On 13.03.22 14:46, William F. Adams via Discuss wrote:
- login didn't work in Google Chrome running on Windows
Sounds like you are referring to https://autodrop.cloud/openscad/
I'm not sure there's someone here who knows about the details.
There's a hackaday project page though:
https://hackaday.io/project/184367-openscadcloud-browser-based-openscad-environment
The author of that may have been one of the reasons the WASM
build came to life by promoting a bounty for the work. So a
big thanks goes to them.
The one Olivier is working on and making very cool progress,
e.g. supporting Fonts and a set of Libraries, is the one at:
BOSL2 gear example: https://tinyurl.com/ykef7625
At some point I hope we can have an installation on the openscad
website providing a simple way to share embedded designs, maybe
with code view option. So many idea, so little time :-).
I noticed it includes NopSCADlib amongst the libraries but it doesn't seem
to find the included and used files, only the top level ones.
e.g.
include<NopSCADlib/libtest.scad>
Gives:
Could not initialize localization.
WARNING: Can't open library file
'/libraries/NopSCADlib/tests/PSU_shroud.scad'
'/libraries/NopSCADlib/tests/SSR_shroud.scad'
'/libraries/NopSCADlib/tests/strap_handle.scad'
'/libraries/NopSCADlib/tests/socket_box.scad'
'/libraries/NopSCADlib/tests/screw_knob.scad'
'/libraries/NopSCADlib/tests/ribbon_clamp.scad'
'/libraries/NopSCADlib/tests/printed_pulleys.scad'
'/libraries/NopSCADlib/tests/printed_box.scad'
'/libraries/NopSCADlib/tests/pocket_handle.scad'
'/libraries/NopSCADlib/tests/PCB_mount.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/knob.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/handle.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/foot.scad'
'/libraries/NopSCADlib/tests/flat_hinge.scad'
'/libraries/NopSCADlib/tests/fixing_block.scad'
'/libraries/NopSCADlib/tests/fan_guard.scad'
'/libraries/NopSCADlib/tests/door_latch.scad'
'/libraries/NopSCADlib/tests/door_hinge.scad'
'/libraries/NopSCADlib/tests/corner_block.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/carriers.scad'
'/libraries/NopSCADlib/tests/cable_grommets.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/butt_box.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/box.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/zipties.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/variacs.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/washers.scad'
'/libraries/NopSCADlib/tests/veroboard.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/tubings.scad'
'/libraries/NopSCADlib/tests/transformers.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/toggles.scad'
'/libraries/NopSCADlib/tests/Swiss_clips.scad'
'/libraries/NopSCADlib/tests/stepper_motors.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/SSRs.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/springs.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/spades.scad'
'/libraries/NopSCADlib/tests/SK_brackets.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/sheets.scad'
'/libraries/NopSCADlib/tests/shaft_couplings.scad'
'/libraries/NopSCADlib/tests/servo_motors.scad'
'/libraries/NopSCADlib/tests/sealing_strip.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/screws.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/rod.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/rockers.scad'
'/libraries/NopSCADlib/tests/ring_terminals.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/rails.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/pulleys.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/PSUs.scad'
'/libraries/NopSCADlib/tests/press_fit.scad'
'/libraries/NopSCADlib/tests/potentiometers.scad'
'/libraries/NopSCADlib/tests/pillow_blocks.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/pillars.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/PCBs.scad'
'/libraries/NopSCADlib/tests/panel_meters.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/opengrab.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/o_ring.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/nuts.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/modules.scad'
'/libraries/NopSCADlib/tests/microswitches.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/magnets.scad'
'/libraries/NopSCADlib/tests/LED_meters.scad'
'/libraries/NopSCADlib/tests/linear_bearings.scad'
'/libraries/NopSCADlib/tests/light_strips.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/LEDs.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/LDRs.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/leadnuts.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/jack.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/inserts.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/IECs.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/hot_ends.scad'
'/libraries/NopSCADlib/tests/geared_steppers.scad'
'/libraries/NopSCADlib/tests/fuseholder.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/fans.scad'
'/libraries/NopSCADlib/tests/extrusion_brackets.scad'
'/libraries/NopSCADlib/tests/extrusions.scad'
'/libraries/NopSCADlib/tests/drag_chain.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/displays.scad'
'/libraries/NopSCADlib/tests/d_connectors.scad'
'/libraries/NopSCADlib/tests/components.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/circlips.scad'
'/libraries/NopSCADlib/tests/camera_housing.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/cameras.scad'
'/libraries/NopSCADlib/tests/cable_strips.scad'
'/libraries/NopSCADlib/tests/cable_clip.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/buttons.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/bulldogs.scad'
'/libraries/NopSCADlib/tests/box_sections.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/blowers.scad'
'/libraries/NopSCADlib/tests/BLDC_motors.scad'
WARNING: Can't open library file '/libraries/NopSCADlib/tests/belts.scad'
'/libraries/NopSCADlib/tests/bearing_blocks.scad'
'/libraries/NopSCADlib/tests/batteries.scad'
'/libraries/NopSCADlib/tests/ball_bearings.scad'
'/libraries/NopSCADlib/tests/7_segments.scad'
WARNING: Can't open include file 'NopSCADlib/core.scad'.
'/libraries/NopSCADlib/vitamins/NopSCADlib/utils/tube.scad'
'/libraries/NopSCADlib/vitamins/NopSCADlib/utils/thread.scad'
'/libraries/NopSCADlib/vitamins/NopSCADlib/vitamins/rod.scad'
WARNING: Ignoring unknown module 'cable_grommets' in file
../../libraries/NopSCADlib/libtest.scad, line 150
WARNING: Ignoring unknown module 'ribbon_clamps' in file
../../libraries/NopSCADlib/libtest.scad, line 153
WARNING: Ignoring unknown module 'press_fits' in file
../../libraries/NopSCADlib/libtest.scad, line 156
WARNING: Ignoring unknown module 'fixing_blocks' in file
../../libraries/NopSCADlib/libtest.scad, line 160
WARNING: Ignoring unknown module 'corner_blocks' in file
../../libraries/NopSCADlib/libtest.scad, line 164
WARNING: Ignoring unknown module 'feet' in file
../../libraries/NopSCADlib/libtest.scad, line 168
WARNING: Ignoring unknown module 'screw_knobs' in file
../../libraries/NopSCADlib/libtest.scad, line 171
WARNING: Ignoring unknown module 'printed_pulley_test' in file
../../libraries/NopSCADlib/libtest.scad, line 175
WARNING: Ignoring unknown module 'knobs' in file
../../libraries/NopSCADlib/libtest.scad, line 178
WARNING: Ignoring unknown module 'cable_clips' in file
../../libraries/NopSCADlib/libtest.scad, line 182
WARNING: Ignoring unknown module 'strap_handles' in file
../../libraries/NopSCADlib/libtest.scad, line 186
WARNING: Ignoring unknown module 'handle' in file
../../libraries/NopSCADlib/libtest.scad, line 190
WARNING: Ignoring unknown module 'pocket_handles' in file
../../libraries/NopSCADlib/libtest.scad, line 194
WARNING: Ignoring unknown module 'door_hinges' in file
../../libraries/NopSCADlib/libtest.scad, line 198
WARNING: Ignoring unknown module 'flat_hinges' in file
../../libraries/NopSCADlib/libtest.scad, line 202
WARNING: Ignoring unknown module 'printed_boxes' in file
../../libraries/NopSCADlib/libtest.scad, line 207
WARNING: Ignoring unknown module 'box_test' in file
../../libraries/NopSCADlib/libtest.scad, line 211
WARNING: Ignoring unknown module 'bbox_test' in file
../../libraries/NopSCADlib/libtest.scad, line 216
WARNING: Ignoring unknown module 'inserts' in file
../../libraries/NopSCADlib/libtest.scad, line 241
WARNING: Ignoring unknown module 'ring_terminals' in file
../../libraries/NopSCADlib/libtest.scad, line 244
WARNING: Ignoring unknown module 'nuts' in file
../../libraries/NopSCADlib/libtest.scad, line 247
WARNING: Ignoring unknown module 'washers' in file
../../libraries/NopSCADlib/libtest.scad, line 250
WARNING: Ignoring unknown module 'screws' in file
../../libraries/NopSCADlib/libtest.scad, line 253
WARNING: Ignoring unknown module 'circlips' in file
../../libraries/NopSCADlib/libtest.scad, line 256
WARNING: Ignoring unknown module 'o_rings' in file
../../libraries/NopSCADlib/libtest.scad, line 259
WARNING: Ignoring unknown module 'springs' in file
../../libraries/NopSCADlib/libtest.scad, line 262
WARNING: Ignoring unknown module 'sealing_strip_test' in file
../../libraries/NopSCADlib/libtest.scad, line 265
WARNING: Ignoring unknown module 'tubings' in file
../../libraries/NopSCADlib/libtest.scad, line 268
WARNING: Ignoring unknown module 'pillars' in file
../../libraries/NopSCADlib/libtest.scad, line 271
WARNING: Ignoring unknown module 'ball_bearings' in file
../../libraries/NopSCADlib/libtest.scad, line 274
WARNING: Ignoring unknown module 'pulleys' in file
../../libraries/NopSCADlib/libtest.scad, line 277
WARNING: Ignoring unknown module 'leadnuts' in file
../../libraries/NopSCADlib/libtest.scad, line 280
WARNING: Ignoring unknown module 'linear_bearings' in file
../../libraries/NopSCADlib/libtest.scad, line 283
WARNING: Ignoring unknown module 'rods' in file
../../libraries/NopSCADlib/libtest.scad, line 284
WARNING: Ignoring unknown module 'stepper_motors' in file
../../libraries/NopSCADlib/libtest.scad, line 288
WARNING: Ignoring unknown module 'sheets' in file
../../libraries/NopSCADlib/libtest.scad, line 291
WARNING: Ignoring unknown module 'pcbs' in file
../../libraries/NopSCADlib/libtest.scad, line 294
WARNING: Ignoring unknown module 'displays' in file
../../libraries/NopSCADlib/libtest.scad, line 297
WARNING: Ignoring unknown module 'fans' in file
../../libraries/NopSCADlib/libtest.scad, line 300
WARNING: Ignoring unknown module 'fan_guards' in file
../../libraries/NopSCADlib/libtest.scad, line 303
WARNING: Ignoring unknown module 'variacs' in file
../../libraries/NopSCADlib/libtest.scad, line 307
WARNING: Ignoring unknown module 'psus' in file
../../libraries/NopSCADlib/libtest.scad, line 310
WARNING: Ignoring unknown module 'psu_shrouds' in file
../../libraries/NopSCADlib/libtest.scad, line 312
WARNING: Ignoring unknown module 'zipties' in file
../../libraries/NopSCADlib/libtest.scad, line 320
WARNING: Ignoring unknown module 'bulldogs' in file
../../libraries/NopSCADlib/libtest.scad, line 323
WARNING: Ignoring unknown module 'swiss_clips' in file
../../libraries/NopSCADlib/libtest.scad, line 326
WARNING: Ignoring unknown module 'leds' in file
../../libraries/NopSCADlib/libtest.scad, line 340
WARNING: Ignoring unknown module 'ldrs' in file
../../libraries/NopSCADlib/libtest.scad, line 343
WARNING: Ignoring unknown module 'carriers' in file
../../libraries/NopSCADlib/libtest.scad, line 346
WARNING: Ignoring unknown module 'magnets' in file
../../libraries/NopSCADlib/libtest.scad, line 349
WARNING: Ignoring unknown module 'led_meters' in file
../../libraries/NopSCADlib/libtest.scad, line 352
WARNING: Ignoring unknown module 'fuseholders' in file
../../libraries/NopSCADlib/libtest.scad, line 355
WARNING: Ignoring unknown module 'spades' in file
../../libraries/NopSCADlib/libtest.scad, line 358
WARNING: Ignoring unknown module 'buttons' in file
../../libraries/NopSCADlib/libtest.scad, line 361
WARNING: Ignoring unknown module 'jacks' in file
../../libraries/NopSCADlib/libtest.scad, line 364
WARNING: Ignoring unknown module 'microswitches' in file
../../libraries/NopSCADlib/libtest.scad, line 367
WARNING: Ignoring unknown module 'rockers' in file
../../libraries/NopSCADlib/libtest.scad, line 370
WARNING: Ignoring unknown module 'toggles' in file
../../libraries/NopSCADlib/libtest.scad, line 373
WARNING: Ignoring unknown module 'components' in file
../../libraries/NopSCADlib/libtest.scad, line 376
WARNING: Ignoring unknown module 'veroboard_test' in file
../../libraries/NopSCADlib/libtest.scad, line 390
WARNING: Ignoring unknown module 'geared_steppers' in file
../../libraries/NopSCADlib/libtest.scad, line 393
WARNING: Ignoring unknown module 'pcb_mounts' in file
../../libraries/NopSCADlib/libtest.scad, line 396
WARNING: Ignoring unknown module 'cameras' in file
../../libraries/NopSCADlib/libtest.scad, line 399
WARNING: Ignoring unknown module 'd_connectors' in file
../../libraries/NopSCADlib/libtest.scad, line 402
WARNING: Ignoring unknown module 'camera_housings' in file
../../libraries/NopSCADlib/libtest.scad, line 405
WARNING: Ignoring unknown module 'iecs' in file
../../libraries/NopSCADlib/libtest.scad, line 408
WARNING: Ignoring unknown module 'modules' in file
../../libraries/NopSCADlib/libtest.scad, line 417
WARNING: Ignoring unknown module 'ssrs' in file
../../libraries/NopSCADlib/libtest.scad, line 420
WARNING: Ignoring unknown module 'ssr_shrouds' in file
../../libraries/NopSCADlib/libtest.scad, line 422
WARNING: Ignoring unknown module 'blowers' in file
../../libraries/NopSCADlib/libtest.scad, line 426
WARNING: Ignoring unknown module 'batteries' in file
../../libraries/NopSCADlib/libtest.scad, line 429
WARNING: Ignoring unknown module 'hot_ends' in file
../../libraries/NopSCADlib/libtest.scad, line 432
WARNING: Ignoring unknown module 'panel_meters' in file
../../libraries/NopSCADlib/libtest.scad, line 435
WARNING: Ignoring unknown module 'extrusions' in file
../../libraries/NopSCADlib/libtest.scad, line 438
WARNING: Ignoring unknown module 'transformers' in file
../../libraries/NopSCADlib/libtest.scad, line 441
WARNING: Ignoring unknown module 'socket_boxes' in file
../../libraries/NopSCADlib/libtest.scad, line 444
WARNING: Ignoring unknown module 'servo_motors' in file
../../libraries/NopSCADlib/libtest.scad, line 459
WARNING: Ignoring unknown module 'belt_test' in file
../../libraries/NopSCADlib/libtest.scad, line 462
WARNING: Ignoring unknown module 'opengrab_test' in file
../../libraries/NopSCADlib/libtest.scad, line 465
WARNING: Ignoring unknown module 'drag_chains' in file
../../libraries/NopSCADlib/libtest.scad, line 469
WARNING: Ignoring unknown module 'rails' in file
../../libraries/NopSCADlib/libtest.scad, line 472
WARNING: Ignoring unknown module 'cable_strips' in file
../../libraries/NopSCADlib/libtest.scad, line 475
WARNING: Ignoring unknown module 'kp_pillow_blocks' in file
../../libraries/NopSCADlib/libtest.scad, line 478
WARNING: Ignoring unknown module 'sk_brackets' in file
../../libraries/NopSCADlib/libtest.scad, line 481
WARNING: Ignoring unknown module 'extrusion_brackets' in file
../../libraries/NopSCADlib/libtest.scad, line 484
WARNING: Ignoring unknown module 'shaft_couplings' in file
../../libraries/NopSCADlib/libtest.scad, line 487
WARNING: Ignoring unknown module 'scs_bearing_blocks' in file
../../libraries/NopSCADlib/libtest.scad, line 490
WARNING: Ignoring unknown module 'bldc_motors' in file
../../libraries/NopSCADlib/libtest.scad, line 493
WARNING: Ignoring unknown module 'potentiometers' in file
../../libraries/NopSCADlib/libtest.scad, line 496
WARNING: Ignoring unknown module 'box_sections' in file
../../libraries/NopSCADlib/libtest.scad, line 499
WARNING: Ignoring unknown module 'light_strips' in file
../../libraries/NopSCADlib/libtest.scad, line 502
WARNING: Can't open import file
'/libraries/NopSCADlib/vitamins/microview/GKM-002_R05_CHIP_UPPER_HOUSING-1.STL',
import() at line 46
'/libraries/NopSCADlib/vitamins/microview/GKM-003_R05_CHIP_LOWER_HOUSING.STL',
import() at line 53
Geometries in cache: 131
Geometry cache size in bytes: 826544
CGAL Polyhedrons in cache: 4
CGAL cache size in bytes: 145744
Total rendering time: 0:00:16.063
Top level object is a list of objects:
Objects: 2
Bizarrely it does manage to render a hygrometer, which isn't a top level
file.
