CA
Sat, Oct 15, 2016 10:30 AM
On 15. okt. 2016 00:58, Parkinbot wrote:
a = 10;
a();
module a(){
a = a;
echo(a);
echo(a());
a();
function a() = 20;
module a(){
a = a;
echo(a);
echo(a());
function a() = 20;
Very good! Everything is obvious from the context, right?
The problem is implicit, but separate namespaces for variables,
functions and modules. It is confusing to the human reader, such code
will lead to unexpected results. It doesn't matter if the compiler is
'right' if the user expects something else. This kind of confusion is
best avoided (IMHO), and in several other languages it is an error
(example below).
My first idea would be to use an existing front end language with such
issues already handled instead of inventing a new one for OpenSCAD, but
since that is too late perhaps one may at least consider what other
languages do to resolve such issues.
Perhaps in OpenSCAD one could make explicit that 3 namespaces always
exist, for example:
variables : where variable names exist
functions : where function names exist
modules : where module names exist
As long as all symbols used in the OpenSCAD user code are unique across
namespaces, there are no issues and all is working as before. However,
once the same symbol names appear in different namespaces, a warning
could be issued. To remove the warning, the user would use other names
or alternatively use explicit namespace prefixing to make the
interpretation clear, for example:
a = 10;
modules::a();
module a(){
a = a;
echo(a);
echo(functions::a());
modules::a();
function a() = 20;
module a(){
a = a;
echo(a);
function a() = 30;
The fact that modules can be nested, makes it even more confusing to a
reader, the prefixes are supposed to be local in this example.
To compare, I just did a small test. The following code (some irrelevant
code not shown) causes errors in C++ and AngelScript because of name
resolution issues as in your OpenSCAD example. First code line is line 4:
double a = 10;
double a() { return 20; }
void language_test()
print(a());
print(' ');
print(a);
Tryng it with 2 C++ compilers and the AngelScript interpreter gave
consistent errors:
MSVC2013 C++ (windows):
main.cpp(5) : error C2365: 'a' : redefinition; previous definition was
'data variable'
main.cpp(8) : error C2064: term does not evaluate to a function taking 0
arguments
GNU g++ (linux):
main.cpp:5:10: error: ‘double a()’ redeclared as different kind of symbol
main.cpp:8:12: error: ‘a’ cannot be used as a function
Angescript:
asERR : (line 5, col 1) : Name conflict. 'a' is a global property.
However, when introducing an explicit namespace, all are ok:
double a = 10;
namespace functions { double a() { return 20; } }
print(functions::a());
print(' ');
print(a);
the output is : 20 10
As always, this is just food for thought.
Regards
> nice: :
>> a = 10;
>> a();
>> module a(){
>> a = a;
>> echo(a);
>> echo(a());
>> a();
>> function a() = 20;
>> module a(){
>> a = a;
>> echo(a);
>> echo(a());
>> function a() = 20;
(example below).
exist, for example:
a = 10;
modules::a();
module a(){
a = a;
echo(a);
modules::a();
function a() = 20;
module a(){
a = a;
echo(a);
function a() = 30;
double a = 10;
print(a());
print(' ');
print(a);
consistent errors:
'data variable'
arguments
GNU g++ (linux):
Angescript:
double a = 10;
print(' ');
print(a);
Regards
Sat, Oct 15, 2016 5:06 PM
Yes but I choose to use OpenScad to design my 3D objects, not C++ (which I
know) or Angel script (which I don't). I like it as it is now. There is
never ambiguity because if it doesn't have parenthesis after it it is a
variable, if it does it is a function if it is in an expression and a
module otherwise. I don't see how that is confusing.
a();
module a(){
a = a;
echo(a);
echo(a());
a();
function a() = 20;
module a(){
a = a;
echo(a);
echo(a());
function a() = 20;
The problem is implicit, but separate namespaces for variables, functions
and modules. It is confusing to the human reader, such code will lead to
unexpected results. It doesn't matter if the compiler is 'right' if the
user expects something else. This kind of confusion is best avoided (IMHO),
and in several other languages it is an error (example below).
exist, for example:
namespaces, there are no issues and all is working as before. However, once
the same symbol names appear in different namespaces, a warning could be
issued. To remove the warning, the user would use other names or
alternatively use explicit namespace prefixing to make the interpretation
clear, for example:
a = 10;
modules::a();
module a(){
a = a;
echo(a);
modules::a();
function a() = 20;
module a(){
a = a;
echo(a);
function a() = 30;
double a = 10;
print(a());
print(' ');
print(a);
consistent errors:
'data variable'
arguments
GNU g++ (linux):
Angescript:
double a = 10;
print(' ');
print(a);
Regards
>> nice: :
>> a = 10;
>>> a();
>>> module a(){
>>> a = a;
>>> echo(a);
>>> echo(a());
>>> a();
>>> function a() = 20;
>>> module a(){
>>> a = a;
>>> echo(a);
>>> echo(a());
>>> function a() = 20;
> exist, for example:
> clear, for example:
> a = 10;
> modules::a();
> module a(){
> a = a;
> echo(a);
> modules::a();
> function a() = 20;
> module a(){
> a = a;
> echo(a);
> function a() = 30;
> double a = 10;
> print(a());
> print(' ');
> print(a);
> consistent errors:
> 'data variable'
> arguments
> GNU g++ (linux):
> Angescript:
> double a = 10;
> print(' ');
> print(a);
> Regards
> Carsten Arnholm
KM
Kuba Marek
Sat, Oct 15, 2016 7:40 PM
The whole idea of having separate namespaces for functions and
variables is slightly confusing for me. I understand how it works, but
I still find the "a" example incomprehensible.
OpenSCAD calls itself functional language and having functions just be
variable with function value is fairly standard in these. When I
started with OpenSCAD, separate namespaces were the biggest hassle I
encountered.
If keeping the backwards compatibility was too important, then I would
vote for "@" dereferencing a string expression to a function call (so
that @"f"() behaves exactly like f().
Kuba
(which I know) or Angel script (which I don't). I like it as it is
now. There is never ambiguity because if it doesn't have parenthesis
after it it is a variable, if it does it is a function if it is in an
expression and a module otherwise. I don't see how that is confusing.
a();
module a(){
a = a;
echo(a);
echo(a());
a();
function a() = 20;
module a(){
a = a;
echo(a);
echo(a());
function a() = 20;
code will lead to unexpected results. It doesn't matter if the
compiler is 'right' if the user expects something else. This kind
of confusion is best avoided (IMHO), and in several other languages
such issues already handled instead of inventing a new one for
OpenSCAD, but since that is too late perhaps one may at least
consider what other languages do to resolve such issues.
exist, for example:
across namespaces, there are no issues and all is working as
before. However, once the same symbol names appear in different
namespaces, a warning could be issued. To remove the warning, the
user would use other names or alternatively use explicit namespace
prefixing to make the interpretation clear, for example:
a = 10;
modules::a();
module a(){
a = a;
echo(a);
modules::a();
function a() = 20;
module a(){
a = a;
echo(a);
function a() = 30;
to a reader, the prefixes are supposed to be local in this example.
irrelevant code not shown) causes errors in C++ and AngelScript
because of name resolution issues as in your OpenSCAD example.
double a = 10;
print(a());
print(' ');
print(a);
consistent errors:
was 'data variable'
taking 0 arguments
GNU g++ (linux):
symbol main.cpp:8:12: error: ‘a’ cannot be used as a function
Angescript:
double a = 10;
print(' ');
print(a);
Regards
encountered.
that `@"f"()` behaves exactly like `f()`.
Kuba
> >> nice: :
> >> a = 10;
> >>> a();
> >>> module a(){
> >>> a = a;
> >>> echo(a);
> >>> echo(a());
> >>> a();
> >>> function a() = 20;
> >>> module a(){
> >>> a = a;
> >>> echo(a);
> >>> echo(a());
> >>> function a() = 20;
> > exist, for example:
> > a = 10;
> > modules::a();
> > module a(){
> > a = a;
> > echo(a);
> > modules::a();
> > function a() = 20;
> > module a(){
> > a = a;
> > echo(a);
> > function a() = 30;
> > double a = 10;
> > print(a());
> > print(' ');
> > print(a);
> > consistent errors:
> > was 'data variable'
> > taking 0 arguments
> > GNU g++ (linux):
> > Angescript:
> > double a = 10;
> > print(' ');
> > print(a);
> > Regards
> > Carsten Arnholm
Sat, Oct 15, 2016 7:48 PM
Yes that would get my vote. Very simple and powerful while totally
backwards compatible.
The "a" example is confusing only because of the nested definitions causing
hiding. Nothing to do with the separate namespaces. It is always obvious
which of the three namespaces is referenced.
encountered.
Kuba
a();
module a(){
a = a;
echo(a);
echo(a());
a();
function a() = 20;
module a(){
a = a;
echo(a);
echo(a());
function a() = 20;
exist, for example:
a = 10;
modules::a();
module a(){
a = a;
echo(a);
modules::a();
function a() = 20;
module a(){
a = a;
echo(a);
function a() = 30;
double a = 10;
print(a());
print(' ');
print(a);
consistent errors:
was 'data variable'
taking 0 arguments
GNU g++ (linux):
Angescript:
double a = 10;
print(' ');
print(a);
Regards
> encountered.
> Kuba
> > >> nice: :
> > >> a = 10;
> > >>> a();
> > >>> module a(){
> > >>> a = a;
> > >>> echo(a);
> > >>> echo(a());
> > >>> a();
> > >>> function a() = 20;
> > >>> module a(){
> > >>> a = a;
> > >>> echo(a);
> > >>> echo(a());
> > >>> function a() = 20;
> > > exist, for example:
> > > a = 10;
> > > modules::a();
> > > module a(){
> > > a = a;
> > > echo(a);
> > > modules::a();
> > > function a() = 20;
> > > module a(){
> > > a = a;
> > > echo(a);
> > > function a() = 30;
> > > double a = 10;
> > > print(a());
> > > print(' ');
> > > print(a);
> > > consistent errors:
> > > was 'data variable'
> > > taking 0 arguments
> > > GNU g++ (linux):
> > > Angescript:
> > > double a = 10;
> > > print(' ');
> > > print(a);
> > > Regards
> > > Carsten Arnholm
Sun, Oct 16, 2016 2:35 PM
@ could also be used in a statement to have indirect modules as well. It
would be more powerful than children() because you would be able to pass
parameters as you are invoking it in the parent instead of outside it.
causing hiding. Nothing to do with the separate namespaces. It is always
obvious which of the three namespaces is referenced.
encountered.
Kuba
a();
module a(){
a = a;
echo(a);
echo(a());
a();
function a() = 20;
module a(){
a = a;
echo(a);
echo(a());
function a() = 20;
exist, for example:
a = 10;
modules::a();
module a(){
a = a;
echo(a);
modules::a();
function a() = 20;
module a(){
a = a;
echo(a);
function a() = 30;
double a = 10;
print(a());
print(' ');
print(a);
consistent errors:
was 'data variable'
taking 0 arguments
GNU g++ (linux):
Angescript:
double a = 10;
print(' ');
print(a);
Regards
>> encountered.
>> Kuba
>> > >> nice: :
>> > >> a = 10;
>> > >>> a();
>> > >>> module a(){
>> > >>> a = a;
>> > >>> echo(a);
>> > >>> echo(a());
>> > >>> a();
>> > >>> function a() = 20;
>> > >>> module a(){
>> > >>> a = a;
>> > >>> echo(a);
>> > >>> echo(a());
>> > >>> function a() = 20;
>> > > exist, for example:
>> > > a = 10;
>> > > modules::a();
>> > > module a(){
>> > > a = a;
>> > > echo(a);
>> > > modules::a();
>> > > function a() = 20;
>> > > module a(){
>> > > a = a;
>> > > echo(a);
>> > > function a() = 30;
>> > > double a = 10;
>> > > print(a());
>> > > print(' ');
>> > > print(a);
>> > > consistent errors:
>> > > was 'data variable'
>> > > taking 0 arguments
>> > > GNU g++ (linux):
>> > > Angescript:
>> > > double a = 10;
>> > > print(' ');
>> > > print(a);
>> > > Regards
>> > > Carsten Arnholm
RU
Richard Urwin
Sun, Oct 16, 2016 2:58 PM
Very useful, but you could do that without @ as well:
module whatsit (...) {...}
module doit(m)
...transforms... m(parameters);
doit(whatsit);
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18728.html
GF
Greg Frost
Sun, Oct 16, 2016 3:28 PM
nophead wrote
...... but you could do that without @ as well:
module doit(m)
doit(whatsit);
What if you also had a variable called whatsit?
That is where the @ comes in. It disambiguates the namespace like () does with a function.
> module doit(m)
> doit(whatsit);
Sun, Oct 16, 2016 3:58 PM
Exactly. Rather than break everything by unifying the namespaces all it
needs is an @ sign that converts a string to a module or function depending
on the context.
It is also more readable than languages that use the type of the variable
instead. When you see an @ you know there is an indirection. Without it you
need to look at the name and find its type is a function pointer and not a
function to realise that.
On 16 October 2016 at 16:28, Greg Frost gregorybartonfrost@gmail.com
module doit(m)
doit(whatsit);
on the context.
On 16 October 2016 at 16:28, Greg Frost <gregorybartonfrost@gmail.com>
> > module doit(m)
> > doit(whatsit);
> with a function.
adrian
Sun, Oct 16, 2016 4:33 PM
causing
As nested definitions are possible then using a @"" syntax is not advisable
as this would not work in particular contexts:
Or worse, the wrong function could called.
Being able to reference any of the namespaces is only necessary when storing
a reference to it in a definition. (As does doug.moen, I prefer the use of
'definition' over 'variable' as it's value is not mutable.) So, it is only
necessary to use a decorator when referencing from one of the other
namespaces. Doug's suggestion is to use m$ and f$ prefixes to
explicitly reference them. He also stated using v$ for the
variable/definition namespace, but, IMHO that wouldn't be useful, as this
namespace is used by default when assigning to a definition or passing as a
parameter. So the above example becomes like this:
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18733.html
> causing
namespaces. Doug's suggestion is to use *m$* and *f$* prefixes to
explicitly reference them. He also stated using *v$* for the
adrian
Sun, Oct 16, 2016 4:44 PM
FYI, the prefixes are something that Doug is stating he'd use for the
backward compatibility mode and would want the main mode to have a unified
namespace.
Personally, I would like to keep the namespaces separate and have this in
the main mode. Maintaining two modes is not something that is optimal.
Another alternative would be to EXPLICITLY state if the code uses a unified
namespace, which would be marginally better as it would allow simpler
backward compatibility and allow more advanced features to be use in older
code.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18734.html
namespace.
code.
