@nophead: brilliant solution.
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); $ tips: Bezier , hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2 , 3 , 4 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ), text , triang , unit ; $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ), support_tools
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19780.html
Thanks.
The union with nothing is of course redundant (part of some debug code I
forgot to remove) and intersection(c) should be just intersection().
Here is my polyhedron solution.
http://forum.openscad.org/file/n19782/161227_runsun_flatten_surface.png
In progress:
http://forum.openscad.org/file/n19782/161227_runsun_flatten_surface_2.png
http://forum.openscad.org/file/n19782/161227_runsun_flatten_surface_3.png
Conceptually it's easy to understand, and no need to worry about the
triangulation/edge-finding, etc. But:
a) As pointed out by Parkinbot on nophead's approach, this approach bears
the same condition that the shape needs to be known, and each shape has to
be handled separately.
b) In addition, it requires somewhat extensive user functions to calculate
and copy/move the angles and edges, which is not an easy task in OpenSCAD.
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19782.html
I'm not a math guy, but came across this info and was curious if any
"real math" folks on this list have considered using gpu accelerated
code for some of the slow parts of OPENscad. Not a universal solution,
of course, but I suspect the majority of folks using OPENscad for
anything serious have some sort of decent graphics card in their
computer. Maybe a compile-time option to switch on accelerated functions?
see: https://developer.nvidia.com/gpu-accelerated-libraries for an idea
of what is out there already tuned up for gpu hardware...
Bill M
On 12/26/2016 05:28 AM, Parkinbot wrote:
It is always a good project to brush up your math.
dot product
This is the scalar product to be used for the threshold criterium. Apply it
with the normalized (i.e. length=1) normals of your triangles.
cross product
being applied to two vectors spanned by your triag's vertices will get you
the normal of your triangle. Adapt orientation by inverting the sign. Divide
this vector by its length and you get a normalized normal. If you start from
an STL you will already find this value for each triangle there.
angle between two vectors
the scalarproduct of two normalized vectors will be cos(angle). So
acos(dot(a,b)) is your friend.
rotate points around an axis
you find the three matrices in wikipedia
http://www.dtic.mil/dtic/tr/fulltext/u2/a218917.pdf
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19760.html
How did you work out the original polyhedron? Did you calculate the
intersection of cylinders mathematically?
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19784.html
It was done by making 3 arcs, one on the xy-plane (red line below), two on
the yz-plane (green and blue lines), then merge them (for each point, taking
x,y from the red, and z from the green or blue):
http://forum.openscad.org/file/n19786/161227_runsun_flatten_surface_4.png
The position of the centers as well as the radius of those arcs are manually
chosen to make the outcome match the shape presented by jon_bondy.
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19786.html
runsun,
You say you don't have to worry about the triangulation but your code
implicitly knows the triangulation. In a more general case, you will need
to traverse it.
2016-12-27 16:46 GMT-02:00 nophead nop.head@gmail.com:
need
to traverse it.
I only know that I coded without thinking anything about the triangulation,
which, is still a pretty new concept to me. It's likely that I have been
doing triangulation-related stuff but not aware it's called triangulation.
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19793.html
I see, I didn't realise it was that simple. I think it is a special case
because the cylinders are orthogonal and aligned with the axes.
taking
<http://forum.openscad.org/file/n19786/161227_runsun_flatten_surface_4.png
manually
FYI
polgonal python based STL file unfolder:
https://github.com/osresearch/papercraft
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19806.html
