All:
I have a very strange rendering problem where I am trying to add a
cylinder to an
STL file. (Essentially this is to create a flat bottom for 3d printing).
Below is my
openscad code and attached is the STL file.
The issue is when I do F5 the model looks like I want it to.
When I do an F6 the bottom ends up hollow. It actually looks more like
a difference than a union. See attached image.
Reversing the STL and Cylinder does not make a difference.
What am I missing?
//use <write/Write.scad>
baseSTL = "RECYCLING_BIN_ASM.stl";
//End settings
module can(){
//move the stl to center the text at 0,0
rotate([90,0,0] )translate([0,3,0]){
scale([0.05,0.05,0.05])
import(baseSTL);
union(){
cylinder(r=11,h=4,$fn=120);
can();
http://forum.openscad.org/file/n10999/RECYCLING_BIN_FlatBottom.png
http://forum.openscad.org/file/n10999/RECYCLING_BIN_ASM.stl
View this message in context: http://forum.openscad.org/Strange-rendering-issue-with-STL-and-added-object-tp10999.html
What am I missing?
Normally those issues are caused by broken STL files. But in that
case it actually looks more like a bug.
The STL does not show any errors in blender or netfabb. And the
render using the OpenSCAD 2014.03 release version does produce
a different but also strange result.
I guess that needs some deeper investigation...
This is just a guess: remove the scale([0.05]) and increase the radius of
the cylinder by 20.
And see what happens.
2015-01-10 17:09 GMT+01:00 Torsten Paul Torsten.Paul@gmx.de:
What am I missing?
schreiben.
Enjoy!
