projection(cut=true) question
John David
Mon, Aug 25, 2025 5:00 AM
Is there a clean way to set up a projection(cut=var) such that var can be
set in the interface, and if it is not set, then extrude the part to some
thickness without duplicating the call inside an if/then/else?
pseudo code:
if (projection_cut) {
    projection(cut = true)
       part1(var1, ... );
} else {
    linear_extrude(thickness2)
         part1(var1, ... );
I've tried a number of things and get various complaints like:
    projection(cut = projection_cut)
       part1(var1, ... );
and
       part1(var1, ... );
And similar variants.
Anyway, I am hoping to clean up some code.
EBo --
Is there a clean way to set up a projection(cut=var) such that var can be set in the interface, and if it is not set, then extrude the part to some thickness without duplicating the call inside an if/then/else? pseudo code: if (projection_cut) { projection(cut = true) part1(var1, ... ); } else { linear_extrude(thickness2) part1(var1, ... ); } I've tried a number of things and get various complaints like: projection(cut = projection_cut) linear_extrude(thickness2) part1(var1, ... ); and linear_extrude(thickness2) projection(cut = projection_cut) part1(var1, ... ); And similar variants. Anyway, I am hoping to clean up some code. EBo --
John David
Mon, Aug 25, 2025 5:56 AM
I need to modify my description above (I misunderstood what the
projection(cut) was doing).  Basically under normal conditions I want the
part to 3D render, but if I set a cut variable, I wanted it projected into
2D to process as a laser cut file.  I was hoping there was a trick to keep
from duplicating the calls.
EBo --
pseudo code:
        part1(var1, ... );
 } else {
          part1(var1, ... );
        part1(var1, ... );
and
        part1(var1, ... );
EBo --
I need to modify my description above (I misunderstood what the projection(cut) was doing). Basically under normal conditions I want the part to 3D render, but if I set a cut variable, I wanted it projected into 2D to process as a laser cut file. I was hoping there was a trick to keep from duplicating the calls. EBo -- On Mon, Aug 25, 2025 at 1:00 AM John David <ebo.2112@gmail.com> wrote: > Is there a clean way to set up a projection(cut=var) such that var can be > set in the interface, and if it is not set, then extrude the part to some > thickness without duplicating the call inside an if/then/else? > > pseudo code: > > if (projection_cut) { > projection(cut = true) > part1(var1, ... ); > } else { > linear_extrude(thickness2) > part1(var1, ... ); > } > > I've tried a number of things and get various complaints like: > > projection(cut = projection_cut) > linear_extrude(thickness2) > part1(var1, ... ); > > and > > linear_extrude(thickness2) > projection(cut = projection_cut) > part1(var1, ... ); > > And similar variants. > > Anyway, I am hoping to clean up some code. > > EBo -- >
Mon, Aug 25, 2025 7:40 AM
shouldCut = false;
module maybeCut() {
if (shouldCut) {
} else {
maybeCut() sphere(r=20);
Similarly if you really meant project rather than cut.
On 8/25/2025 7:56 AM, John David via Discuss wrote: > Basically under normal conditions I want the part to 3D render, but if > I set a cut variable, I wanted it projected into 2D to process as a > laser cut file.  I was hoping there was a trick to keep from > duplicating the calls. shouldCut = false; module maybeCut() { if (shouldCut) { projection(cut=true) children(); } else { children(); } } maybeCut() sphere(r=20); Similarly if you really meant project rather than cut.
John David
Mon, Aug 25, 2025 11:12 AM
Thank you.  That worked!
On Mon, Aug 25, 2025 at 3:40 AM Jordan Brown openscad@jordan.maileater.net
shouldCut = false;
module maybeCut() {
if (shouldCut) {
} else {
Thank you. That worked! On Mon, Aug 25, 2025 at 3:40 AM Jordan Brown <openscad@jordan.maileater.net> wrote: > > On 8/25/2025 7:56 AM, John David via Discuss wrote: > > Basically under normal conditions I want the part to 3D render, but if I > set a cut variable, I wanted it projected into 2D to process as a laser cut > file. I was hoping there was a trick to keep from duplicating the calls. > > shouldCut = false; > > module maybeCut() { > if (shouldCut) { > projection(cut=true) > children(); > } else { > children(); > } > } > > maybeCut() sphere(r=20); > > > Similarly if you really meant project rather than cut. > > >
