F5 works, but F6 gives: ERROR: CGAL error in CGAL_Nef_polyhedron3():
arnholm@arnholm.org
Thu, Jan 18, 2018 12:25 PM
On 2018-01-18 10:29, Parkinbot wrote:
cacb wrote
Perhaps one could also say that a polyhedron with fewer than 4 faces
is
always an error, perhaps with the exception of zero faces in the case
of
using it within hull()?
I am heavily using this feature
  • to preview 2D-polygons placed in 3D space,
  • to see, what sweep() will do with my code
  • to check for selfintersections
Indeed I even don't see much sense in restricting STL output to
"proper"
manifolds. Is it part of the format specification?
My comment was not referring to STL or other output formats, only the
internal OpenSCAD definition of polyhedron. Ref. the OpenSCAD
documentation of polyhedron I lniked to. Either the documentation should
be changed to reflect the software, or the documented rule requiring
planar faces should be enforced.
OpenSCAD should tell the user when it receives clearly illegal input
according to documentation. Such illegal polyhedrons are usually a sign
of user error. There are many examples of novice users that run into
problems because they make mistakes in this area. My comment was
motivated to help such users.
Experienced users like yourself may "abuse" it to achieve useful special
effects like you describe. This is quite legitimate, but it sounds to me
like a different feature. You could perhaps serve both groups of users
by
a) Enforcing stricter rules on polyhedrons, and give good error messages
instead of silently accepting everything that is clearly wrong given
polyhedron definitions. This would help novice users.
b) Introduce a new feature to serve the more advanced needs you
describe. For example you could introduce a new object type called
"polygonsoup" (or whatever name you prefer) that has exactly the same
input syntax as polyhedron, but with relaxed rules, allowing previews of
polygons in 3d space.
Or, if you don't like a new type, then the default behaviour of
polyhedron could be as in a), but an extra "relaxed_rules=true"
parameter could relax the rules, so you get b).
On 2018-01-18 10:29, Parkinbot wrote: > cacb wrote >> Perhaps one could also say that a polyhedron with fewer than 4 faces >> is >> always an error, perhaps with the exception of zero faces in the case >> of >> using it within hull()? > > I am heavily using this feature > - to preview 2D-polygons placed in 3D space, > - to see, what sweep() will do with my code > - to check for selfintersections > > Indeed I even don't see much sense in restricting STL output to > "proper" > manifolds. Is it part of the format specification? My comment was not referring to STL or other output formats, only the internal OpenSCAD definition of polyhedron. Ref. the OpenSCAD documentation of polyhedron I lniked to. Either the documentation should be changed to reflect the software, or the documented rule requiring planar faces should be enforced. OpenSCAD should tell the user when it receives clearly illegal input according to documentation. Such illegal polyhedrons are usually a sign of user error. There are many examples of novice users that run into problems because they make mistakes in this area. My comment was motivated to help such users. Experienced users like yourself may "abuse" it to achieve useful special effects like you describe. This is quite legitimate, but it sounds to me like a different feature. You could perhaps serve both groups of users by a) Enforcing stricter rules on polyhedrons, and give good error messages instead of silently accepting everything that is clearly wrong given polyhedron definitions. This would help novice users. b) Introduce a new feature to serve the more advanced needs you describe. For example you could introduce a new object type called "polygonsoup" (or whatever name you prefer) that has exactly the same input syntax as polyhedron, but with relaxed rules, allowing previews of polygons in 3d space. Or, if you don't like a new type, then the default behaviour of polyhedron could be as in a), but an extra "relaxed_rules=true" parameter could relax the rules, so you get b). Carsten Arnholm
Thu, Jan 18, 2018 2:23 PM
Polyhedron and polygon is like Peek and Poke of BASIC. While it opens the
door to hell, it does all the rest, what you can't do with the ordinary
language. History has shown that any accepted language needs such backdoors
and I don't see anything wrong in having some features for power users of
OpenSCAD, as they give most of the qualified feedback and do most of the
testing and "marketing" by producing impressive designs. To be honest,
without polyhedron I would have dropped the language after three weeks of
use, latest. In my eyes it is the real expressive power of OpenSCAD. Why
castrate it - and break a lot of code out there? Because a novice user can
stumble over it? If you offer a solution that differences out several
primitives with little differences, he will stumble at this point. You are
using and propagating AngleScript, because it lets you do things, that
OpenSCAD doesn't let you do. So you will understand this point.
I wouldn't touch these primitives, but opt to more emphazise the difference
between CSG and CGAL in the documentation. Most people especially beginners
don't know this essential difference.
F6 can (and should) give warnings about improper topologies, like it does
when it finds a singularity. But why should it prevent me with an error from
writing out an improper topology into an STL?
Why sacrifice parts of the expressive power of CSG (e.g. color), only
because CGAL is not rich enough? There is a F5 and a F6. And they lead into
different worlds. E.g. I use OpenSCAD a lot to produce animations and to
explain things visually. You don't need proper polyhedrons or manifolds for
that, but fast and powerful code.
I would also provide a built-in import function like
data = import("mystl.stl");
that lets me implement all sorts of query and modifier stuff like
function boundary(data) = ...
or write code like
polyhedron(data[0]. data[1]);
and introduce at least a rudimentary interface for data import in a
standardized format (binary and ASCII). This would offer a pathway to solve
most of the severe problems (like quering a design), more experienced people
run into after having invested some learning time into OpenSCAD and trying
to implement something more sophisticated. Of course the import function
should be extended to support all data formats, OpenSCAD can write out.
Currently one has to write (or find) code that converts these formats into
SCAD code, which is very clumsy.
cacb wrote > Experienced users like yourself may "abuse" it to achieve useful special > effects like you describe. Polyhedron and polygon is like Peek and Poke of BASIC. While it opens the door to hell, it does all the rest, what you can't do with the ordinary language. History has shown that any accepted language needs such backdoors and I don't see anything wrong in having some features for power users of OpenSCAD, as they give most of the qualified feedback and do most of the testing and "marketing" by producing impressive designs. To be honest, without polyhedron I would have dropped the language after three weeks of use, latest. In my eyes it is the real expressive power of OpenSCAD. Why castrate it - and break a lot of code out there? Because a novice user can stumble over it? If you offer a solution that differences out several primitives with little differences, he will stumble at this point. You are using and propagating AngleScript, because it lets you do things, that OpenSCAD doesn't let you do. So you will understand this point. I wouldn't touch these primitives, but opt to more emphazise the difference between CSG and CGAL in the documentation. Most people especially beginners don't know this essential difference. F6 can (and should) give warnings about improper topologies, like it does when it finds a singularity. But why should it prevent me with an error from writing out an improper topology into an STL? Why sacrifice parts of the expressive power of CSG (e.g. color), only because CGAL is not rich enough? There is a F5 and a F6. And they lead into different worlds. E.g. I use OpenSCAD a lot to produce animations and to explain things visually. You don't need proper polyhedrons or manifolds for that, but fast and powerful code. I would also provide a built-in import function like data = import("mystl.stl"); that lets me implement all sorts of query and modifier stuff like function boundary(data) = ... or write code like polyhedron(data[0]. data[1]); and introduce at least a rudimentary interface for data import in a standardized format (binary and ASCII). This would offer a pathway to solve most of the severe problems (like quering a design), more experienced people run into after having invested some learning time into OpenSCAD and trying to implement something more sophisticated. Of course the import function should be extended to support all data formats, OpenSCAD can write out. Currently one has to write (or find) code that converts these formats into SCAD code, which is very clumsy. -- Sent from: http://forum.openscad.org/
Thu, Jan 18, 2018 5:20 PM
"proper" manifolds. Is it part of the format specification?
I have no idea whether there's  anything in the format spec, but it's
quite frustrating to generate something with OpenSCAD, feed it to my
slicer, and have my slicer misbehave because it doesn't follow the rules.
(As best I can tell, usually this happens when there are extremely small
features that start running into the OpenSCAD resolution limits - like
when I took my 25.4:1 scale model of my house and then scaled it down by
a further 25.4:1.)
(Intuitively, I would say that a string of points that aren't coplanar
cannot be a face of a polyhedron.  They might be something else, and I
don't have a problem with having a way to create and manipulate them
under a different name.)
On 1/18/2018 1:29 AM, Parkinbot wrote: > Indeed I even don't see much sense in restricting STL output to > "proper" manifolds. Is it part of the format specification? I have no idea whether there's  anything in the format spec, but it's quite frustrating to generate something with OpenSCAD, feed it to my slicer, and have my slicer misbehave because it doesn't follow the rules. (As best I can tell, usually this happens when there are extremely small features that start running into the OpenSCAD resolution limits - like when I took my 25.4:1 scale model of my house and then scaled it down by a further 25.4:1.) (Intuitively, I would say that a string of points that aren't coplanar cannot be a face of a polyhedron.  They might be something else, and I don't have a problem with having a way to create and manipulate them under a different name.)
Thu, Jan 18, 2018 5:51 PM
Is there a middle ground here where error messages are displayed when an
invalid STL file is created, so that you can avoid feeding that STL to
your slicer while the other OpenSCAD features remain intact?  Perhaps I
am missing a subtlety here
  • like when I took my 25.4:1 scale model of my house and then scaled
Sent from my desktop computer.
I do not receive emails while away from my desk,
nor do I receive texts on my main phone number
(which is a land line).
If you know that I am on the road, please text me.
If you know that I am home, please email me.
Is there a middle ground here where error messages are displayed when an invalid STL file is created, so that you can avoid feeding that STL to your slicer while the other OpenSCAD features remain intact?  Perhaps I am missing a subtlety here Jon On 1/18/2018 12:20 PM, Jordan Brown wrote: > On 1/18/2018 1:29 AM, Parkinbot wrote: >> Indeed I even don't see much sense in restricting STL output to >> "proper" manifolds. Is it part of the format specification? > > I have no idea whether there's  anything in the format spec, but it's > quite frustrating to generate something with OpenSCAD, feed it to my > slicer, and have my slicer misbehave because it doesn't follow the rules. > > (As best I can tell, usually this happens when there are extremely > small features that start running into the OpenSCAD resolution limits > - like when I took my 25.4:1 scale model of my house and then scaled > it down by a further 25.4:1.) > > (Intuitively, I would say that a string of points that aren't coplanar > cannot be a face of a polyhedron.  They might be something else, and I > don't have a problem with having a way to create and manipulate them > under a different name.) > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Sent from my desktop computer. I do not receive emails while away from my desk, nor do I receive texts on my main phone number (which is a land line). If you know that I am on the road, please text me. If you know that I am home, please email me.
Thu, Jan 18, 2018 6:03 PM
Currently there is either no hint (emptying the cache can help), or a
cryptic CGAL error or a warning in the case of a singularity.
The current workaround to have a user defined polyhedron explicitly tested
for manifoldness is to union it with something else (any Boolean operation
will do) starting from an empty cache.
mypolyhedron();
cube();
a further 25.4:1.)
There was a planarity bug connected with polyhedra faces in the late 2017
dev builds, which has been fixed in the 2018.1.x Have you tried to update?
It is also known that you can sometimes heal a small scale design by scaling
it up, while a scale-down is never a good idea.
JordanBrown wrote > On 1/18/2018 1:29 AM, Parkinbot wrote: >> Indeed I even don't see much sense in restricting STL output to >> "proper" manifolds. Is it part of the format specification? > > I have no idea whether there's  anything in the format spec, but it's > quite frustrating to generate something with OpenSCAD, feed it to my > slicer, and have my slicer misbehave because it doesn't follow the rules. Currently there is either no hint (emptying the cache can help), or a cryptic CGAL error or a warning in the case of a singularity. The current workaround to have a user defined polyhedron explicitly tested for manifoldness is to union it with something else (any Boolean operation will do) starting from an empty cache. mypolyhedron(); cube(); > (As best I can tell, usually this happens when there are extremely small > features that start running into the OpenSCAD resolution limits - like > when I took my 25.4:1 scale model of my house and then scaled it down by > a further 25.4:1.) > > (Intuitively, I would say that a string of points that aren't coplanar > cannot be a face of a polyhedron.  They might be something else, and I > don't have a problem with having a way to create and manipulate them > under a different name.) There was a planarity bug connected with polyhedra faces in the late 2017 dev builds, which has been fixed in the 2018.1.x Have you tried to update? It is also known that you can sometimes heal a small scale design by scaling it up, while a scale-down is never a good idea. -- Sent from: http://forum.openscad.org/
Thu, Jan 18, 2018 6:47 PM
language.
My point was simply that the door to hell does not have to be wide open
for everyone all the time. You can open it when you want to.
I think you scanned my post too fast, because I never said there is
anything wrong with power features, on the contrary I said power
features are legitimate. My message is to support the needs of both
novices as well as power users, and my post suggested ways of doing it.
To be honest,
stumble over it?
To my knowledge, nobody suggests dropping polyhedron.
Carsten Arnholmdy
On 18. jan. 2018 15:23, Parkinbot wrote: > Polyhedron and polygon is like Peek and Poke of BASIC. While it opens the > door to hell, it does all the rest, what you can't do with the ordinary > language. My point was simply that the door to hell does not have to be wide open for everyone all the time. You can open it when you want to. > History has shown that any accepted language needs such backdoors > and I don't see anything wrong in having some features for power users of > OpenSCAD, as they give most of the qualified feedback and do most of the > testing and "marketing" by producing impressive designs. I think you scanned my post too fast, because I never said there is anything wrong with power features, on the contrary I said power features are legitimate. My message is to support the needs of both novices as well as power users, and my post suggested ways of doing it. > To be honest, > without polyhedron I would have dropped the language after three weeks of > use, latest. In my eyes it is the real expressive power of OpenSCAD. Why > castrate it - and break a lot of code out there? Because a novice user can > stumble over it? To my knowledge, nobody suggests dropping polyhedron. Carsten Arnholmdy
Thu, Jan 18, 2018 11:39 PM
Carsten I reread your post and you are right. An additional parameter for
polyhedron properly defaulted for novices will not close the door to hell.
Ok, it will break some code, but the fix would be straight forward.
My point is that added complexity like introducing a new, somehow "safer"
polyhedron primitive (say it will solve the "pink" challenge (CCW/CW
orientation) and check for manifoldness (without the Boolean operation
workaround) will not seal all traps a novice can and will encounter.
Wouldn't it just throw yet another, hopefully more reliable CGAL error (no
cache flush required any more) or even THE error, polyhedron users are all
waiting for? The only thing, I really opted for was: Make a reliable warning
and not an error out of it, to not prevent people from outputing
non-manifold STLs if they want.
An error will indicate, but not solve the self-intersection and singularity
challenges and trap the people there. While the documentation is quite
explicit on the pink challenge, it happens from time to time that people
sign in, who got trapped there. Is this a weakness of the language? Yes it
can be fixed. OpenSCAD could check it and automatically switch to F12 mode.
But then a novice might not know, why the output (partly) turned pink. So
let's also output a warning or even an error? But most errors and warnings
are hard to read or neglected ...
Carsten I reread your post and you are right. An additional parameter for polyhedron properly defaulted for novices will not close the door to hell. Ok, it will break some code, but the fix would be straight forward. My point is that added complexity like introducing a new, somehow "safer" polyhedron primitive (say it will solve the "pink" challenge (CCW/CW orientation) and check for manifoldness (without the Boolean operation workaround) will not seal all traps a novice can and will encounter. Wouldn't it just throw yet another, hopefully more reliable CGAL error (no cache flush required any more) or even THE error, polyhedron users are all waiting for? The only thing, I really opted for was: Make a reliable warning and not an error out of it, to not prevent people from outputing non-manifold STLs if they want. An error will indicate, but not solve the self-intersection and singularity challenges and trap the people there. While the documentation is quite explicit on the pink challenge, it happens from time to time that people sign in, who got trapped there. Is this a weakness of the language? Yes it can be fixed. OpenSCAD could check it and automatically switch to F12 mode. But then a novice might not know, why the output (partly) turned pink. So let's also output a warning or even an error? But most errors and warnings are hard to read or neglected ... -- Sent from: http://forum.openscad.org/
Fri, Jan 19, 2018 5:52 AM
to update?
I don't use polyhedra very much.  My top-level comment was that
generating STL files that don't follow the rules is rude.
And a side comment that by a common-sense definition, a list of points
that's not coplanar is not a polyhedron face.
I did need a scaled-down version of the model.  (After all, it's a model
of my house; it has to include a copy of the model https://xkcd.com/878/.)
I don't remember how I got it to print.  Maybe I just ignored the things
the slicer did wrong.  I might have been better off having the STL be
full-sized (about a meter across) and then scaling down in the slicer.
On 1/18/2018 10:03 AM, Parkinbot wrote: > There was a planarity bug connected with polyhedra faces in the late > 2017 dev builds, which has been fixed in the 2018.1.x Have you tried > to update? I don't use polyhedra very much.  My top-level comment was that generating STL files that don't follow the rules is rude. And a side comment that by a common-sense definition, a list of points that's not coplanar is not a polyhedron face. > It is also known that you can sometimes heal a small scale design by > scaling it up, while a scale-down is never a good idea. I did need a scaled-down version of the model.  (After all, it's a model of my house; it has to include a copy of the model <https://xkcd.com/878/>.) I don't remember how I got it to print.  Maybe I just ignored the things the slicer did wrong.  I might have been better off having the STL be full-sized (about a meter across) and then scaling down in the slicer.
Fri, Jan 19, 2018 9:00 PM
If you buy a product or pay a lot money for the licence, the word "rude"
might apply ...
If you want constructive help it is a good idea to show some code that
misbehaves and - again - to test it with the latest development snapshot
first.
JordanBrown wrote > I don't use polyhedra very much.  My top-level comment was that generating > STL files that don't follow the rules is rude. If you buy a product or pay a lot money for the licence, the word "rude" might apply ... > And a side comment that by a common-sense definition, a list of points > that's not coplanar is not a polyhedron face. If you want constructive help it is a good idea to show some code that misbehaves and - again - to test it with the latest development snapshot first. -- Sent from: http://forum.openscad.org/
CC
Chris Camacho
Fri, Jan 19, 2018 9:05 PM
might apply ...
On the contrary if its free (as in beer) and open source then it would
be "rude" to make some inappropriate output to a STL file, if not at
least because you're sure gonna get called out on it... in public... so
better to do it right....
On 19/01/18 21:00, Parkinbot wrote: > If you buy a product or pay a lot money for the licence, the word "rude" > might apply ... On the contrary if its free (as in beer) and open source then it would be "rude" to make some inappropriate output to a STL file, if not at least because you're sure gonna get called out on it... in public... so better to do it right....
