even stranger....
i printed the thing anyway.... so i noticed, that instead of subtracting
the bearing-encroaching, it made a union?????
stranger and stranger....
good evening....
Bruno
Am Do., 11. Juli 2019 um 19:59 Uhr schrieb bboett bboett@gmail.com:
ok.....
while trying to print the other part, that compiled..... i noticed that the
insert for the bearing was missing....
i commented the difference in
https://github.com/nohkumado/spulenhalter/blob/master/Spulenhalterschraube.scad
to make the insert visible, its there, and it should remove its slice from
the minkovsky transformed handle, shouldn't it?
while it does work on the other end of the holder, it doesn't work on the
handle :(
that makes it really strange for me....
any light welcome!
Bruno
ciao
Bruno
http://bboett.free.fr
http://aikido.zorn.free.fr
What threads.scad are you using?
I've got this dated 2015-01-24
// Rohloff hub thread:
//metric_thread(34, 1, 10, internal=true, n_starts=6);
Note the uncommented example.
When I render that I get errors.
Your code does 'include <threads.scad>' rather than 'use <...>'
So if it is the same thread.scad, it will call that example & get that
error.
But assuming you may have commented out that example, it still gets:
violation! Expr: e_below != SHalfedge_handle() File:
/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/SNC_FM_decorator.h
Line: 426
This is an error in threads.scad.
Sorry spoke to soon [again...].
In knauf.scad, if I do
knauf(29,50);
cube();
I get the error. Probably your polygons.
I'll have a look, but need to use another PC.
No poly's are good.
This is the F5 before F6 problem, ie bug in OpenSCAD.
Do Design/flush-caches before doing F6, no error. Or just F6 on a fresh run
of OpenSCAD.
From my recollection when I last tried to drill down, it is the combination
of minkowski & linear_extrude that triggers the problem. Suspect conversion
of floats to ints for clipper & back.
wow... that did it !
any chance that bug gets fixed soon?
anyway, thanks Michael!
ciao
Bruno
Am Fr., 12. Juli 2019 um 05:09 Uhr schrieb MichaelAtOz <
oz.at.michael@gmail.com>:
No poly's are good.
of OpenSCAD.
ciao
Bruno
I raised an issue https://github.com/openscad/openscad/issues/2991 to
address it, as you can see it is an insidious bug.
