Editor window not showing
MP
Marijan Pollak
Fri, Mar 17, 2017 3:38 AM
Suddenly there is no editor window, my computer is complaining about  no
backup space.
Scad hangs or fell in some loop before.
View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941.html
Suddenly there is no editor window, my computer is complaining about no backup space. Scad hangs or fell in some loop before. -- View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941.html Sent from the OpenSCAD mailing list archive at Nabble.com.
EB
Eric Buijs
Fri, Mar 17, 2017 3:48 PM
Try View --> Hide editor in de menu.
View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941p20945.html
Try View --> Hide editor in de menu. -- View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941p20945.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MP
Marijan Pollak
Sat, Mar 18, 2017 7:50 PM
Found it. Now at least i am able to work.  Sometimes OpenScad fell unto
loop, screen white and hour glass showing
it is busy doing god know what..
Got minor brainstroke, have problem to write
On Fri, Mar 17, 2017 at 4:48 PM, Eric Buijs [via OpenSCAD] <
ml-node+s1091067n20945h1@n5.nabble.com> wrote:
Regards from Croatia, the Homeland of one of greatest inventors from 19th
and 20th Centuries, Engineer Nikola Tesla!
View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941p20956.html
Found it. Now at least i am able to work. Sometimes OpenScad fell unto loop, screen white and hour glass showing it is busy doing god know what.. Got minor brainstroke, have problem to write , On Fri, Mar 17, 2017 at 4:48 PM, Eric Buijs [via OpenSCAD] < ml-node+s1091067n20945h1@n5.nabble.com> wrote: > Try View --> Hide editor in de menu. > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > http://forum.openscad.org/Editor-window-not-showing-tp20941p20945.html > To unsubscribe from Editor window not showing, click here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=20941&code=b2Jlcm9ubXBAZ21haWwuY29tfDIwOTQxfC00Mzg5MzYyNzk=> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- Regards from Croatia, the Homeland of one of greatest inventors from 19th and 20th Centuries, Engineer Nikola Tesla! -- View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941p20956.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Mar 18, 2017 9:47 PM
For some models with thousands polygons, the preview screen update is very
time consuming. Either avoid changing the view with the mouse or render it
with F6 before doing it.
2017-03-18 16:50 GMT-03:00 Marijan Pollak oberonmp@gmail.com:
For some models with thousands polygons, the preview screen update is very time consuming. Either avoid changing the view with the mouse or render it with F6 before doing it. 2017-03-18 16:50 GMT-03:00 Marijan Pollak <oberonmp@gmail.com>: > Sometimes OpenScad fell unto loop, screen white and hour glass showing it > is busy doing god know what.. > >
MP
Marijan Pollak
Sun, Mar 19, 2017 1:07 PM
That is what bothers me. I usually have simple nodels and use low
resolution untill finish, It seems that no two commands have to be given
and
I have touch screen that sometimes skip tapping. If it looks it miss i have
to tap again, but sometimes it just react slowly, and i do not know whic
is which.
On Sat, Mar 18, 2017 at 10:48 PM, Ronaldo [via OpenSCAD] <
2017-03-18 16:50 GMT-03:00 Marijan Pollak <[hidden email]
http:///user/SendEmail.jtp?type=node&node=20957&i=0>:
[hidden email] http:///user/SendEmail.jtp?type=node&node=20957&i=1
below:
http://forum.openscad.org/Editor-window-not-showing-tp20941p20957.html
NAML
View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941p20958.html
That is what bothers me. I usually have simple nodels and use low resolution untill finish, It seems that no two commands have to be given and I have touch screen that sometimes skip tapping. If it looks it miss i have to tap again, but sometimes it just react slowly, and i do not know whic is which. On Sat, Mar 18, 2017 at 10:48 PM, Ronaldo [via OpenSCAD] < ml-node+s1091067n20957h73@n5.nabble.com> wrote: > For some models with thousands polygons, the preview screen update is very > time consuming. Either avoid changing the view with the mouse or render it > with F6 before doing it. > > 2017-03-18 16:50 GMT-03:00 Marijan Pollak <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=20957&i=0>>: > >> Sometimes OpenScad fell unto loop, screen white and hour glass showing it >> is busy doing god know what.. >> >> > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=20957&i=1> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > http://forum.openscad.org/Editor-window-not-showing-tp20941p20957.html > To unsubscribe from Editor window not showing, click here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=20941&code=b2Jlcm9ubXBAZ21haWwuY29tfDIwOTQxfC00Mzg5MzYyNzk=> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- Regards from Croatia, the Homeland of one of greatest inventors from 19th and 20th Centuries, Engineer Nikola Tesla! -- View this message in context: http://forum.openscad.org/Editor-window-not-showing-tp20941p20958.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Mar 19, 2017 1:21 PM
It sure would be nice if F5 and F6 reacted IMMEDIATELY with an hourglass
cursor.
given and
know whic
is which.
On Sat, Mar 18, 2017 at 10:48 PM, Ronaldo [via OpenSCAD] <[hidden
It sure would be nice if F5 and F6 reacted IMMEDIATELY with an hourglass cursor. On 3/19/2017 9:07 AM, Marijan Pollak wrote: > That is what bothers me. I usually have simple nodels and use low > resolution untill finish, It seems that no two commands have to be > given and > I have touch screen that sometimes skip tapping. If it looks it miss i > have to tap again, but sometimes it just react slowly, and i do not > know whic > is which. > > On Sat, Mar 18, 2017 at 10:48 PM, Ronaldo [via OpenSCAD] <[hidden > email] </user/SendEmail.jtp?type=node&node=20958&i=0>> wrote: > > For some models with thousands polygons, the preview screen update > is very time consuming. Either avoid changing the view with the > mouse or render it with F6 before doing it. >
