jpmendes
Thu, Sep 10, 2015 11:26 PM
To the OpenSCAD developers.
First of all thanks for your amazing work.
In the past August I started modelling a real delta 3d printer, that I
intend to publish for the community, based on an new idea I had some time
ago. It has been a pain in the ... not because of OpenSCAD of course, debut
because although a have a 6 core processor I do not have a 3D oriented
graphics board. I'm a poor guy... So for the poor guys of this world please
try to help.
My suggestions are:
1 - The scintilla editor should remember on startup the modules, functions,
and instances that were collapsed in the previous session.
2 - Please add a command line to adjust the viewpoint. The lag between the
action of the mouse and the display update drives me crazy.
3 - Automatic backup every time we press «F5» in order to be possible to
kill the process if we are caught in a loop or extreme delay and not loose
the work, recovering the work from the backup.
4 - Better than suggestion 3, would be to have a button to stop CSG tree
compilation like the one for CGAL compilation.
5 - Even better than 4 would be the editor to be independent of the
compilation processes. The CSG tree compilation could be done over an
automatically generated backup copy of the actual file with a process
running in background. If «F5» pressed again the background running process
would be aborted a a new one started. Now I think I'm asking for too much
Any help to speed up things to the poor guys of this world is welcome.
Thanks.
View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760.html
try to help.
My suggestions are:
Thanks.
MS
Mark Schafer
Thu, Sep 10, 2015 11:47 PM
re 3.
FWIW - I get an automatic F5 when I save.
So instead of doing an F5 I do a ctrl-S.
This way my file is always up to date (of course you have to manage
versions on disk).
try to help.
My suggestions are:
Thanks.
Checked by AVG - www.avg.com
Version: 2015.0.6125 / Virus Database: 4419/10615 - Release Date: 09/10/15
re 3.
versions on disk).
> try to help.
> My suggestions are:
> Thanks.
> No virus found in this message.
jpmendes
Fri, Sep 11, 2015 12:17 AM
Thanks, its better than nothing. I will try it although my «F5» is already
instinctive.
Regards.
View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13763.html
instinctive.
Regards.
DB
don bright
Fri, Sep 11, 2015 3:36 AM
Just curious... what kind of graphics do you have? Can you go to
help/library-info and paste it on pastebin or somewhere? How big is your
scad file (thousands of lines?).
don bright
hmbright@fastmail.fm
debut
please
try to help.
My suggestions are:
functions,
loose
process
Thanks.
don bright
> debut
> please
> try to help.
> My suggestions are:
> functions,
> the
> loose
> process
> Thanks.
CL
Chow Loong Jin
Fri, Sep 11, 2015 10:45 AM
try to help.
A powerful CPU (number of cores doesn't matter because CGAL is single-threaded)
goes further than a powerful graphics card for doing OpenSCAD stuff, actually.
I'm on a Core i7 Ivy Bridge machine with integrated graphics and 16GB of RAM.
My suggestions are:
I use emacs as my external editor and OpenSCAD as merely a viewer. If the F5
frame-rate is too slow, I do F6 instead, which gives me a much better view. If
all else fails, I export it to an stl using the command line (I have Makefiles
for my scad projects, so I can just use my editor's compile function for this)
and use Meshlab to view the part.
I really recommend using an external editor because at least for me, OpenSCAD
hangs while rendering complex objects, and it really drives me nuts to not be
able to do anything while waiting for the render.
TL;DR: An external editor goes a long way to retaining your sanity while using
OpenSCAD.
Kind regards,
Loong Jin
> try to help.
> My suggestions are:
OpenSCAD.
Kind regards,
Loong Jin
Fri, Sep 11, 2015 11:36 AM
If the F5 frame rate gets too low I add render() to the top level objects
to get the speed back. The first F5 takes longer but after that it is
faster as it simply uses the cached CGAL mesh.
single-threaded)
actually.
RAM.
My suggestions are:
F5
view. If
Makefiles
this)
OpenSCAD
be
> debut
> please
> > try to help.
> single-threaded)
> actually.
> RAM.
> > My suggestions are:
> functions,
> the
> loose
> F5
> view. If
> Makefiles
> this)
> OpenSCAD
> be
> process
> using
> OpenSCAD.
> Kind regards,
> Loong Jin
jpmendes
Fri, Sep 11, 2015 3:16 PM
Thank you all for the suggestions.
I have an ASUS motherboard M5A78L-M/USB3 with embedded graphics ATI Radeon
HD3000 and 8 GB of RAM. The ram allocated to the graphics is the maximum
that the bios allows, 1 GB.
Code now is 1.2k lines with 60 modules.
Regards.
View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13770.html
Regards.
MC
Matthew Caron
Fri, Sep 11, 2015 4:16 PM
Some thoughts:
- What 6 core CPU do you have which doesn't have an integrated GPU? If
it does, and you are not using it, it may be better than the video board
you have.
- I use an external editor and tell OpenSCAD to watch a file. Every
time I save the file, it reloads the model. Then you can use whatever
editor you like.
try to help.
My suggestions are:
Thanks.
"When a self-governing people confer upon their government the power
to take money from some and give it to others, the process will not
stop until the last bone of the last taxpayer is picked bare."
-- Howard E. Kershner (Kershner's First Law)
PGP Key: http://www.mattcaron.net/pgp_key.txt
~~ Matt Caron ~~
Some thoughts:
1. What 6 core CPU do you have which doesn't have an integrated GPU? If
you have.
2. I use an external editor and tell OpenSCAD to watch a file. Every
editor you like.
> try to help.
> My suggestions are:
> Thanks.
~~ Matt Caron ~~
jpmendes
Fri, Sep 11, 2015 5:18 PM
Hi, the biggest problem with my preferred editor Notepad++ (I'm using
windows) is that it do not recognize the opening and closing of curly braces
correctly and do not collapse the entities correctly also. Even with
OpenSCAD extension, that I found on Thingiverse, enabled it doesn't work
well.
View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13773.html
well.
DB
don bright
Fri, Sep 11, 2015 11:23 PM
is your scad file publicly available? it could help with testing...
don bright
don bright
> Radeon
> Regards.
