Discuss Digest, Vol 143, Issue 20 re adding and subtracting...
Roger Whiteley
Tue, Oct 27, 2026 8:15 AM
BOSL befuddles me, completely,
I routinely build objects using this approach (which I know for many
discussion readers is like teaching grandma to suck eggs)
difference () {
    union ( ){
        build_object_part1(); // any number of modules with
        build_object_part2(); // any number of modules with
    subtract_from_object ();// typically a hole chamfered on both ends,
the thickness of the built object.
just plain OpenSCAD.  works for me... :-)
Here's an RJ45 socket without BOSL.  Setting up the variables is almost
longer than the module call:
rj45_socket
(led=true,led_style="jewel",outer_block_colour="grey",inner_block_colour="black");//set
led=true to get leds in socket
module rj45_socket
(led=false,led_style="jewel",outer_block_colour="grey",inner_block_colour="black")
block_wide = 15;
block_high = 13;
socket_z = 3;
wide = 11.91;
high = 6.83;
notch_wide = 8.7;
notch_high = 8.52;
latch_wide = 4.06;
latch_high = 10;
pin_pitch = 1.02;
pin_long = 8;
pin_colour = "gold";
pin_dia = 0.56;
pin_count = 8;
pin_angle = 70;
pin_land = 0.51;
led_w = 2.75;
led_z = 1.75;
led_green = "lime";
led_yellow = "yellow";
pins_width = (pin_count-1)*pin_pitch;
//echo(pins_width=pins_width);
//construct the profile
    difference () {
        color (outer_block_colour) cube ([block_wide,10,block_high]);
        color (inner_block_colour)
            translate ([(block_wide-wide)/2,-cd,socket_z])
                cube([wide,9,high]);
            translate ([(block_wide-notch_wide)/2,-cd,socket_z])
                cube ([notch_wide,9,notch_high]);
            translate ([(block_wide-latch_wide)/2,-cd,socket_z])
                cube ([latch_wide,9,latch_high-0.1]);
        }//end diff
    translate ([(block_wide-pins_width)/2,2,2.5]) {
        for (i = [ 0 : pin_count-1 ]) {
            translate ([i*pin_pitch,0,0])
                rotate ([-pin_angle,0,0])
                    color(pin_colour) cylinder
(d=pin_dia,h=pin_long,$fn=20);
        }//end for
    }//end translate
    if (led) {
        translate ([1.6,0.5,10.9]) led_block
(led_colour=led_yellow,led_style);
        translate ([13.4,0.5,10.9]) led_block
(led_colour=led_green,led_style);
    //end if
    module led_block (led_colour,led_style) {
        if ( led_style == "jewel" )
        color (led_colour) {
            hull () {
                cube ([led_w,1,led_z],center=true);
                sphere (d=1.75);
            }//end hull
        }//end colour
        else {
        color (led_colour) cube ([led_w,1.1,led_z],center=true);
    }//end led_block
}//end module
BOSL befuddles me, completely, I routinely build objects using this approach (which I know for many discussion readers is like teaching grandma to suck eggs) difference () {     union ( ){         build_object_part1(); // any number of modules with         build_object_part2(); // any number of modules with         .....        }     subtract_from_object ();// typically a hole chamfered on both ends, the thickness of the built object.     subtract_from_object ();// typically a hole chamfered on both ends, the thickness of the built object.     ......     } just plain OpenSCAD.  works for me... :-) Here's an RJ45 socket without BOSL.  Setting up the variables is almost longer than the module call: rj45_socket (led=true,led_style="jewel",outer_block_colour="grey",inner_block_colour="black");//set led=true to get leds in socket module rj45_socket (led=false,led_style="jewel",outer_block_colour="grey",inner_block_colour="black") { block_wide = 15; block_high = 13; socket_z = 3; wide = 11.91; high = 6.83; notch_wide = 8.7; notch_high = 8.52; latch_wide = 4.06; latch_high = 10; pin_pitch = 1.02; pin_long = 8; pin_colour = "gold"; pin_dia = 0.56; pin_count = 8; pin_angle = 70; pin_land = 0.51; led_w = 2.75; led_z = 1.75; led_green = "lime"; led_yellow = "yellow"; pins_width = (pin_count-1)*pin_pitch; //echo(pins_width=pins_width); //construct the profile     difference () {         color (outer_block_colour) cube ([block_wide,10,block_high]);         color (inner_block_colour)             translate ([(block_wide-wide)/2,-cd,socket_z])                 cube([wide,9,high]);         color (inner_block_colour)             translate ([(block_wide-notch_wide)/2,-cd,socket_z])                 cube ([notch_wide,9,notch_high]);         color (inner_block_colour)             translate ([(block_wide-latch_wide)/2,-cd,socket_z])                 cube ([latch_wide,9,latch_high-0.1]);         }//end diff     translate ([(block_wide-pins_width)/2,2,2.5]) {         for (i = [ 0 : pin_count-1 ]) {             translate ([i*pin_pitch,0,0])                 rotate ([-pin_angle,0,0])                     color(pin_colour) cylinder (d=pin_dia,h=pin_long,$fn=20);         }//end for     }//end translate     if (led) {         translate ([1.6,0.5,10.9]) led_block (led_colour=led_yellow,led_style);         translate ([13.4,0.5,10.9]) led_block (led_colour=led_green,led_style);     //end if     }     module led_block (led_colour,led_style) {         if ( led_style == "jewel" )         color (led_colour) {             hull () {                 cube ([led_w,1,led_z],center=true);                 sphere (d=1.75);             }//end hull         }//end colour         else {         color (led_colour) cube ([led_w,1.1,led_z],center=true);               }     }//end led_block }//end module
