Fusion360 and OpenSCAD
Fri, Oct 7, 2016 6:31 PM
On 06. okt. 2016 21:46, Torsten Paul wrote:
I think it's more a matter of scope. It's not intended to
cover all possible cases giving thousands of parameters. It's
supposed to "just work" for the simple/normal case. For
everything more advanced, I agree that a separate, specialized
application is a better choice.
I think the problem is that it is hard to tell in advance what is a
simple/normal case that should "just work" and when it does not, you
wonder why...
I just implemented OpenSCAD export as an alternative in my profile
generator, here is the generated OpenSCAD source to extrude the Ford
logo, as an illustration of the technique:
http://arnholm.org/tmp/profiles/Ford_neg.scad
On 06. okt. 2016 21:46, Torsten Paul wrote: > I think it's more a matter of scope. It's not intended to > cover all possible cases giving thousands of parameters. It's > supposed to "just work" for the simple/normal case. For > everything more advanced, I agree that a separate, specialized > application is a better choice. I think the problem is that it is hard to tell in advance what is a simple/normal case that should "just work" and when it does not, you wonder why... I just implemented OpenSCAD export as an alternative in my profile generator, here is the generated OpenSCAD source to extrude the Ford logo, as an illustration of the technique: http://arnholm.org/tmp/profiles/Ford_neg.scad Carsten Arnholm
Rob Ward
Sat, Oct 8, 2016 1:02 AM
It looks very interesting, but I too find it of no use.  Is there a
drawing package that is has been modeled on (that I obviously have never
used before) that might explain how to use it.  The programmer seem
assume a lot of prior knowledge, and experience. It just appears to
randomly add points and lines once the initial line is drawn. Is it just
a proof of principle, not a finished product?  Nice .js work all the same.
Rob
On 07/10/16 04:30, jon wrote:
Thank you, Torsten, but this "tool" is not documented sufficiently for
me to even understand where to start.
On 10/6/2016 1:05 PM, Torsten Paul wrote:
On 10/06/2016 01:49 PM, jon wrote:
Or a tool that allows you to position Bezier handles
which are then converted to smoothed lines and then
imported into OpenSCAD
Not integrated, but still nice way to just draw polygon:
http://daid.eu/~daid/3d/
source: https://github.com/daid/OpenSCAD-polygon-editor
It looks very interesting, but I too find it of no use. Is there a drawing package that is has been modeled on (that I obviously have never used before) that might explain how to use it. The programmer seem assume a lot of prior knowledge, and experience. It just appears to randomly add points and lines once the initial line is drawn. Is it just a proof of principle, not a finished product? Nice .js work all the same. Rob On 07/10/16 04:30, jon wrote: > Thank you, Torsten, but this "tool" is not documented sufficiently for > me to even understand where to start. > > Jon > > > On 10/6/2016 1:05 PM, Torsten Paul wrote: >> On 10/06/2016 01:49 PM, jon wrote: >>> Or a tool that allows you to position Bezier handles >>> which are then converted to smoothed lines and then >>> imported into OpenSCAD >>> >> Not integrated, but still nice way to just draw polygon: >> >> http://daid.eu/~daid/3d/ >> >> source: https://github.com/daid/OpenSCAD-polygon-editor >> >> ciao, >> Torsten. >> >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
MS
Mark Schafer
Sat, Oct 8, 2016 1:26 AM
Rob,
You need Inkscape and the openSCAD extension:
As Marius said earlier there is also an SVG import in latest inkscape -
turn it on in experimental in Preferences/Features/
the same.
Rob
Rob, You need Inkscape and the openSCAD extension: - https://inkscape.org/en/download/addons/ - http://www.thingiverse.com/thing:1065500 As Marius said earlier there is also an SVG import in latest inkscape - turn it on in experimental in Preferences/Features/ On 10/8/2016 2:02 PM, Rob Ward wrote: > It looks very interesting, but I too find it of no use. Is there a > drawing package that is has been modeled on (that I obviously have > never used before) that might explain how to use it. The programmer > seem assume a lot of prior knowledge, and experience. It just appears > to randomly add points and lines once the initial line is drawn. Is it > just a proof of principle, not a finished product? Nice .js work all > the same. > > Rob
Sat, Oct 8, 2016 8:41 AM
Referring to the polygon builder at http://daid.eu/~daid/3d/
I figured out how to use it, it is quite easy.
To draw a polygon, press the green plus button and click in the drawing
area repeatedly to lay out the polygon points.
To remove a point, press the red minus button and click one of the
points to make it go away.
To change the position of a point, press the mouse cursor button, then
point to one of the points drawn, press and hold left mouse button
(point turns red) and drag the point to the new location.
Making rounded corners. Let us assume you have a polygon with 4 corners.
To make one of them 'round', click it in the drawing (it turns red) then
press the button showing a curve with 3 point symbols (under the green
plus). Two "ghost points" will appear near the selected drawing point
and the curve will be distorted near that point. To change the shape of
the distortion, drag these "ghost points" (presumably the Bezier
handles) to new locations. To get a nice smooth shape the Bezier points
and the original point should be roughly on a straight tangent line
relative to the curve.
Screenshot 1 (polygon builder)
https://gyazo.com/ea2f78ac043499612fde635e5c4197ee
Obviously, the idea is that the "OpenSCAD code" window contains code for
an extended polygon producing the same shape, you just cut/paste the
generated code into OpenSCAD
Screenshot 2 (OpenSCAD)
https://gyazo.com/00ae59cd254035568d6a1283ddca7830
Rob
Referring to the polygon builder at http://daid.eu/~daid/3d/ I figured out how to use it, it is quite easy. To draw a polygon, press the green plus button and click in the drawing area repeatedly to lay out the polygon points. To remove a point, press the red minus button and click one of the points to make it go away. To change the position of a point, press the mouse cursor button, then point to one of the points drawn, press and hold left mouse button (point turns red) and drag the point to the new location. Making rounded corners. Let us assume you have a polygon with 4 corners. To make one of them 'round', click it in the drawing (it turns red) then press the button showing a curve with 3 point symbols (under the green plus). Two "ghost points" will appear near the selected drawing point and the curve will be distorted near that point. To change the shape of the distortion, drag these "ghost points" (presumably the Bezier handles) to new locations. To get a nice smooth shape the Bezier points and the original point should be roughly on a straight tangent line relative to the curve. Screenshot 1 (polygon builder) https://gyazo.com/ea2f78ac043499612fde635e5c4197ee Obviously, the idea is that the "OpenSCAD code" window contains code for an extended polygon producing the same shape, you just cut/paste the generated code into OpenSCAD Screenshot 2 (OpenSCAD) https://gyazo.com/00ae59cd254035568d6a1283ddca7830 Carsten Arnholm On 08. okt. 2016 03:02, Rob Ward wrote: > It looks very interesting, but I too find it of no use. Is there a > drawing package that is has been modeled on (that I obviously have never > used before) that might explain how to use it. The programmer seem > assume a lot of prior knowledge, and experience. It just appears to > randomly add points and lines once the initial line is drawn. Is it just > a proof of principle, not a finished product? Nice .js work all the same. > > Rob > > > On 07/10/16 04:30, jon wrote: >> Thank you, Torsten, but this "tool" is not documented sufficiently for >> me to even understand where to start. >> >> Jon >> >> >> On 10/6/2016 1:05 PM, Torsten Paul wrote: >>> On 10/06/2016 01:49 PM, jon wrote: >>>> Or a tool that allows you to position Bezier handles >>>> which are then converted to smoothed lines and then >>>> imported into OpenSCAD >>>> >>> Not integrated, but still nice way to just draw polygon: >>> >>> http://daid.eu/~daid/3d/ >>> >>> source: https://github.com/daid/OpenSCAD-polygon-editor >>> >>> ciao, >>> Torsten. >>> >>> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sat, Oct 8, 2016 1:03 PM
Thank you, Carsten.  The polygon builder is quite useful, if only as a
starting point for a more parametric approach.
same.
Rob
Checked by AVG - www.avg.com
Version: 2016.0.7797 / Virus Database: 4656/13167 - Release Date:
10/07/16
Thank you, Carsten. The polygon builder is quite useful, if only as a starting point for a more parametric approach. Jon On 10/8/2016 4:41 AM, Carsten Arnholm wrote: > Referring to the polygon builder at http://daid.eu/~daid/3d/ > > I figured out how to use it, it is quite easy. > > To draw a polygon, press the green plus button and click in the > drawing area repeatedly to lay out the polygon points. > > To remove a point, press the red minus button and click one of the > points to make it go away. > > To change the position of a point, press the mouse cursor button, then > point to one of the points drawn, press and hold left mouse button > (point turns red) and drag the point to the new location. > > Making rounded corners. Let us assume you have a polygon with 4 > corners. To make one of them 'round', click it in the drawing (it > turns red) then press the button showing a curve with 3 point symbols > (under the green plus). Two "ghost points" will appear near the > selected drawing point and the curve will be distorted near that > point. To change the shape of the distortion, drag these "ghost > points" (presumably the Bezier handles) to new locations. To get a > nice smooth shape the Bezier points and the original point should be > roughly on a straight tangent line relative to the curve. > > Screenshot 1 (polygon builder) > https://gyazo.com/ea2f78ac043499612fde635e5c4197ee > > Obviously, the idea is that the "OpenSCAD code" window contains code > for an extended polygon producing the same shape, you just cut/paste > the generated code into OpenSCAD > > Screenshot 2 (OpenSCAD) > https://gyazo.com/00ae59cd254035568d6a1283ddca7830 > > Carsten Arnholm > > On 08. okt. 2016 03:02, Rob Ward wrote: >> It looks very interesting, but I too find it of no use. Is there a >> drawing package that is has been modeled on (that I obviously have never >> used before) that might explain how to use it. The programmer seem >> assume a lot of prior knowledge, and experience. It just appears to >> randomly add points and lines once the initial line is drawn. Is it just >> a proof of principle, not a finished product? Nice .js work all the >> same. >> >> Rob >> >> >> On 07/10/16 04:30, jon wrote: >>> Thank you, Torsten, but this "tool" is not documented sufficiently for >>> me to even understand where to start. >>> >>> Jon >>> >>> >>> On 10/6/2016 1:05 PM, Torsten Paul wrote: >>>> On 10/06/2016 01:49 PM, jon wrote: >>>>> Or a tool that allows you to position Bezier handles >>>>> which are then converted to smoothed lines and then >>>>> imported into OpenSCAD >>>>> >>>> Not integrated, but still nice way to just draw polygon: >>>> >>>> http://daid.eu/~daid/3d/ >>>> >>>> source: https://github.com/daid/OpenSCAD-polygon-editor >>>> >>>> ciao, >>>> Torsten. >>>> >>>> >>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7797 / Virus Database: 4656/13167 - Release Date: > 10/07/16 > >
Jerry Davis
Sat, Oct 8, 2016 1:49 PM
Carsten: Nice work documenting this.
I had no idea about the nice curving options.
You seem to know quite a bit about this tool:
Do you know what the button on the right does (brings up the url and file
option)? And how to use it?
How do you add points that you want to be in between two other points
instead of adding the point at the end?
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
Raspberry Pi and Openscad developer
The most exciting phrase to hear in science - the one that heralds new
discoveries - is not "Eureka!" but "That's funny...".
- Isaac. Asimov
to make it go away.
curve.
Rob
Carsten: Nice work documenting this. I had no idea about the nice curving options. You seem to know quite a bit about this tool: Do you know what the button on the right does (brings up the url and file option)? And how to use it? How do you add points that you want to be in between two other points instead of adding the point at the end? -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Openscad developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov On Sat, Oct 8, 2016 at 1:41 AM, Carsten Arnholm <arnholm@arnholm.org> wrote: > Referring to the polygon builder at http://daid.eu/~daid/3d/ > > I figured out how to use it, it is quite easy. > > To draw a polygon, press the green plus button and click in the drawing > area repeatedly to lay out the polygon points. > > To remove a point, press the red minus button and click one of the points > to make it go away. > > To change the position of a point, press the mouse cursor button, then > point to one of the points drawn, press and hold left mouse button (point > turns red) and drag the point to the new location. > > Making rounded corners. Let us assume you have a polygon with 4 corners. > To make one of them 'round', click it in the drawing (it turns red) then > press the button showing a curve with 3 point symbols (under the green > plus). Two "ghost points" will appear near the selected drawing point and > the curve will be distorted near that point. To change the shape of the > distortion, drag these "ghost points" (presumably the Bezier handles) to > new locations. To get a nice smooth shape the Bezier points and the > original point should be roughly on a straight tangent line relative to the > curve. > > Screenshot 1 (polygon builder) > https://gyazo.com/ea2f78ac043499612fde635e5c4197ee > > Obviously, the idea is that the "OpenSCAD code" window contains code for > an extended polygon producing the same shape, you just cut/paste the > generated code into OpenSCAD > > Screenshot 2 (OpenSCAD) > https://gyazo.com/00ae59cd254035568d6a1283ddca7830 > > Carsten Arnholm > > > On 08. okt. 2016 03:02, Rob Ward wrote: > >> It looks very interesting, but I too find it of no use. Is there a >> drawing package that is has been modeled on (that I obviously have never >> used before) that might explain how to use it. The programmer seem >> assume a lot of prior knowledge, and experience. It just appears to >> randomly add points and lines once the initial line is drawn. Is it just >> a proof of principle, not a finished product? Nice .js work all the same. >> >> Rob >> >> >> On 07/10/16 04:30, jon wrote: >> >>> Thank you, Torsten, but this "tool" is not documented sufficiently for >>> me to even understand where to start. >>> >>> Jon >>> >>> >>> On 10/6/2016 1:05 PM, Torsten Paul wrote: >>> >>>> On 10/06/2016 01:49 PM, jon wrote: >>>> >>>>> Or a tool that allows you to position Bezier handles >>>>> which are then converted to smoothed lines and then >>>>> imported into OpenSCAD >>>>> >>>>> Not integrated, but still nice way to just draw polygon: >>>> >>>> http://daid.eu/~daid/3d/ >>>> >>>> source: https://github.com/daid/OpenSCAD-polygon-editor >>>> >>>> ciao, >>>> Torsten. >>>> >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sat, Oct 8, 2016 3:36 PM
Hi Jerry,
Well, I had not seen the tool before, I am just able to guess :-) Now I
guessed what the file option is all about: You are supposed to pick up
an image file to use as background for manual sketching.
At first I tried an OpenSCAD source file ... I thought perhaps it could
read a polygon as well as write one, but then it complained that the
file I gave it wasn't an image. That gave me a hint it wanted an image :-)
So I tried the Ford logo image file (.png) and it worked
https://gyazo.com/094c5662fa9aea39373a0b9b811d9c10
The window that says "Paths" allows you to define several individual
paths (a.k.a. polygons) in the same sketch, click [New] to start a new
path. To do the Ford logo example manually it means 4 different
polygons/paths.
  • outer contour of the letter "F"
  • inner contour of the small loop in the letter "F"
  • outer contour of the letters "ord"
  • inner contour of the letter "d"
So in theory you could sketch the logo by tracing the image manually,
but it gets complicated/tedious and inaccurate. It is much better to use
an automatic tool when possible. For simpler stuff I guess it could
work, or if the image is not directly suitable for automatic analysis
(some are not).
Apparently, there is no way to use the GUI to add points in between to
other points, or at least I could not figure it out. You can always
insert the extra point by typing in the correct place in the tiny
"OpenSCAD code" window, then the curve will be updated correctly.
However, this to some degree defeats the purpose of the tool, because
you are then back to editing the source directly, just in a much smaller
window than usual....
I also tried pasting polygon code from OpenSCAD into the code window,
but that failed when the coordinates were outside the window range, the
polygon builder does not fit the coordinates automatically, and it does
not understand scale() or other transformations. It just not usable for
too large or too small coordinates. It also turns out that the
definition of "too small" and "too large" is unclear, I opened the
polygon builder in Firefox on both Windows7 and Kubuntu 15.10, for some
reason the x-range is [-72,72] on Kubuntu and [-88,88] on Win7, so when
I copied a polygon from polygon builder from Win7 to Kubuntu, parts of
the polygon were hidden under the toolbox and I could not reach it.
It is a nice idea, but with clear limitations.
On 08. okt. 2016 15:49, Jerry Davis wrote: > Carsten: Nice work documenting this. > > I had no idea about the nice curving options. > > You seem to know quite a bit about this tool: > > Do you know what the button on the right does (brings up the url and > file option)? And how to use it? > > How do you add points that you want to be in between two other points > instead of adding the point at the end? Hi Jerry, Well, I had not seen the tool before, I am just able to guess :-) Now I guessed what the file option is all about: You are supposed to pick up an image file to use as background for manual sketching. At first I tried an OpenSCAD source file ... I thought perhaps it could read a polygon as well as write one, but then it complained that the file I gave it wasn't an image. That gave me a hint it wanted an image :-) So I tried the Ford logo image file (.png) and it worked https://gyazo.com/094c5662fa9aea39373a0b9b811d9c10 The window that says "Paths" allows you to define several individual paths (a.k.a. polygons) in the same sketch, click [New] to start a new path. To do the Ford logo example manually it means 4 different polygons/paths. - outer contour of the letter "F" - inner contour of the small loop in the letter "F" - outer contour of the letters "ord" - inner contour of the letter "d" So in theory you could sketch the logo by tracing the image manually, but it gets complicated/tedious and inaccurate. It is much better to use an automatic tool when possible. For simpler stuff I guess it could work, or if the image is not directly suitable for automatic analysis (some are not). Apparently, there is no way to use the GUI to add points in between to other points, or at least I could not figure it out. You can always insert the extra point by typing in the correct place in the tiny "OpenSCAD code" window, then the curve will be updated correctly. However, this to some degree defeats the purpose of the tool, because you are then back to editing the source directly, just in a much smaller window than usual.... I also tried pasting polygon code from OpenSCAD into the code window, but that failed when the coordinates were outside the window range, the polygon builder does not fit the coordinates automatically, and it does not understand scale() or other transformations. It just not usable for too large or too small coordinates. It also turns out that the definition of "too small" and "too large" is unclear, I opened the polygon builder in Firefox on both Windows7 and Kubuntu 15.10, for some reason the x-range is [-72,72] on Kubuntu and [-88,88] on Win7, so when I copied a polygon from polygon builder from Win7 to Kubuntu, parts of the polygon were hidden under the toolbox and I could not reach it. It is a nice idea, but with clear limitations. Carsten Arnholm
Jerry Davis
Sat, Oct 8, 2016 4:19 PM
yes, it is a nice idea. And I can live with some of the limitations.
I have been able to do some stuff with that tool, that eluded me until now.
I can now put in a rough idea of what I want to build, "smooth" it, and
achieve a reasonable result.
- Isaac. Asimov
Hi Jerry,
yes, it is a nice idea. And I can live with some of the limitations. I have been able to do some stuff with that tool, that eluded me until now. I can now put in a rough idea of what I want to build, "smooth" it, and achieve a reasonable result. -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Openscad developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov On Sat, Oct 8, 2016 at 8:36 AM, Carsten Arnholm <arnholm@arnholm.org> wrote: > On 08. okt. 2016 15:49, Jerry Davis wrote: > >> Carsten: Nice work documenting this. >> >> I had no idea about the nice curving options. >> >> You seem to know quite a bit about this tool: >> >> Do you know what the button on the right does (brings up the url and >> file option)? And how to use it? >> >> How do you add points that you want to be in between two other points >> instead of adding the point at the end? >> > > Hi Jerry, > > Well, I had not seen the tool before, I am just able to guess :-) Now I > guessed what the file option is all about: You are supposed to pick up an > image file to use as background for manual sketching. > > At first I tried an OpenSCAD source file ... I thought perhaps it could > read a polygon as well as write one, but then it complained that the file I > gave it wasn't an image. That gave me a hint it wanted an image :-) > > So I tried the Ford logo image file (.png) and it worked > https://gyazo.com/094c5662fa9aea39373a0b9b811d9c10 > > The window that says "Paths" allows you to define several individual paths > (a.k.a. polygons) in the same sketch, click [New] to start a new path. To > do the Ford logo example manually it means 4 different polygons/paths. > > - outer contour of the letter "F" > - inner contour of the small loop in the letter "F" > - outer contour of the letters "ord" > - inner contour of the letter "d" > > So in theory you could sketch the logo by tracing the image manually, but > it gets complicated/tedious and inaccurate. It is much better to use an > automatic tool when possible. For simpler stuff I guess it could work, or > if the image is not directly suitable for automatic analysis (some are not). > > Apparently, there is no way to use the GUI to add points in between to > other points, or at least I could not figure it out. You can always insert > the extra point by typing in the correct place in the tiny "OpenSCAD code" > window, then the curve will be updated correctly. However, this to some > degree defeats the purpose of the tool, because you are then back to > editing the source directly, just in a much smaller window than usual.... > > I also tried pasting polygon code from OpenSCAD into the code window, but > that failed when the coordinates were outside the window range, the polygon > builder does not fit the coordinates automatically, and it does not > understand scale() or other transformations. It just not usable for too > large or too small coordinates. It also turns out that the definition of > "too small" and "too large" is unclear, I opened the polygon builder in > Firefox on both Windows7 and Kubuntu 15.10, for some reason the x-range is > [-72,72] on Kubuntu and [-88,88] on Win7, so when I copied a polygon from > polygon builder from Win7 to Kubuntu, parts of the polygon were hidden > under the toolbox and I could not reach it. > > It is a nice idea, but with clear limitations. > > Carsten Arnholm > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sat, Oct 8, 2016 4:22 PM
No idea, from what I see looking at the github
project, it's a simple but useful tool created on
a weekend 5 years ago. It's certainly not a finished
product, I don't even think it makes sense to push
it that way.
Would it be useful to deploy in a bit more visible
location and add the nice docs Carsten wrote in the
previous messages?
I guess we could ask Daid to clarify the license.
On 10/08/2016 03:02 AM, Rob Ward wrote: > Is it just a proof of principle, not a finished product? > Nice .js work all the same. > No idea, from what I see looking at the github project, it's a simple but useful tool created on a weekend 5 years ago. It's certainly not a finished product, I don't even think it makes sense to push it that way. Would it be useful to deploy in a bit more visible location and add the nice docs Carsten wrote in the previous messages? I guess we could ask Daid to clarify the license. ciao, Torsten.
Sun, Oct 9, 2016 12:53 AM
cacb wrote
You can always
There is a resize tool on the bottom right of the text box. It's a big
clunky, you need to drag slowly.
You can also drag the toolbox elsewhere if you need to.
View this message in context: http://forum.openscad.org/Fusion360-and-OpenSCAD-tp18493p18622.html
cacb wrote > You can always > insert the extra point by typing in the correct place in the tiny > "OpenSCAD code" window, then the curve will be updated correctly. > However, this to some degree defeats the purpose of the tool, because > you are then back to editing the source directly, just in a much smaller > window than usual.... There is a resize tool on the bottom right of the text box. It's a big clunky, you need to drag slowly. You can also drag the toolbox elsewhere if you need to. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Fusion360-and-OpenSCAD-tp18493p18622.html Sent from the OpenSCAD mailing list archive at Nabble.com.
