I'm having a hard time trying to cross compile OpenSCAD under Ubuntu for
Windows.
I did manage tio get executables in june, but recently I get the following
error:
../src/LibraryInfo.cc:27:17: fatal error: zip.h: No such file or directory
Any good soul with an advice for me?
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413.html
for Windows.
Is that cross compiling using MXE (like the official binaries are
compiled)?
error:
This means it did detect libzip for some reason and set ENABLE_LIBZIP
but either the include path is wrong or it's not installed.
There is currently an build issue where the MXE build does not find
libzip, but that should just disable compression support, not fail
to build.
Actually I did run the cross build for master yesterday on our build
machine and that did run though.
You nailed it. Disabling zip in openscad.pro by commenting away the line
CONFIG += libzip
the compilation goes on (not finished yet but seems promising anyway).
Maybe a bug in the detection logic for zip support.
Worth opening a bug report?
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20415.html
Hmm, can you find out why it thinks it's there? As I didn't
have this so far, it will be hard to fix without additional
information.
Unless it will go away when fixing the other issue I mentioned,
but that does not seem too likely.
Maybe it's detecting the header installed on Linux instead of
just looking in the cross compilation env?
I swear I have no idea of how the different build tools work but, yes, I will
definitely give it a try. At worse I will be of no help but will learn
something (something I should have learned quite a time ago).
In the meantime another problem showed up. As I said compilation was going
at full speed. So this time is the linker complaining:
/usr/bin/ld: unrecognized option '--stack'
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20417.html
Now that sounds like it's running the wrong linker.
So back to the first question, how exactly are you doing the
cross compilation. It might case some mix-up of system native
and cross compilation.
The build server uses essentially:
export MXEDIR=/opt/mxe
. ./scripts/setenv-mingw-xbuild.sh 64
./scripts/release-common.sh -snapshot mingw64
Which does expect full MXE environment in /opt/mxe
I'm using the scripts provided:
source scripts/setenv-mingw-xbuild.sh
scripts mingw-x-build-dependencies.sh
and then running qmake and make (the way I did a few months ago)
cd mingw32.static
qmake ../openscad.pro CONFIG+=mingw-cross-env
make
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20419.html
For the firs issue regarding libzip I suspect the MXE builder script simply
does not specify the libzip package.
I modified it adding libzip in 4 places and now it's downlaoding libzip and
compiling it.
This actually solves the problem but creates a new one (oh my!)
../src/import_amf.cc:330:66: error: cannot convert 'const value_type* {aka
const wchar_t*}' to 'const char*' for argument '2' to 'zip_file*
zip_fopen(zip*, const char*, zip_flags_t)'
zipfile = zip_fopen(archive, f.filename().c_str(), ZIP_FL_NODIR);
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20420.html
cd mingw32.static
make
I'm not sure what's going on then, the scripts should set
up the environment to the cross compilation stuff. For some
reason you are still getting the wrong linker as the error
shows. I think it is supposed to run the mingw one which is
<MXE>/usr/bin/x86_64-w64-mingw32.static-ld
Can you trace all the command line output (maybe running
qmake with -d to make it verbose) into some file and put
that to pastebin or something? Maybe this gives some clue
what's going wrong.
qmakelog.zip http://forum.openscad.org/file/n20423/qmakelog.zip
the qmake output exceeded 512kB, so I could not upload it to pastebin
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20423.html
