B
buttim
Tue, Feb 14, 2017 1:08 AM
For completeness I tried a 64 bits build only to hit a wall of errors in
GeometryEvaluator.cc.
I might have screwed up something though: it's 2AM here and I definitely
need some rest!
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20424.html
need some rest!
B
buttim
Sat, Feb 18, 2017 12:10 AM
...stuck
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20469.html
...stuck
B
buttim
Fri, Mar 3, 2017 10:46 PM
Since there is absolutely no way to cross compile for Windows, at least on my
PC, I turned to compiling for Ubuntu. After a few corrections I managed to
get the editor enhancements back in the current source base.
Is it worth to extract a patch file and post it here or is my experiment
doomed to fall in limbo again (so better have some TV instead)?
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20716.html
Fri, Mar 3, 2017 11:14 PM
my experiment doomed to fall in limbo again (so better have
some TV instead)?
Could you put your change into a pull-request on github?
That would make it much easier to check it out on the different
platforms.
> some TV instead)?
platforms.
B
buttim
Fri, Mar 3, 2017 11:35 PM
Sure. Since I'm a newbee can you just outline the correct sequence of
actions? Should I create a new branch or something? I'll be glad to document
on the details, I just need a broad idea.
Thanks
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20718.html
Thanks
Fri, Mar 3, 2017 11:50 PM
of actions? Should I create a new branch or something? I'll be glad
to document on the details, I just need a broad idea.
The help entry point on github for this would be
https://help.github.com/articles/fork-a-repo/
I think it's basically (using only command line).
get github account if you don't have one already
(optional, I think) upload ssh-key to github account
clone/fork the openscad repository into your account
git clone git@github.com:<your-account>/openscad.git
cd openscad
git checkout editor-enhancements master
patch ...
git status # to see what's new and changed
git add <new / changed files>
git commit # add short description of the change
git push # might output a warning, in that case use the command suggested
- now the branch should show up on your account in your
openscad repo copy and github should show the option
to create a pull request
- get github account if you don't have one already
- (optional, I think) upload ssh-key to github account
- clone/fork the openscad repository into your account
cd openscad
patch ...
Sat, Mar 4, 2017 2:47 AM
my PC,
Not sure what you mean by this. Do you mean you can't make a Windows build
on a non-Windows machine, which is what that literally means. Or do you
have a Windows machine and can't build OpenScad for it?
I am building OpenScad on Win7 using the instructions here:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows.
The resulting .exe runs on Windows via the MSYS2 shell but I can't get it
to run directly from Windows. So I am not sure if it is a real Window's
build or not. Is it a Linux build built on Windows using a Linux emulator?
If it builds on Windows using a Linux emulator does that count as a cross
compiling? It is after all a .exe. Totally confused!
cd openscad
patch ...
my PC,
> cd openscad
> patch ...
> ciao,
> Torsten.
Sat, Mar 4, 2017 4:37 AM
This was related to https://github.com/openscad/openscad/issues/1964
The official Windows build of OpenSCAD is currently built on a Linux server using MXE (http://mxe.cc/), which is capable of cross-compiling Windows binaries from a non-Windows environment. The reason for this is is mostly that we don’t have any core developers who use Windows as their primary platform so we’re lacking some of the expertise needed to maintain a stable native build. MXE has proven to be work pretty well as all the build systems for all dependencies are maintained somewhere else.
> On Mar 3, 2017, at 21:47, nop head <nop.head@gmail.com> wrote:
> […] Totally confused!
Sat, Mar 4, 2017 11:42 AM
The MSYS2 build I am using seems to think it is cross compiling on Linux
but it actually running in Cygwin. So does that class as cross compiling
or is it a native build?
The resulting .exe needs some dlls, so it is not statically linked like the
official Windows build.
> -Marius
Sat, Mar 4, 2017 5:28 PM
On Mar 4, 2017, at 06:42, nop head nop.head@gmail.com wrote:
The MSYS2 build I am using seems to think it is cross compiling on Linux but it actually running in Cygwin. So does that class as cross compiling or is it a native build?
The MSYS2 build just uses mingw, so it’s not cross compiling.
Perhaps some of the “think it is cross compiling” is actually testing for gcc/glibc/posix vs. Microsoft’s compilers/libraries. Lots of opportunities for cleanup there : /
