev,
>>>> demolding it *the* key for successful metal casting.
>>>> inspiration.
>>>> For my tool i spent
>>>>> Regards
>>>>> Sanjeev
Fri, Feb 24, 2023 3:20 PM
you have spokes also which are not perfectly in center and the difference
doesn't work, due to the profile of the spokes.
Also if we need to work on this, it should be a generic solution as far as
possible which can be used elsewhere.
half)
triangles.
handle things using difference or intersection appropriately...?
challenge (intersection with a cube where one face is the center line) -
can you explain?
Hi Sanjeev,
hopefully hit the start point again
half respectively
upper half
2d
function.
it in python...
cheers
Hi Guenther
openscad language.
hi Sanjeev,
inspiration.
For my tool i spent
extracted to develop other side of the mould.
Regards
Sanjeev
> half)
> triangles.
> can you explain?
>> wrote:
>>> Hi Sanjeev,
>>> half respectively
>>> upper half
>>> 2d
>>> function.
>>> it in python...
>>> cheers
>>>> Hi Guenther
>>>> openscad language.
>>>>> hi Sanjeev,
>>>>> inspiration.
>>>>> For my tool i spent
>>>>>> Regards
>>>>>> Sanjeev
GS
Guenther Sohler
Hi Daniel,
In ideal case, a model like a wheel, is actually symmetrical around a flat
XY plane with 0 elevation at a certain z coordinate and fulfilling sanjeevs
task is just to
difference and to intersect with a big cube.
Unfortunately many models are not as easy as that. they have the point of
maximum lateral extent in differenz z heights.
If you still split such a model with a flat XY cut face, you could end up
in an upper mold which has faces which point downwards.
Did you browse youtube videos on green sand casting ? its very interesting.
if you do, you might get an idea why I came up with such a complicated
picture cut like in my first post.
half)
triangles.
can you explain?
Hi Sanjeev,
half respectively
upper half
2d
function.
it in python...
cheers
Hi Guenther
openscad language.
hi Sanjeev,
inspiration.
For my tool i spent
Regards
Sanjeev
Hi Daniel,
task is just to
> half)
> triangles.
> can you explain?
>> wrote:
>>> Hi Sanjeev,
>>> half respectively
>>> upper half
>>> 2d
>>> function.
>>> it in python...
>>> cheers
>>>> Hi Guenther
>>>> openscad language.
>>>>> hi Sanjeev,
>>>>> inspiration.
>>>>> For my tool i spent
>>>>>> Regards
>>>>>> Sanjeev
DH
Daniel Harvey
Fri, Feb 24, 2023 3:47 PM
Hi Guenther,
In everything I have seen, an inprint is made in each of two halves, and
the halves are assembled together (with imprinting objects removed) and the
resulting mold is filled with a liquid that sets. But in all these cases
the two halves basically have a flat intersection face. In the example of
your Gollum bust, how are the two halves with the non-flat faces turned
into a mold? Also it seems like there would be many objects that could not
be handled at all - objects where there is no cutline that doesn't create a
situation with an upward pointing face that is shadowed by a downward
pointing one.
On Fri, Feb 24, 2023 at 8:22 AM Guenther Sohler guenther.sohler@gmail.com
Hi Daniel,
task is just to
interesting. if you do, you might get an idea why I came up with such a
complicated picture cut like in my first post.
each half)
triangles.
can you explain?
Hi Sanjeev,
is not necessarily the triangles with the normvector show up and down
half respectively
upper half
not 2d
required "helper point" to use to tesselate the polygon in a concave -
friendly way.
"roof" function.
make it in python...
cheers
Hi Guenther
on.
openscad language.
as it is taking a lot of my time.
hi Sanjeev,
inspiration.
possible to split the face at the symmetry line using "difference" or
"intersection" ?
For my tool i spent
when splitting the model into 2 halves ....
wheel.
Regards
Sanjeev
Hi Guenther,
pointing one.
On Fri, Feb 24, 2023 at 8:22 AM Guenther Sohler <guenther.sohler@gmail.com>
> Hi Daniel,
> task is just to
>> each half)
>> triangles.
>> can you explain?
>>>> Hi Sanjeev,
>>>> half respectively
>>>> upper half
>>>> not 2d
>>>> friendly way.
>>>> "roof" function.
>>>> cheers
>>>>> Hi Guenther
>>>>> on.
>>>>> openscad language.
>>>>>> hi Sanjeev,
>>>>>> inspiration.
>>>>>> "intersection" ?
>>>>>> For my tool i spent
>>>>>>> wheel.
>>>>>>> Regards
>>>>>>> Sanjeev
GS
Guenther Sohler
Fri, Feb 24, 2023 4:06 PM
Hi Daniel,
Maybe you have only seen mold halves with a flat cutline, because
the models werd specially designed to have a flat cutline ?
(or nobody has managed to split models with a non-planar cutline ? )
But you are right.
Cutting an object into 2 halves can be a challenge. Finding out that the
gollum bust has an issue to demold i only found out after I managed to
retrieve the cutline.
(between the ears and the neck)
Also I doubt that the gollum bust can be demolded with a flat cutline.
Generally I believe it's quite hard to find busts on Thingiverse which can
easily be split for demolding.
But I was successfully able to split batman.
https://cults3d.com/en/3d-model/art/batman-bust-ready-for-sandcast-molding
When you look at the splitted parts separated, you might understand, why a
flat cutline would not work out
Just for interest, do you have some experience with sand casting ?
On Fri, Feb 24, 2023 at 4:48 PM Daniel Harvey dwaharvey@gmail.com wrote:
Hi Guenther,
pointing one.
Hi Daniel,
flat XY plane with 0 elevation at a certain z coordinate and fulfilling
sanjeevs task is just to
each half)
triangles.
can you explain?
Hi Sanjeev,
edges where edge-up meet edge-down
upper half respectively
upper half
not 2d
friendly way.
"roof" function.
cheers
Hi Guenther
be great, although i have very limited understanding of softwares.
on.
openscad language.
hobby.
hi Sanjeev,
more inspiration.
all bust are splittable for molding.
"intersection" ?
watching if the z coordinate of the normal vector is pointing up or down.
For my tool i spent
wheel.
to get one half of the mould.
Regards
Sanjeev
Hi Daniel,
But you are right.
On Fri, Feb 24, 2023 at 4:48 PM Daniel Harvey <dwaharvey@gmail.com> wrote:
> Hi Guenther,
> pointing one.
> wrote:
>> Hi Daniel,
>>> each half)
>>> triangles.
>>> can you explain?
>>>>> Hi Sanjeev,
>>>>> upper half
>>>>> not 2d
>>>>> friendly way.
>>>>> "roof" function.
>>>>> cheers
>>>>>> Hi Guenther
>>>>>> on.
>>>>>> openscad language.
>>>>>> hobby.
>>>>>>> hi Sanjeev,
>>>>>>> more inspiration.
>>>>>>> "intersection" ?
>>>>>>> For my tool i spent
>>>>>>>> wheel.
>>>>>>>> Regards
>>>>>>>> Sanjeev
