Convert from object to polygon/polyhedron.
RU
Richard Urwin
Sun, Oct 16, 2016 5:50 PM
I've used unified namespaces all my life; it's not [i]that[/i] confusing. In
my opinion it's more confusing to have two different things with the same
name. Granted it would be necessary to allow some route for backward
compatibility.
I don't like $ used in that way. We already have $fn and other special
variables, using $ for namespace resolution will lead to such monstrosities
as "f$$myspecial". What about ":", which is used in similar contexts in
other languages?
Is there a particular reason that a statement such as
foo = f:bar
cannot be handled without special decoration on the definition of bar? It is
recognisable as a reference rather than a call by not having the
parentheses. If it is done that way then the scope becomes more obvious --
it is the bar that is in scope when foo is defined, not the bar that is in
scope when foo is used.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18736.html
I've used unified namespaces all my life; it's not [i]that[/i] confusing. In my opinion it's more confusing to have two different things with the same name. Granted it would be necessary to allow some route for backward compatibility. I don't like $ used in that way. We already have $fn and other special variables, using $ for namespace resolution will lead to such monstrosities as "f$$myspecial". What about ":", which is used in similar contexts in other languages? Is there a particular reason that a statement such as foo = f:bar cannot be handled without special decoration on the definition of bar? It is recognisable as a reference rather than a call by not having the parentheses. If it is done that way then the scope becomes more obvious -- it is the bar that is in scope when foo is defined, not the bar that is in scope when foo is used. -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18736.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Sun, Oct 16, 2016 6:46 PM
Using a non-unified namespace is what is being said as confusing, not the
other way around.  Using decorators to resolve the ambiguity is not that
confusing either, IMHO.
Using a ':' should be fine.  AFAIK, the only place that ':' is used is for
ranges and ?: conditionals.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18738.html
Using a non-unified namespace is what is being said as confusing, not the other way around. Using decorators to resolve the ambiguity is not that confusing either, IMHO. Using a ':' should be fine. AFAIK, the only place that ':' is used is for ranges and ?: conditionals. -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18738.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Sun, Oct 16, 2016 6:56 PM
Oh wait, using a single colon might make the language harder to parse when
parsing conditionals.
Would require that the decorator is checked for first:
And on failure, then check for conditional:
Perhaps a double colon?  An @ sign?
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18739.html
Oh wait, using a single colon might make the language harder to parse when parsing conditionals. Would require that the decorator is checked for first: And on failure, then check for conditional: Perhaps a double colon? An @ sign? -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18739.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CA
Sun, Oct 16, 2016 8:26 PM
Double colon is precisely what some other languages use. It makes sense.
On 16. okt. 2016 20:56, adrian wrote: > Perhaps a double colon? Double colon is precisely what some other languages use. It makes sense. Carsten Arnholm
RU
Richard Urwin
Sun, Oct 16, 2016 8:34 PM
Good point.
What about ".", as in f.func? It's not as standard and it kind of shuts the
door on aggregate types.
Apostrophe?  f'func? It kind of disappears between those two f's.
Tilde? f~func? Looks like a minus sign.
Caret? f^func?
The more I think about this, the more I feel it's all going to descend into
Perl-style babble.
How about: function func
function and module are already recognised symbols and are not syntactically
allowed in this context. It's more typing, but its meaning is absolutely
clear.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18742.html
Good point. What about ".", as in f.func? It's not as standard and it kind of shuts the door on aggregate types. Apostrophe? f'func? It kind of disappears between those two f's. Tilde? f~func? Looks like a minus sign. Caret? f^func? The more I think about this, the more I feel it's all going to descend into Perl-style babble. How about: function func function and module are already recognised symbols and are not syntactically allowed in this context. It's more typing, but its meaning is absolutely clear. -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18742.html Sent from the OpenSCAD mailing list archive at Nabble.com.
KM
Kuba Marek
Mon, Oct 17, 2016 7:19 AM
Or another option (fairly usable):
What about keeping separate function namespace for backwards
compatibility and introducing JavaScript-ish lambdas that exist in
variable namespace?
Usage example:
f = function(a, b) a + b;
instead of
function f(a, b) = a + b;
This should be easy to parse, make functions behave in a familiar way
for people coming from other languages and add lambdas as a bonus.
Kuba
Good point.
Caret? f^func?
Or another option (fairly usable): What about keeping separate function namespace for backwards compatibility and introducing JavaScript-ish lambdas that exist in variable namespace? Usage example: f = function(a, b) a + b; instead of function f(a, b) = a + b; This should be easy to parse, make functions behave in a familiar way for people coming from other languages and add lambdas as a bonus. Kuba > Good point. > > What about ".", as in f.func? It's not as standard and it kind of > shuts the door on aggregate types. > > Apostrophe? f'func? It kind of disappears between those two f's. > Tilde? f~func? Looks like a minus sign. > Caret? f^func? > > The more I think about this, the more I feel it's all going to > descend into Perl-style babble. > > How about: function func > function and module are already recognised symbols and are not > syntactically allowed in this context. It's more typing, but its > meaning is absolutely clear. > > > > -- > View this message in context: > http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18742.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
O
otto
Mon, Oct 17, 2016 7:23 AM
Python likes:
lambda x: x+2
For anonymous syntax.
Lisp likes
(lambda (x) (+ arg 2))
For same operation.  I don't particularly like either construct but
either could be implemented.
I have now implemented
@(x:x+2)
in my prototype system.  It works just as well as the
function @<tok_id>(<arglist>)=<expr>
I tried earlier.
It is completely compatible with mixed name spaces and breaks no
earlier code.
If you wish to assign the function to a variable in the main name space
it can be done.  Dereferencing is done with the "@" symbol as well.
Any (almost) of the suggested syntaxes is easy to add to openScad.  The
(bison) parser works nearly flawlessly and was neatly programmed.  I
have had no trouble hacking the code.
Here is an example of openScad code using the new syntax.
function reduce(func,vec) =
len(vec)==2 ? @func(vec[0],vec[1]) : @func(vec[0],reduce(func,[for (i=[1:len(vec)-1]) vec[i]]));
echo(reduce(@(x,y:x+y),[1,2,3,4,5]));
echo(reduce(@(x,y:x*y),[1,2,3,4,5]));
cossin=@(x,y:sin(x)-cos(y));
echo(reduce(cossin,[1,2,3,4,5]));
RESULT
ECHO: 15
ECHO: 120
ECHO: -0.982406
For me, Openscad1.1 is much more interesting than openScad 2.0..
That is, I do not believe that any changes should break previous code.
I have not yet posted the new code to github, but this time I will do so
as a complete clone of the current system in order to make it easier to
test.
For me, to make my work possible, I wanted a system that implemented
some new functionality but in which I could have confidence that code
written by others continues to work.
I think the explicit dereferencing is better than a check during
compilation or execution and easier to implement and maintain.  I am
also considering the same kind of syntax for an anonymous module, where
an address can be passed around in a normal variable and dereferenced
when needed.  I considered @f() for functions and @m() for modules but
choose in my current prototype to use "@" unmodified.  Hacking the code
to support modules is more difficult and currently I have not started
trying, so I have no idea just how much I would be biting off.  Any
syntax for indirect functions is fairly easy for me at this point with
my current understanding of the code.
I have no intention of breaking any current code which means of course,
maintaining the separation of the name spaces.  When I get a clone of
the system set up for prototyping, I will add this kind of functionality
as I develop it and if people want it added to the base system they can
lobby for that or simply use the cloned/modified version.
Regards
Otto
On Sun, 16 Oct 2016 13:34:00 -0700 (MST)
Richard Urwin soronlin+openscad@googlemail.com wrote:
Good point.
Caret? f^func?
Python likes: lambda x: x+2 For anonymous syntax. Lisp likes (lambda (x) (+ arg 2)) For same operation. I don't particularly like either construct but either could be implemented. I have now implemented @(x:x+2) in my prototype system. It works just as well as the function @<tok_id>(<arglist>)=<expr> I tried earlier. It is completely compatible with mixed name spaces and breaks no earlier code. If you wish to assign the function to a variable in the main name space it can be done. Dereferencing is done with the "@" symbol as well. Any (almost) of the suggested syntaxes is easy to add to openScad. The (bison) parser works nearly flawlessly and was neatly programmed. I have had no trouble hacking the code. Here is an example of openScad code using the new syntax. function reduce(func,vec) = len(vec)==2 ? @func(vec[0],vec[1]) : @func(vec[0],reduce(func,[for (i=[1:len(vec)-1]) vec[i]])); echo(reduce(@(x,y:x+y),[1,2,3,4,5])); echo(reduce(@(x,y:x*y),[1,2,3,4,5])); cossin=@(x,y:sin(x)-cos(y)); echo(reduce(cossin,[1,2,3,4,5])); /************************** RESULT ECHO: 15 ECHO: 120 ECHO: -0.982406 **************************/ For me, Openscad1.1 is much more interesting than openScad 2.0.. That is, I do not believe that any changes should break previous code. I have not yet posted the new code to github, but this time I will do so as a complete clone of the current system in order to make it easier to test. For me, to make my work possible, I wanted a system that implemented some new functionality but in which I could have confidence that code written by others continues to work. I think the explicit dereferencing is better than a check during compilation or execution and easier to implement and maintain. I am also considering the same kind of syntax for an anonymous module, where an address can be passed around in a normal variable and dereferenced when needed. I considered @f() for functions and @m() for modules but choose in my current prototype to use "@" unmodified. Hacking the code to support modules is more difficult and currently I have not started trying, so I have no idea just how much I would be biting off. Any syntax for indirect functions is fairly easy for me at this point with my current understanding of the code. I have no intention of breaking any current code which means of course, maintaining the separation of the name spaces. When I get a clone of the system set up for prototyping, I will add this kind of functionality as I develop it and if people want it added to the base system they can lobby for that or simply use the cloned/modified version. Regards Otto On Sun, 16 Oct 2016 13:34:00 -0700 (MST) Richard Urwin <soronlin+openscad@googlemail.com> wrote: > Good point. > > What about ".", as in f.func? It's not as standard and it kind of > shuts the door on aggregate types. > > Apostrophe? f'func? It kind of disappears between those two f's. > Tilde? f~func? Looks like a minus sign. > Caret? f^func? > > The more I think about this, the more I feel it's all going to > descend into Perl-style babble. > > How about: function func > function and module are already recognised symbols and are not > syntactically allowed in this context. It's more typing, but its > meaning is absolutely clear. > > > > -- > View this message in context: > http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18742.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Oct 17, 2016 7:50 AM
Von: "Kuba Marek" blue.cube@seznam.cz
instead of
I don't think we have a problem at definition time,
the trouble is where the data is passed to another
function (or module).
E.g (ignoring modules completely for now).
f = 6;
function f(x) = 1;
function call_indirect(func, x) = func(x);
call_indirect(f); // is that the variable or function?
As we don't have types, we can't easily infer which
of the 'f' thingies is supposed to be passed to the
call_indirect() function.
To clarify which one is meant, we either have to use a
unified namespace, or have the user declare explicitely
which of the namespaces too choose from.
Von: "Kuba Marek" <blue.cube@seznam.cz> > f = function(a, b) a + b; > instead of > function f(a, b) = a + b; > I don't think we have a problem at definition time, the trouble is where the data is passed to another function (or module). E.g (ignoring modules completely for now). f = 6; function f(x) = 1; function call_indirect(func, x) = func(x); call_indirect(f); // is that the variable or function? As we don't have types, we can't easily infer which of the 'f' thingies is supposed to be passed to the call_indirect() function. To clarify which one is meant, we either have to use a unified namespace, or have the user declare explicitely which of the namespaces too choose from. ciao, Torsten.
KM
Kuba Marek
Mon, Oct 17, 2016 8:59 AM
f = 6;
function f(x) = 1;
In my proposal this code would behave exactly as it does now and pass
the value 6.
If you wanted to pass the function, the example would have to look like
this:
// f = 6; // With this line the next one would cause an error
f = function f(x) 1;
call_indirect(f);
This is exactly what would be happening -- by using the lambda syntax
instead of the existing syntax you would be saying "this is a
variable with function as a value" instead of "this is a function"
Kuba
> f = 6; > function f(x) = 1; > function call_indirect(func, x) = func(x); > > call_indirect(f); // is that the variable or function? In my proposal this code would behave exactly as it does now and pass the value 6. If you wanted to pass the function, the example would have to look like this: // f = 6; // With this line the next one would cause an error f = function f(x) 1; call_indirect(f); > To clarify which one is meant, we either have to use a > unified namespace, or have the user declare explicitely > which of the namespaces too choose from. This is exactly what would be happening -- by using the lambda syntax instead of the existing syntax you would be saying "this is a variable with function as a value" instead of "this is a function" Kuba
RU
Richard Urwin
Mon, Oct 17, 2016 11:58 AM
RESULT
ECHO: 15
ECHO: 120
ECHO: -0.982406
The @ in the indirect call is required for backwards compatibility but every
other use of @ could be replaced by "function", making your code:
len(vec)==2 ? @func(vec[0],vec[1]) : @func(vec[0],reduce(@func,[for
echo(reduce(function(x,y:x+y),[1,2,3,4,5]));
echo(reduce(function(x,y:x*y),[1,2,3,4,5]));
cossin=function(x,y:sin(x)-cos(y));
To my mind, that is more readable.
Then, if eventually the namespaces are merged, the @ could be deprecated and
phased out.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18752.html
ottojas wrote > Here is an example of openScad code using the new syntax. > > function reduce(func,vec) = > len(vec)==2 ? @func(vec[0],vec[1]) : @func(vec[0],reduce(func,[for > (i=[1:len(vec)-1]) vec[i]])); > > echo(reduce(@(x,y:x+y),[1,2,3,4,5])); > echo(reduce(@(x,y:x*y),[1,2,3,4,5])); > > cossin=@(x,y:sin(x)-cos(y)); > echo(reduce(cossin,[1,2,3,4,5])); > > /************************** > RESULT > ECHO: 15 > ECHO: 120 > ECHO: -0.982406 > **************************/ The @ in the indirect call is required for backwards compatibility but every other use of @ could be replaced by "function", making your code: function reduce(func,vec) = len(vec)==2 ? @func(vec[0],vec[1]) : @func(vec[0],reduce(@func,[for (i=[1:len(vec)-1]) vec[i]])); echo(reduce(function(x,y:x+y),[1,2,3,4,5])); echo(reduce(function(x,y:x*y),[1,2,3,4,5])); cossin=function(x,y:sin(x)-cos(y)); echo(reduce(cossin,[1,2,3,4,5])); To my mind, that is more readable. Then, if eventually the namespaces are merged, the @ could be deprecated and phased out. -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18752.html Sent from the OpenSCAD mailing list archive at Nabble.com.
