F5 works, but F6 gives: ERROR: CGAL error in CGAL_Nef_polyhedron3():
Fri, Jan 19, 2018 11:13 PM
2018-01-19 3:52 GMT-02:00 Jordan Brown openscad@jordan.maileater.net:
And a side comment that by a common-sense definition, a list of points
that's not coplanar is not a polyhedron face.
​Most non-trivial sets of more than 3 points are not planar ​due to
floating point approximations. And some measure is necessary to cope with
the different number representations of OpenSCAD and CGAL. As far as I
know, OpenSCAD triangulates every polyhedron facet with more that 3
vertices precisely to avoid non-planarity issues. It can be argued that its
triangulation is not "optimal" in some sense but we cannot blame it for
doing this.
Polyhedron is a very flexible primitive. It is possible to define a
non-manifold and/or singular surfaces even with borders or multiple shells
with polyhedron. If degenerated faces are avoided, you can render it
nevertheless while no boolean operations is performed. That may be a hell
or a heaven depending on what you are doing or want to do.
What Uwe's workaround brought up is that the hull operator may "heal"
(most) defective polyhedron generating a valid solid with a manifold shell:
the convex hull of the polyhedron face vertices. That is nice, because
mathematically the hull operation does not require any structure linking
the points.
I don't think there is anything wrong with the current processing of
polyhedron. But...
Consider the following:
e = 5;
p = [ [0,0,  0],[10, 0,  0],[0,10,  0],[0,0,  10],
[0,0,10+e],[10,10,10+e],[0,10,0+e],[10,0,0+e] ];
faces1 = [[0,1,2],
[0,2,3],
[0,3,1],
[1,3,2]];
faces2 = [[4,6,5],
[4,5,7],
[4,7,6],
[5,6,7]];
polyhedron(p, concat(faces1,faces2));
This polyhedron is really the union of a pair of tetrahedra provided that
the parameter e is positive. It can be boolean operated with another
primitive and renders fine. However, when I set the parameter e to 1e-6 and
union it with a cube, my 01.06 version running on Windows crashes. Worst
than that, setting e to 1e-5 I am able to render it unioned with a cube and
generate a STL file. Although the file is not defective (it represents
exactly the two tetrahedra with a small gap of about 1e-05) OpenSCAD
crashes when I try to import it.
Summarizing, my points are:
a) it is fine to define polyhedra that cannot be boolean operated because
they are not manifold;
b) it is fine that those polyhedra produce STL files that are not manifold
provided a warning is issued;
c) it is not fine that a STL file representing a manifold exported by
OpenSCAD cannot be imported by OpenSCAD.
2018-01-19 3:52 GMT-02:00 Jordan Brown <openscad@jordan.maileater.net>: > And a side comment that by a common-sense definition, a list of points > that's not coplanar is not a polyhedron face. > ​Most non-trivial sets of more than 3 points are not planar ​due to floating point approximations. And some measure is necessary to cope with the different number representations of OpenSCAD and CGAL. As far as I know, OpenSCAD triangulates every polyhedron facet with more that 3 vertices precisely to avoid non-planarity issues. It can be argued that its triangulation is not "optimal" in some sense but we cannot blame it for doing this. Polyhedron is a very flexible primitive. It is possible to define a non-manifold and/or singular surfaces even with borders or multiple shells with polyhedron. If degenerated faces are avoided, you can render it nevertheless while no boolean operations is performed. That may be a hell or a heaven depending on what you are doing or want to do. What Uwe's workaround brought up is that the hull operator may "heal" (most) defective polyhedron generating a valid solid with a manifold shell: the convex hull of the polyhedron face vertices. That is nice, because mathematically the hull operation does not require any structure linking the points. I don't think there is anything wrong with the current processing of polyhedron. But... Consider the following: e = 5; p = [ [0,0, 0],[10, 0, 0],[0,10, 0],[0,0, 10], [0,0,10+e],[10,10,10+e],[0,10,0+e],[10,0,0+e] ]; faces1 = [[0,1,2], [0,2,3], [0,3,1], [1,3,2]]; faces2 = [[4,6,5], [4,5,7], [4,7,6], [5,6,7]]; polyhedron(p, concat(faces1,faces2)); This polyhedron is really the union of a pair of tetrahedra provided that the parameter e is positive. It can be boolean operated with another primitive and renders fine. However, when I set the parameter e to 1e-6 and union it with a cube, my 01.06 version running on Windows crashes. Worst than that, setting e to 1e-5 I am able to render it unioned with a cube and generate a STL file. Although the file is not defective (it represents exactly the two tetrahedra with a small gap of about 1e-05) OpenSCAD crashes when I try to import it. Summarizing, my points are: a) it is fine to define polyhedra that cannot be boolean operated because they are not manifold; b) it is fine that those polyhedra produce STL files that are not manifold provided a warning is issued; c) it is not fine that a STL file representing a manifold exported by OpenSCAD cannot be imported by OpenSCAD.
