flattening curved surfaces
Thu, Dec 29, 2016 3:18 AM
Jon,
I attached some code with the basic math for unrolling a triangulated
surface. As expected the mapping is straightforward.
Also tested the surface separation with your object. Using n1*n2 > 0.9 works
perfectly fine.
http://forum.openscad.org/file/n19807/unroll.png
unroll.scad http://forum.openscad.org/file/n19807/unroll.scad
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19807.html
Jon, I attached some code with the basic math for unrolling a triangulated surface. As expected the mapping is straightforward. Also tested the surface separation with your object. Using n1*n2 > 0.9 works perfectly fine. <http://forum.openscad.org/file/n19807/unroll.png> unroll.scad <http://forum.openscad.org/file/n19807/unroll.scad> -- View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19807.html Sent from the OpenSCAD mailing list archive at Nabble.com.
R
runsun
Thu, Dec 29, 2016 6:00 AM
Nicely done, Parkinbot. To my understanding, the approach seems to be the
same as mine, only you presented in a much simpler way. While I said
earlier,
"it requires somewhat extensive user functions to calculate and copy/move
the angles and edges, which is not an easy task in OpenSCAD."
The simplicity of your code let me rethink that statement.
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 );   $ tips: Collection of tips on github
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19809.html
Nicely done, Parkinbot. To my understanding, the approach seems to be the same as mine, only you presented in a much simpler way. While I said earlier, "it requires somewhat extensive user functions to calculate and copy/move the angles and edges, which is not an easy task in OpenSCAD." The simplicity of your code let me rethink that statement. ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); &nbsp; $ tips: Collection of tips on github -- View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19809.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Dec 29, 2016 11:43 AM
Thanks!
OpenScad is well equipped to do this sort of vector and matrix calculations.
The handicap starts, whenever you want to juggle around with and manipulate
collections of structures like triags imported from an STL. You then wish to
have a (much) richer language. Caught within the functional paradigm code
gets really slow and clumsy and you are tempted to escape through the small
procedural backdoor of /C-style for/, which makes it even more unreadable
and mind blowing.
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19813.html
Thanks! OpenScad is well equipped to do this sort of vector and matrix calculations. The handicap starts, whenever you want to juggle around with and manipulate collections of structures like triags imported from an STL. You then wish to have a (much) richer language. Caught within the functional paradigm code gets really slow and clumsy and you are tempted to escape through the small procedural backdoor of /C-style for/, which makes it even more unreadable and mind blowing. -- View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19813.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Dec 29, 2016 1:22 PM
LOL!  Thanks!  I just got the surfaces separated last night. Today I
flatten them.  It has been entertaining.  I've made lots of mistakes!
The specific application I have in mind involves accepting 3D designs
that were created using tools other than OpenSCAD, meaning that I need
to be able to work on STL files, so I'm not sure how many of the
OpenSCAD solutions that have been offered would be suitable.  I suppose
one could convert an STL file into a polygon using an external script,
but doing it all in one place in one program seems best for me.
I was going to do as you did (take each triangle and rotate it and shift
it to flatten it to the existing surface) but I am now thinking I will
just create a new set of triangles on a plane directly.
On 12/28/2016 10:18 PM, Parkinbot wrote:
Jon,
perfectly fine.
Checked by AVG - www.avg.com
Version: 2016.0.7924 / Virus Database: 4739/13664 - Release Date: 12/28/16
LOL! Thanks! I just got the surfaces separated last night. Today I flatten them. It has been entertaining. I've made lots of mistakes! The specific application I have in mind involves accepting 3D designs that were created using tools other than OpenSCAD, meaning that I need to be able to work on STL files, so I'm not sure how many of the OpenSCAD solutions that have been offered would be suitable. I suppose one could convert an STL file into a polygon using an external script, but doing it all in one place in one program seems best for me. I was going to do as you did (take each triangle and rotate it and shift it to flatten it to the existing surface) but I am now thinking I will just create a new set of triangles on a plane directly. :) On 12/28/2016 10:18 PM, Parkinbot wrote: > Jon, > > I attached some code with the basic math for unrolling a triangulated > surface. As expected the mapping is straightforward. > > Also tested the surface separation with your object. Using n1*n2 > 0.9 works > perfectly fine. > > <http://forum.openscad.org/file/n19807/unroll.png> > > unroll.scad <http://forum.openscad.org/file/n19807/unroll.scad> > > > > -- > View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19807.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7924 / Virus Database: 4739/13664 - Release Date: 12/28/16 > >
Thu, Dec 29, 2016 2:41 PM
script,
Yeah. It is a trival IO-converter that picks the "normal" (optional) and
"vertex" lines and inserts some brackets and commas around and between the
numbers to get scad-Code.
A (masochistic) purist could also augment a pair of string quotes at the
beginning and the end of the STL and then try to parse the file with
OpenSCAD using an import like this:
a = include
<augmented.stl>
to enter the "rich" world of OpenSCAD's string manipulation. If have done
that a while ago just for fun to find out how much you can squeeze out of
OpenSCAD's string processing. The runtime was so poor (~3 minutes for a
200kB stl) that I never finished the code to also parse exponents. Anyone,
who is interested in it, can find the code attached and try to parse a
simple stl like a cube or a sphere with it.
directly.
I wonder how you will implement the word "just" without parsing your STL
into a common-edge topology tree and unrolling this tree.
parse_stl.scad http://forum.openscad.org/file/n19816/parse_stl.scad
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19816.html
jon_bondy wrote > I suppose one could convert an STL file into a polygon using an external > script, Yeah. It is a trival IO-converter that picks the "normal" (optional) and "vertex" lines and inserts some brackets and commas around and between the numbers to get scad-Code. A (masochistic) purist could also augment a pair of string quotes at the beginning and the end of the STL and then try to parse the file with OpenSCAD using an import like this: > a = include > <augmented.stl> > ; to enter the "rich" world of OpenSCAD's string manipulation. If have done that a while ago just for fun to find out how much you can squeeze out of OpenSCAD's string processing. The runtime was so poor (~3 minutes for a 200kB stl) that I never finished the code to also parse exponents. Anyone, who is interested in it, can find the code attached and try to parse a simple stl like a cube or a sphere with it. jon_bondy wrote > but I am now thinking I will just create a new set of triangles on a plane > directly. I wonder how you will implement the word "just" without parsing your STL into a common-edge topology tree and unrolling this tree. parse_stl.scad <http://forum.openscad.org/file/n19816/parse_stl.scad> -- View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19816.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Dec 29, 2016 3:12 PM
My thought is to locate an edge triangle, and use recursion to go
through all of the other triangles.  The first triangle will be placed
on the z=0 plane, and subsequent triangles will be placed next to the
previous triangle, just by knowing the shape of the triangle.
We will see.  It's been a bumpy ride, and this may be just another bump.
On 12/29/2016 9:41 AM, Parkinbot wrote:
directly.
My thought is to locate an edge triangle, and use recursion to go through all of the other triangles. The first triangle will be placed on the z=0 plane, and subsequent triangles will be placed next to the previous triangle, just by knowing the shape of the triangle. We will see. It's been a bumpy ride, and this may be just another bump. Jon On 12/29/2016 9:41 AM, Parkinbot wrote: > jon_bondy wrote >> but I am now thinking I will just create a new set of triangles on a plane >> directly. > I wonder how you will implement the word "just" without parsing your STL > into a common-edge topology tree and unrolling this tree. > > parse_stl.scad <http://forum.openscad.org/file/n19816/parse_stl.scad> >
Thu, Dec 29, 2016 3:19 PM
What happens if you have a curve in more than one dimension that can't be
flattened without tares in it?
plane
directly.
What happens if you have a curve in more than one dimension that can't be flattened without tares in it? On 29 December 2016 at 15:12, jon <jon@jonbondy.com> wrote: > My thought is to locate an edge triangle, and use recursion to go through > all of the other triangles. The first triangle will be placed on the z=0 > plane, and subsequent triangles will be placed next to the previous > triangle, just by knowing the shape of the triangle. > > We will see. It's been a bumpy ride, and this may be just another bump. > > Jon > > > On 12/29/2016 9:41 AM, Parkinbot wrote: > >> jon_bondy wrote >> >>> but I am now thinking I will just create a new set of triangles on a >>> plane >>> directly. >>> >> I wonder how you will implement the word "just" without parsing your STL >> into a common-edge topology tree and unrolling this tree. >> >> parse_stl.scad <http://forum.openscad.org/file/n19816/parse_stl.scad> >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Thu, Dec 29, 2016 3:24 PM
I imagine that you are correct.  It happens that the particular
application I am working with assumes that each surface is a portion of
a cylinder, so it only curves in one direction.
 triangle.
 bump.
         directly.
     parsing your STL
     parse_stl.scad
     <http://forum.openscad.org/file/n19816/parse_stl.scad>>
Checked by AVG - www.avg.com http://www.avg.com
Version: 2016.0.7924 / Virus Database: 4739/13667 - Release Date: 12/29/16
I imagine that you are correct. It happens that the particular application I am working with assumes that each surface is a portion of a cylinder, so it only curves in one direction. On 12/29/2016 10:19 AM, nop head wrote: > What happens if you have a curve in more than one dimension that can't > be flattened without tares in it? > > On 29 December 2016 at 15:12, jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>> wrote: > > My thought is to locate an edge triangle, and use recursion to go > through all of the other triangles. The first triangle will be > placed on the z=0 plane, and subsequent triangles will be placed > next to the previous triangle, just by knowing the shape of the > triangle. > > We will see. It's been a bumpy ride, and this may be just another > bump. > > Jon > > > On 12/29/2016 9:41 AM, Parkinbot wrote: > > jon_bondy wrote > > but I am now thinking I will just create a new set of > triangles on a plane > directly. > > I wonder how you will implement the word "just" without > parsing your STL > into a common-edge topology tree and unrolling this tree. > > parse_stl.scad > <http://forum.openscad.org/file/n19816/parse_stl.scad > <http://forum.openscad.org/file/n19816/parse_stl.scad>> > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > Version: 2016.0.7924 / Virus Database: 4739/13667 - Release Date: 12/29/16 >
Thu, Dec 29, 2016 5:01 PM
that is a correct approach. But it needs to build a common edge tree (= no
circular pathes allowed) first, which you then can traverse recursively.
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19821.html
jon_bondy wrote > My thought is to locate an edge triangle, and use recursion to go > through all of the other triangles. The first triangle will be placed > on the z=0 plane, and subsequent triangles will be placed next to the > previous triangle, just by knowing the shape of the triangle. that is a correct approach. But it needs to build a common edge tree (= no circular pathes allowed) first, which you then can traverse recursively. -- View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19821.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Dec 29, 2016 5:57 PM
I think I know how to do that!  Time will tell!
I think I know how to do that! Time will tell! On 12/29/2016 12:01 PM, Parkinbot wrote: > jon_bondy wrote >> My thought is to locate an edge triangle, and use recursion to go >> through all of the other triangles. The first triangle will be placed >> on the z=0 plane, and subsequent triangles will be placed next to the >> previous triangle, just by knowing the shape of the triangle. > that is a correct approach. But it needs to build a common edge tree (= no > circular pathes allowed) first, which you then can traverse recursively. > > > > -- > View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19821.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7924 / Virus Database: 4739/13667 - Release Date: 12/29/16 > >
