feedback on "C-style for"
Wed, Jun 1, 2016 8:07 PM
I've been playing with "C-style for" (which is an experimental feature in
the dev build).
It gets a bit cumbersome for complex examples with multiple loop variables,
so I'd like to suggest an improvement.
What I'd like is a parallel, pattern matching assignment statement. For
example,
[x,y,z] = point;
requires 'point' to be a list with exactly 3 elements (otherwise an error
is reported). The 3 elements are assigned to x, y and z. This would be
really handy for updating multiple loop variables in the update step.
First example is the fibonacci sequence.
function fibonacci(n) =
for (a=0, b=1; b <= n; t=a, a=b, b=a+t) b
echo(fibonacci(10)); // [1, 1, 2, 3, 5, 8]
I'd like to get rid of the temporary variable 't', which I need because I
can't do a parallel assignment of a and b in the update step.
function fibonacci2(n) =
for (a=0, b=1; b <= n; [a,b]=[b, b=a+b]) b
Second example is prime factors.
function prime_factors(n) =
for (n=n, f=2;
n>1;
n1 = n%f==0 ? n/f : n,
f = n%f==0 ? f : f+1,
n = n1)
if (n%f==0) f
echo(prime_factors(20)); // [2,2,5]
There are two things I'd like to fix here: the extra variable n1, and the
need to duplicate the 'n%f==0 ? ... : ...' logic for updating n and f.
function prime_factors2(n) =
for (n=n, f=2;
n>1;
[n,f] = n%f==0 ? [n/f,f] : [n,f+1])
if (n%f==0) f
As you can see, with this change the code becomes a lot shorter.
I've been playing with "C-style for" (which is an experimental feature in the dev build). It gets a bit cumbersome for complex examples with multiple loop variables, so I'd like to suggest an improvement. What I'd like is a parallel, pattern matching assignment statement. For example, [x,y,z] = point; requires 'point' to be a list with exactly 3 elements (otherwise an error is reported). The 3 elements are assigned to x, y and z. This would be really handy for updating multiple loop variables in the update step. First example is the fibonacci sequence. function fibonacci(n) = [ for (a=0, b=1; b <= n; t=a, a=b, b=a+t) b ]; echo(fibonacci(10)); // [1, 1, 2, 3, 5, 8] I'd like to get rid of the temporary variable 't', which I need because I can't do a parallel assignment of a and b in the update step. function fibonacci2(n) = [ for (a=0, b=1; b <= n; [a,b]=[b, b=a+b]) b ]; Second example is prime factors. function prime_factors(n) = [ for (n=n, f=2; n>1; n1 = n%f==0 ? n/f : n, f = n%f==0 ? f : f+1, n = n1) if (n%f==0) f ]; echo(prime_factors(20)); // [2,2,5] There are two things I'd like to fix here: the extra variable n1, and the need to duplicate the 'n%f==0 ? ... : ...' logic for updating n and f. function prime_factors2(n) = [ for (n=n, f=2; n>1; [n,f] = n%f==0 ? [n/f,f] : [n,f+1]) if (n%f==0) f ]; As you can see, with this change the code becomes a lot shorter.
Ronaldo
Wed, Jun 1, 2016 8:27 PM
I agree this allows to more concise code. But, why would only mutable
variable assignment have such a distinct privilege?
View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17514.html
I agree this allows to more concise code. But, why would only mutable variable assignment have such a distinct privilege? -- View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17514.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jun 1, 2016 8:38 PM
Pattern matching assignment is useful everywhere. (But my post was about "C
style for", and I didn't want to digress.)
The other place I would find it particularly useful (in my code, at least)
is for functions that take [x,y,z] points as arguments. Eg,
function f([x,y,z]) = ...;
f([0, 10, 10])
Pattern matching assignment is useful everywhere. (But my post was about "C style for", and I didn't want to digress.) The other place I would find it particularly useful (in my code, at least) is for functions that take [x,y,z] points as arguments. Eg, function f([x,y,z]) = ...; f([0, 10, 10]) On 1 June 2016 at 16:27, Ronaldo <rcmpersiano@gmail.com> wrote: > I agree this allows to more concise code. But, why would only mutable > variable assignment have such a distinct privilege? > > > > -- > View this message in context: > http://forum.openscad.org/feedback-on-C-style-for-tp17512p17514.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
W
wolf
Thu, Jun 2, 2016 12:33 AM
"Bei dem ist 'ne Schraube locker" (literally "He has a loose screw", more
idiomatic "NUTS") and "Daar lê 'n slang in die gras" (literally" "There
hides a snake in the grass", more idiomatic "that's very buggy code") were
my first impressions when I read doug.moen's proposal.
But let me quote someone else: <github.com/doug-moen/openscad2>
"OpenSCAD2 is a backward compatible redesign of the OpenSCAD language. The
goals are:
to make OpenSCAD easier to use;
to make OpenSCAD more expressive and powerful, not by adding complexity
and piling on features, but by making the core language simpler and more
uniform, and by removing restrictions on how language elements can be
composed together to create larger components."
I am not going to dig up here what OpenSCAD developers have written on this
forum about "C-style programming". Simply put, for non-C programmers,
C-style programming is very difficult to read. "barely readable" it was
called in the tutorial I used to learn OpenSCAD. Rather consider how many
new users have problems with conditionals, or with polygon(), or are
actually using list comprehension.
On the latter, from what I can gather from this forum, only its creator
actually uses it, for everyone else it's too complicated. Or why would we
hear complaints about long render times? Look at the code samples provided,
and it soon becomes obvious that long render times arise from people
stuffing the renderer with work that is not truly needed for the creation of
the shape they are after. If they had but understood list comprehension, and
how lists can eliminate unused corners and faces before CGAL gets hold of
them, they could have saved themselves a lot of frustration . . .
If you live in a country where only a single language is spoken, your
thinking gets limited by the capabilities of that language. That's why
translating the initial quotes is so unsatisfactory and why they inevitably
loose their wittiness in translation. As doug.moen has pointed out in
another thread
(http://forum.openscad.org/Polygon-using-relative-points-rather-than-absolute-td17414.html
and https://github.com/openscad/openscad/wiki/Mutable-Variables), functional
programming is actually a dead end road, imperative-type programming had to
be introduced to achieve universality.
And that's why I object to "C-style for". Proper coding style should be
modelled as close to English language semantics as is possible. Conciseness
should not be an objective - easy learning should. And that means
  1. rewrite all manuals and replace the word "variable" with "constant". Have
    that courage, and admit to yourself that when values are assigned at compile
    time they become constants - calling them variables is fudging/evading the
    issue.
  2. introduce genuine variables (==mutable constants), as pointed out in
  3. forget about "C-style programming" as its use implies the OpenSCAD user
    is already familiar with C, before he/she can consider learning OpenSCAD.
    "C-style" constructs are admittedly easy for C-programmers, but mostly are
    "barely readable" for people not familiar with C.
  4. The for loop should take the form
    for i:=1 to </endval/> step </stepval/>
    because that is English, and thus accessible to everyone capable of reading
    the OpenSCAD manual.
Consider that functional languages came about as a response to the ease with
which the (mis)use of pointers in C can generate buggy code. List
Comprehension (array or *struct in C) is just one way to get around the
potential trouble lurking here. Resist the objections raised by functional
language zealots, and keep the OpenSCAD language simple and readable,
without requiring a background in C. Introduce genuine (==mutable)
variables.
OpenSCAD2 is the way forward, not "C-style". Treat a function as a pointer
to a value, or a list of values. Whether these values were obtained at
compile time or at run time is important only the the developer, it is
immaterial to the user.
View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17516.html
"Bei dem ist 'ne Schraube locker" (literally "He has a loose screw", more idiomatic "NUTS") and "Daar lê 'n slang in die gras" (literally" "There hides a snake in the grass", more idiomatic "that's very buggy code") were my first impressions when I read doug.moen's proposal. But let me quote someone else: <github.com/doug-moen/openscad2> "OpenSCAD2 is a backward compatible redesign of the OpenSCAD language. The goals are: to make OpenSCAD easier to use; to make OpenSCAD more expressive and powerful, not by adding complexity and piling on features, but by making the core language simpler and more uniform, and by removing restrictions on how language elements can be composed together to create larger components." I am not going to dig up here what OpenSCAD developers have written on this forum about "C-style programming". Simply put, for non-C programmers, C-style programming is very difficult to read. "barely readable" it was called in the tutorial I used to learn OpenSCAD. Rather consider how many new users have problems with conditionals, or with polygon(), or are actually using list comprehension. On the latter, from what I can gather from this forum, only its creator actually uses it, for everyone else it's too complicated. Or why would we hear complaints about long render times? Look at the code samples provided, and it soon becomes obvious that long render times arise from people stuffing the renderer with work that is not truly needed for the creation of the shape they are after. If they had but understood list comprehension, and how lists can eliminate unused corners and faces before CGAL gets hold of them, they could have saved themselves a lot of frustration . . . If you live in a country where only a single language is spoken, your thinking gets limited by the capabilities of that language. That's why translating the initial quotes is so unsatisfactory and why they inevitably loose their wittiness in translation. As doug.moen has pointed out in another thread (http://forum.openscad.org/Polygon-using-relative-points-rather-than-absolute-td17414.html and https://github.com/openscad/openscad/wiki/Mutable-Variables), functional programming is actually a dead end road, imperative-type programming had to be introduced to achieve universality. And that's why I object to "C-style for". Proper coding style should be modelled as close to English language semantics as is possible. Conciseness should not be an objective - easy learning should. And that means 1. rewrite all manuals and replace the word "variable" with "constant". Have that courage, and admit to yourself that when values are assigned at compile time they become constants - calling them variables is fudging/evading the issue. 2. introduce genuine variables (==mutable constants), as pointed out in <https://github.com/openscad/openscad/wiki/Mutable-Variables> 3. forget about "C-style programming" as its use implies the OpenSCAD user is already familiar with C, before he/she can consider learning OpenSCAD. "C-style" constructs are admittedly easy for C-programmers, but mostly are "barely readable" for people not familiar with C. 4. The for loop should take the form for i:=1 to </endval/> step </stepval/> because that is English, and thus accessible to everyone capable of reading the OpenSCAD manual. Consider that functional languages came about as a response to the ease with which the (mis)use of pointers in C can generate buggy code. List Comprehension (array or *struct in C) is just one way to get around the potential trouble lurking here. Resist the objections raised by functional language zealots, and keep the OpenSCAD language simple and readable, without requiring a background in C. Introduce genuine (==mutable) variables. OpenSCAD2 is the way forward, not "C-style". Treat a function as a pointer to a value, or a list of values. Whether these values were obtained at compile time or at run time is important only the the developer, it is immaterial to the user. -- View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17516.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Jun 2, 2016 1:51 AM
goals are:
Well said.
frustration . . .
I disagree here.
+1
And that means
Worth considering. Really need to solve the overriding of 'identifiers'
(currently called variables) set in an include<> tho. Also fix command line
'-D var'.
  1. introduce genuine variables (==mutable constants), as pointed out in
Still not for Frankenstein... also IMO "parallel, pattern matching
assignment statement" is just another head bolted on. I'm sure we all have
"gee, it would be nice to" have's, then suddenly the language explodes like
a multi-tool with everything open...
http://forum.openscad.org/file/n17517/swiss-army-knife-1.jpg
  1. forget about "C-style programming" as its use implies the OpenSCAD user
Yes, keep OpenSCAD easy for beginners; while I'm an experienced coder and
can read most languages, I found the transition to OpenSCAD very easy and
hope it stays relatively uncomplicated for future newcomers.
  1. The for loop should take the form
    for i:=1 to <
endval
step <
stepval
50/50
+1
-1
View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17517.html
wolf wrote > "Bei dem ist 'ne Schraube locker" (literally "He has a loose screw", more > idiomatic "NUTS") and "Daar lê 'n slang in die gras" (literally" "There > hides a snake in the grass", more idiomatic "that's very buggy code") were > my first impressions when I read doug.moen's proposal. > > But let me quote someone else: &lt;github.com/doug-moen/openscad2&gt; > > "OpenSCAD2 is a backward compatible redesign of the OpenSCAD language. The > goals are: > > to make OpenSCAD easier to use; > to make OpenSCAD more expressive and powerful, not by adding > complexity and piling on features, but by making the core language simpler > and more uniform, and by removing restrictions on how language elements > can be composed together to create larger components." Well said. > I am not going to dig up here what OpenSCAD developers have written on > this forum about "C-style programming". Simply put, for non-C programmers, > C-style programming is very difficult to read. "barely readable" it was > called in the tutorial I used to learn OpenSCAD. Rather consider how many > new users have problems with conditionals, or with polygon(), or are > actually using list comprehension. > On the latter, from what I can gather from this forum, only its creator > actually uses it, for everyone else it's too complicated. Or why would we > hear complaints about long render times? Look at the code samples > provided, and it soon becomes obvious that long render times arise from > people stuffing the renderer with work that is not truly needed for the > creation of the shape they are after. If they had but understood list > comprehension, and how lists can eliminate unused corners and faces before > CGAL gets hold of them, they could have saved themselves a lot of > frustration . . . > > If you live in a country where only a single language is spoken, your > thinking gets limited by the capabilities of that language. That's why > translating the initial quotes is so unsatisfactory and why they > inevitably loose their wittiness in translation. As doug.moen has pointed > out in another thread > (http://forum.openscad.org/Polygon-using-relative-points-rather-than-absolute-td17414.html > and https://github.com/openscad/openscad/wiki/Mutable-Variables), > functional programming is actually a dead end road, imperative-type > programming had to be introduced to achieve universality. I disagree here. > And that's why I object to "C-style for". Proper coding style should be > modelled as close to English language semantics as is possible. > Conciseness should not be an objective - easy learning should. +1 > And that means > 1. rewrite all manuals and replace the word "variable" with "constant". > Have that courage, and admit to yourself that when values are assigned at > compile time they become constants - calling them variables is > fudging/evading the issue. Worth considering. Really need to solve the overriding of 'identifiers' (currently called variables) set in an include<> tho. Also fix command line '-D var'. > 2. introduce genuine variables (==mutable constants), as pointed out in > &lt;https://github.com/openscad/openscad/wiki/Mutable-Variables&gt; Still not for Frankenstein... also IMO "parallel, pattern matching assignment statement" is just another head bolted on. I'm sure we all have "gee, it would be nice to" have's, then suddenly the language explodes like a multi-tool with everything open... <http://forum.openscad.org/file/n17517/swiss-army-knife-1.jpg> > 3. forget about "C-style programming" as its use implies the OpenSCAD user > is already familiar with C, before he/she can consider learning OpenSCAD. > "C-style" constructs are admittedly easy for C-programmers, but mostly are > "barely readable" for people not familiar with C. Yes, keep OpenSCAD easy for beginners; while I'm an experienced coder and can read most languages, I found the transition to OpenSCAD very easy and hope it stays relatively uncomplicated for future newcomers. > 4. The for loop should take the form > for i:=1 to < / > endval / >> step < / > stepval / >> > because that is English, and thus accessible to everyone capable of > reading the OpenSCAD manual. 50/50 > Consider that functional languages came about as a response to the ease > with which the (mis)use of pointers in C can generate buggy code. List > Comprehension (array or *struct in C) is just one way to get around the > potential trouble lurking here. Resist the objections raised by functional > language zealots, and keep the OpenSCAD language simple and readable, > without requiring a background in C. +1 > Introduce genuine (==mutable) variables. -1 > OpenSCAD2 is the way forward, not "C-style". Treat a function as a pointer > to a value, or a list of values. Whether these values were obtained at > compile time or at run time is important only the the developer, it is > immaterial to the user. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17517.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Jamie_K
Thu, Jun 2, 2016 4:04 AM
When it comes to mutable variables, it comes down to the deep question of
pure functional or not.  I disagree that pure functional is a dead-end road,
but the choice is a fork in the road where you need to decisively pick one
or the other.
If the answer is pure functional, then do{} introduces internal
inconsistency, and the "proper" (meaning internally coherent) way to support
mutation is via first-class functions, closures, and monads.  If OpenSCAD
does grow in this direction, then in a functional future looking /back/ at
do{}, it's going to be even more clumsy to retain coherence and work around
all the implications of backward compatibility and funky interactions.
I won't argue about whether functional or imperative is "better" or more
elegant, but I will argue that pure functional thinking is much more
/specialized/ than sequential style thinking.  I have heard it said that
functional programming is more like mathematics and less like programming,
and I would agree.  Yet I still believe that this mathematical style of
thinking is less common and less accessible to non-specialists, beginner or
not!  Anybody can bang out a bit of procedural code, but not everyone can
wrap their heads around closures, continuations, tail-recursion, or monads.
If the choice is to loosen the pure-functional requirement and forgo strict
referential transparency then I would /still/ suggest that do{} blocks are
not as good as if mutation were adopted as part of a more coherent
imperative language.
View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17519.html
When it comes to mutable variables, it comes down to the deep question of pure functional or not. I disagree that pure functional is a dead-end road, but the choice is a fork in the road where you need to decisively pick one or the other. If the answer is pure functional, then do{} introduces internal inconsistency, and the "proper" (meaning internally coherent) way to support mutation is via first-class functions, closures, and monads. If OpenSCAD does grow in this direction, then in a functional future looking /back/ at do{}, it's going to be even more clumsy to retain coherence and work around all the implications of backward compatibility and funky interactions. I won't argue about whether functional or imperative is "better" or more elegant, but I will argue that pure functional thinking is much more /specialized/ than sequential style thinking. I have heard it said that functional programming is more like mathematics and less like programming, and I would agree. Yet I still believe that this mathematical style of thinking is less common and less accessible to non-specialists, beginner or not! Anybody can bang out a bit of procedural code, but not everyone can wrap their heads around closures, continuations, tail-recursion, or monads. If the choice is to loosen the pure-functional requirement and forgo strict referential transparency then I would /still/ suggest that do{} blocks are not as good as if mutation were adopted as part of a more coherent imperative language. -- View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17519.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Ronaldo
Thu, Jun 2, 2016 6:10 AM
@ Jamie K
I can't agree more.
Before OpenSCAD, I worked with Sketchup for almost two years. I think the
success of Sketchup relies on the elementary set of operators it provides.
Everybody is able to select an edge, extend a line, close a face, extrude a
rectangle. You don't need more than elementary geometry for that except... a
lot of manual work.
After using OpenSCAD for a little more than an year, my Sketchup
installation is outdated and unused. If you intend to do more than basic
cube and cylinder assembly in Sketchup without a enormous effort you will
have to find a plugin or write one yourself. But that means to write Ruby
code, deal with a enormous and confusing API and event oriented programming.
In short, you will have to divert a lot from your modelling focus.
What I found in OpenSCAD was the opposite. I am all the time concentrated in
my problem. And since geometric modelling is geometry, it is mathematics. In
the OpenSCAD world, again, if you only intend to assemble a few cubes and
cylinders, extrude a DXF, generate its stl file, you have support to do it.
But for me the main strength of OpenSCAD is to play with mathematical
objects. And in a mathematical framework.
I had not any previous experience with functional programming before. My
programming background was structured programming (anybody out there knows
what is that? :) ). I am still a Pascal programmer that tried reluctantly to
code in C and Ruby. But neither one fulfill my expectations. I would not
like to see the OpenSCAD language follow that roads. Now that I am about to
master list comprehension I don't want to step back.
I agree that OpenSCAD should be easy to learn but I think its main target
should be the more mathematical minded people. I have been writing a lot of
OpenSCAD code oriented to modelling with Bezier surfaces. I started a
experiment with f-rep, a modelling system based on implicity surface. Those
are examples of very powerful modelling framework but they require a good
mathematical background to be useful.
I feel some constraint in the OpenSCAD language possibly due to my limited
programming experience. What I would expect is a richer set of operators for
lists, first class functions and more efficiency both in the programming
interpretation and preview and render. I can live without mutable variables.
View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17521.html
@ Jamie K I can't agree more. Before OpenSCAD, I worked with Sketchup for almost two years. I think the success of Sketchup relies on the elementary set of operators it provides. Everybody is able to select an edge, extend a line, close a face, extrude a rectangle. You don't need more than elementary geometry for that except... a lot of manual work. After using OpenSCAD for a little more than an year, my Sketchup installation is outdated and unused. If you intend to do more than basic cube and cylinder assembly in Sketchup without a enormous effort you will have to find a plugin or write one yourself. But that means to write Ruby code, deal with a enormous and confusing API and event oriented programming. In short, you will have to divert a lot from your modelling focus. What I found in OpenSCAD was the opposite. I am all the time concentrated in my problem. And since geometric modelling is geometry, it is mathematics. In the OpenSCAD world, again, if you only intend to assemble a few cubes and cylinders, extrude a DXF, generate its stl file, you have support to do it. But for me the main strength of OpenSCAD is to play with mathematical objects. And in a mathematical framework. I had not any previous experience with functional programming before. My programming background was structured programming (anybody out there knows what is that? :) ). I am still a Pascal programmer that tried reluctantly to code in C and Ruby. But neither one fulfill my expectations. I would not like to see the OpenSCAD language follow that roads. Now that I am about to master list comprehension I don't want to step back. I agree that OpenSCAD should be easy to learn but I think its main target should be the more mathematical minded people. I have been writing a lot of OpenSCAD code oriented to modelling with Bezier surfaces. I started a experiment with f-rep, a modelling system based on implicity surface. Those are examples of very powerful modelling framework but they require a good mathematical background to be useful. I feel some constraint in the OpenSCAD language possibly due to my limited programming experience. What I would expect is a richer set of operators for lists, first class functions and more efficiency both in the programming interpretation and preview and render. I can live without mutable variables. -- View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17521.html Sent from the OpenSCAD mailing list archive at Nabble.com.
arnholm@arnholm.org
Thu, Jun 2, 2016 11:50 AM
more
that
programming,
beginner or
not!
Agreed. This is common sense.
I don't understand how the argument for a "functional" language follows
from the objective of ease of use for beginners, except for trivial code
which is really equally trivial in any language, "functional" or not.
monads.
This is true, it can defeat the noble objective of OpenSCAD being
accessible to non-specialists.
About a year ago on this list, I stated that I thought the focus of
OpenSCAD was too much on language definition compared to other
functionality, and that this follows from the fact that OpenSCAD defines
it own language syntax. To me, it seems this is still the case.
On 2016-06-02 06:04, Jamie_K wrote: > I won't argue about whether functional or imperative is "better" or > more > elegant, but I will argue that pure functional thinking is much more > /specialized/ than sequential style thinking. I have heard it said > that > functional programming is more like mathematics and less like > programming, > and I would agree. Yet I still believe that this mathematical style of > thinking is less common and less accessible to non-specialists, > beginner or > not! Agreed. This is common sense. I don't understand how the argument for a "functional" language follows from the objective of ease of use for beginners, except for trivial code which is really equally trivial in any language, "functional" or not. > Anybody can bang out a bit of procedural code, but not everyone can > wrap their heads around closures, continuations, tail-recursion, or > monads. This is true, it can defeat the noble objective of OpenSCAD being accessible to non-specialists. About a year ago on this list, I stated that I thought the focus of OpenSCAD was too much on language definition compared to other functionality, and that this follows from the fact that OpenSCAD defines it own language syntax. To me, it seems this is still the case. Carsten Arnholm
Thu, Jun 2, 2016 6:12 PM
It is used by non-specialists, looking at the various post
all over the internet. I believe it certainly should stay that
way. I don't think that means it's impossible to add some more
advanced features.
Based on what? There's quite some discussion on the list here,
and that's good. It's a big topic, so seeing different viewpoints
is nice. The work Doug does in writing down the ideas and
driving the discussion is just awesome.
As far as development goes, looking at the github history,
there's only a very very tiny effort to already include some
of the ideas that fit nicely into the existing code.
So I see only one "problem", the wishlist is very long compared
to the available development power. But that's just how things
tend to go with open source projects. There's a number of nice
things waiting to be finished, it's just taking time...
On 06/02/2016 01:50 PM, arnholm@arnholm.org wrote: > This is true, it can defeat the noble objective of OpenSCAD > being accessible to non-specialists. > It *is* used by non-specialists, looking at the various post all over the internet. I believe it certainly should stay that way. I don't think that means it's impossible to add some more advanced features. > About a year ago on this list, I stated that I thought the > focus of OpenSCAD was too much on language definition > compared to other functionality, and that this follows from > the fact that OpenSCAD defines it own language syntax. To me, > it seems this is still the case. > Based on what? There's quite some discussion on the list here, and that's good. It's a big topic, so seeing different viewpoints is nice. The work Doug does in writing down the ideas and driving the discussion is just awesome. As far as development goes, looking at the github history, there's only a very very tiny effort to already include some of the ideas that fit nicely into the existing code. So I see only one "problem", the wishlist is very long compared to the available development power. But that's just how things tend to go with open source projects. There's a number of nice things waiting to be finished, it's just taking time... ciao, Torsten.
Jamie_K
Thu, Jun 2, 2016 10:57 PM
A minor point I'd like to clarify, is when I speak of accessibility to
non-specialists, I'm talking about the more advanced programming aspects,
such as defining and using functions or list comprehensions.  There is no
question that ordinary geometry and modules are tremendously useful and
easily accessible.
When it comes to offset a polygon, or convert relative points to absolute,
what should be easy becomes a test of whether you understand tail recursion.
Opening up the programming aspects to non-specialists could expand creation
and sharing of operators (dilate, generate-mold, slice,
cleanup-non-manifold, voronoi-subdivide, or whatever).  As it is now, almost
all creation and sharing is of models, not operators.  With a proliferation
of operators, the designer who can't (or doesn't want to) write code could
see a lot of benefit too.
-Jamie
View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17540.html
A minor point I'd like to clarify, is when I speak of accessibility to non-specialists, I'm talking about the more advanced programming aspects, such as defining and using functions or list comprehensions. There is no question that ordinary geometry and modules are tremendously useful and easily accessible. When it comes to offset a polygon, or convert relative points to absolute, what should be easy becomes a test of whether you understand tail recursion. Opening up the programming aspects to non-specialists could expand creation and sharing of operators (dilate, generate-mold, slice, cleanup-non-manifold, voronoi-subdivide, or whatever). As it is now, almost all creation and sharing is of models, not operators. With a proliferation of operators, the designer who can't (or doesn't want to) write code could see a lot of benefit too. -Jamie -- View this message in context: http://forum.openscad.org/feedback-on-C-style-for-tp17512p17540.html Sent from the OpenSCAD mailing list archive at Nabble.com.
