flattening curved surfaces
Thu, Dec 29, 2016 6:51 PM
On 29. des. 2016 16:12, jon wrote:
My thought is to locate an edge triangle, and use recursion to go
through all of the other triangles.
I admire the self-flagellation of trying something like that using
OpenSCAD. If you even manage the coding and encounter an STL with tens
or even hundreds of thousands of triangles, recursion will probably not
work.
On 29. des. 2016 16:12, jon wrote: > My thought is to locate an edge triangle, and use recursion to go > through all of the other triangles. I admire the self-flagellation of trying something like that using OpenSCAD. If you even manage the coding and encounter an STL with tens or even hundreds of thousands of triangles, recursion will probably not work. Carsten Arnholm
Thu, Dec 29, 2016 6:53 PM
On 29. des. 2016 15:41, Parkinbot wrote:
A (masochistic) purist could also augment a pair of string quotes at the
beginning and the end of the STL and then try to parse the file with
OpenSCAD using an import like this:
a = include
<augmented.stl>
Try it with a binary STL :-)
On 29. des. 2016 15:41, Parkinbot wrote: > A (masochistic) purist could also augment a pair of string quotes at the > beginning and the end of the STL and then try to parse the file with > OpenSCAD using an import like this: > > >> a = include >> <augmented.stl> >> ; Try it with a binary STL :-) Carsten Arnholm
Thu, Dec 29, 2016 7:35 PM
I am writing all of this in Delphi Pascal; as to the 10K or 100K
triangles, it will have to work on 500  before I can try to crash it
with big models!
not work.
I am writing all of this in Delphi Pascal; as to the 10K or 100K triangles, it will have to work on 500 before I can try to crash it with big models! :) On 12/29/2016 1:51 PM, Carsten Arnholm wrote: > On 29. des. 2016 16:12, jon wrote: >> My thought is to locate an edge triangle, and use recursion to go >> through all of the other triangles. > > I admire the self-flagellation of trying something like that using > OpenSCAD. If you even manage the coding and encounter an STL with tens > or even hundreds of thousands of triangles, recursion will probably > not work. > > Carsten Arnholm
