OpenScad currently reports volumes for 3D which is lumps plus one and
contours for 2D. However missing tabs that should be unioned would not
change the number of lumps. Detached tabs would but that is not actually
the original problem.
On 18 March 2016 at 09:53, arnholm@arnholm.org wrote:
On 2016-03-18 09:31, Rogier Wolff wrote:
I KNOW I can "fix" it by overlapping the objects.
The problem is: occasionally you forget to preventively fix it, and
you place an object exactly where it is supposed to go.
The render looks fine, you laser or 3D print it, and... wasted time
and material. I understand that according to openscad if rounding
errors cause two surfaces to not-touch, then there are simply two
objects. That is actually the easiest case as mathematically there is
no problem.
In my case however there WAS an error, I think caused by the planes
being EXACTLY in the same spot.
The software cannot know your expectations, it can only know what your
instructions were. If the two objects happen to intersect based on your
instructions, they become thing as far as the software is concerned. If
not, they are two. You can only call the result an error after comparing
with your unstated expectations, the software has no way of knowing these
expectations (after all it isn't psychic).
I think the best you can hope for is that the software reports back how
many "lumps" (=independent bodies) the resulting object consists of after
boolean operations. If you have two objects you believe should be unioned
into one, and the software reports the result is consisting of two lumps,
then you have a chance of comparing the result with your expectations. This
is exactly what I have been doing when experimenting with carve (another
boolean engine).
So a suggestion could be that openscad reports the number of lumps in the
result.
Sorry for butting in here. I was also taking the OP's comment as a
misunderstanding of the tool. But, in the explanation was a little
kernel that might be worth some thought as an enhancement.
When we want to force a union (and not deal with rounding errors
causing gaps), we always explain how to make one object a little larger
and union.
The OP suggested that if OpenSCAD could recognize the case where two
objects are within some epsilon and warn would be a good thing. That
made me think of other similar values that we already have: $fn, $fa,
and $fs.
What if we had a $epsilon, and OpenSCAD could use it to either warn of
objects that are within that distance or automatically union? Would
that help new users? I'm not sure how much effort it would be (since I
haven't look at the code in a long time), but maybe it's worth some
thought.
(The current behavior would remain if $epsilon is 0. For many cases,
problems would go away with $epsilon = 0.01. The designer could tweak
this value to allow items to be closer or force them to stay further
away.)
At the moment, I don't think this should be considered a proposal. Just
the beginnings of a thought experiment.
G. Wade
On Fri, 18 Mar 2016 10:05:50 +0000
actually the original problem.
is no problem.
your instructions were. If the two objects happen to intersect
based on your instructions, they become thing as far as the
software is concerned. If not, they are two. You can only call the
result an error after comparing with your unstated expectations,
the software has no way of knowing these expectations (after all it
isn't psychic).
how many "lumps" (=independent bodies) the resulting object
consists of after boolean operations. If you have two objects you
believe should be unioned into one, and the software reports the
result is consisting of two lumps, then you have a chance of
comparing the result with your expectations. This is exactly what I
have been doing when experimenting with carve (another boolean
engine).
in the result.
If it doesn't have to be right, I can make it arbitrarily fast.
-- Rick Hoselton
I would second this or something like this as a feature request.
I am a relatively new openSCAD user.
I make mostly mechanical pieces, and really like the programatic /
parametric way of designing my parts
over traditional visual tools. However the need to constantly fudge things
just a bit is for me burdensome. I have exact measurements (generated
mathematically) but these can change and having to add in some delta to be
certain that parts join to form a solid can get a bit tricky and seeing
interior surface separations/flaws can be a challenge.
I like the idea of one or two epsilon type values.... that add some function
but when set to 0 result in everything working just as it does now.
I would suggest maybe two values that if zero do nothing.
(for discussion called $op - overlapping plane and $sp - separating plane)
(these would typically be very small numbers like .001 or whatever is needed
to cover up rounding)
(.001 seems to work most of the time for me, though in practice .01 is
usually fine too)
$op positive will force the merging of objects separated by less than that
value.
$sp positive would force separation of objects that due to rounding may
touch or be separated by less than this amount.
(I need to think about $sp a bit, I feel like there is a similar need when
differencing objects, where $op addresses unions how this other
differencing/separating property would work I need to consider.)
Perhaps negative numbers would report as a warning but not actually make any
change.
How to do this separation or merging might be a bit of a challenge but using
some method similar to
what we do manually by adding or subtracting some small amount to allow for
rounding errors to be masked
seems like good starting point.
View this message in context: http://forum.openscad.org/Touching-surfaces-tp16508p16574.html
