Flattening from rotate extrude. Is it possible?
BS
Ben Senior
Tue, Jan 22, 2019 9:07 AM
Hi there,
I was blown away when I found OpenSCAD last week - it feels like the modelling tool I’ve always been waiting for - and it’s also turning into an opportunity to think more about functional programming ;-)
The first thing I built has been a VR headset to be laser cut out of ply.  I’ve parameterised it to accommodate different head shapes, eye distances, eye strengths, glasses etc.
The parts fit together with slots and tabs, so I use OpenSCAD to union the tabs with some parts, then intersect them with others to create the slots where the tabs will need to go.
Finally, I iterate over all the modules describing the parts, putting them together and then translating them back to a single surface so I have a description of the parts to be cut.
=== The bit I don’t get:  ===
I’ve started thinking about what it would take to have rounded edges on the headset.  The “rotate extrude” operator will do this just fine… but if I then intersect this with tabs on that curve, I want to be able to flatten that curved element to the flattened cube from which it would be bent, and which would still contain those tabs to be lasered from the material.  Is this clear?
I put a small drawing here to explain a little more what I mean : https://cloud.eyeskills.org/s/iiTApF73Lg4bFFA
Does anybody have a hint/suggestion how I might approach this “unwinding” of the extrusion and rotation?
Kindest Regards,
Ben
Hi there, I was blown away when I found OpenSCAD last week - it feels like the modelling tool I’ve always been waiting for - and it’s also turning into an opportunity to think more about functional programming ;-) The first thing I built has been a VR headset to be laser cut out of ply. I’ve parameterised it to accommodate different head shapes, eye distances, eye strengths, glasses etc. The parts fit together with slots and tabs, so I use OpenSCAD to union the tabs with some parts, then intersect them with others to create the slots where the tabs will need to go. Finally, I iterate over all the modules describing the parts, putting them together and then translating them back to a single surface so I have a description of the parts to be cut. === The bit I don’t get: === I’ve started thinking about what it would take to have rounded edges on the headset. The “rotate extrude” operator will do this just fine… but if I then intersect this with tabs on that curve, I want to be able to flatten that curved element to the flattened cube from which it would be bent, and which would still contain those tabs to be lasered from the material. Is this clear? I put a small drawing here to explain a little more what I mean : https://cloud.eyeskills.org/s/iiTApF73Lg4bFFA Does anybody have a hint/suggestion how I might approach this “unwinding” of the extrusion and rotation? Kindest Regards, Ben
S
shadowwynd
Tue, Jan 22, 2019 11:37 AM
My first thought (maybe not understanding exactly the problem is to look at
"living hinges".  This is where you laser a series of very fine lines so
that you can flex a project; this is a way to then have curved edges on a
laser cut.
http://forum.openscad.org/Living-Hinges-td18217.html
My first thought (maybe not understanding exactly the problem is to look at "living hinges". This is where you laser a series of very fine lines so that you can flex a project; this is a way to then have curved edges on a laser cut. http://forum.openscad.org/Living-Hinges-td18217.html -- Sent from: http://forum.openscad.org/
BS
Ben Senior
Tue, Jan 22, 2019 11:54 AM
That’s what I was planning on doing :-)  But now imagine that you have another perpendicular surface that penetrates it…
In OpenSCAD I’d like to “roll the curved surface” - see where the next part intersects it… then compute the difference of the rolled surface (i.e. with a slot where the other part cuts it)… then “roll” the rolled part “flat” so that I know exactly what to laser cut, so that when I physically roll it back into shape the slot will be in just the right spot for the other part?
Does that make more sense?
Difficult for me to describe elegantly!
laser cut.
That’s what I was planning on doing :-) But now imagine that you have another perpendicular surface that penetrates it… In OpenSCAD I’d like to “roll the curved surface” - see where the next part intersects it… then compute the difference of the rolled surface (i.e. with a slot where the other part cuts it)… then “roll” the rolled part “flat” so that I know exactly what to laser cut, so that when I physically roll it back into shape the slot will be in just the right spot for the other part? Does that make more sense? Difficult for me to describe elegantly! > On 22. Jan 2019, at 12:37, shadowwynd <shadowwynd@gmail.com> wrote: > > My first thought (maybe not understanding exactly the problem is to look at > "living hinges". This is where you laser a series of very fine lines so > that you can flex a project; this is a way to then have curved edges on a > laser cut. > > http://forum.openscad.org/Living-Hinges-td18217.html > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
S
shadowwynd
Tue, Jan 22, 2019 12:33 PM
You will probably have to do it the "long" way ... use the arc length of your
curved surface (radius & angle) to calculate the offset of the slot.
https://www.mathopenref.com/arclength.html
If you have a complex curve that can't be calculated easily, export to
inkscape and use the "Measure path" tool and go from there....
You will probably have to do it the "long" way ... use the arc length of your curved surface (radius & angle) to calculate the offset of the slot. https://www.mathopenref.com/arclength.html If you have a complex curve that can't be calculated easily, export to inkscape and use the "Measure path" tool and go from there.... -- Sent from: http://forum.openscad.org/
BS
Ben Senior
Tue, Jan 22, 2019 12:56 PM
Well, I guess that’s fine in principle, but it kind of negates the coolest feature of OpenSCAD somehow.
If the user’s eye strength shifts, all I have to do is shift the plate holding the lens moves along the Z axis. The “difference” calculations with the tabs on that plate and the surrounding case automatically (at the moment) produce all the tab holes in the right place.
If I go down that route, then I am mixing two totally different approaches towards doing things - where I’m implicitly forming holes based on simulating construction, and another where I’m explicitly defining holes based on replicating a bunch of calculations about where the tab should be (which may require replicating a lot of steps as different groups of assemblies are moved into position).
I hope there’s another way?
Well, I guess that’s fine in principle, but it kind of negates the coolest feature of OpenSCAD somehow. If the user’s eye strength shifts, all I have to do is shift the plate holding the lens moves along the Z axis. The “difference” calculations with the tabs on that plate and the surrounding case automatically (at the moment) produce all the tab holes in the right place. If I go down that route, then I am mixing two totally different approaches towards doing things - where I’m implicitly forming holes based on simulating construction, and another where I’m explicitly defining holes based on replicating a bunch of calculations about where the tab should be (which may require replicating a *lot* of steps as different groups of assemblies are moved into position). I hope there’s another way? > On 22. Jan 2019, at 13:33, shadowwynd <shadowwynd@gmail.com> wrote: > > You will probably have to do it the "long" way ... use the arc length of your > curved surface (radius & angle) to calculate the offset of the slot. > > https://www.mathopenref.com/arclength.html > > If you have a complex curve that can't be calculated easily, export to > inkscape and use the "Measure path" tool and go from there.... > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Tue, Jan 22, 2019 2:12 PM
for the other part?
Congratulation, this is a quite ambitious project - especially for somebody
who started with OpenSCAD only a week ago.
Despite all its merits, OpenSCAD also has its drawbacks that pop up in the
moment you want to do really fancy stuff. One is, that it doesn't allow you
to query an object. Therefore you don't get hands on the vertex coordinates
of an object. Being able to access these coordinates you could think about
defining a reverse transformation function that unrolls the object ...
Another one is that you can't define and apply non-affine transformations on
objects. Rolling and unrolling would be such a transformation.
rotate_extrude() is an operator that maps from 2D into 3D. You are looking
for an operator that maps from 3D to 2D. The only one OpenSCAD offers is
again affine: projection()
However, there is a technique that rolls a 3D object along a plane, cuts
slices by means of intersection() and unions the result. But this is an
exhausting and slow process with an unsatisfactory result.
http://forum.openscad.org/file/t887/CWCCW.png
See the following code:
r=40;  // radius
a=4;  // height
b=50;  // width
resolution = 8;
i=180*$t;  // to animate select view/Animate and set  FPS=10, Steps=40
animate();
unroll(i);  //
module animate()
rad = i/180PIr;
rotate([0,90,0])
translate([-r-5,rad,0])
rotate([0,0,-i])
piece();
translate([0,rad,0]) window(resolution);
module unroll(j)
for(i=[0:resolution:j])
rad = i/180PIr;
intersection()
rotate([0,90,0])
translate([-r-a,rad,0])
rotate([0,0,-i])
piece();
module window(width)
translate([0, -width/2, 0])cube([b, width, 2*a]);
module piece()
rotate_extrude(angle=180) translate([r, 0]) square([a, b]);
rotate([-60, 0, -45])cylinder(r=5, h=100);
okobloko wrote > In OpenSCAD I’d like to “roll the curved surface” - see where the next > part intersects it… then compute the difference of the rolled surface > (i.e. with a slot where the other part cuts it)… then “roll” the rolled > part “flat” so that I know exactly what to laser cut, so that when I > physically roll it back into shape the slot will be in just the right spot > for the other part? Congratulation, this is a quite ambitious project - especially for somebody who started with OpenSCAD only a week ago. Despite all its merits, OpenSCAD also has its drawbacks that pop up in the moment you want to do really fancy stuff. One is, that it doesn't allow you to query an object. Therefore you don't get hands on the vertex coordinates of an object. Being able to access these coordinates you could think about defining a reverse transformation function that unrolls the object ... Another one is that you can't define and apply non-affine transformations on objects. Rolling and unrolling would be such a transformation. rotate_extrude() is an operator that maps from 2D into 3D. You are looking for an operator that maps from 3D to 2D. The only one OpenSCAD offers is again affine: projection() However, there is a technique that rolls a 3D object along a plane, cuts slices by means of intersection() and unions the result. But this is an exhausting and slow process with an unsatisfactory result. <http://forum.openscad.org/file/t887/CWCCW.png> See the following code: r=40; // radius a=4; // height b=50; // width resolution = 8; i=180*$t; // to animate select view/Animate and set FPS=10, Steps=40 animate(); unroll(i); // module animate() { rad = i/180*PI*r; rotate([0,90,0]) translate([-r-5,rad,0]) rotate([0,0,-i]) piece(); # translate([0,rad,0]) window(resolution); } module unroll(j) { for(i=[0:resolution:j]) { rad = i/180*PI*r; intersection() { rotate([0,90,0]) translate([-r-a,rad,0]) rotate([0,0,-i]) piece(); translate([0,rad,0]) window(resolution); } } } module window(width) { translate([0, -width/2, 0])cube([b, width, 2*a]); } module piece() { difference() { rotate_extrude(angle=180) translate([r, 0]) square([a, b]); rotate([-60, 0, -45])cylinder(r=5, h=100); } } -- Sent from: http://forum.openscad.org/
Tue, Jan 22, 2019 2:24 PM
A repost of the image, because nabble seems to crossref uploads using the
same filename.
http://forum.openscad.org/file/t887/unroll.png
A repost of the image, because nabble seems to crossref uploads using the same filename. <http://forum.openscad.org/file/t887/unroll.png> -- Sent from: http://forum.openscad.org/
BS
Ben Senior
Tue, Jan 22, 2019 5:19 PM
:-)  I actually love this approach.  Unfortunately it won’t produce results that will work well for a laser cutter I suspect… but it’s still great :-)
Do you think non-affine transformations might be on the cards for OpenSCAD at some point?
I didn’t do anything clever (ten hours work from first opening OpenSCAD, and it shows :-/ )  but to give a clearer idea of the situation if you’re interested: here’s the file I was working on without rounded edges https://cloud.eyeskills.org/s/CbcqJH4eisoqRfa
for the other part?
r=40;  // radius
a=4;  // height
b=50;  // width
resolution = 8;
animate();
unroll(i);  //
module animate()
rad = i/180PIr;
rotate([0,90,0])
rotate([0,0,-i])
piece();
module unroll(j)
rad = i/180PIr;
intersection()
rotate([0,90,0])
rotate([0,0,-i])
piece();
module piece()
:-) I actually love this approach. Unfortunately it won’t produce results that will work well for a laser cutter I suspect… but it’s still great :-) Do you think non-affine transformations might be on the cards for OpenSCAD at some point? I didn’t do anything clever (ten hours work from first opening OpenSCAD, and it shows :-/ ) but to give a clearer idea of the situation if you’re interested: here’s the file I was working on without rounded edges https://cloud.eyeskills.org/s/CbcqJH4eisoqRfa > On 22. Jan 2019, at 15:12, Parkinbot <rudolf@digitaldocument.de> wrote: > > okobloko wrote >> In OpenSCAD I’d like to “roll the curved surface” - see where the next >> part intersects it… then compute the difference of the rolled surface >> (i.e. with a slot where the other part cuts it)… then “roll” the rolled >> part “flat” so that I know exactly what to laser cut, so that when I >> physically roll it back into shape the slot will be in just the right spot >> for the other part? > > Congratulation, this is a quite ambitious project - especially for somebody > who started with OpenSCAD only a week ago. > > Despite all its merits, OpenSCAD also has its drawbacks that pop up in the > moment you want to do really fancy stuff. One is, that it doesn't allow you > to query an object. Therefore you don't get hands on the vertex coordinates > of an object. Being able to access these coordinates you could think about > defining a reverse transformation function that unrolls the object ... > Another one is that you can't define and apply non-affine transformations on > objects. Rolling and unrolling would be such a transformation. > rotate_extrude() is an operator that maps from 2D into 3D. You are looking > for an operator that maps from 3D to 2D. The only one OpenSCAD offers is > again affine: projection() > > However, there is a technique that rolls a 3D object along a plane, cuts > slices by means of intersection() and unions the result. But this is an > exhausting and slow process with an unsatisfactory result. > > <http://forum.openscad.org/file/t887/CWCCW.png> > > See the following code: > > r=40; // radius > a=4; // height > b=50; // width > resolution = 8; > > i=180*$t; // to animate select view/Animate and set FPS=10, Steps=40 > animate(); > unroll(i); // > > > module animate() > { > rad = i/180*PI*r; > rotate([0,90,0]) > translate([-r-5,rad,0]) > rotate([0,0,-i]) > piece(); > # translate([0,rad,0]) window(resolution); > } > > module unroll(j) > { > for(i=[0:resolution:j]) > { > rad = i/180*PI*r; > intersection() > { > rotate([0,90,0]) > translate([-r-a,rad,0]) > rotate([0,0,-i]) > piece(); > > translate([0,rad,0]) window(resolution); > } > } > } > > module window(width) > { > translate([0, -width/2, 0])cube([b, width, 2*a]); > } > > > module piece() > { > difference() > { > rotate_extrude(angle=180) translate([r, 0]) square([a, b]); > rotate([-60, 0, -45])cylinder(r=5, h=100); > } > } > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Doug Moen
Tue, Jan 22, 2019 10:32 PM
It's a lot of work to implement properly.
First, non-affine transformations can introduce self-intersections, and make the mesh non-manifold. So we would need automatic mesh repair to fix a transformed mesh before a boolean operation could be applied to it.
Second, consider twisting or bending a cube or a cuboid. You would need to subdivide the existing faces into smaller faces, add more vertices, before applying the transformation. So we'd need a mesh subdivision operation.
Third, non-affine transformations like bend can cause vertices to get farther apart in some regions, and closer together in other regions. If you have first subdivided the mesh finely enough to handle the worst case regions of the shape, then after the transformation, you may need to simplify the mesh in the areas where there are more vertices than necessary. So automatic mesh simplification is another operation that would be useful to have.
> Do you think non-affine transformations might be on the cards for > OpenSCAD at some point? It's a lot of work to implement properly. First, non-affine transformations can introduce self-intersections, and make the mesh non-manifold. So we would need automatic mesh repair to fix a transformed mesh before a boolean operation could be applied to it. Second, consider twisting or bending a cube or a cuboid. You would need to subdivide the existing faces into smaller faces, add more vertices, before applying the transformation. So we'd need a mesh subdivision operation. Third, non-affine transformations like bend can cause vertices to get farther apart in some regions, and closer together in other regions. If you have first subdivided the mesh finely enough to handle the worst case regions of the shape, then after the transformation, you may need to simplify the mesh in the areas where there are more vertices than necessary. So automatic mesh simplification is another operation that would be useful to have.
Tue, Jan 22, 2019 11:27 PM
As I wrote, it is not fast, but it will work with a laser cutter if you
project it down and and export it as DXF or SVG. Of course the rounded face
at least needs a form that can be mathematically explicitly expressed and
unrolled. Use my code and try
projection() unroll(180);
at some point?
We've had discussions about this years ago, when I was starting with
OpenSCAD. Meanwhile I've lost hope to see solutions for both of the
mentioned drawbacks. If you have another language, you can use it to parse
an STL, apply any non-affine transformation you like, write it out and
reimport it to OpenSCAD. However, as Doug already mentioned, the task is not
trivial as it can involve a lot of additional considerations and work and it
requires you to know exactly what you do.
okobloko wrote > Unfortunately it won’t produce results that will work well for a laser > cutter I suspect… but it’s still great :-) As I wrote, it is not fast, but it will work with a laser cutter if you project it down and and export it as DXF or SVG. Of course the rounded face at least needs a form that can be mathematically explicitly expressed and unrolled. Use my code and try projection() unroll(180); okobloko wrote > Do you think non-affine transformations might be on the cards for OpenSCAD > at some point? We've had discussions about this years ago, when I was starting with OpenSCAD. Meanwhile I've lost hope to see solutions for both of the mentioned drawbacks. If you have another language, you can use it to parse an STL, apply any non-affine transformation you like, write it out and reimport it to OpenSCAD. However, as Doug already mentioned, the task is not trivial as it can involve a lot of additional considerations and work and it requires you to know exactly what you do. -- Sent from: http://forum.openscad.org/
