Mon, Jul 25, 2016 12:56 AM
I have been printing parts that were designed to have vertical walls,
but the walls are not vertical. I looked at the layers as generated by
my slicer, and the vertical walls were moving from layer to layer. I
tried a different slicer, with the same results. This is all explained
better in the OpenSCAD source file.
I have attached the SCAD file as well as the generated STL file: I hope
they make it. Any thoughts? I'm using 2015-3-2 on Windows 10.
Mon, Jul 25, 2016 2:49 AM
http://forum.openscad.org/file/n17970/Anomoly.jpg
Netfabb says it is 10.8mm wide which is as you specified.
Adding
color("blue",0.4) {
translate([-ar,-0.25,-0.5]) cube([ar2,0.5,1]);
translate([-ar,-0.25,20-0.5]) cube([ar2,0.5,1]);
Then using Netfabb rulers;
http://forum.openscad.org/file/n17970/Anomoly_rules.jpg
means you have problems with your slicers...
View this message in context: http://forum.openscad.org/Strange-problem-with-verticality-tp17969p17970.html
<http://forum.openscad.org/file/n17970/Anomoly.jpg>
Adding
color("blue",0.4) {
translate([-ar,-0.25,-0.5]) cube([ar*2,0.5,1]);
translate([-ar,-0.25,20-0.5]) cube([ar*2,0.5,1]);
<http://forum.openscad.org/file/n17970/Anomoly_rules.jpg>
Mon, Jul 25, 2016 3:06 AM
I tried the stl file with Slic3r and all layers of vertical walls are
equal. I used Repetier with parallel projection. Are you sure you are not
visualizing it with perspective projection?
2016-07-24 23:49 GMT-03:00 MichaelAtOz oz.at.michael@gmail.com:
Adding
color("blue",0.4) {
2016-07-24 23:49 GMT-03:00 MichaelAtOz <oz.at.michael@gmail.com>:
> Adding
> color("blue",0.4) {
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
Mon, Jul 25, 2016 11:13 AM
And there you have it. Perspective projection.
This still leaves me with prints that are wrong, but at least now I can
view things correctly (thank you!). I now have NO idea why the prints
are as they are.
Thanks again
not visualizing it with perspective projection?
are as they are.
Thanks again
Mon, Jul 25, 2016 12:13 PM
Tends to be a slipping coupling, pully or belt, if you print at slow speeds
it is reduced; the jerk at high speeds shows it up.
View this message in context: http://forum.openscad.org/Strange-problem-with-verticality-tp17969p17973.html
Mon, Jul 25, 2016 2:18 PM
This would be good advice ... except that my machine uses lead screws on
all axes. I will ponder further. Thanks!
DB
David Boyd
Mon, Jul 25, 2016 2:22 PM
Could be cumulative error due to a slight difference in step/mm calibration.
on all axes. I will ponder further. Thanks!
speeds
========= mailto:david.boyd@usstem.org ============
David W. Boyd
7371 Atlas Walk Way, #242
Gainesville, Va 20155
fax: +1-703-656-4829
cell: +1-703-402-7908
============== http://usstem.org/ ============
First Robotic Mentor - FRC, FTC - www.iliterobotics.org
Board Member- USSTEM Foundation - www.usstem.org
Program Assistant - USFIRST - www.usfirst.org
The information contained in this message may be privileged
and/or confidential and protected from disclosure.
If the reader of this message is not the intended recipient
or an employee or agent responsible for delivering this message
to the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication
is strictly prohibited. If you have received this communication
in error, please notify the sender immediately by replying to
this message and deleting the material from any computer.
>> speeds
David W. Boyd
Mon, Jul 25, 2016 9:30 PM
Then your steppers are losing steps/skipping
http://machinedesign.com/motorsdrives/why-open-loop-steppers-lose-steps-and-how-solve-problem
View this message in context: http://forum.openscad.org/Strange-problem-with-verticality-tp17969p17976.html
<http://machinedesign.com/motorsdrives/why-open-loop-steppers-lose-steps-and-how-solve-problem>
Mon, Jul 25, 2016 9:35 PM
Thanks for the thought, but in fact the remainder of the print is
pristine, so that is not the problem.
> Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above.
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2016.0.7690 / Virus Database: 4627/12682 - Release Date: 07/25/16
Mon, Jul 25, 2016 10:01 PM
How exactly are your prints not vertical? Are they slanted, growing bigger
at each layer? Or what?
2016-07-25 18:35 GMT-03:00 jon jon@jonbondy.com:
2016-07-25 18:35 GMT-03:00 jon <jon@jonbondy.com>:
