jamcultur
Tue, Mar 27, 2018 8:46 PM
As I mentioned in another thread, I have a long complicated piece of OpenSCAD
code that I am trying to
simplify so that I can enhance it, but I haven't found a way that works yet.
My latest attempt to modularize the code failed, and I don't understand why.
Here's a simplified example with three .scad files.
part1.scad___________
module part1() {
echo("part1");
part2();
part2.scad___________
module part2() {
echo("part2");
part_test.scad_________
use <part1.scad>
use <part2.scad>
part1();
When I try to preview or render part_test.scad, I get the message, "WARNING:
Ignoring unknown module 'part2', even though there is a "use <part2.scad>"
statement in the file, and part2.scad is in the same directory. If I move
the "use <part2.scad>" statement from part_test.scad, to part1.scad, it
works, but that structure would not allow me to modularize my code in a
useful way. Is there a way to make this work?
module part1() {
echo("part1");
part2();
____________________
module part2() {
echo("part2");
use <part1.scad>
use <part2.scad>
part1();
Tue, Mar 27, 2018 8:59 PM
part2() is defined only after the compilation of part1.scad. Reverse the
use's order in part_test.scad.
Em ter, 27 de mar de 2018 21:46, jamcultur nyponen@gmail.com escreveu:
OpenSCAD
yet.
why.
module part1() {
echo("part1");
part2();
module part2() {
echo("part2");
use <part1.scad>
use <part2.scad>
part1();
"WARNING:
Em ter, 27 de mar de 2018 21:46, jamcultur <nyponen@gmail.com> escreveu:
> OpenSCAD
> yet.
> why.
> module part1() {
> echo("part1");
> part2();
> module part2() {
> echo("part2");
> use <part1.scad>
> use <part2.scad>
> part1();
> "WARNING:
> Sent from: http://forum.openscad.org/
Tue, Mar 27, 2018 9:09 PM
I don't think that will work.
part1.scad uses part2, so it must use part2.scad.
part_test.scad only needs to use part1.scad.
OpenSCAD
yet.
why.
module part1() {
echo("part1");
part2();
module part2() {
echo("part2");
use <part1.scad>
use <part2.scad>
part1();
"WARNING:
<part2.scad>"
>> OpenSCAD
>> yet.
>> why.
>> module part1() {
>> echo("part1");
>> part2();
>> module part2() {
>> echo("part2");
>> use <part1.scad>
>> use <part2.scad>
>> part1();
>> "WARNING:
>> <part2.scad>"
>> _______________________________________________
jamcultur
Tue, Mar 27, 2018 9:13 PM
I tried that, and it didn't work. I still get the message WARNING: Ignoring
unknown module 'part2'.
HJ
Hugo Jackson
Tue, Mar 27, 2018 9:49 PM
I think your error message is not from “part_test.scad” but from part1.scad which can’t find part2.
If you add
use <part2.scad> to part.scad like this:
part1.scad _________
use <part2.scad>
module part1() {
echo(“part1”);
part2();
It should work fine.
module part1() {
echo("part1");
part2();
module part2() {
echo("part2");
use <part1.scad>
use <part2.scad>
part1();
If you add
use <part2.scad>
module part1() {
echo(“part1”);
part2();
> module part1() {
> echo("part1");
> part2();
> module part2() {
> echo("part2");
> use <part1.scad>
> use <part2.scad>
> part1();
HJ
Hugo Jackson
Tue, Mar 27, 2018 9:50 PM
sorry… duh… I see thats you know that.
Tue, Mar 27, 2018 10:16 PM
On 3/27/2018 1:46 PM, jamcultur wrote:
If I move the "use <part2.scad>" statement from part_test.scad, to part1.scad, it works, but that structure would not allow me to modularize my code in a useful way.
Actually, it's requiring you to modularize your program.
The main program invokes only part1. It doesn't know about part2. It
is only part1 that knows that it needs part2, so it is the one that
needs the "use".
Actually, it's *requiring* you to modularize your program.
needs the "use".
jamcultur
Tue, Mar 27, 2018 11:35 PM
<part2.scad>
needs the "use".
I need part1 and part2 to be independent modules without any information
about each other. That is so that I can code different versions of part_test
that use different versions of part1 and part2. I want any version of part1
to work with any version of part2. That won't work if put the use for a
particular version of part2 in part1.
>> If I move the "use
> <part2.scad>
> needs the "use".
doug moen
Wed, Mar 28, 2018 12:10 AM
Then I guess you need include instead of use.
<part2.scad>
needs the "use".
Then I guess you need `include` instead of `use`.
On 27 March 2018 at 19:35, jamcultur <nyponen@gmail.com> wrote:
> >> If I move the "use
> > <part2.scad>
> > needs the "use".
> part_test
Wed, Mar 28, 2018 9:33 AM
Or pass part2 to part1 as a child.
<part2.scad>
needs the "use".
>> >> If I move the "use
>> > <part2.scad>
>> > needs the "use".
>> part_test
>> part1
