JW
Joe Weinpert
Sun, May 21, 2023 6:24 PM
Is there a way to begin a turtle path at a different point than the default
[0,0] origin?
Joe Weinpert
skidrowacademy.com
[0,0] origin?
Joe Weinpert
skidrowacademy.com
DP
David Phillip Oster
Sun, May 21, 2023 6:41 PM
None of the examples on https://github.com/revarbat/BOSL2/wiki/drawing.scad
have an origin of [0,0].
Example:
path = [[0,100], [100,100], [200,0], [100,-100], [100,0]];
rotate([-10,-10,-10])translate([-100,-10,-10])linear_extrude(0.1)stroke(path,
width=20);
On Sun, May 21, 2023 at 11:25 AM Joe Weinpert joe.weinpert@gmail.com
default [0,0] origin?
Joe Weinpert
skidrowacademy.com
Example:
width=20);
On Sun, May 21, 2023 at 11:25 AM Joe Weinpert <joe.weinpert@gmail.com>
> Joe Weinpert
> skidrowacademy.com
JW
Joe Weinpert
Mon, May 22, 2023 2:29 PM
When using turtle() drawing always begins at [0,0] and facing right by
default. My problem was the need to draw something that was different.
I did figure out the answer, however, by using the turtle() "state" command
to set the beginning point of the path
shape = turtle(
state = [0,1.5], // starting point
["left", // turn to use arcright next
"arcright", .125,
"move", .75,
"arcright", .125,
"move", .75,
"arcleft", .375,
"move", .625,
"right",
"untily", 0,
"right",
"untilx", 1,
"arcright", .375,
"untily", 1.25,
"arcleft", .125,
"untilx", .125,
"arcright", .125]
Joe Weinpert
skidrowacademy.com
On Sun, May 21, 2023 at 2:43 PM David Phillip Oster <
https://github.com/revarbat/BOSL2/wiki/drawing.scad have an origin of
[0,0].
Example:
width=20);
Joe Weinpert
skidrowacademy.com
shape = turtle(
"arcright", .125,
"move", .75,
"arcright", .125,
"move", .75,
"arcleft", .375,
"move", .625,
"right",
"untily", 0,
"right",
"untilx", 1,
"arcright", .375,
"untily", 1.25,
"arcleft", .125,
"untilx", .125,
"arcright", .125]
Joe Weinpert
skidrowacademy.com
> [0,0].
> Example:
> include <BOSL2/std.scad>
> width=20);
>> Joe Weinpert
>> skidrowacademy.com
DP
David Phillip Oster
Mon, May 22, 2023 4:18 PM
Thanks for teaching me about the state parameter to turtle(). Now that
I see your answer, it is clear that I misread your question.
Thanks for teaching me about the *state* parameter to *turtle()*. Now that
Tue, May 23, 2023 1:18 AM
Another option is to do your path starting at the origin, then use move() to translate the entire path.
ie: path = move([10,5], p=turtle(...)); Which is pretty much how you have to do it with turtle3d().
On May 22, 2023, at 7:29 AM, Joe Weinpert joe.weinpert@gmail.com wrote:
When using turtle() drawing always begins at [0,0] and facing right by default. My problem was the need to draw something that was different.
I did figure out the answer, however, by using the turtle() "state" command to set the beginning point of the path
shape = turtle(
"arcright", .125,
"move", .75,
"arcright", .125,
"move", .75,
"arcleft", .375,
"move", .625,
"right",
"untily", 0,
"right",
"untilx", 1,
"arcright", .375,
"untily", 1.25,
"arcleft", .125,
"untilx", .125,
"arcright", .125]
Joe Weinpert
skidrowacademy.com http://skidrowacademy.com/
On Sun, May 21, 2023 at 2:43 PM David Phillip Oster <davidphilliposter@gmail.com mailto:davidphilliposter@gmail.com> wrote:
None of the examples on https://github.com/revarbat/BOSL2/wiki/drawing.scad have an origin of [0,0].
Example:
rotate([-10,-10,-10])translate([-100,-10,-10])linear_extrude(0.1)stroke(path, width=20);
On Sun, May 21, 2023 at 11:25 AM Joe Weinpert <joe.weinpert@gmail.com mailto:joe.weinpert@gmail.com> wrote:
Another option is to do your path starting at the origin, then use `move()` to translate the entire path.
ie: `path = move([10,5], p=turtle(...));` Which is pretty much how you have to do it with `turtle3d()`.
- Revar
> shape = turtle(
> "arcright", .125,
> "move", .75,
> "arcright", .125,
> "move", .75,
> "arcleft", .375,
> "move", .625,
> "right",
> "untily", 0,
> "right",
> "untilx", 1,
> "arcright", .375,
> "untily", 1.25,
> "arcleft", .125,
> "untilx", .125,
> "arcright", .125]
> Joe Weinpert
> skidrowacademy.com <http://skidrowacademy.com/>
> On Sun, May 21, 2023 at 2:43 PM David Phillip Oster <davidphilliposter@gmail.com <mailto:davidphilliposter@gmail.com>> wrote:
>> Example:
>> On Sun, May 21, 2023 at 11:25 AM Joe Weinpert <joe.weinpert@gmail.com <mailto:joe.weinpert@gmail.com>> wrote:
>>> Is there a way to begin a turtle path at a different point than the default [0,0] origin?
>>> Joe Weinpert
>>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
