O
otto
Thu, Oct 6, 2016 1:41 AM
GPL license now with the code.
On Wed, 5 Oct 2016 18:11:39 -0700
otto otto@123phase.com wrote:
I have written a library for my work with and for openscad that does
affine transforms. I use it to generate a module that will rotate
about the line through any two points in space given the two points.
It simplifies a number of operations if you can wrap your brain around
the affine transform.
Code and test examples are at:
https://github.com/ottojas/openscad-affine
I would appreciate any testing comments etc.
I just created the library and realized I havn't (yet) included the
license for you to do whatever you want with it. I will do that now.
Thanks for any help
Otto
> Thanks for any help
> Otto
O
otto
Mon, Oct 10, 2016 8:53 AM
I have hacked the openscad source code to support function indirection.
Here is a sample of how it works. Function is decorated with the "@"
character when it is created and when it is used, but not when it is
passed to another function.
//Preferred usage//
function @xsq(x) = x*x;
function @recip(x)=1/x;
vec1=[1,2,3];
vec2=[.1,.7];
function map(func,vec) = [for (i=vec) @func(i)];
echo(map(xsq,vec1));
echo(map(xsq,vec2));
echo(map(recip,vec1));
echo(map(recip,vec2));
//Other crazy usage//
function div3(x)=x/3;
indirect = "div3";
echo(map(indirect,vec2));
Output is:
ECHO: [1, 4, 9]
ECHO: [0.01, 0.49]
ECHO: [1, 0.5, 0.333333]
ECHO: [10, 1.42857]
ECHO: [0.0333333, 0.233333]
Everything is contained in the github repositor:
There is a pdf file there with some sample 3D and 2D output. In order
to get this capability you need to add about 30 lines of code in
changes to five files in the source directory. These are relatively
stable files and you may get away with simply copying them from the
ojasSources directory.
This is very much a work in progress. Comments, questions, flames,
laughter, mockery etc. all welcome. If anyone tests this please let me
know what your experience is. Everything is gnu public license as is
the source code for openscad.
Regards
Otto
//Preferred usage//
vec1=[1,2,3];
vec2=[.1,.7];
indirect = "div3";
Output is:
ECHO: [1, 4, 9]
ECHO: [0.01, 0.49]
ECHO: [10, 1.42857]
Regards
Otto
Mon, Oct 10, 2016 9:06 AM
You don't seem to use the @ sign in the places I would expect. I don't see
a need for them in the function definition as any function should be
passable as an argument. I would expect them to be needed where a function
is called from a string, so:
function xsq(x) = x*x;
function recip(x)=1/x;
vec1=[1,2,3];
vec2=[.1,.7];
echo(map("xsq",vec1));
echo(map"("xsq",vec2));
echo(map("recip",vec1));
echo(map("recip",vec2));
The @ sign could also be used to make a function literal instead of passing
string but that is a bigger change to the language. Simply adding @ to take
a string and look up function seems like a simple mod. Creating a new
variable type that is a function would have much bigger implications
because it could be used in any expression. Keeping the name as a string
allows all sorts of tricks by concatenating suffixes, etc.
//Preferred usage//
vec1=[1,2,3];
vec2=[.1,.7];
indirect = "div3";
Output is:
ECHO: [1, 4, 9]
ECHO: [0.01, 0.49]
ECHO: [10, 1.42857]
Regards
Otto
vec1=[1,2,3];
vec2=[.1,.7];
> //Preferred usage//
> vec1=[1,2,3];
> vec2=[.1,.7];
> indirect = "div3";
> Output is:
> ECHO: [1, 4, 9]
> ECHO: [0.01, 0.49]
> ECHO: [10, 1.42857]
> Regards
> Otto
O
otto
Mon, Oct 10, 2016 9:19 AM
On Mon, 10 Oct 2016 10:06:50 +0100
nop head nop.head@gmail.com wrote:
The goal was to get what I wanted easily. The changes are small and
the code seems quite stable.
In declaring a function with the @ decoration.
As in function @xsq(x) = x*x
xsq is an ID token and the variable xsq is given a unique function name
as its contents. The name is a digit followed by a period. You can
see it by echoing xsq.
You can then pass xsq around and then dereference it with @. Because we
use openscads well designed and consistent parsing/compiling environment
to do all the work, this is fast. As designed I hadn't really
anticipated the side effect that any function can be passed as its token
name, and dereferenced later. The great thing about this is that the
compiler resolves functions by there string name and all I needed to do
was detect the decorator in the parser and then do one level of
indirection. The nice thing is it is safe, it doesn't break other code
and it requires only small changes to the source code and it works
now. Please test the code in the repository if you are inclined or
have the time.
Regards
Otto
don't see a need for them in the function definition as any function
should be passable as an argument. I would expect them to be needed
where a function is called from a string, so:
vec1=[1,2,3];
vec2=[.1,.7];
passing string but that is a bigger change to the language. Simply
adding @ to take a string and look up function seems like a simple
mod. Creating a new variable type that is a function would have much
bigger implications because it could be used in any expression.
Keeping the name as a string allows all sorts of tricks by
indirection.
"@" character when it is created and when it is used, but not when
it is passed to another function.
//Preferred usage//
vec1=[1,2,3];
vec2=[.1,.7];
indirect = "div3";
Output is:
ECHO: [1, 4, 9]
ECHO: [0.01, 0.49]
ECHO: [10, 1.42857]
order to get this capability you need to add about 30 lines of code
in changes to five files in the source directory. These are
relatively stable files and you may get away with simply copying
them from the ojasSources directory.
let me know what your experience is. Everything is gnu public
license as is the source code for openscad.
Regards
Otto
have the time.
Regards
Otto
> vec1=[1,2,3];
> vec2=[.1,.7];
> > indirection.
> > //Preferred usage//
> > vec1=[1,2,3];
> > vec2=[.1,.7];
> > indirect = "div3";
> > Output is:
> > ECHO: [1, 4, 9]
> > ECHO: [0.01, 0.49]
> > ECHO: [10, 1.42857]
> > Regards
> > Otto
Mon, Oct 10, 2016 9:44 AM
So @xsq becomes both a name mangled function and a variable holding its
name? That seems like a bit of a kludge to me.
Defining functions normally and passing them with @name would allow the
compiler to check it was a valid function name without having to have
specially decorated functions. They could be passed as string equal to
their name and then calling @func() could work with any string that equals
a function name. Seems less kludgey to me. You only have one type of
function rather than ones that have to be called normally and ones that
need to be called with @.
have the time.
Regards
Otto
vec1=[1,2,3];
vec2=[.1,.7];
indirection.
//Preferred usage//
vec1=[1,2,3];
vec2=[.1,.7];
indirect = "div3";
Output is:
ECHO: [1, 4, 9]
ECHO: [0.01, 0.49]
ECHO: [10, 1.42857]
Regards
Otto
> have the time.
> Regards
> Otto
> > vec1=[1,2,3];
> > vec2=[.1,.7];
> > > indirection.
> > > //Preferred usage//
> > > vec1=[1,2,3];
> > > vec2=[.1,.7];
> > > indirect = "div3";
> > > Output is:
> > > ECHO: [1, 4, 9]
> > > ECHO: [0.01, 0.49]
> > > ECHO: [10, 1.42857]
> > > Regards
> > > Otto
O
otto
Mon, Oct 10, 2016 5:13 PM
its name? That seems like a bit of a kludge to me.
Well its like this, you can pass a function with the name of the
function in quotes.
vec = [1,2,3];
echo(map("div3",vec));
And it works:
ECHO: [0.333333, 0.666667, 1]
Using the construct funcion @xyz .., gives you a way to create a
function and have the compiler generate a name for the function and put
it in a variable for you. "@" used in other contexts is simply a
dereferencing operator. It does require that the name following the
"@" is a variable name known by the compiler and not an expression
returning a string. "@concat("d","iv3")" will not work.
A syntax that would work nicely (but requires more hacking on my part)
would be to create true anonymous functions with syntax such as follows.
Abandon the "function @...",
shorten it to "@(<argument list>,<function,def>)"
Which returns the created name of the function. This would allow for
a more anonymous lambda like usage.
Map could then be invoked, map(@(x,x/3),[1,2,3]), which is more compact
and would get the right behavior.
Thanks for the questions and idea. You are helping me think it
through. Please try current code. I think I will try to program
this capability next week. I am going on a trip this week.
BTW what is best way to pass on this code in github.
Regards
Otto
the compiler to check it was a valid function name without having to
have specially decorated functions. They could be passed as string
equal to their name and then calling @func() could work with any
string that equals a function name. Seems less kludgey to me. You
only have one type of function rather than ones that have to be
called normally and ones that need to be called with @.
name as its contents. The name is a digit followed by a period.
You can see it by echoing xsq.
Because we use openscads well designed and consistent
parsing/compiling environment to do all the work, this is fast. As
designed I hadn't really anticipated the side effect that any
function can be passed as its token name, and dereferenced later.
The great thing about this is that the compiler resolves functions
by there string name and all I needed to do was detect the
decorator in the parser and then do one level of indirection. The
nice thing is it is safe, it doesn't break other code and it
requires only small changes to the source code and it works now.
Please test the code in the repository if you are inclined or have
the time.
Regards
Otto
function should be passable as an argument. I would expect them
to be needed where a function is called from a string, so:
vec1=[1,2,3];
vec2=[.1,.7];
of passing string but that is a bigger change to the language.
Simply adding @ to take a string and look up function seems like
a simple mod. Creating a new variable type that is a function
would have much bigger implications because it could be used in
any expression. Keeping the name as a string allows all sorts of
indirection.
the "@" character when it is created and when it is used, but
not when it is passed to another function.
//Preferred usage//
vec1=[1,2,3];
vec2=[.1,.7];
indirect = "div3";
Output is:
ECHO: [1, 4, 9]
ECHO: [0.01, 0.49]
ECHO: [10, 1.42857]
code in changes to five files in the source directory. These
are relatively stable files and you may get away with simply
copying them from the ojasSources directory.
flames, laughter, mockery etc. all welcome. If anyone tests
this please let me know what your experience is. Everything is
gnu public license as is the source code for openscad.
Regards
Otto
On Mon, 10 Oct 2016 10:44:13 +0100
function in quotes.
vec = [1,2,3];
And it works:
Regards
Otto
> > the time.
> > Regards
> > Otto
> > > vec1=[1,2,3];
> > > vec2=[.1,.7];
> > > > indirection.
> > > > //Preferred usage//
> > > > vec1=[1,2,3];
> > > > vec2=[.1,.7];
> > > > indirect = "div3";
> > > > Output is:
> > > > ECHO: [1, 4, 9]
> > > > ECHO: [0.01, 0.49]
> > > > ECHO: [10, 1.42857]
> > > > Regards
> > > > Otto
B
Bananapeel
Mon, Oct 10, 2016 7:15 PM
I don't know why this thread is inside the thread "Convert from object to
polygon/polyhedron." Anyways, regarding passing functions as arguments:
IMO, there's just one "proper" syntax for this. And that is, that the name
without () acts as a variable, and () means call. And function becomes just
another type, like string and int. This means functions and variables must
occupy the same namespace. This syntax can also work for modules, however,
this means variables, functions and modules all share the same namespace,
which currently isn't the case.
Using () on a variable that isn't of type function or module would give a
runtime error.
Example:
//Preferred usage//
vec1=[1, 2, 3];
vec2=[0.1, 0.7];
function map(func,vec) = [for (i=vec) func(i)];
indirect = div3;
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18659.html
runtime error.
Example:
//Preferred usage//
vec1=[1, 2, 3];
vec2=[0.1, 0.7];
indirect = div3;
adrian
Mon, Oct 10, 2016 8:50 PM
Yes, I feel that my thread got hijacked somehow.
just another type, like string and int. This means functions and variables
must occupy the same namespace. This syntax can also work for modules,
however, this means variables, functions and modules all share the same
namespace, which currently isn't the case.
runtime error.
Yes, this sounds somewhat reasonable, but these namespaces don't have to
collide. They can still be (and really should remain) separate, as changing
this could break a lot of scripts. One can gain access to the function
namespace using that @ sign (or some other sign. I assume that & wasn't
used for simplicity):
It would also be nice to have proper lambdas:
This syntax would introduce being able to create true lambdas on the fly,
instead of always having to name them and access the function namespace.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18662.html
> runtime error.
O
otto
Mon, Oct 10, 2016 9:15 PM
Let me summarize current situation:
The following work in my current code:
box = "recip";
vec1=[1, 2, 3];
map(box,vec);
map(xsq,vec);
Objections have been:
- First version using "function @xsq(x)" seems kludgy.
- One suggestion was the following syntax:
vec1=[1, 2, 3];
which seems intuitive.
3. (my own objections) None of these allow for lambda like syntax.
I have a particular problem with my own current code and all
suggestions. They fail to implement lambda. Suggestion 2 is
essentially the same way that python deals with indirection, Python
provides two methods of creating a function. One method uses a def
statement and the other uses the Lambda construct. They are equivalent
and dereferencing is automatic.
I believe I can get the lambda behavior relatively easily in the current
system. To add lambda syntax I will implement it as:
@(<argumentlist>:<functionDefintion>)
which I think is easier to read than (from python):
lambda <argumentlist>:<functionDefintion>
Either implementation is possible and if enough people request one over
the other, I am willing to implement either. The first is much simpler
to add for me with my current shallow knowledge of how the code works
and really requires very small changes.
The following would then work:
vec1=[1, 2, 3];
recip = @(x:1/x);
map(recip,vec); //this would work as before
map(@(x,x*x),vec); //this would be using @ as lambda.
I actually believe that the dereferencing of a variable name using "@"
makes the code clearer and easier to maintain and we lose nothing in
terms of capabilities.
If anyone wants to hack the code themselves to obtain any behavior, I
am happy to help point out where in the code changes can be made.
Currently there are only about 30 lines of code that have been added. In
addition, there are some problems currently in my code that could use
some work. I will post these in openscad-affine when I have time.
Collaboration on this is desirable. Incidentally I need these changes
for my work. The modules in paraSolids are essential for me and need
the function indirection capabilities to work.
For examples of pretty picture please see: ParaSolidExamples.pdf
which is among the files at https://github.com/ottojas/openscad-affine
The repo needs some re-arrangement but I think everything is there..
Thoughts?
I would really like it if someone would test the code I have written.
I am almost exclusively on debian based linux systems. Debian, Ubuntu
and mint. I would be happy to build a binary for one of these if that
is what someone willing to test would like. I am definitely going to
implement the second syntax when i have time (next week at earliest),
that is the "@(<argument list>:<function definition>)" syntax for an
anonymous function.
If requested, I will fork the complete source code setup so you can
compile on any system. Is that a good idea??
Regards
Otto
On Mon, 10 Oct 2016 12:15:31 -0700 (MST)
object to polygon/polyhedron." Anyways, regarding passing functions
as arguments:
name without () acts as a variable, and () means call. And function
becomes just another type, like string and int. This means functions
and variables must occupy the same namespace. This syntax can also
work for modules, however, this means variables, functions and
modules all share the same namespace, which currently isn't the case.
give a runtime error.
Example:
//Preferred usage//
vec1=[1, 2, 3];
vec2=[0.1, 0.7];
indirect = div3;
box = "recip";
vec1=[1, 2, 3];
map(box,vec);
map(xsq,vec);
1. First version using "function @xsq(x)" seems kludgy.
2. One suggestion was the following syntax:
> vec1=[1, 2, 3];
vec1=[1, 2, 3];
recip = @(x:1/x);
Thoughts?
anonymous function.
Regards
Otto
> as arguments:
> Example:
> //Preferred usage//
> vec1=[1, 2, 3];
> vec2=[0.1, 0.7];
> indirect = div3;
Mon, Oct 10, 2016 9:23 PM
request one over the other, I am willing to implement
either. The first is much simpler to add for me with
my current shallow knowledge of how the code works and
Did you see the work Doug did?
https://github.com/doug-moen/openscad2
It's proposing a way to a more powerful language while still
trying to be as compatible as possible.
It would be ideal if we could get the feature aligned with
those efforts. I think it would be a nice thing to get for
current OpenSCAD already.
