BL
Bryan Lee
Fri, Aug 26, 2022 7:17 AM
I am trying to make a topographic model.
(Think one of those things that shows how high the mountains are.)
My model needs to show the peaks and the valleys.
I have vector curves that represent elevations. (I hand traced these from an old map.)
I can import these as a grey-scale PNG of elevations, or as multiple SVGs
that create 2D polygons and extrude them.
However, I want the sides to be sloped, like a real mountain. NOT have
vertical sides like extrusions.
If this were just a single convex mountain, I could do a hull() around the
multiple elevation levels.
But hull() will create a "flat" area between mountain peeks, and it will
not show the valleys.
Does anyone have suggestions for an algorithm that will work similar to
hull(), but that will curve the surface into concave areas?
Michael Möller
Fri, Aug 26, 2022 7:38 AM
And the surface() doesn't work, because ...?
Michael, fra mobilen
fre. 26. aug. 2022 09.19 skrev Bryan Lee leebc11@acm.org:
an old map.)
fre. 26. aug. 2022 09.19 skrev Bryan Lee <leebc11@acm.org>:
> an old map.)
W
Whosawhatsis
Fri, Aug 26, 2022 9:00 AM
Off the top of my head, what if you break up your map into a grid of squares, and do a convex hull for all of the contour layers in each square? The size of the squares would determine the smallest concave feature you can have.
You might implement this by extruding each contour to its appropriate elevation and unioning those. Then you could loop over X and Y coordinates creating a grid of tall cubes. Intersect your unioned extruded contours with each cube, hull the result, then union them all back together.
Alternatively, you could try doing the intersection with squares in 2D before extruding. I imagine that method would result in a bit more code, but could be substantially faster to run.
BL
Bryan Lee
Fri, Aug 26, 2022 10:17 AM
Surface() does exactly what I need!
Not sure I've used it, so I'd forgotten.
Thank you Michael Möller!
Thus Michael Möller hast written on Fri, Aug 26, 2022 at 09:38:40AM +0200, and, according to prophecy, it shall come to pass that:
an old map.)
> an old map.)
Fri, Aug 26, 2022 10:34 AM
I've seen software (other than openscad) that does that,and iirc i used
some to produce g-code for machining relief maps, but i can't remember
much about it.
If you search the internet, for 'converting a stack of polygons into a
polyhedron' or 'generating an stl file from a stack of polyhedrons' or
similar, you will find a number of solutions, which may be helpful e.g.
https://stackoverflow.com/questions/60066405/create-a-stl-file-from-a-collection-of-points
If you want to keep it all within openscad, then maybe easiest to get
the contour points on a grid, size depending on the precision you want,
then plot thin cubes between them, or something. I think 'surface' needs
a grid.
A rough and ready look at it, depending on the resolution of your
points, would be to plot a sphere at each point location.
Or convert your polygons to a point cloud (you've got the x,y,z points,
just needs formatting I guess,) and Meshlab will produce an stl from a
point cloud.
Best of luck,
Ray
much about it.
a grid.
point cloud.
Best of luck,
Ray
AC
A. Craig West
Fri, Aug 26, 2022 1:20 PM
I've written code that turns a stack of polygons into a polyhedron, but it
requires all of the polygons to have the same number of points
much about it.
a grid.
point cloud.
Best of luck,
Ray
> much about it.
> a grid.
> point cloud.
> Best of luck,
> Ray
> from an old map.)
> the
Fri, Aug 26, 2022 8:31 PM
I've written code that takes a stack of polygons and produces a polyhedron
with no restriction on the vertex counts of the polyhedra. But getting
good results can be pretty slow if you have a lot of vertices. I also
envisioned the problem as featuring multiple disconnected elevation lines,
so one polygon might need to connect to two polygons at some point, which
my code won't do.
For the curious, the code I'm talking about is the BOSL2 skin() module:
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-skin
much about it.
a grid.
point cloud.
Best of luck,
Ray
my code won't do.
>> much about it.
>> a grid.
>> point cloud.
>> Best of luck,
>> Ray
>> from an old map.)
>> SVGs
>> the
Sat, Aug 27, 2022 12:14 AM
I wrote a concave hull function sometime back in openscad, but it's not
even close to perfect.
I remember reading few articles.
Will check and forward to you in case you can use them to write a good
algorithm.
Concave hull has a lot of application in case it could be done
an old map.)
algorithm.
> an old map.)
Sat, Aug 27, 2022 1:26 AM
With the ignorance of one who had never tried it, I was thinking that
this "triangularize a contour map" problem couldn't be too hard.
But then I realized that it was even less obvious than I thought how to
connect two adjacent contour lines. Simple concentric mountains seem
straightforward enough. However, two peaks can make for cases that I
don't even know how to start on.
1111111111111111111111111111111111111
1 1
1 2222222 22222222 1
1 2 2 2 2 1
1 1
I keep thinking about doing something with USGS 3D Elevation Program
files. They are even already conveniently in grayscale image format.
Unfortunately, they are also, shall we say, kind of big. The 1x1 degree
tile for my area in Southern California is 437M, a 10Kx10K pixel image.
(Each pixel is about 10 meters.) I tried a couple of general-purpose
image editor/viewers, and they couldn't handle it. Maybe ImageMagick,
but I'll have to read up on how to do it. GIMP came closet, loading it
but then for some reason showing everything but water as 100% white.
The JPEG is a reasonable size, but is too low-resolution for the kind of
model I want to make:
https://prd-tnm.s3.amazonaws.com/StagedProducts/Elevation/13/TIFF/current/n35w119/USGS_13_n35w119.jpg
Here's the full directory:
https://prd-tnm.s3.amazonaws.com/index.html?prefix=StagedProducts/Elevation/13/TIFF/current/
Note that the directory names are latitude/longitude, but unobviously
they refer to the high end of the range so n35w119 refers to latitude
34.000-34.999 and longitude 118.000-118.999.
Unfortunately, as you might guess from the name, it seems that the USGS
only stocks data for the US. (Which doesn't make any sense, since I'm
sure it's derived from satellites and they fly over most or all of the
world.)
1 1
1 2 2 2 2 1
1 1
world.)
Sat, Aug 27, 2022 3:20 AM
This maybe a good read
an old map.)
> an old map.)
