boolean nits
Mon, Jun 15, 2015 11:28 AM
if one attempts
if (x==1) or (x==2)
the compiler does not complain, but it does not do the obvious thing, either
if one attempts
if ((x==1) or (x==2))
one does get a compiler error message
if one attempts
if ((x==1) || (x==2))
it works.
I would advocate that the first syntax should generate an error message
if one attempts if (x==1) or (x==2) the compiler does not complain, but it does not do the obvious thing, either if one attempts if ((x==1) or (x==2)) one does get a compiler error message if one attempts if ((x==1) || (x==2)) it works. I would advocate that the first syntax should generate an error message Jon
Mon, Jun 15, 2015 11:34 AM
The first one is valid syntax. It means if x is one call module "or"
passing x==2, i.e. false.
It gives WARNING: Ignoring unknown module 'or'. Unless you have a module
called or.
On 15 June 2015 at 12:28, jon jon@jonbondy.com wrote:
if one attempts
if (x==1) or (x==2)
either
if one attempts
if one attempts
it works.
The first one is valid syntax. It means if x is one call module "or" passing x==2, i.e. false. It gives WARNING: Ignoring unknown module 'or'. Unless you have a module called or. On 15 June 2015 at 12:28, jon <jon@jonbondy.com> wrote: > if one attempts > > if (x==1) or (x==2) > > the compiler does not complain, but it does not do the obvious thing, > either > > if one attempts > > if ((x==1) or (x==2)) > > one does get a compiler error message > > if one attempts > > if ((x==1) || (x==2)) > > it works. > > I would advocate that the first syntax should generate an error message > > Jon > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Jun 15, 2015 12:47 PM
Thank you
module called or.
mailto:jon@jonbondy.com> wrote:
 if one attempts
 if (x==1) or (x==2)
 thing, either
 if one attempts
 if one attempts
 it works.
 message
Checked by AVG - www.avg.com http://www.avg.com
Version: 2015.0.6030 / Virus Database: 4360/10017 - Release Date: 06/14/15
Thank you On 6/15/2015 7:34 AM, nop head wrote: > The first one is valid syntax. It means if x is one call module "or" > passing x==2, i.e. false. > > It gives WARNING: Ignoring unknown module 'or'. Unless you have a > module called or. > > > On 15 June 2015 at 12:28, jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>> wrote: > > if one attempts > > if (x==1) or (x==2) > > the compiler does not complain, but it does not do the obvious > thing, either > > if one attempts > > if ((x==1) or (x==2)) > > one does get a compiler error message > > if one attempts > > if ((x==1) || (x==2)) > > it works. > > I would advocate that the first syntax should generate an error > message > > Jon > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > Version: 2015.0.6030 / Virus Database: 4360/10017 - Release Date: 06/14/15 >
