Johan Jonker wrote
Any idea for another way to draw this?
Well, have a look at the sweep renderer shown in
http://www.thingiverse.com/thing:900137
Instead of feeding in a NACA profile, you'd just create a circle (or any
other 2D-shape). Building on the scheme shown in example2() the code is as
fast as it can get in OpenSCAD (especially for CGAL)
You also might be interested to use an interpolation scheme, which makes the
path calculation for your thing very convenient
http://forum.openscad.org/general-extrusion-imperfect-tp14740p14758.html
respectively
I've ported the nSpline library, but yet did'nt have time to connect it with
my sweep renderer in OpenSCAD and to publish it.
Rudolf
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15008.html
I changed the delta into a variable one:
/module calyx(buiten)
delta = 2;
delta2 = delta/2;
delta3 = delta2/2;
delta4 = delta3/2;
for (height = [0:delta:maxheight-4delta])
calyx_segment(height, delta, buiten);
for (height = [maxheight-4delta:delta2:maxheight-4delta2])
calyx_segment(height, delta2, buiten);
for (height = [maxheight-4delta2:delta3:maxheight-4delta3])
calyx_segment(height, delta3, buiten);
for (height = [maxheight-4delta3:delta4:maxheight-delta4])
calyx_segment(height, delta4, buiten);
And also corrected the culculations for the thickness. It is a dy/dx of a
power to 4: (y = B -x^4*A)
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15016.html
@ parkinbot: Interesting this sweep function. And it is indeed fast.
But it's a little to complicate for a beginner like me to implement now.
@neon22. The delta error is corrected nog. This is the result at this
moment.
Rendering the inside and the outside with $fn= 100 took about 20 minutes.
http://forum.openscad.org/file/n15019/kelk.jpg
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15019.html
very beautiful
moment.
Checked by AVG - www.avg.com
Version: 2016.0.7227 / Virus Database: 4477/11133 - Release Date: 12/07/15
For anyone who likes the end result.
I generate the file twice and then substract them in an other scad file.
It is also in this file but takes too long to render (even F5).
// object: bass clarinet bell
// version: 4
// design: J.G.Jonker
// website: sax.jonker.co
// date: 7-12-2015
$fn=100;
maxheight = 150;
d_btm_inside = 41;
d_btm_wall =17.5;
d_top_inside = 138;
d_top_wall = 4;
t_top = 60;
rotatie_top = 45;
mildfactor = 0.5;
h_tenon = 5;
astraal = maxheight/sin(rotatie_top);
// translate([0,0,-150]) calyx(buiten=true);
translate([0,0,-150]) calyx(buiten=false);
delta = 2;
delta2 = delta/2;
delta3 = delta2/2;
delta4 = delta3/2;
calyx_segment(height, delta, buiten,0);
for (height = [maxheight-7delta2:delta2:maxheight-4delta2])
calyx_segment(height, delta2, buiten,0);
for (height = [maxheight-7delta3:delta3:maxheight-4delta3])
calyx_segment(height, delta3, buiten,0);
for (height = [maxheight-7delta4:delta4:maxheight-2*delta4])
calyx_segment(height, delta4, buiten,0);
for (height = [maxheight-delta4:delta4:maxheight-delta4])
calyx_segment(height, delta4, buiten,d_top_wall);
module calyx_segment(height,delta,buiten,top)
percentage = height/maxheight;
percentage2 = (height+delta)/maxheight;
d_inside = d_top_inside
- pow((1-percentage),0.25)* (d_top_inside -
d_btm_inside);
d_inside2 = d_top_inside
- pow((1-percentage2),0.25)* (d_top_inside -
d_btm_inside);
rc = atan(4maxheightpow((d_top_inside -
d_btm_inside),-4)* pow(d_top_inside - d_inside,3));
rc2 = atan(4maxheightpow((d_top_inside -
d_btm_inside),-4)* pow(d_top_inside-d_inside2,3));
// determine de wall thickness
// keep the outside straight until d_top_wall is reached
d_wall = (d_inside + d_top_wall) < (d_btm_inside+d_btm_wall) ?
(d_btm_inside+d_btm_wall - d_inside):
d_top_wall;
d_wall2 = (d_inside2 + d_top_wall) < (d_btm_inside+d_btm_wall) ?
(d_btm_inside+d_btm_wall - d_inside2):
d_top_wall;
dx_raw = (d_inside2-d_inside)/2;
s_raw = sqrt(dx_raw*dx_raw+delta*delta);
dx1 = d_wall * sin(rc);
dx2 = d_wall * sin(rc2);
dy1 = d_wall * cos(rc);
dy2 = d_wall * cos(rc2);
//echo("delta's", rc,rc2,dx1,dx2,dy1,dy2);
//echo("y x", d_inside, d_inside2, height, height+delta);
//echo("hoek", hoek, hoek2);
hoek = rotatie_top*percentage;
hoek2 = rotatie_top*percentage2;
if (buiten == true)
cylinder_pie(hoek, hoek2,
-astraal*(1-cos(hoek*percentage))*mildfactor,
-astraal*(1-cos(hoek2*percentage2))*mildfactor,
height-dy1,
height+delta-dy2,d_inside/2+dx1,d_inside2/2+dx2,top,0);
else
-astraal*(1-cos(hoekpercentage))mildfactor,
-astraal(1-cos(hoek2percentage2))*mildfactor,
height, height+delta,d_inside/2,d_inside2/2,top,4);
module cylinder_pie(angle1, angle2, dx1,dx2,dy1,dy2,r1,r2,top,dr)
// draw top and bottom cylinders
// rotate the cylinder
// hull the cylinders
// trick: draw an extra thick and large cylinder when the top is
reached and
d=0.01;
//echo("top", top,dr);
hull()
translate([ 0,dx1,dy1])
rotate( angle1, ([1,0,0]))
translate([0,0,-d])
cylinder(d,r1, r1, center=false);
translate([ 0,dx2,dy2])
rotate( angle2, ([1,0,0]))
translate([0,0,d])
cylinder(d+top,r2, r2, center=false);
if (top > 0)
translate([0,0,d])
cylinder(d+top,r2+dr, r2+dr, center=false);
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15025.html
With the code as-is I get a nice horn shape.
E.g. set $fn to 12 on first line for faster results.
But I get a bad object if I change "buiten=true" over in the difference loop
and get the other surface.
I.e.
// translate([0,0,-150]) calyx(buiten=false);
The nice bell shape is gone. I've tracked it to the first region in calcyx:
for (height = [0:delta:maxheight-4*delta])
http://forum.openscad.org/file/n15026/bell-2.png
But I can't see the bug.
(For me, at low $fn the difference goes pretty fast, and only 20 sec for
$fn=100.
but the resulting object is super slow in camera due to large number of
surfaces.
The Render() takes a very long time (48sec for $fn=12) even for single
surface.)
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15026.html
This will fix the bug:
d_wall = ((d_inside + d_top_wall) < (d_btm_inside+d_btm_wall) ?
d_top_wall)/2;
d_wall2 = ((d_inside2 + d_top_wall) < (d_btm_inside+d_btm_wall)
d_top_wall)/2;
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15028.html
Found it - it was this:
dx2 = d_wall2 * sin(rc2);
dy2 = d_wall2 * cos(rc2);
They were d_wall and not d_wall2
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15029.html
Yes are very right, that was also wrong.
Another thing is that I see small white dots in the object. I thougth that
everything is done to make it watertight. Also when I import all SLT files
sometime a large hole appears in the object depending on the angle that the
object is viewed. Is it in bug in OpenScad or in my design?
http://forum.openscad.org/file/n15037/waterdicht.jpg
http://forum.openscad.org/file/n15037/waterdicht2.jpg
View this message in context: http://forum.openscad.org/Tips-to-keep-the-speed-acceptable-tp14952p15037.html
Have you set the convexity parameter to import?
