OpenSCAD output of BREP file format.
K
KeithSloan52
Sun, May 14, 2017 9:33 AM
kintel wrote
So what happens to the not supported nodes? Ignored? Not sure that would
help at all.
Unsupported nodes would in this proposal simply be rendered out as
explicit polyhedrons.
That would be very useful. The important think from a FreeCAD importer point
of view would be that such options could be turned on/off via command line
switch(s) as FreeCAD calls the command line version of OpenSCAD under the
covers
kintel wrote
As an example of a recent change, rotate_extrude() now supports an “angle”
parameter. I’m not sure if that has yet been added to the FreeCAD
importer.
I will look into that when I can find the time.
Not sure how many FreeCAD users use the OpenSCAD importer. I know Sebastian
Hoogen was of the opinion that not enough people used it to worry about it.
Maybe it would be useful to have a survey in the FreeCAD forum (if that is
possible)
View this message in context: http://forum.openscad.org/OpenSCAD-output-of-BREP-file-format-tp21443p21465.html
kintel wrote >> So what happens to the not supported nodes? Ignored? Not sure that would >> help at all. >> > Unsupported nodes would in this proposal simply be rendered out as > explicit polyhedrons. That would be very useful. The important think from a FreeCAD importer point of view would be that such options could be turned on/off via command line switch(s) as FreeCAD calls the command line version of OpenSCAD under the covers kintel wrote > As an example of a recent change, rotate_extrude() now supports an “angle” > parameter. I’m not sure if that has yet been added to the FreeCAD > importer. I will look into that when I can find the time. Not sure how many FreeCAD users use the OpenSCAD importer. I know Sebastian Hoogen was of the opinion that not enough people used it to worry about it. Maybe it would be useful to have a survey in the FreeCAD forum (if that is possible) -- View this message in context: http://forum.openscad.org/OpenSCAD-output-of-BREP-file-format-tp21443p21465.html Sent from the OpenSCAD mailing list archive at Nabble.com.
