Reversed faces
doug moen
Mon, Jan 11, 2016 4:42 PM
From the Admesh library, referenced by
https://github.com/openscad/openscad/issues/1042:
A common problem with STL files is that some or all of facets are oriented
backwards; i.e. the vertices are listed in a clockwise direction when
viewed from outside the part.  Admesh repairs the orientation of facets
according to the following algorithm:
  1. Generate the neighbors list for all facets.
  2. Inspect the first neighbor of the first facet to determine the
    orientation of its vertices.
  3. If the neighboring facet is oriented in the same direction as the first
    facet, mark the neighbor as checked.  If the neighboring facet is oriented
    opposite to the first facet, reverse the neighbor, and mark it as checked.
  4. Repeat steps 2 and 3 until all facets have been checked.
    The above algorithm ensures that all connected facets are oriented in the
    same direction.  However, if the first facet is backwards, then all facets
    will be backwards.  The correct orientation for the entire part is
    determined after the volume has been calculated.  If the volume is
    negative, then all of the facets must be backwards.  Admesh then reverses
    all facets to set the correct orientation.
Nop Head's original suggestion is to report if two neighbouring facets have
opposite orientations, which matches what Admesh does. And that probably
takes care of the most common case where people screw up the arguments to
polyhedron and ask for help on the forum. It wouldn't be perfect, but it
would be progress.
Detecting whether all faces are backwards looks more complicated and
expensive. There's no "local" property you can test, as in the neighbouring
facet test. It's a global property of the entire shape.
  • Admesh does this by computing the volume, and testing if it is
    negative. Computing the volume might be expensive? There's another thread,
    a pull request for a "probe" function, which adds the ability to compute
    the volume of a shape, but this computation is said to be very expensive.
    It requires a convex decomposition, which in itself is expensive.
  • I'm not sure how Admesh deals with a complex object containing an
    interior void. Then you have an interior mesh, and an exterior mesh, which
    aren't connected. The interior mesh is expected to have a negative volume,
    while the exterior mesh is expected to have a positive volume.
On 11 January 2016 at 08:59, Marius Kintel marius@kintel.net wrote:
Some related issues:
https://github.com/openscad/openscad/issues/348
https://github.com/openscad/openscad/issues/590
Two things:
o We should rewrite our mesh class to support tests and operators like
this. This would also be a good step towards repairing imported STLs which
CGAL struggles with. We could also look at external libraries with good
mesh classes.
o Highlights of reversed faces in preview mode: It should be possible to
simply turn this on.
-Marius
>From the Admesh library, referenced by https://github.com/openscad/openscad/issues/1042: A common problem with STL files is that some or all of facets are oriented backwards; i.e. the vertices are listed in a clockwise direction when viewed from outside the part. Admesh repairs the orientation of facets according to the following algorithm: 1. Generate the neighbors list for all facets. 2. Inspect the first neighbor of the first facet to determine the orientation of its vertices. 3. If the neighboring facet is oriented in the same direction as the first facet, mark the neighbor as checked. If the neighboring facet is oriented opposite to the first facet, reverse the neighbor, and mark it as checked. 4. Repeat steps 2 and 3 until all facets have been checked. The above algorithm ensures that all connected facets are oriented in the same direction. However, if the first facet is backwards, then all facets will be backwards. The correct orientation for the entire part is determined after the volume has been calculated. If the volume is negative, then all of the facets must be backwards. Admesh then reverses all facets to set the correct orientation. Nop Head's original suggestion is to report if two neighbouring facets have opposite orientations, which matches what Admesh does. And that probably takes care of the most common case where people screw up the arguments to polyhedron and ask for help on the forum. It wouldn't be perfect, but it would be progress. Detecting whether all faces are backwards looks more complicated and expensive. There's no "local" property you can test, as in the neighbouring facet test. It's a global property of the entire shape. - Admesh does this by computing the volume, and testing if it is negative. Computing the volume might be expensive? There's another thread, a pull request for a "probe" function, which adds the ability to compute the volume of a shape, but this computation is said to be very expensive. It requires a convex decomposition, which in itself is expensive. - I'm not sure how Admesh deals with a complex object containing an interior void. Then you have an interior mesh, and an exterior mesh, which aren't connected. The interior mesh is expected to have a negative volume, while the exterior mesh is expected to have a positive volume. On 11 January 2016 at 08:59, Marius Kintel <marius@kintel.net> wrote: > Some related issues: > > https://github.com/openscad/openscad/issues/348 > https://github.com/openscad/openscad/issues/1042 > https://github.com/openscad/openscad/issues/590 > > Two things: > o We should rewrite our mesh class to support tests and operators like > this. This would also be a good step towards repairing imported STLs which > CGAL struggles with. We could also look at external libraries with good > mesh classes. > o Highlights of reversed faces in preview mode: It should be possible to > simply turn this on. > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Mon, Jan 11, 2016 4:55 PM
Does polyhedron currently work if you have an interior hole with a negative
volume?
Two things:
mesh classes.
-Marius
Does polyhedron currently work if you have an interior hole with a negative volume? On 11 January 2016 at 16:42, doug moen <doug@moens.org> wrote: > From the Admesh library, referenced by > https://github.com/openscad/openscad/issues/1042: > > A common problem with STL files is that some or all of facets are oriented > backwards; i.e. the vertices are listed in a clockwise direction when > viewed from outside the part. Admesh repairs the orientation of facets > according to the following algorithm: > 1. Generate the neighbors list for all facets. > 2. Inspect the first neighbor of the first facet to determine the > orientation of its vertices. > 3. If the neighboring facet is oriented in the same direction as the first > facet, mark the neighbor as checked. If the neighboring facet is oriented > opposite to the first facet, reverse the neighbor, and mark it as checked. > 4. Repeat steps 2 and 3 until all facets have been checked. > The above algorithm ensures that all connected facets are oriented in the > same direction. However, if the first facet is backwards, then all facets > will be backwards. The correct orientation for the entire part is > determined after the volume has been calculated. If the volume is > negative, then all of the facets must be backwards. Admesh then reverses > all facets to set the correct orientation. > > Nop Head's original suggestion is to report if two neighbouring facets > have opposite orientations, which matches what Admesh does. And that > probably takes care of the most common case where people screw up the > arguments to polyhedron and ask for help on the forum. It wouldn't be > perfect, but it would be progress. > > Detecting whether all faces are backwards looks more complicated and > expensive. There's no "local" property you can test, as in the neighbouring > facet test. It's a global property of the entire shape. > > - Admesh does this by computing the volume, and testing if it is > negative. Computing the volume might be expensive? There's another thread, > a pull request for a "probe" function, which adds the ability to compute > the volume of a shape, but this computation is said to be very expensive. > It requires a convex decomposition, which in itself is expensive. > - I'm not sure how Admesh deals with a complex object containing an > interior void. Then you have an interior mesh, and an exterior mesh, which > aren't connected. The interior mesh is expected to have a negative volume, > while the exterior mesh is expected to have a positive volume. > > > > On 11 January 2016 at 08:59, Marius Kintel <marius@kintel.net> wrote: > >> Some related issues: >> >> https://github.com/openscad/openscad/issues/348 >> https://github.com/openscad/openscad/issues/1042 >> https://github.com/openscad/openscad/issues/590 >> >> Two things: >> o We should rewrite our mesh class to support tests and operators like >> this. This would also be a good step towards repairing imported STLs which >> CGAL struggles with. We could also look at external libraries with good >> mesh classes. >> o Highlights of reversed faces in preview mode: It should be possible to >> simply turn this on. >> >> -Marius >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
doug moen
Mon, Jan 11, 2016 5:21 PM
I tried and got a CGAL error.
If it doesn't work, then that may be bad news for users of STL -> SCAD file
converters. This trick is used for posting OpenSCAD files to Thingiverse,
since the thingiverse customizer won't work if your scad file imports an
STL file: the imported polyhedron must instead be written as inline code. I
haven't used one of these converters: you could write one smart enough to
detect interior voids and generate difference() statements.
negative volume?
    checked.
Two things:
mesh classes.
-Marius
I tried and got a CGAL error. If it doesn't work, then that may be bad news for users of STL -> SCAD file converters. This trick is used for posting OpenSCAD files to Thingiverse, since the thingiverse customizer won't work if your scad file imports an STL file: the imported polyhedron must instead be written as inline code. I haven't used one of these converters: you could write one smart enough to detect interior voids and generate difference() statements. On 11 January 2016 at 11:55, nop head <nop.head@gmail.com> wrote: > Does polyhedron currently work if you have an interior hole with a > negative volume? > > On 11 January 2016 at 16:42, doug moen <doug@moens.org> wrote: > >> From the Admesh library, referenced by >> https://github.com/openscad/openscad/issues/1042: >> >> A common problem with STL files is that some or all of facets are >> oriented backwards; i.e. the vertices are listed in a clockwise direction >> when viewed from outside the part. Admesh repairs the orientation of >> facets according to the following algorithm: >> 1. Generate the neighbors list for all facets. >> 2. Inspect the first neighbor of the first facet to determine the >> orientation of its vertices. >> 3. If the neighboring facet is oriented in the same direction as the >> first facet, mark the neighbor as checked. If the neighboring facet is >> oriented opposite to the first facet, reverse the neighbor, and mark it as >> checked. >> 4. Repeat steps 2 and 3 until all facets have been checked. >> The above algorithm ensures that all connected facets are oriented in the >> same direction. However, if the first facet is backwards, then all facets >> will be backwards. The correct orientation for the entire part is >> determined after the volume has been calculated. If the volume is >> negative, then all of the facets must be backwards. Admesh then reverses >> all facets to set the correct orientation. >> >> Nop Head's original suggestion is to report if two neighbouring facets >> have opposite orientations, which matches what Admesh does. And that >> probably takes care of the most common case where people screw up the >> arguments to polyhedron and ask for help on the forum. It wouldn't be >> perfect, but it would be progress. >> >> Detecting whether all faces are backwards looks more complicated and >> expensive. There's no "local" property you can test, as in the neighbouring >> facet test. It's a global property of the entire shape. >> >> - Admesh does this by computing the volume, and testing if it is >> negative. Computing the volume might be expensive? There's another thread, >> a pull request for a "probe" function, which adds the ability to compute >> the volume of a shape, but this computation is said to be very expensive. >> It requires a convex decomposition, which in itself is expensive. >> - I'm not sure how Admesh deals with a complex object containing an >> interior void. Then you have an interior mesh, and an exterior mesh, which >> aren't connected. The interior mesh is expected to have a negative volume, >> while the exterior mesh is expected to have a positive volume. >> >> >> >> On 11 January 2016 at 08:59, Marius Kintel <marius@kintel.net> wrote: >> >>> Some related issues: >>> >>> https://github.com/openscad/openscad/issues/348 >>> https://github.com/openscad/openscad/issues/1042 >>> https://github.com/openscad/openscad/issues/590 >>> >>> Two things: >>> o We should rewrite our mesh class to support tests and operators like >>> this. This would also be a good step towards repairing imported STLs which >>> CGAL struggles with. We could also look at external libraries with good >>> mesh classes. >>> o Highlights of reversed faces in preview mode: It should be possible to >>> simply turn this on. >>> >>> -Marius >>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
MK
Marius Kintel
Mon, Jan 11, 2016 6:03 PM
Hm, that should work - we fixed some bugs related to that a while ago.
I’ll give it a spin..
-Marius
Hm, that should work - we fixed some bugs related to that a while ago. I’ll give it a spin.. -Marius > On Jan 11, 2016, at 12:21 PM, doug moen <doug@moens.org> wrote: > > I tried and got a CGAL error. > > If it doesn't work, then that may be bad news for users of STL -> SCAD file converters. This trick is used for posting OpenSCAD files to Thingiverse, since the thingiverse customizer won't work if your scad file imports an STL file: the imported polyhedron must instead be written as inline code. I haven't used one of these converters: you could write one smart enough to detect interior voids and generate difference() statements. > > On 11 January 2016 at 11:55, nop head <nop.head@gmail.com> wrote: > Does polyhedron currently work if you have an interior hole with a negative volume?
Mon, Jan 11, 2016 7:24 PM
On 11. jan. 2016 17:05, nop head wrote:
Pointing away from the material is a bit ambiguous for concave polyhedra
as a normal pointing outwards could hit another part of the object.
No it isn't ambiguous. It refers only to the immediate direction of the
non-material wrt. the face as compared to the immediate direction of the
solid material wrt. the same face.
On 11. jan. 2016 17:05, nop head wrote: > Pointing away from the material is a bit ambiguous for concave polyhedra > as a normal pointing outwards could hit another part of the object. No it isn't ambiguous. It refers only to the immediate direction of the non-material wrt. the face as compared to the immediate direction of the solid material wrt. the same face. Carsten Arnholm
MS
Mark Schafer
Mon, Jan 11, 2016 9:47 PM
You can determine the correct orientation at the outset by randomly
sampling faces until you find one whose normal does not collide with any
other faces on the object. I.e. if there is a face whose normal, when
raycast, does not hit any other faces, then that face has the correct
orientation.
In practise sampling some % of faces in the object looking for a single
fail to set the orientation.
Then start the growing/winding procedure with that face.
You can determine the correct orientation at the outset by randomly sampling faces until you find one whose normal does not collide with any other faces on the object. I.e. if there is a face whose normal, when raycast, does not hit any other faces, then that face has the correct orientation. In practise sampling some % of faces in the object looking for a single fail to set the orientation. Then start the growing/winding procedure with that face.
Mon, Jan 11, 2016 10:19 PM
Not ambiguous as a definition but in practice there is no solid material,
just faces representing its boundary. So as the previous post says you need
to see if the normal intersects another face. I.e. you need to find an
outwards normal that doesn't intersect. One that does intersect is
ambiguous on a concave object.
orientation.
>No it isn't ambiguous. It refers only to the immediate direction of the non-material wrt. the face as compared to the immediate direction of the solid material wrt. the same face. Not ambiguous as a definition but in practice there is no solid material, just faces representing its boundary. So as the previous post says you need to see if the normal intersects another face. I.e. you need to find an outwards normal that doesn't intersect. One that does intersect is ambiguous on a concave object. On 11 January 2016 at 21:47, Mark Schafer <mschafer@wireframe.biz> wrote: > You can determine the correct orientation at the outset by randomly > sampling faces until you find one whose normal does not collide with any > other faces on the object. I.e. if there is a face whose normal, when > raycast, does not hit any other faces, then that face has the correct > orientation. > In practise sampling some % of faces in the object looking for a single > fail to set the orientation. > Then start the growing/winding procedure with that face. > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
GF
Greg Frost
Tue, Jan 12, 2016 9:44 AM
If it intersects an even number of times, you started on the outside. If it intersects an odd number, you are on the inside.
> On 12 Jan 2016, at 8:49 am, nop head <nop.head@gmail.com> wrote: > > >No it isn't ambiguous. It refers only to the immediate direction of the non-material wrt. the face as compared to the immediate direction of the solid material wrt. the same face. > > Not ambiguous as a definition but in practice there is no solid material, just faces representing its boundary. So as the previous post says you need to see if the normal intersects another face. I.e. you need to find an outwards normal that doesn't intersect. One that does intersect is ambiguous on a concave object. > >> On 11 January 2016 at 21:47, Mark Schafer <mschafer@wireframe.biz> wrote: >> You can determine the correct orientation at the outset by randomly sampling faces until you find one whose normal does not collide with any other faces on the object. I.e. if there is a face whose normal, when raycast, does not hit any other faces, then that face has the correct orientation. >> In practise sampling some % of faces in the object looking for a single fail to set the orientation. >> Then start the growing/winding procedure with that face > If it intersects an even number of times, you started on the outside. If it intersects an odd number, you are on the inside.
Tue, Jan 12, 2016 10:00 AM
Yes if you are careful about intersecting another face at an edge or a
vertex or along its plane.
On 12 January 2016 at 09:44, Greg Frost gregorybartonfrost@gmail.com
orientation.
Yes if you are careful about intersecting another face at an edge or a vertex or along its plane. On 12 January 2016 at 09:44, Greg Frost <gregorybartonfrost@gmail.com> wrote: > > > On 12 Jan 2016, at 8:49 am, nop head <nop.head@gmail.com> wrote: > > >No it isn't ambiguous. It refers only to the immediate direction of the > non-material wrt. the face as compared to the immediate direction of the > solid material wrt. the same face. > > Not ambiguous as a definition but in practice there is no solid material, > just faces representing its boundary. So as the previous post says you need > to see if the normal intersects another face. I.e. you need to find an > outwards normal that doesn't intersect. One that does intersect is > ambiguous on a concave object. > > On 11 January 2016 at 21:47, Mark Schafer <mschafer@wireframe.biz> wrote: > >> You can determine the correct orientation at the outset by randomly >> sampling faces until you find one whose normal does not collide with any >> other faces on the object. I.e. if there is a face whose normal, when >> raycast, does not hit any other faces, then that face has the correct >> orientation. >> In practise sampling some % of faces in the object looking for a single >> fail to set the orientation. >> Then start the growing/winding procedure with that face > > > If it intersects an even number of times, you started on the outside. If > it intersects an odd number, you are on the inside. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Tue, Jan 12, 2016 12:06 PM
Many of my issues occur with lines/planes and faces of circles/cylinders with
varying $fn values, particularly intersection/difference, how does this
approach consider the tangential inconsistency of the curve approximation.
He says naively...  ;) or provocatively...if I have 1/2 an understanding...
Newly minted Admin - PM me if you need anything, or if I've done something stupid...
View this message in context: http://forum.openscad.org/Reversed-faces-tp15649p15673.html
Many of my issues occur with lines/planes and faces of circles/cylinders with varying $fn values, particularly intersection/difference, how does this approach consider the tangential inconsistency of the curve approximation. He says naively... ;) or provocatively...if I have 1/2 an understanding... ----- Newly minted Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Reversed-faces-tp15649p15673.html Sent from the OpenSCAD mailing list archive at Nabble.com.
