Convert from object to polygon/polyhedron.
adrian
Tue, Oct 4, 2016 12:02 AM
Hi all,
Is there a way to convert a 2D objects to a polygon format? Or a 3D object
to a polyhedron format?
To  be able to go that way, rather than make a polygon / polyhedron from
points and paths /faces would be awesome, as this would open up a whole new
set of abilities.
Thanks.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522.html
Hi all, Is there a way to convert a 2D objects to a polygon format? Or a 3D object to a polyhedron format? To be able to go that way, rather than make a polygon / polyhedron from points and paths /faces would be awesome, as this would open up a whole new set of abilities. Thanks. -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Ronaldo
Tue, Oct 4, 2016 12:25 AM
Yes, there is but not with OpenSCAD language yet. A python code by Neon22
converts AMF files (possibly exported by OpenSCAD) to a text file in the
OpenSCAD polyhedron format. See this discussion:
http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-td18145.html#a18156
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18523.html
Yes, there is but not with OpenSCAD language yet. A python code by Neon22 converts AMF files (possibly exported by OpenSCAD) to a text file in the OpenSCAD polyhedron format. See this discussion: http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-td18145.html#a18156 <http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-td18145.html#a18156> -- View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18523.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MS
Mark Schafer
Tue, Oct 4, 2016 10:51 AM
also on thingiverse is an inkscape extension which exports vector
objects to openscad format directly:
Yes it would be nice if we could have lines as first class objects in
OpenSCAD but for now these tools might help you
Checked by AVG - www.avg.com
Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: 10/03/16
also on thingiverse is an inkscape extension which exports vector objects to openscad format directly: - http://www.thingiverse.com/thing:1065500 Yes it would be nice if we could have lines as first class objects in OpenSCAD but for now these tools might help you On 10/4/2016 1:25 PM, Ronaldo wrote: > Yes, there is but not with OpenSCAD language yet. A python code by Neon22 > converts AMF files (possibly exported by OpenSCAD) to a text file in the > OpenSCAD polyhedron format. See this discussion: > http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-td18145.html#a18156 > <http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-td18145.html#a18156> > > > > -- > View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18523.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: 10/03/16 > >
PF
Peter Falke
Tue, Oct 4, 2016 12:42 PM
The reason there is no such thing is that OpenSCAD can not change/set the
variables (set any(!) variable) during  execution.
But the 2d primitives are eaily written by your self.
The 3D primitives are doable too, but a little harder.
2016-10-04 12:51 GMT+02:00 Mark Schafer mschafer@wireframe.biz:
The reason there is no such thing is that OpenSCAD can not change/set the variables (set any(!) variable) during execution. But the 2d primitives are eaily written by your self. The 3D primitives are doable too, but a little harder. 2016-10-04 12:51 GMT+02:00 Mark Schafer <mschafer@wireframe.biz>: > also on thingiverse is an inkscape extension which exports vector objects > to openscad format directly: > - http://www.thingiverse.com/thing:1065500 > > Yes it would be nice if we could have lines as first class objects in > OpenSCAD but for now these tools might help you > > > > On 10/4/2016 1:25 PM, Ronaldo wrote: > >> Yes, there is but not with OpenSCAD language yet. A python code by Neon22 >> converts AMF files (possibly exported by OpenSCAD) to a text file in the >> OpenSCAD polyhedron format. See this discussion: >> http://forum.openscad.org/Wrapping-text-around-a-complex- >> geometry-td18145.html#a18156 >> <http://forum.openscad.org/Wrapping-text-around-a-complex- >> geometry-td18145.html#a18156> >> >> >> >> -- >> View this message in context: http://forum.openscad.org/Conv >> ert-from-object-to-polygon-polyhedron-tp18522p18523.html >> Sent from the OpenSCAD mailing list archive at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: 10/03/16 >> >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
AH
Adrian H
Tue, Oct 4, 2016 1:09 PM
True that all variables are constants, but there could be an operator that
returns the points.  That wouldn't break that paradigm.  Something like:
_2d = points_edges()
intersection()
circle(1, $fn=20);
square(2);
_3d = points_faces()
intersection()
sphere(1, $fn=20);
cube(2);
Where:
_2d=[ [point0, point1, ...], [ [edge0, ...], [edge1, ...], ...];
_3d=[ [point0, point1, ...], [ [face0, ...], [face1, ...], ...];
On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke <
10/03/16
True that all variables are constants, but there could be an operator that returns the points. That wouldn't break that paradigm. Something like: _2d = points_edges() intersection() { circle(1, $fn=20); square(2); } _3d = points_faces() intersection() { sphere(1, $fn=20); cube(2); } Where: _2d=[ [point0, point1, ...], [ [edge0, ...], [edge1, ...], ...]; _3d=[ [point0, point1, ...], [ [face0, ...], [face1, ...], ...]; On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke < stempeldergeschichte@googlemail.com> wrote: > The reason there is no such thing is that OpenSCAD can not change/set the > variables (set any(!) variable) during execution. > But the 2d primitives are eaily written by your self. > The 3D primitives are doable too, but a little harder. > > 2016-10-04 12:51 GMT+02:00 Mark Schafer <mschafer@wireframe.biz>: > >> also on thingiverse is an inkscape extension which exports vector objects >> to openscad format directly: >> - http://www.thingiverse.com/thing:1065500 >> >> Yes it would be nice if we could have lines as first class objects in >> OpenSCAD but for now these tools might help you >> >> >> >> On 10/4/2016 1:25 PM, Ronaldo wrote: >> >>> Yes, there is but not with OpenSCAD language yet. A python code by Neon22 >>> converts AMF files (possibly exported by OpenSCAD) to a text file in the >>> OpenSCAD polyhedron format. See this discussion: >>> http://forum.openscad.org/Wrapping-text-around-a-complex-geo >>> metry-td18145.html#a18156 >>> <http://forum.openscad.org/Wrapping-text-around-a-complex-ge >>> ometry-td18145.html#a18156> >>> >>> >>> >>> -- >>> View this message in context: http://forum.openscad.org/Conv >>> ert-from-object-to-polygon-polyhedron-tp18522p18523.html >>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >>> ----- >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: >>> 10/03/16 >>> >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
AH
Adrian H
Tue, Oct 4, 2016 1:32 PM
Oh, and further to this, yes, one can write the primitives and the
operators, but that would be reinventing the wheel, and would definitely be
slower.  Especially with things like hull() and minkowski().
The information is available, it just needs to be made available.
Thinking about this further, the operators that I described are actually a
module to function crossover, which doesn't currently exist in OpenSCAD,
but perhaps it could possibly be doable?  Maybe by some incremental build
process?
As I understand it, it currently builds by:
  1. calculate all variables/functions
  2. calculate all operations/modules.
  3. show result on screen result
What I would be suggesting is to iterate over the first 2 steps, executing
each iteration, child node first, up to such crossover points until
everything is calculated, and then do step 3.
Yes, that would be a significant change to the paradigm, but doable?
10/03/16
Oh, and further to this, yes, one can write the primitives and the operators, but that would be reinventing the wheel, and would definitely be slower. Especially with things like hull() and minkowski(). The information is available, it just needs to be made available. Thinking about this further, the operators that I described are actually a module to function crossover, which doesn't currently exist in OpenSCAD, but perhaps it could possibly be doable? Maybe by some incremental build process? As I understand it, it currently builds by: 1. calculate all variables/functions 2. calculate all operations/modules. 3. show result on screen result What I would be suggesting is to iterate over the first 2 steps, executing each iteration, child node first, up to such crossover points until everything is calculated, and then do step 3. Yes, that would be a significant change to the paradigm, but doable? On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke < stempeldergeschichte@googlemail.com> wrote: > The reason there is no such thing is that OpenSCAD can not change/set the > variables (set any(!) variable) during execution. > But the 2d primitives are eaily written by your self. > The 3D primitives are doable too, but a little harder. > > 2016-10-04 12:51 GMT+02:00 Mark Schafer <mschafer@wireframe.biz>: > >> also on thingiverse is an inkscape extension which exports vector objects >> to openscad format directly: >> - http://www.thingiverse.com/thing:1065500 >> >> Yes it would be nice if we could have lines as first class objects in >> OpenSCAD but for now these tools might help you >> >> >> >> On 10/4/2016 1:25 PM, Ronaldo wrote: >> >>> Yes, there is but not with OpenSCAD language yet. A python code by Neon22 >>> converts AMF files (possibly exported by OpenSCAD) to a text file in the >>> OpenSCAD polyhedron format. See this discussion: >>> http://forum.openscad.org/Wrapping-text-around-a-complex-geo >>> metry-td18145.html#a18156 >>> <http://forum.openscad.org/Wrapping-text-around-a-complex-ge >>> ometry-td18145.html#a18156> >>> >>> >>> >>> -- >>> View this message in context: http://forum.openscad.org/Conv >>> ert-from-object-to-polygon-polyhedron-tp18522p18523.html >>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >>> ----- >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: >>> 10/03/16 >>> >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Tue, Oct 4, 2016 1:59 PM
The problem is that with F5 preview the geometry is never calculated. It is
straight from variables to pixels, so the information is never there unless
you use render().
process?
On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke <stempeldergeschichte@
Neon22
10/03/16
The problem is that with F5 preview the geometry is never calculated. It is straight from variables to pixels, so the information is never there unless you use render(). On 4 October 2016 at 14:32, Adrian H <adrianh.bsc@gmail.com> wrote: > Oh, and further to this, yes, one can write the primitives and the > operators, but that would be reinventing the wheel, and would definitely be > slower. Especially with things like hull() and minkowski(). > > The information is available, it just needs to be made available. > > Thinking about this further, the operators that I described are actually a > module to function crossover, which doesn't currently exist in OpenSCAD, > but perhaps it could possibly be doable? Maybe by some incremental build > process? > > As I understand it, it currently builds by: > > 1. calculate all variables/functions > 2. calculate all operations/modules. > 3. show result on screen result > > What I would be suggesting is to iterate over the first 2 steps, executing > each iteration, child node first, up to such crossover points until > everything is calculated, and then do step 3. > > Yes, that would be a significant change to the paradigm, but doable? > > > On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke <stempeldergeschichte@ > googlemail.com> wrote: > >> The reason there is no such thing is that OpenSCAD can not change/set >> the variables (set any(!) variable) during execution. >> But the 2d primitives are eaily written by your self. >> The 3D primitives are doable too, but a little harder. >> >> 2016-10-04 12:51 GMT+02:00 Mark Schafer <mschafer@wireframe.biz>: >> >>> also on thingiverse is an inkscape extension which exports vector >>> objects to openscad format directly: >>> - http://www.thingiverse.com/thing:1065500 >>> >>> Yes it would be nice if we could have lines as first class objects in >>> OpenSCAD but for now these tools might help you >>> >>> >>> >>> On 10/4/2016 1:25 PM, Ronaldo wrote: >>> >>>> Yes, there is but not with OpenSCAD language yet. A python code by >>>> Neon22 >>>> converts AMF files (possibly exported by OpenSCAD) to a text file in the >>>> OpenSCAD polyhedron format. See this discussion: >>>> http://forum.openscad.org/Wrapping-text-around-a-complex-geo >>>> metry-td18145.html#a18156 >>>> <http://forum.openscad.org/Wrapping-text-around-a-complex-ge >>>> ometry-td18145.html#a18156> >>>> >>>> >>>> >>>> -- >>>> View this message in context: http://forum.openscad.org/Conv >>>> ert-from-object-to-polygon-polyhedron-tp18522p18523.html >>>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>>> ----- >>>> No virus found in this message. >>>> Checked by AVG - www.avg.com >>>> Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: >>>> 10/03/16 >>>> >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
AH
Adrian H
Thu, Oct 6, 2016 12:07 AM
Oh, that's unfortunate.  But, can not the same idea apply to the preview?
It still has to have points to be able to show the preview, doesn't it?
process?
Neon22
10/03/16
Oh, that's unfortunate. But, can not the same idea apply to the preview? It still has to have points to be able to show the preview, doesn't it? On Oct 4, 2016 10:00 AM, "nop head" <nop.head@gmail.com> wrote: > The problem is that with F5 preview the geometry is never calculated. It > is straight from variables to pixels, so the information is never there > unless you use render(). > > On 4 October 2016 at 14:32, Adrian H <adrianh.bsc@gmail.com> wrote: > >> Oh, and further to this, yes, one can write the primitives and the >> operators, but that would be reinventing the wheel, and would definitely be >> slower. Especially with things like hull() and minkowski(). >> >> The information is available, it just needs to be made available. >> >> Thinking about this further, the operators that I described are actually >> a module to function crossover, which doesn't currently exist in OpenSCAD, >> but perhaps it could possibly be doable? Maybe by some incremental build >> process? >> >> As I understand it, it currently builds by: >> >> 1. calculate all variables/functions >> 2. calculate all operations/modules. >> 3. show result on screen result >> >> What I would be suggesting is to iterate over the first 2 steps, >> executing each iteration, child node first, up to such crossover points >> until everything is calculated, and then do step 3. >> >> Yes, that would be a significant change to the paradigm, but doable? >> >> >> On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke < >> stempeldergeschichte@googlemail.com> wrote: >> >>> The reason there is no such thing is that OpenSCAD can not change/set >>> the variables (set any(!) variable) during execution. >>> But the 2d primitives are eaily written by your self. >>> The 3D primitives are doable too, but a little harder. >>> >>> 2016-10-04 12:51 GMT+02:00 Mark Schafer <mschafer@wireframe.biz>: >>> >>>> also on thingiverse is an inkscape extension which exports vector >>>> objects to openscad format directly: >>>> - http://www.thingiverse.com/thing:1065500 >>>> >>>> Yes it would be nice if we could have lines as first class objects in >>>> OpenSCAD but for now these tools might help you >>>> >>>> >>>> >>>> On 10/4/2016 1:25 PM, Ronaldo wrote: >>>> >>>>> Yes, there is but not with OpenSCAD language yet. A python code by >>>>> Neon22 >>>>> converts AMF files (possibly exported by OpenSCAD) to a text file in >>>>> the >>>>> OpenSCAD polyhedron format. See this discussion: >>>>> http://forum.openscad.org/Wrapping-text-around-a-complex-geo >>>>> metry-td18145.html#a18156 >>>>> <http://forum.openscad.org/Wrapping-text-around-a-complex-ge >>>>> ometry-td18145.html#a18156> >>>>> >>>>> >>>>> >>>>> -- >>>>> View this message in context: http://forum.openscad.org/Conv >>>>> ert-from-object-to-polygon-polyhedron-tp18522p18523.html >>>>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>>> ----- >>>>> No virus found in this message. >>>>> Checked by AVG - www.avg.com >>>>> Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: >>>>> 10/03/16 >>>>> >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Oct 6, 2016 12:26 AM
Preview doesn't compute boolean operations points. Try preview cube(10);
rotate(15) sphere(10,$fn=12); with Show edges on. You will see no edges at
the intersection line.
2016-10-05 21:07 GMT-03:00 Adrian H adrianh.bsc@gmail.com:
process?
Neon22
10/03/16
Preview doesn't compute boolean operations points. Try preview cube(10); rotate(15) sphere(10,$fn=12); with Show edges on. You will see no edges at the intersection line. 2016-10-05 21:07 GMT-03:00 Adrian H <adrianh.bsc@gmail.com>: > Oh, that's unfortunate. But, can not the same idea apply to the preview? > It still has to have points to be able to show the preview, doesn't it? > On Oct 4, 2016 10:00 AM, "nop head" <nop.head@gmail.com> wrote: > >> The problem is that with F5 preview the geometry is never calculated. It >> is straight from variables to pixels, so the information is never there >> unless you use render(). >> >> On 4 October 2016 at 14:32, Adrian H <adrianh.bsc@gmail.com> wrote: >> >>> Oh, and further to this, yes, one can write the primitives and the >>> operators, but that would be reinventing the wheel, and would definitely be >>> slower. Especially with things like hull() and minkowski(). >>> >>> The information is available, it just needs to be made available. >>> >>> Thinking about this further, the operators that I described are actually >>> a module to function crossover, which doesn't currently exist in OpenSCAD, >>> but perhaps it could possibly be doable? Maybe by some incremental build >>> process? >>> >>> As I understand it, it currently builds by: >>> >>> 1. calculate all variables/functions >>> 2. calculate all operations/modules. >>> 3. show result on screen result >>> >>> What I would be suggesting is to iterate over the first 2 steps, >>> executing each iteration, child node first, up to such crossover points >>> until everything is calculated, and then do step 3. >>> >>> Yes, that would be a significant change to the paradigm, but doable? >>> >>> >>> On Tue, Oct 4, 2016 at 8:42 AM, Peter Falke < >>> stempeldergeschichte@googlemail.com> wrote: >>> >>>> The reason there is no such thing is that OpenSCAD can not change/set >>>> the variables (set any(!) variable) during execution. >>>> But the 2d primitives are eaily written by your self. >>>> The 3D primitives are doable too, but a little harder. >>>> >>>> 2016-10-04 12:51 GMT+02:00 Mark Schafer <mschafer@wireframe.biz>: >>>> >>>>> also on thingiverse is an inkscape extension which exports vector >>>>> objects to openscad format directly: >>>>> - http://www.thingiverse.com/thing:1065500 >>>>> >>>>> Yes it would be nice if we could have lines as first class objects in >>>>> OpenSCAD but for now these tools might help you >>>>> >>>>> >>>>> >>>>> On 10/4/2016 1:25 PM, Ronaldo wrote: >>>>> >>>>>> Yes, there is but not with OpenSCAD language yet. A python code by >>>>>> Neon22 >>>>>> converts AMF files (possibly exported by OpenSCAD) to a text file in >>>>>> the >>>>>> OpenSCAD polyhedron format. See this discussion: >>>>>> http://forum.openscad.org/Wrapping-text-around-a-complex-geo >>>>>> metry-td18145.html#a18156 >>>>>> <http://forum.openscad.org/Wrapping-text-around-a-complex-ge >>>>>> ometry-td18145.html#a18156> >>>>>> >>>>>> >>>>>> >>>>>> -- >>>>>> View this message in context: http://forum.openscad.org/Conv >>>>>> ert-from-object-to-polygon-polyhedron-tp18522p18523.html >>>>>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>>> >>>>>> ----- >>>>>> No virus found in this message. >>>>>> Checked by AVG - www.avg.com >>>>>> Version: 2016.0.7797 / Virus Database: 4656/13139 - Release Date: >>>>>> 10/03/16 >>>>>> >>>>>> >>>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
O
otto
Thu, Oct 6, 2016 1:11 AM
I have written a library for my work with and for openscad that does
affine transforms.  I use it to generate a module that will rotate
about the line through any two points in space given the two points.  It
simplifies a number of operations if you can wrap your brain around
the affine transform.
Code and test examples are at:
https://github.com/ottojas/openscad-affine
I would appreciate any testing comments etc.
I just created the library and realized I havn't (yet) included the
license for you to do whatever you want with it.  I will do that now.
Thanks for any help
Otto
I have written a library for my work with and for openscad that does affine transforms. I use it to generate a module that will rotate about the line through any two points in space given the two points. It simplifies a number of operations if you can wrap your brain around the affine transform. Code and test examples are at: https://github.com/ottojas/openscad-affine I would appreciate any testing comments etc. I just created the library and realized I havn't (yet) included the license for you to do whatever you want with it. I will do that now. Thanks for any help Otto
