Issue fixed - thank you all.
While on fixing the manual, let me point out two other issues that are
likely to cause head scratching.
The OpenSCAD manual describes the capabilities of a command in a form that
looks like the fragment of an example. This is a good thing, as it makes
reading the manual a lot easier as, e.g., the average Linux man-page. For
DXF extrusion, such an example is given, but it is not complete. Shouldn't
there be a reference/link outlining that a full description is given
elsewhere? That I am not misunderstood: I like idea of giving a piece of
sample code. But also: do people arriving at this piece of code know that
some [optional] parameters have been omitted?
Second issue,
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_the_2D_Subsystem
Under
"Extruding a Polygon
Extrusion can also be performed on polygons with points chosen by the user.
Here is a simple polygon and its (fine-grained: $fn=200) rotational
extrusion (/profile and lathe/)." I have issues with the English used,
specifically the portion in italics. To my understanding, a lathe is a
machine to produce parts with rotational symmetry, and not a part that has
rotational symmetry. Can't the piece of text be replaced with (/before and
after rotation/)? Italics again added for emphasis.
wolf
View this message in context: http://forum.openscad.org/conflicting-manual-entries-tp16467p16530.html
I think simply removing the text in brackets is clearer.
extrusion.
Second issue,
Under
wolf
Wolf:
Second issue,
Under
wolf
