To the OpenSCAD developers. Please help the poor guys.
MC
Matthew Caron
Sat, Sep 12, 2015 12:18 AM
Emacs runs under Windows. :-)
On 09/11/2015 01:18 PM, jpmendes wrote:
Hi, the biggest problem with my preferred editor Notepad++ (I'm using
windows) is that it do not recognize the opening and closing of curly braces
correctly and do not collapse the entities correctly also. Even with
OpenSCAD extension, that I found on Thingiverse, enabled it doesn't work
well.
View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13773.html
"When a self-governing people confer upon their government the power
to take money from some and give it to others, the process will not
stop until the last bone of the last taxpayer is picked bare."
-- Howard E. Kershner (Kershner's First Law)
PGP Key: http://www.mattcaron.net/pgp_key.txt
~~ Matt Caron ~~
Emacs runs under Windows. :-) On 09/11/2015 01:18 PM, jpmendes wrote: > Hi, the biggest problem with my preferred editor Notepad++ (I'm using > windows) is that it do not recognize the opening and closing of curly braces > correctly and do not collapse the entities correctly also. Even with > OpenSCAD extension, that I found on Thingiverse, enabled it doesn't work > well. > > > > > -- > View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13773.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- "When a self-governing people confer upon their government the power to take money from some and give it to others, the process will not stop until the last bone of the last taxpayer is picked bare." -- Howard E. Kershner (Kershner's First Law) PGP Key: http://www.mattcaron.net/pgp_key.txt ~~ Matt Caron ~~
GW
G. Wade Johnson
Sat, Sep 12, 2015 1:03 PM
On Fri, 11 Sep 2015 20:18:42 -0400
So does vim/gvim.<grin/>
using windows) is that it do not recognize the opening and closing
of curly braces correctly and do not collapse the entities
correctly also. Even with OpenSCAD extension, that I found on
Thingiverse, enabled it doesn't work well.
They made a very satisfying thump when they hit the floor.
-- G'Kar - "A Late Delivery from Avalon"
On Fri, 11 Sep 2015 20:18:42 -0400 Matthew Caron <matt@mattcaron.net> wrote: > Emacs runs under Windows. :-) So does vim/gvim.<grin/> > On 09/11/2015 01:18 PM, jpmendes wrote: > > Hi, the biggest problem with my preferred editor Notepad++ (I'm > > using windows) is that it do not recognize the opening and closing > > of curly braces correctly and do not collapse the entities > > correctly also. Even with OpenSCAD extension, that I found on > > Thingiverse, enabled it doesn't work well. > > > > > > > > > > -- > > View this message in context: > > http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13773.html > > Sent from the OpenSCAD mailing list archive at Nabble.com. > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > -- They made a very satisfying thump when they hit the floor. -- G'Kar - "A Late Delivery from Avalon"
jpmendes
Sat, Sep 12, 2015 4:31 PM
I will publish my files only after building the first prototype and it
proves well. Maybe within 1 to 2 months. I do not want to do a release that
is a failure.
Thanks anyway.
Regards.
View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13787.html
Hi, I will publish my files only after building the first prototype and it proves well. Maybe within 1 to 2 months. I do not want to do a release that is a failure. Thanks anyway. Regards. -- View this message in context: http://forum.openscad.org/To-the-OpenSCAD-developers-Please-help-the-poor-guys-tp13760p13787.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Sep 13, 2015 1:05 PM
On 09/11/2015 01:26 AM, jpmendes wrote:
2 - Please add a command line to adjust the viewpoint. The lag between the
action of the mouse and the display update drives me crazy.
The (not yet finished) work on 3D mouse support also made it possible to
support also other ways of controlling the viewport. I've added a simple
DBus interface too which allows remote control. This will be only available
for Linux though. I have no idea if there are sensible options for the
other platforms.
3 - Automatic backup every time we press «F5» in order to be possible to
kill the process if we are caught in a loop or extreme delay and not loose
the work, recovering the work from the backup.
This is already there. Every time you compile a modified file, a backup
is made and that's mentioned as first line in the console window.
(e.g. "Saved backup file: /home/.local/share/OpenSCAD/backups/unsaved-backup-MTJ13858.scad")
Any help to speed up things to the poor guys of this world is welcome.
The biggest improvements can usually be obtained by changing the code
to work around complexity issues for both graphics rendering (F5) and
mesh generation (F6).
Of cause it would be ideal if that would not be needed, but even with
all potential improvements to OpenSCAD, I suspect for very complex models
that will alway be the case.
On 09/11/2015 01:26 AM, jpmendes wrote: > 2 - Please add a command line to adjust the viewpoint. The lag between the > action of the mouse and the display update drives me crazy. > The (not yet finished) work on 3D mouse support also made it possible to support also other ways of controlling the viewport. I've added a simple DBus interface too which allows remote control. This will be only available for Linux though. I have no idea if there are sensible options for the other platforms. > 3 - Automatic backup every time we press «F5» in order to be possible to > kill the process if we are caught in a loop or extreme delay and not loose > the work, recovering the work from the backup. > This is already there. Every time you compile a modified file, a backup is made and that's mentioned as first line in the console window. (e.g. "Saved backup file: /home/.local/share/OpenSCAD/backups/unsaved-backup-MTJ13858.scad") > Any help to speed up things to the poor guys of this world is welcome. > The biggest improvements can usually be obtained by changing the code to work around complexity issues for both graphics rendering (F5) and mesh generation (F6). Of cause it would be ideal if that would not be needed, but even with all potential improvements to OpenSCAD, I suspect for very complex models that will alway be the case. ciao, Torsten.
LT
Len Trigg
Sun, Sep 13, 2015 7:21 PM
Awesome! Can you add F6 render and save to STL  to the DBus interface too?
Cheers,
Len
other platforms.
loose
Awesome! Can you add F6 render and save to STL to the DBus interface too? Cheers, Len On 14 Sep 2015 1:05 am, "Torsten Paul" <Torsten.Paul@gmx.de> wrote: > On 09/11/2015 01:26 AM, jpmendes wrote: > > 2 - Please add a command line to adjust the viewpoint. The lag between > the > > action of the mouse and the display update drives me crazy. > > > The (not yet finished) work on 3D mouse support also made it possible to > support also other ways of controlling the viewport. I've added a simple > DBus interface too which allows remote control. This will be only available > for Linux though. I have no idea if there are sensible options for the > other platforms. > > > 3 - Automatic backup every time we press «F5» in order to be possible to > > kill the process if we are caught in a loop or extreme delay and not > loose > > the work, recovering the work from the backup. > > > This is already there. Every time you compile a modified file, a backup > is made and that's mentioned as first line in the console window. > (e.g. "Saved backup file: > /home/.local/share/OpenSCAD/backups/unsaved-backup-MTJ13858.scad") > > > Any help to speed up things to the poor guys of this world is welcome. > > > The biggest improvements can usually be obtained by changing the code > to work around complexity issues for both graphics rendering (F5) and > mesh generation (F6). > Of cause it would be ideal if that would not be needed, but even with > all potential improvements to OpenSCAD, I suspect for very complex models > that will alway be the case. > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Sep 13, 2015 8:02 PM
Yes, actually any menu/toolbar action is available too as the button
input events are mapped to existing UI actions. The question is how
to add parameters (e.g. for the export actions).
On 09/13/2015 09:21 PM, Len Trigg wrote: > Awesome! Can you add F6 render and save to STL to the DBus interface too? > Yes, actually any menu/toolbar action is available too as the button input events are mapped to existing UI actions. The question is how to add parameters (e.g. for the export actions). ciao, Torsten.
