If there is a known path to compile OpenSCAD to run under Cygwin, I would be
very interested. More specifically, I mean compiled and linked with the
cygwin1.dll using the X11 and POSIX file i/o.
Why? because it is much easier to do build scripting under Unix-like
environments. I currently make use of the cross-compiled Windows binary, but
it is not deal with file permission very robustly.
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20750.html
I don’t know if anyone has attempted that. Most people wanting smth. like this tend to simply just do it under Linux :)
At some point a user will want a system-level design approach and suitable
design flow. Although I prefer Unix-based platforms for development, I have
no issue with others who, for whatever reason, are using a Windows-based
platform. Cygwin allows those users to leverage the mature tool chains of
Unix-based platforms. It sounds like a good fit to me...
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20761.html
Does anybody know how to make the .exe built under Cygwin statically link
like the official Windows binary? It seems odd to me that the MSYS2 version
doesn't build the same result as the cross compiled version. Is it because
the MSYS2 packages are dynamically linked?
have
link like the official Windows binary? It seems odd to me that the
MSYS2 version doesn't build the same result as the cross compiled
version. Is it because the MSYS2 packages are dynamically linked?
MSYS2 pretty much replicates a Unix shell environment so the build
mostly does similar setup as on a Linux system and uses the dynamic
libraries provided by the "Distribution" (= MSYS2).
All that minus some glitches in the OpenSCAD build system caused
by the overlap of both MXE and MSYS2 using MinGW.
Don put a lot of effort into the MXE setup which can support
compiling static libraries when selected. This works as MXE
is more a build environment and not a binary distribution of
applications to run.
I am building OpenScad on Win7 using the instructions here:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows.
The resulting .exe runs on Windows via the MSYS2 shell but I
can't get it to run directly from Windows. So I am not sure
if it is a real Window's build or not.
That's probably due to all the internal path references and such
stuff. Otherwise MinGW should generate a native binary without
any references to a runtime Unix environment like cygwin.
I'm not sure there's a simple way to package the MinGW binary
to run fully standalone.
Really glad to see so many people interested by this issue. Anybody
volunteering to check if he/she finds the same problems while cross
compiling?
Il 05/mar/2017 11:29, "tp3 [via OpenSCAD]" <
[hidden email] http:///user/SendEmail.jtp?type=node&node=20763&i=0
-- Torsten
below:
http://forum.openscad.org/Windows-cross-compilation-tp20413p20763.html
To unsubscribe from Windows cross compilation, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=20413&code=bWF1cml6aW8uYnV0dGlAZ21haWwuY29tfDIwNDEzfDE4OTg0NTUyNTk=
NAML
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20764.html
MSYS2 provides all that without the extra runtime emulation layer.
I don't see how that matters much to the user. The only benefit
seems to be at development time as it might be possible to take
Unix code and compile without specific Windows support where MinGW
needs some kind of Windows support in the application itself.
have
The system-level design referred to is regarding using OpenSCAD, not
compiling it... IE: now that one has an OpenSCAD executable how to use it as
a tool in a design flow on collections of *.scad design files.
...not complaining about the existing windows compilation solution... and
kudos to any and all who contributed to that effort! Just checking if anyone
had worked on a Cygwin compile as it sounded like someone had.
Cheers,
Roy
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20767.html
version
I am no Cygwin expert, but from what I understand, it is not possible
https://cygwin.com/faq/faq.html#faq.programming.static-linking to do so.
It appears to be an intentional limitation by design.
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20768.html
not compiling it... IE: now that one has an OpenSCAD executable
how to use it as a tool in a design flow on collections of *.scad
design files.
That was my point about. I don't see how it matters to the user
which libraries or compilation environments the OpenSCAD binary
was compiled from.
I'm not aware of any Cygwin work being done, and actually I don't
see much reason for this. It's likely to be a huge effort and
will also require someone who is really committed to also maintain
it in the future.
It might be easier trying to compile and package the MSYS2 binary
so it can run without MSYS2 installed (if that's possible, but I
think it should be).
What might be useful and was worked on by different people in the
past is a Visual Studio based build. That's also not a simple task,
mainly due to the libraries that need to be build and setup.
It's basically a chicken and egg issue.
The MSYS2 build is mainly a workaround to at least be able to
provide a solution for someone who wants to build directly on
Windows.
