Sun, Oct 25, 2020 5:40 AM
Why can't you see my script? It was in my email reply to the group.
You can also see it in the forum here:
http://forum.openscad.org/Another-missing-feature-All-I-want-for-Xmas-tp30314p30351.html
You can use $vpd with scale() to set the size of the text as I did in my
example.
You have to enter the window size in pixels at the start of my screen,
copied from the GUI status line. I attempt to relate them to the camera
with $vpf but my calculation is not quite right.
On Sun, 25 Oct 2020 at 02:35, Caddiy mikeonenine@web.de wrote:
/but isn't quite right in determining the precise offset needed depending
on
the screen width and height in pixels. It does get it the right size and
orientation and roughly in the bottom right. You can see in the picture I
posted it says Hell instead of Hello./
I cannot assess your script, I haven't got that far. But are you sure the
values of $vp* are in any way related to the number of pixels on your
computer monitor? It doesn't strike me as a particularly promising
approach.
Is there a way to apply $vpd to a single object as can be done with $vpr&t,
as opposed to the whole scene?
example.
> on
> approach.
Sun, Oct 25, 2020 6:05 AM
This is a more correct version but it always looks like the text is center
justified but it isn't. Not sure what I got wrong.
window = [776, 362]; // Copied from the bottom of the GUI
sphere(20);
translate($vpt)
rotate($vpr)
scale($vpd / window.y)
translate([window.x, -window.y] / 2 * tan($vpf))
linear_extrude(0.001)
text("hello", valign = "baseline", halign = "right");
example.
on
approach.
$vpr&t,
sphere(20);
translate($vpt)
rotate($vpr)
> example.
>> on
>> approach.
>> $vpr&t,
D
dpa
Sun, Oct 25, 2020 9:41 AM
I don't know if it's the case here, but I'll take Nop's question as an
opportunity to point out that I actually noticed that I don't receive all
the posts as email! It seems to be random.
So if you really want to be sure that you can read all the posts you have
to go to http://forum.openscad.org/!
Strange but is like this
Am So., 25. Okt. 2020 um 06:41 Uhr schrieb nop head <nop.head@gmail.com>:
Sun, Oct 25, 2020 10:20 AM
OK this is a version that works.
window = [737, 888]; // Copied from the bottom of the GUI
sphere(20);
translate($vpt)
rotate($vpr)
translate([$vpd * window.x / window.y, -$vpd] * tan($vpf / 2))
sphere(20);
translate($vpt)
rotate($vpr)
example.
depending on
approach.
$vpr&t,
sphere(20);
translate($vpt)
rotate($vpr)
> sphere(20);
> translate($vpt)
> rotate($vpr)
>> example.
>>> depending on
>>> approach.
>>> $vpr&t,
Sun, Oct 25, 2020 10:29 AM
Slightly more concise:
sphere(20);
translate($vpt)
rotate($vpr)
translate([window.x / window.y, -1] * $vpd * tan($vpf / 2))
The window pixel dimensions are needed for two reasons. 1) to get the
correct x offset that depends on the aspect ratio and 2) to scale the text
if you don't want its size to change when the window is resized. So we need
yet another $ variable, $vpw to be the window size in pixels.
sphere(20);
translate($vpt)
rotate($vpr)
center justified but it isn't. Not sure what I got wrong.
sphere(20);
translate($vpt)
rotate($vpr)
example.
depending on
I
approach.
$vpr&t,
sphere(20);
translate($vpt)
rotate($vpr)
> sphere(20);
> translate($vpt)
> rotate($vpr)
>> sphere(20);
>> translate($vpt)
>> rotate($vpr)
>>> example.
>>>> depending on
>>>> I
>>>> the
>>>> approach.
>>>> $vpr&t,
Sun, Oct 25, 2020 12:34 PM
It was "I cannot assess your script, I haven't got that far."
I believe that is not Access, but comprehend.
Some internet providers are less friendly to mailing-lists.
You can also get a Digest semi-daily too, which should have all the posts.
See http://lists.openscad.org/mailman/options/discuss_lists.openscad.org
- on the Forum, click on my MichaelAtOz label, there is a link to email me.
* on the Forum, click on my MichaelAtOz label, there is a link to email me.
C
Caddiy
Sun, Oct 25, 2020 6:20 PM
That is correct. Thank you. A lot of the stuff here is over my head.
But it was originally from Nophead, not dpa.
C
Caddiy
Sun, Oct 25, 2020 6:27 PM
The above reply was to Michael@Oz, but for some reason it shows dpa instead.
Sun, Oct 25, 2020 6:30 PM
Does the latest code I posted work for you?
> instead.
C
Caddiy
Sun, Oct 25, 2020 6:33 PM
Slightly more concise...
Looks interesting. Will try it out.
