Why doesn't this use statement work?
jamcultur
Wed, Mar 28, 2018 4:09 PM
doug.moen wrote
Then I guess you need include instead of use.
Include doesn't work for the same reason as use. It needs to be placed in
part1.scad instead of part_test.scad.
doug.moen wrote > Then I guess you need `include` instead of `use`. Include doesn't work for the same reason as use. It needs to be placed in part1.scad instead of part_test.scad. -- Sent from: http://forum.openscad.org/
jamcultur
Wed, Mar 28, 2018 4:12 PM
nophead wrote
Or pass part2 to part1 as a child.
Could you explain how to pass part2 to part1 as a child? I've already tried
to use children() to do what I want to do, and it didn't work, as I
described in this post:
children() doesn't work with objects generated in a for loop
http://forum.openscad.org/How-to-apply-changes-to-all-shapes-generated-in-a-for-loop-td23685.html
nophead wrote > Or pass part2 to part1 as a child. Could you explain how to pass part2 to part1 as a child? I've already tried to use children() to do what I want to do, and it didn't work, as I described in this post: children() doesn't work with objects generated in a for loop <http://forum.openscad.org/How-to-apply-changes-to-all-shapes-generated-in-a-for-loop-td23685.html> -- Sent from: http://forum.openscad.org/
doug moen
Wed, Mar 28, 2018 4:26 PM
I tested the following and it works for me.
part1.scad___________
module part1() {
echo("part1");
part2();
part2.scad___________
module part2() {
echo("part2");
part_test.scad_________
include <part1.scad>
include <part2.scad>
part1();
I tested the following and it works for me. part1.scad___________ module part1() { echo("part1"); part2(); } ____________________ part2.scad___________ module part2() { echo("part2"); } ____________________ part_test.scad_________ include <part1.scad> include <part2.scad> part1(); ____________________ On 28 March 2018 at 12:09, jamcultur <nyponen@gmail.com> wrote: > doug.moen wrote > > Then I guess you need `include` instead of `use`. > > Include doesn't work for the same reason as use. It needs to be placed in > part1.scad instead of part_test.scad. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Mar 28, 2018 4:42 PM
Well yes and no. A for loop produces a union of all its iterations, so only
produces one child. I think modules do the same. Nothing can return
multiple children, you can only pass them explicitly as a list.
But for this case it would work to decouple part1 and part 2.
module part1() {
echo("part1");
module part2() {
echo("part2");
use <part1.scad>
use <part2.scad>
part1() part2();
module part1() {
echo("part1");
part2();
module part2() {
echo("part2");
part1();
>children() doesn't work with objects generated in a for loop Well yes and no. A for loop produces a union of all its iterations, so only produces one child. I think modules do the same. Nothing can return multiple children, you can only pass them explicitly as a list. But for this case it would work to decouple part1 and part 2. part1.scad___________ module part1() { echo("part1"); children(); } ____________________ part2.scad___________ module part2() { echo("part2"); } ____________________ part_test.scad_________ use <part1.scad> use <part2.scad> part1() part2(); On 28 March 2018 at 17:26, doug moen <doug@moens.org> wrote: > I tested the following and it works for me. > > part1.scad___________ > > module part1() { > echo("part1"); > part2(); > } > ____________________ > > > part2.scad___________ > > module part2() { > echo("part2"); > } > ____________________ > > > part_test.scad_________ > > include <part1.scad> > include <part2.scad> > > part1(); > ____________________ > > > On 28 March 2018 at 12:09, jamcultur <nyponen@gmail.com> wrote: > >> doug.moen wrote >> > Then I guess you need `include` instead of `use`. >> >> Include doesn't work for the same reason as use. It needs to be placed in >> part1.scad instead of part_test.scad. >> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
jamcultur
Fri, Mar 30, 2018 3:05 PM
include
<part1.scad>
include
<part2.scad>
part1();
It didn't work when I first tested it because I had
use <part1.scad>
I did that because I had some code in part1.scad that I didn't want to be
executed when the file was included. When I took that code out and included
both files, it worked. I think this might be the best solution for me and I
will continue testing it. Thank you!
doug.moen wrote > I tested the following and it works for me. > > part_test.scad_________ > > include > <part1.scad> > include > <part2.scad> > part1(); > ____________________ It didn't work when I first tested it because I had use <part1.scad> include <part2.scad> I did that because I had some code in part1.scad that I didn't want to be executed when the file was included. When I took that code out and included both files, it worked. I think this might be the best solution for me and I will continue testing it. Thank you! -- Sent from: http://forum.openscad.org/
jamcultur
Fri, Mar 30, 2018 3:08 PM
only
module part1() {
echo("part1");
module part2() {
echo("part2");
use
<part1.scad>
use
<part2.scad>
part1() part2();
I haven't tested this yet to see if it will work with my code that generates
objects in a loop, but I will. Thanks.
nophead wrote >>children() doesn't work with objects generated in a for loop > > Well yes and no. A for loop produces a union of all its iterations, so > only > produces one child. I think modules do the same. Nothing can return > multiple children, you can only pass them explicitly as a list. > > But for this case it would work to decouple part1 and part 2. > > part1.scad___________ > > module part1() { > echo("part1"); > children(); > } > ____________________ > > > part2.scad___________ > > module part2() { > echo("part2"); > } > ____________________ > > > part_test.scad_________ > > use > <part1.scad> > use > <part2.scad> > part1() part2(); I haven't tested this yet to see if it will work with my code that generates objects in a loop, but I will. Thanks. -- Sent from: http://forum.openscad.org/
Fri, Mar 30, 2018 5:19 PM
I don't think you can generate objects in a loop. It is always a single
object because the results are implicitly unioned. The only way I know to
get multiple children is to list them explicitly. E.g.
part1() {
part2();
cube();
sphere();
only
module part1() {
echo("part1");
module part2() {
echo("part2");
use
<part1.scad>
use
<part2.scad>
part1() part2();
generates
I don't think you can generate objects in a loop. It is always a single object because the results are implicitly unioned. The only way I know to get multiple children is to list them explicitly. E.g. part1() { part2(); cube(); sphere(); } On 30 March 2018 at 16:08, jamcultur <nyponen@gmail.com> wrote: > nophead wrote > >>children() doesn't work with objects generated in a for loop > > > > Well yes and no. A for loop produces a union of all its iterations, so > > only > > produces one child. I think modules do the same. Nothing can return > > multiple children, you can only pass them explicitly as a list. > > > > But for this case it would work to decouple part1 and part 2. > > > > part1.scad___________ > > > > module part1() { > > echo("part1"); > > children(); > > } > > ____________________ > > > > > > part2.scad___________ > > > > module part2() { > > echo("part2"); > > } > > ____________________ > > > > > > part_test.scad_________ > > > > use > > <part1.scad> > > use > > <part2.scad> > > part1() part2(); > > I haven't tested this yet to see if it will work with my code that > generates > objects in a loop, but I will. Thanks. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Fri, Mar 30, 2018 5:45 PM
part1() {
    part2();
    cube();
   sphere();
[ Just thinking out loud.  This seems like an interesting idea; I'm not
pushing hard for it. ]
I wonder how reasonable it would be to have a construct that would take
a CSG tree and crack it apart into individual subtrees.
That is, "explode() union() { x; y; }" would be equivalent to "x; y;".
(For operations other than "union" maybe it would be an error, or maybe
the operation would be discarded.)
From a tree manipulation standpoint it seems plausible, and it seems
like it might be useful, e.g. allowing a wrapper module to pass its
children to an inner module as individual objects:
module inner() {
	// do something with children
	echo($children);
module outer() {
	// do stuff, then invoke inner on the children
	inner() explode() children();
outer() {
	sphere();
	cube();
would echo 2, not 1.
From a syntactic perspective, I'm bothered by having something that
looks like a module but yields more than one object.  It seems like some
kind of different syntax would be desirable.
On 3/30/2018 10:19 AM, nop head wrote: > I don't think you can generate objects in a loop. It is always a > single object because the results are implicitly unioned. The only way > I know to get multiple children is to list them explicitly. E.g. > > part1() { >     part2(); >     cube(); >    sphere(); > } [ Just thinking out loud.  This seems like an interesting idea; I'm not pushing hard for it. ] I wonder how reasonable it would be to have a construct that would take a CSG tree and crack it apart into individual subtrees. That is, "explode() union() { x; y; }" would be equivalent to "x; y;".  (For operations other than "union" maybe it would be an error, or maybe the operation would be discarded.) >From a tree manipulation standpoint it seems plausible, and it seems like it might be useful, e.g. allowing a wrapper module to pass its children to an inner module as individual objects: module inner() { // do something with children echo($children); } module outer() { // do stuff, then invoke inner on the children inner() explode() children(); } outer() { sphere(); cube(); } would echo 2, not 1. >From a syntactic perspective, I'm bothered by having something that looks like a module but yields more than one object.  It seems like some kind of different syntax would be desirable.
jamcultur
Fri, Mar 30, 2018 8:24 PM
I tried nophead's solution in my code, and it worked. In case anyone is
interested, my code is a jewelry design program. I've made about 60 designs
with the previous version. Here is a pendant I designed with it that I cast
in sterling silver.
http://forum.openscad.org/file/t1635/AlienArthropod3.jpg
Although the previous version could be used to design a huge range of
geometric and fractal designs, there were things I wanted to do with it that
it couldn't do. The reorganized version is much more powerful, flexible, and
extendable. Here's a design I made to test the reorganized code. This design
would have been impossible with the previous version, but was easy with the
reorganized version.
http://forum.openscad.org/file/t1635/1a.png
http://forum.openscad.org/file/t1635/1b.png
I probably won't make this one in metal. It's not really my style. But I'm
excited about what I can now design.
I tried nophead's solution in my code, and it worked. In case anyone is interested, my code is a jewelry design program. I've made about 60 designs with the previous version. Here is a pendant I designed with it that I cast in sterling silver. <http://forum.openscad.org/file/t1635/AlienArthropod3.jpg> Although the previous version could be used to design a huge range of geometric and fractal designs, there were things I wanted to do with it that it couldn't do. The reorganized version is much more powerful, flexible, and extendable. Here's a design I made to test the reorganized code. This design would have been impossible with the previous version, but was easy with the reorganized version. <http://forum.openscad.org/file/t1635/1a.png> <http://forum.openscad.org/file/t1635/1b.png> I probably won't make this one in metal. It's not really my style. But I'm excited about what I can now design. -- Sent from: http://forum.openscad.org/
Sun, Apr 1, 2018 8:07 AM
In that case, that's a hint we should think about possibly chaiging
things in the language.
The C language was designed so that the basic functions do things that
are useful, but also that they don't do too much. For example, printf
does not automatically add a newline. writing a function to add that
is easy, building something that removes the newline is not.
So.... a list of objects is easily unioned by adding union in
front, while a unioned list is not easily un-unioned.
for (i=[0:10:50])
translate ([i,i,0]) cube (15);
should give me the list of 6 cubes,  while
union () {
for (i=[0:10:50])
gives the union of those objects.
only
module part1() {
echo("part1");
module part2() {
echo("part2");
use
<part1.scad>
use
<part2.scad>
part1() part2();
generates
** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 **
**    Delftechpark 26 2628 XH  Delft, The Netherlands. KVK: 27239233    **
-- BitWizard writes Linux device drivers for any device you may have! --
On Fri, Mar 30, 2018 at 06:19:27PM +0100, nop head wrote: > I don't think you can generate objects in a loop. It is always a single > object because the results are implicitly unioned. In that case, that's a hint we should think about possibly chaiging things in the language. The C language was designed so that the basic functions do things that are useful, but also that they don't do too much. For example, printf does not automatically add a newline. writing a function to add that is easy, building something that removes the newline is not. So.... a list of objects is easily unioned by adding union in front, while a unioned list is not easily un-unioned. for (i=[0:10:50]) translate ([i,i,0]) cube (15); should give me the list of 6 cubes, while union () { for (i=[0:10:50]) translate ([i,i,0]) cube (15); } gives the union of those objects. Roger. > > On 30 March 2018 at 16:08, jamcultur <nyponen@gmail.com> wrote: > > > nophead wrote > > >>children() doesn't work with objects generated in a for loop > > > > > > Well yes and no. A for loop produces a union of all its iterations, so > > > only > > > produces one child. I think modules do the same. Nothing can return > > > multiple children, you can only pass them explicitly as a list. > > > > > > But for this case it would work to decouple part1 and part 2. > > > > > > part1.scad___________ > > > > > > module part1() { > > > echo("part1"); > > > children(); > > > } > > > ____________________ > > > > > > > > > part2.scad___________ > > > > > > module part2() { > > > echo("part2"); > > > } > > > ____________________ > > > > > > > > > part_test.scad_________ > > > > > > use > > > <part1.scad> > > > use > > > <part2.scad> > > > part1() part2(); > > > > I haven't tested this yet to see if it will work with my code that > > generates > > objects in a loop, but I will. Thanks. > > > > > > > > > > -- > > Sent from: http://forum.openscad.org/ > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- ** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 ** ** Delftechpark 26 2628 XH Delft, The Netherlands. KVK: 27239233 ** *-- BitWizard writes Linux device drivers for any device you may have! --* The plan was simple, like my brother-in-law Phil. But unlike Phil, this plan just might work.
