Thanks for those hints. It makes more sense to me now with a few
starters. Nice 2D editor. As well as the other features mentioned, I
particularly like the two "handles" controlling the Beziers being
independent at the point where they are created. I don't like the other
systems where the Bezier point has controls on either side of the point
connected like symmetrical dumbbells. Plus the <scroll mouse>+CTRL
provides a basic Zoom feature as well.
Rob
On 09/10/16 02:36, Carsten Arnholm wrote:
On 08. okt. 2016 15:49, Jerry Davis wrote:
Carsten: Nice work documenting this.
I had no idea about the nice curving options.
You seem to know quite a bit about this tool:
Do you know what the button on the right does (brings up the url and
file option)? And how to use it?
How do you add points that you want to be in between two other points
instead of adding the point at the end?
Hi Jerry,
Well, I had not seen the tool before, I am just able to guess :-) Now
I guessed what the file option is all about: You are supposed to pick
up an image file to use as background for manual sketching.
At first I tried an OpenSCAD source file ... I thought perhaps it
could read a polygon as well as write one, but then it complained that
the file I gave it wasn't an image. That gave me a hint it wanted an
image :-)
So I tried the Ford logo image file (.png) and it worked
https://gyazo.com/094c5662fa9aea39373a0b9b811d9c10
The window that says "Paths" allows you to define several individual
paths (a.k.a. polygons) in the same sketch, click [New] to start a new
path. To do the Ford logo example manually it means 4 different
polygons/paths.
So in theory you could sketch the logo by tracing the image manually,
but it gets complicated/tedious and inaccurate. It is much better to
use an automatic tool when possible. For simpler stuff I guess it
could work, or if the image is not directly suitable for automatic
analysis (some are not).
Apparently, there is no way to use the GUI to add points in between to
other points, or at least I could not figure it out. You can always
insert the extra point by typing in the correct place in the tiny
"OpenSCAD code" window, then the curve will be updated correctly.
However, this to some degree defeats the purpose of the tool, because
you are then back to editing the source directly, just in a much
smaller window than usual....
I also tried pasting polygon code from OpenSCAD into the code window,
but that failed when the coordinates were outside the window range,
the polygon builder does not fit the coordinates automatically, and it
does not understand scale() or other transformations. It just not
usable for too large or too small coordinates. It also turns out that
the definition of "too small" and "too large" is unclear, I opened the
polygon builder in Firefox on both Windows7 and Kubuntu 15.10, for
some reason the x-range is [-72,72] on Kubuntu and [-88,88] on Win7,
so when I copied a polygon from polygon builder from Win7 to Kubuntu,
parts of the polygon were hidden under the toolbox and I could not
reach it.
It is a nice idea, but with clear limitations.
Rob Ward
Lake Tyers Beach, 3909
Lake Tyers Beach Website http://www.laketyersbeach.net.au
XP to XUbuntu http://www.laketyersbeach.net.au/XP2XU.html
On 09. okt. 2016 02:53, MichaelAtOz wrote:
There is a resize tool on the bottom right of the text box. It's a big
clunky, you need to drag slowly.
You can also drag the toolbox elsewhere if you need to.
Ah, yes you are right on both accounts. It makes it a bit more useful.
Odd resize feature, but with a bit of care it works. Thanks.
On 06. okt. 2016 18:58, Torsten Paul wrote:
We still need to work out some of the details, but
https://github.com/openscad/openscad/pull/1110 should
be able to handle at least the simpler cases using
the potrace library.
I have been playing a bit more with generating 3d models from images or
other data sources. For the case of an image, instead of using potrace,
the idea was to automatically generate the modeller code to create a
'language version' of a profile.
For example, using this image as input
http://arnholm.org/tmp/profiles/guy.png
OpenSCAD code was generated, the image profile is now a module:
http://arnholm.org/tmp/profiles/guy.scad
Same thing in AngelScript code, the image profile is now a function
http://arnholm.org/tmp/profiles/guy.as
Both produce very similar looking results, using quite different
internal libraries. Regardless of the preferred modeller, with such an
approach one can build a library of profiles expressed directly in the
modeller language, not having to rely on external files.
I also find it interesting to compare the syntax. In Angelscript, the
shapes are real language variables that can be modified. Assembling the
final model is a simple linear process where the profile object is
modified several times. In OpenSCAD it has to be expressed as a
recursion, not quite as easy IMHO. But in both cases the result is the same.
Regards
