I often find myself thinking about OpenSCAD best practises and programming
best practises, and one idea I've been thinking about recently is whenever
there's a situation where I'd use union I instead use it as a reminder to
instead make it a module as an opportunity to name and describe what that
bit of code is doing.
I think OpenSCAD should be made up of lots of small modules in the same way
that small functions is a best practise for programming.
Thoughts?
Many minor union()s are of obscure parts that would be incredibly
difficult to name as a module(). I use module()s when I can name them
easily and clearly. The remaining code is commented but not named as a
module().
programming best practises, and one idea I've been thinking about
recently is whenever there's a situation where I'd use union I instead
use it as a reminder to instead make it a module as an opportunity to
name and describe what that bit of code is doing.
same way that small functions is a best practise for programming.
To push back, the fact that they are obscure is all the more reason to name
them, because they'll be difficult to figure out what they do, if you come
back to the code in a couple months.
Yes it can be difficult but it like that expression "there are only two
difficult things in programming, recursion and naming things". Difficult but
worth doing if you want to make the code more readable. There's nothing
wrong with long descriptive names.
