Sun, Dec 25, 2016 12:39 AM
I have a bit of code at the end of this question. It produces a shape
with 4 curved sides, each of which lies on the surface of a cylinder.
Note that this is an example shape: I want to work with families of
similar shapes, not just with this one example.
I would like a way to take each of the 4 surfaces and produce a 2D shape
that, when cut out and bent, would conform to the original surface. The
idea is to be able to create the original shape out of, say, cardboard
by cutting out the 4 2D shapes and then taping them together.
I have a conceptual idea of how this would be done in a traditional
programming language if I had a list of the coordinates along each of
the 4 boundary lines. I considered re-writing the code, below, as a
sweep, and generating the coordinates explicitly, but a) that is not
trivial (to me), and ii) I want to solve the more general case where the
equations that determine the shape are not known. I looked at the
generated STL file, and the coordinates are there, but not organized in
the way that I would want them to be.
This may be more effort than I want to expend, but I wondered if anyone
had a brilliant insight.
Thanks!
le = 10; // length
d1 = 25; // diameter of top
d2 = 35; // diameter of bottom
d = -8; // delta to drop center of bottom
$fn = 100;
module shape() {
translate([0, 0, -6])
translate([-le/2, 0, 0])
rotate([0, 90, 0])
cylinder(h = le, d = d1);
translate([-1, 0, d])
rotate([0, 90, 0])
cylinder(h = le + 2, d = d2);
translate([10, 0, 0])
cylinder(h = 100, d = 30);
translate([-10, 0, 0])
shape();
*difference() {
shape();
translate([0, 0, -4])
scale([0.8, 0.8, 2])
shape();
Thanks!
le = 10; // length
$fn = 100;
module shape() {
rotate([0, 90, 0])
rotate([0, 90, 0])
shape();
*difference() {
shape();
shape();
FV
Frank van der Hulst
Sun, Dec 25, 2016 1:30 AM
You might want to look at map projections... cartographers have been
working on this for centuries (for the oblate spheroid class of surfaces).
with 4 curved sides, each of which lies on the surface of a cylinder. Note
that this is an example shape: I want to work with families of similar
idea is to be able to create the original shape out of, say, cardboard by
programming language if I had a list of the coordinates along each of the 4
boundary lines. I considered re-writing the code, below, as a sweep, and
generating the coordinates explicitly, but a) that is not trivial (to me),
and ii) I want to solve the more general case where the equations that
determine the shape are not known. I looked at the generated STL file, and
the coordinates are there, but not organized in the way that I would want
them to be.
Thanks!
le = 10; // length
$fn = 100;
module shape() {
rotate([0, 90, 0])
rotate([0, 90, 0])
shape();
*difference() {
shape();
shape();
> them to be.
> Thanks!
> Jon
> le = 10; // length
> $fn = 100;
> module shape() {
> intersection() {
> difference() {
> rotate([0, 90, 0])
> rotate([0, 90, 0])
> intersection() {
> shape();
> *difference() {
> shape();
> shape();
Sun, Dec 25, 2016 1:46 AM
Whether your idea is really worth pursuing is a issue in itself, but if
you want to try it is probably easier to export to AMF, OpenSCAD can do
it. https://en.wikipedia.org/wiki/Additive_Manufacturing_File_Format
AMF is an XML file format containing the result of booleans in a form
very similar to an OpenSCAD polyhedron, with unique vertices separate
from the (triangular) faces and each face defined as 3 vertex indices.
This means you have topology to work with, not just a "polygon soup" as
in STL. With STL you would have to rediscover a topology first, a
non-trivial task in the general case.
So in principle, using a traditional programming language, you could
read the AMF and detect the "boundary lines" by evaluating the angles
between neighbouring faces (finding neighbouring faces requires topology
evaluation). That would be just the start of another non-trivial task to
detect the faces bound by those boundaries. It could certainly succeed,
but a general solution would take quite some effort.
Using only OpenSCAD, something like that is not possible at all, since
there is no way in the language to access the vertices and faces of the
result of a boolean operation.
Sun, Dec 25, 2016 1:52 AM
That was not the answer I was hoping for, but it certainly is the answer
I was looking for!
Thank you!
if you want to try it is probably easier to export to AMF, OpenSCAD
can do it.
as in STL. With STL you would have to rediscover a topology first, a
topology evaluation). That would be just the start of another
non-trivial task to detect the faces bound by those boundaries. It
could certainly succeed, but a general solution would take quite some
effort.
the result of a boolean operation.
Checked by AVG - www.avg.com
Version: 2016.0.7924 / Virus Database: 4739/13648 - Release Date:
12/24/16
I was looking for!
Thank you!
> can do it.
> effort.
> Carsten Arnholm
> No virus found in this message.
> 12/24/16
R
runsun
Sun, Dec 25, 2016 2:31 AM
I imagine that if it's possible to generate those shapes in polyhedron, it
won't be hard to achieve what you want.
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); $ tips: Bezier , hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2 , 3 , 4 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ), text , triang , unit ; $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ), support_tools
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19731.html
Sun, Dec 25, 2016 9:16 AM
I was looking for!
Thank you!
You are welcome. At least it may have saved you some time chasing the
unobtainable.
> I was looking for!
> Thank you!
unobtainable.
Sun, Dec 25, 2016 11:47 AM
Incidental to the question but when I put a # in front of the first
cylinder it doesn't show the whole cylinder. It does for the other three
cylinders. Why is that?
I was looking for!
Thank you!
>> I was looking for!
>> Thank you!
> unobtainable.
> Carsten Arnholm
R
Ronaldo
Sun, Dec 25, 2016 12:16 PM
Carsten is right but there is a workaround. A python code by Neon22 converts
AMF files (possibly exported by OpenSCAD) to a text file in the OpenSCAD
polyhedron format. See this discussion
<http://forum.openscad.org/Wrapping-text-around-a-complex-geometry-td18145.html#a18156>
. By using its output file in you OpenSCAD code, you will have access to the
model vertices and a code may be devised to find and unfold the developable
surfaces. However, the latest doesn't seem to be a trivial task. See for
instance:
http://complexitys.com/english/geometry/developable-surfaces/#.WF9isH10ca9
<http://complexitys.com/english/geometry/developable-surfaces/#.WF9isH10ca9>
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19735.html
Sun, Dec 25, 2016 1:40 PM
Jon,
I like your approach and I don't think it is too difficult to implement, if
you restrict the design to a set of constraints, which your parser can
assume to hold without further testing. (Also I don't see any advantage in
using AMF instead of STL.)
Rules:
- (unrolling) - Your design is composed by a set of surfaces, which are
unrollable in 2D. This puts a bunch of restrictions on the surfaces (!!!)
- (separation) - two edge-adjacent triangles belong to different surfaces,
if the scalar product of their normals exceeds some threshold parameter TH.
So what does your algorithm? It reads the triags into a set T and
a) finds and hooks the three (common edge) neighbours to each triag in T.
b) calculates the scalar products of each two neighboured triag normals and
classifies by means of the threshold TH, if the two triags belong to the
same surfaces or not. Not-on-the-same-surface neighbours will be unhooked.
c) select any triag in T and move it to a set S. Continue with all its
same-surface neighbours and so on, until all same-surface triags are in S.
d. repeat with c until T is empty and get a set SS of surfaces.
e) unroll each surface S in SS into 2D. For example start with any triag t
i) find an affine transformation f that maps t undistorted to 2D (always
can be found).
ii) apply f to all direct neighbours and find for each of them a rotation
g that maps them to the 2D plane
iii) continue with ii using g(f(t)) until done.
You see, the scheme is quite straight forward (and easy to implement) and
the only difficulty you will encounter is step e), where it turns out
whether your design obeys to rule 1 or not. If it doesn't, you will have to
find a way (=heuristics) to deal with it. This can get more nasty.
View this message in context: http://forum.openscad.org/flattening-curved-surfaces-tp19727p19736.html
Jon,
Rules:
1. (unrolling) - Your design is composed by a set of surfaces, which are
2. (separation) - two edge-adjacent triangles belong to different surfaces,
can be found).
Sun, Dec 25, 2016 1:44 PM
I KNEW there was a reason that I was about to retire! This should keep
me out of trouble for a while! Thanks for the pseudo code!
On 12/25/2016 8:40 AM, Parkinbot wrote:
Jon,
Rules:
can be found).
Version: 2016.0.7924 / Virus Database: 4739/13649 - Release Date: 12/24/16
> Jon,
> Rules:
> can be found).
> Sent from the OpenSCAD mailing list archive at Nabble.com.
